Snorkel Scissor Lifts S2255RTE S2755RTE Parts Manual 15382-2 2020
Brand: Snorkel
Type of Machine: Scissor Lift
Model: Snorkel S2255RTE S2755RTE Scissor Lift
Serial Number: S2255RTE-07-200700001 & S2755RTE-07-200700001 Onwards
Part Number: 15382-2
Publication Date: 2020
Number of Pages: 139 Pages
Repair Parts
Wheel Mounting Assembly
Steer Axle Assembly
Base Assembly
Swing Arms Assembly
Bolt On Stabilisers Assembly
Serial Plate Mount Assembly
Control Cabinet Assembly
Control Box Mounting Assembly
Motor Cabinet Assembly
Motor Cabinet Charger Assembly
Power Cabinet Assembly
Cabinet Mounting Assembly
Stabiliser Leg Assembly - Before Sn S2255rt-07-230300325, S2755rt-07-230300434
Stabiliser Leg Assembly - From Sn S2755re-07-230100010
Base/Stack/Platform Assembly
Bleed Down Cover Assembly
Platform Assembly
Platform Rear Handrail Assembly
Scissor Stack - S2255rt - Version 6
Scissor Stack - S2755rt - Version 6
Angle Transducer
Angle Transducer - After May 2024
Plastic Hydraulic Fluid Reservoir Assembly
Steel Hydraulic Fluid Reservoir Assembly
Aluminium Hydraulic Fluid Reservoir Assembly With Heater - Version 6
Aluminium Hydraulic Fluid Reservoir Assembly - Without Heater - Version 6
Aluminium Hydraulic Fluid Reservoir Assembly - With Heater - Version 7
Aluminium Hydraulic Fluid Reservoir Assembly - Without Heater - Version 7
Decals/Placards
Hydraulics
Main Manifold - Added Fittings
Main Manifold - No Added Fittings
4wheel Drive Manifold - Added Fittings
4wheel Drive Manifold - No Added Fittings
Auto Stabiliser Manifold - Added Fittings
Auto Stabiliser Manifold - No Added Fittings
Axle Cylinder Assembly
Steer Cylinder Assembly
Lift Cylinder Assembly
Stabilisers Cylinder Assembly - Imperial Cylinders
Stabiliser Leg Assembly - Metric Cylinders
House Part Numbers And Colour Codes
Electrical
Gp400 And I/O Allocations
Lower Control Box Assembly
Upper Control Box Assembly
Options
240v At Base Assembly
240v At Platform Assembly
Side Gate
Schematics
Motor Control Schematic
Wiring Schematic
Hydraulic Schematic
Appendix A
ages Index
Appendix B
arts Index
Brand: Snorkel
Repair Parts
Steer Axle Assembly
Base Assembly
Swing Arms Assembly
Platform Assembly
Angle Transducer
Decals/Placards
Hydraulics
Electrical
Options
Side Gate
Schematics
Wiring Schematic
Hydraulic Schematic
Appendix A
Appendix B
