Snorkel Scissor Lifts S2255RT S2255BE S2755RT S2755BE Parts Manual 15286-2 2019
Brand: Snorkel
Type of Machine: Scissor Lift
Model: Snorkel S2255RT S2255BE S2755RT S2755BE Scissor Lift
Serial Number: S2255RT-07-190100208 & S2755RT-07-180700201 Onwards
Part Number: 15286-2
Publication Date: 2019
Number of Pages: 359 Pages
Repair Parts
Generic Assembly - S2255rt - January 2026 And After
Generic Assembly - S2255be - January 2026 And After
Generic Assembly - S2755rt - January 2026 And After
Generic Assembly - S2755be - January 2026 And After
Chassis Assembly - S2255 - January 2026 And After
Base Assembly
Wheel Mounting Assembly
Bolt On Stabilisers Assembly
Steer Axle Assembly
Swing Arms Assembly
Control Cabinet Assembly - Sxx55
Cabinets Mounting Assembly
Control Cabinet Assembly - Before Sn S2255rt-07-200900248, S2755rt-07-200900299
Control Cabinet Assembly - After Sn S2255rt-07-200900248, S2755rt-07-200900299
Lower Control Box Mounting Assembly
Engine Assembly - Kubota D902 Tier 4 Final
Coupler Assembly
Engine Cabinet Assembly - Before Sn S2255rt-07-190600225 And S2755rt-07-190600251
Engine Cabinet Assembly - Sn S2255rt-07-190600225 - S2255rt-07-230700/S2755rt-07-190600251 - S2755rt-07-230700
Engine Cabinet Assembly - After Sn S2255rt-07-230700, S2755rt-07-230700
Fuel Cabinet Assembly - Steel Tank
Fuel Cabinet Assembly - Plastic Tank - After Sn S2255rt-07-200900248/S2755rt-07-200900299
Fuel Cabinet Assembly - Plastic Tank - Before Sn S2255rt-07-200900248/S2755rt-07-200900299
Radiator Guard - After Sn S2255rt-07-210100259/S2755rt-07-210100320
Stabiliser Leg Assembly - Before Sn S2255rt-07-230300325, S2755rt-07-230300434
Stabiliser Leg Assembly - Sn S2255rt-07-230300325, S2755rt-07-230300434
Base/Stack/Platform Assembly
Stack Assembly - S22xx - January 2026 And After
Scissor Stack - S2255rt - Version 6
Scissor Stack - S2755rt - Version 6
Bleed Down Cover Assembly
Platform Assembly
Platform Assembly - Sxx55 - January 2026 And After
Platform Side Gate Assembly - Sxx55 - January 2026 And After
Platform Rear Handrail Assembly - Before Sn S2255rt-07-220800312, S2755rt-07-220800408
Platform Rear Handrail - After Sn S2255rt-07-220800312 And S2755rt-07-220800408
Angle Transducers - Before Sn S2255rt-07-200900243 S2755rt-07-200900305
Angle Transducer - After Sn S2255rt-07-200900243 S2755rt-07-200900305
Angle Transducer - After May 2024
Plastic Fuel Tank Assembly - Diesel
Plastic Hydraulic Fluid Reservoir Assembly
Steel Fuel Tank Assembly - Diesel
Steel Hydraulic Fluid Reservoir Assembly - With Heater
Steel Hydraulic Fluid Reservoir Assembly - No Heater
Aluminium Hydraulic Fluid Reservoir Assembly With Heater - Version 6
Aluminium Fuel Tank Assembly
Aluminium Hydraulic Fluid Reservoir Assembly - Without Heater - Version 6
Aluminium Hydraulic Fluid Reservoir Assembly - With Heater - Version 7
Aluminium Hydraulic Fluid Reservoir Assembly - Without Heater - Version 7
Serial Plate Mount Assembly
Decals/Placards
Decals/Placards - Bi-Energy Machines
Decal Kit - S2255rt - Ansi - January 2026 And After
Decal Kit - S2255rt - Ce - January 2026 And After
Decal Kit - S2255be - Ansi - January 2026 And After
Decal Kit - S2255be - Ce - January 2026 And After
Decal Kit - S2255be - Ansi - Transition - January 2026 And After
Decal Kit - S2255be - Ce - Transition - January 2026 And After
Decal Kit - S2755rt - Ansi - December 2025 And After
Decal Kit - S2755rt - Ce - December 2025 And After
Decal Kit - S2755be - Ansi - December 2025 And After
Decal Kit - S2755be - Ansi - Transition - December 2025 And After
Decal Kit - S2755be - Ce - December 2025 And After
Decal Kit - S2755be - Ce - Transition - December 2025 And After
Hydraulics
Main Manifold - Added Fittings
Main Manifold - No Added Fittings
Pressure Filter Assembly
4wheel Drive Manifold - Added Fittings
4wheel Drive Manifold - No Added Fittings
Auto Stabiliser Manifold - Added Fittings
Auto Stabiliser Manifold - No Added Fittings
Axle Cylinder Assembly
Steer Cylinder Assembly
Lift Cylinder Assembly
Stabilisers Cylinder Assembly - Imperial Cylinders
Stabiliser Cylinder Assembly - Metric Cylinders
Stack Hydraulic / Electrical Assembly Installation - S2255 - January 2026 And After
House Part Numbers And Colour Codes
Electrical
Loom List
Lower Control Box - As/Nzs/Ce - Diesel
Lower Control Box - Dc - As/Nzs/Ce - Bi-Energy Diesel 24v
Battery Box Mounting
Cabinet Assembly 2255 24vdc
24v Dc Assembly
Upper Control Box 14023-01 - As/Nzs/Ce - Diesel
Upper Control Box 14023-02 - Ansi - Diesel
Upper Control Box 14023-03 - Petrol/Lpg - Ansi
Upper Control Box 14023-06 Reverse Lift - As/Nzs/Ce - Diesel
Upper Control Box 14023-07 Petrol/Lpg - Reverse Lift - Ansi
Upper Control Box 14023-13 24v Reverse Lift - As/Nzs/Ce - Diesel
Upper Control Box Cover Assembly
Gp400 And I/O Allocations
Options
Inverter
Cold Weather Block Heater Battery Warmer
110v Ac Plug Assembly - Sxx55 - Ansi - January 2026 And After
240v At Base Assembly
240v At Platform Assembly
Side Gate
Schematics
Hydraulic Schematic
Wiring Schematic
Appendix A
ages Index
Appendix B
arts Index
Brand: Snorkel
Repair Parts
Base Assembly
Steer Axle Assembly
Swing Arms Assembly
Coupler Assembly
Platform Assembly
Decals/Placards
Hydraulics
Electrical
Loom List
24v Dc Assembly
Options
Inverter
Side Gate
Schematics
Hydraulic Schematic
Wiring Schematic
Appendix A
Appendix B
