Momed80
150
35,046
Snorkel Scissor Lifts S2770RT to S3970BE Parts Manual 13865-2 2017
Brand: Snorkel
Type of Machine: Scissor Lift
Type of Manual: Parts Manual, Hydraulic Schematic
Model: Snorkel S3970RT S3370RT S2770RT S3970BE S3370BE S2770BE Scissor Lift
Serial Number: S2770RT-07-000111, S3370RT-07-000111, S3970RT-07-000103 and after
Part Number: 13865-2
Publication Date: 2017
Number of Pages: 224 Pages
Repair Parts
Chassis Assembly
Engine Assembly - Kubota D902 Tier 3
Engine Assembly - Kubota D902 Tier 4 Final
Engine Assembly - After Sn S2770rt-07-171000299/S3370rt-07-171000351/S3970rt-171000201 - Kubota D902 Tier 4
Coupler Assembly
Engine Cabinet Assembly
Cabinets Assembly
Diesel Fuel Tank Assembly
Steer Assembly
Swing Arms Assembly
Hydraulic Cabinet
Hydraulic Cabinet - After Sn S2770rt-07-171000299/S3370rt-07-171000351/S3970rt-07-171000201
Hydraulic Fluid Reservoir Assembly
Base/Stack/Platform Assembly - 30mm Pins - From Sn S2770rt-07-170500279 S3370rt-07-170500318 S3970rt-07-170700193 - Version 6
Base/Stack/Platform Assembly 1" Pins - From Sn Sxx70rt-07-000100 To S2770rt-07-170500278 S3370rt-07-170500317 S3970rt-07-170700192 - Version 4
Stabiliser Assembly - From Sn S2770rt-07-170400274 S3370rt-07-170100284 S3970rt-07-170200180 - Version 5/6
Stabiliser Assembly - From Sn Sxx70rt-000100 To S2770rt 170400273 S3370rt-07-170100283 S3970rt-170200179 - Version 4
Emergency Bleed Down - Sr3370rt/Sr3970rt
Emergency Bleed Down - S2770rt
Platform Assembly 30mm Pins - From Sn S2770rt-07-170500279 S3370rt-07-170500318 S3970rt-07-170700193 - Version 6
Platform Rear Handrail Assembly
Scissor Stack Assembly 1" Pins - From Sn S3970rt-07-000100 To S3970rt-07-170700192 - Version 4 - 3970
Scissor Stack Assembly 1" Pins - From Sn S3370rt-07-000100 To S3370rt-07-170500317 - Version 4 - 3370
Scissor Stack Assembly 1" Pins - From Sn S2770rt-07-000100 To S2770rt-07-170500278 - Version 4 - 2770
Scissor Stack Assembly 30mm Pins - From Sn S2770rt-07-170500279 - 2770
Scissor Stack Assembly 30mm Pins - From Sn S3970rt-07-170700193 - 3970
Scissor Stack Assembly 30mm Pins - From Sn S3370rt-07-170500318 - 3370
Scissor Stack Tees
Decals/Placards
Hydraulics
12570 Drive Motor
12571 Drive Motor W/Brake
Mico Wheel Brakes
Gear Hub Assembly
Auto Stabiliser Manifold - With Fittings
Auto Stabiliser Manifold - No Fittings
4wheel Drive Manifold With Fittings
4wheel Drive Manifold - No Fittings
Main Manifold Fittings
Main Manifold - No Added Fittings - After Sn S2770rt-07-171000299/S3370rt-07-171000351/S3970rt-07-171000201
Main Manifold - With Fittings - After Sn S2770rt-07-171000299, S3370rt-07-171000351, S3970rt-07-171000201
Lower Lift Cylinder
Upper Lift Cylinder Assembly
Axle Cylinder
Steer Cylinder
Stabiliser Cylinder Assembly - Version 4
Stabiliser Cylinder Assembly - Version 5
Hose Part Numbers And Colour Codes
Electrical
Looms-3370
Lower Control Box - Ansi - Petrol/Lgp
Lower Control Box - Ansi - Diesel
Inverter - 2500w 24v
Inverter Weldment
110 Power To Platform To Inverter Cable
Inverter Tap Block Plate
Inverter Cover Plate
Lower Control Box - Ce/As/Nz - Diesel
24v Dc Battery Box Mounting
24v Dc Hydraulic Cabinet
24v Dc Assembly
Gp400 Menu
Upper Control Box - Metal Plug - As/Nzs/Ce - Diesel
Upper Control Box - Metal Plug - Ansi - Diesel
Upper Control Box - Metal Plug - Ansi - Petrol/Lpg
Upper Control Box - Plastic Plug - As/Nzs/Ce - Diesel
Upper Control Box - Plastic Plug - Ansi - Diesel
Upper Control Box - Plastic Plug - Ansi - Petrol/Lpg
I/O Allocations
Options
Foam Floatation Tyres
Gear Hub Assembly
Inverter
High Torque Sxx70 Non-Mark
Flow Control Valve Assembly
Engine Assembly - Lpg - Kubota Wg752
Engine Cabinet Assembly - Lpg
Cabinets Assembly - Lpg
Ac110v At Platform
240vac At Platform
240vac Assembly
Schematics
Hydraulic Schematic
Engine Compartment Wiring - Cable Throttle Machines
Electrical Schematic
Appendix A:pages Index
Appendix B:parts Index
