Momed80
150
35,046
Snorkel Aerial Work Platform UNO41D UNO41G Repair Parts Manual 0152875
Brand: Snorkel
Type of Manual: Repair Parts Manual
Model: Snorkel UNO41D UNO41G Aerial Work Platform
Part Number: 0152875
Number of Pages: 226 Pages
Service and parts information
To order service or repair parts
ANSI and OSHA compliance
Manuals
Parts order form
Section 1 - Repair parts
Chassis/turntable mounting
Drive
Steering
Swing drive mounting
Fuel tank
Hydraulic oil reservoir mounting
Booms mounting
Upper boom and hose carrier
Upper boom
Hose carrier
Extend cylinder
Platform, gravity gate
Platform, swinging gate
Platform rotation gear box, Hub city
Chassis cowling
Turntable cowling
Engine mounting, Ford gasoline
Engine, Ford gasoline
Engine mounting, Kubota diesel
Engine, Kubota diesel
Air cleaner
Placards and decals
Gear hub, drive - Auburn
Gear hub, Steer - Auburn
Swing drive - Gear Products
Swing drive, Perfection
Swing drive, Tulsa Winch
Tires and wheels
Section 2 - Hydraulics
Chassis hydraulic equipment
Chassis hydraulic hoses
Turntable hydraulic equipment
Turntable hydraulic hoses
Booms hydraulic equipment
Drive control valve
Transmission valve
Package valve, Rexroth
Package valve, Vickers
Control valve package, Rexroth
Control valve package, Vickers
Add-on valve, Rexroth
Add-on valve, Vickers
Control valve, drive
AC generator valve
Accumulator, chassis
Accumulator, turntable
Check valve
Lower boom lift cylinder
Cylinder, lower boom lift - GBI
Cylinder, lower boom lift - Green
Cylinder, lower boom lift- Texas
Cylinder, lower boom lift - Rosenboom
Middle boom lift cylinder
Upper boom lift cylinder
Cylinder, boom lift - GBI
Cylinder, boom lift - Green
Cylinder, boom lift - Seabee
Cylinder, extension - GBI
Master level cylinder
Cylinder, master level - Green
Cylinder, master level - Prince
Slave level cylinder
Cylinder, slave level - GBI
Cylinder, slave level - Prince
Cylinder, slave level - Texas
Cylinder, steering - Green
Cylinder, steering - Prince
Cylinder, steering - Texas
Dual counterbalance valve, Fluid Tech
Dual counterbalance valve, Weco
Emergency power pump
Flow divider, Fluid Tech
Flow divider, Sun Hydraulics
Gear flow divider
High-low speed valve
hydraulic motor and brake
Hydraulic oil return filter
Hydraulic drive motor, steering end
Hydraulic drive motor, drive end
Hydraulic pump and fittings
Sense line dump valve
Solenoid valve, high-low shift
Transmission valve package, Fluid Tech
Transmission valve package, Vickers
Pressure switch
Section 3 - Electrical
Chassis electrical, Ford
Chassis electrical, Kubota
Turntable electrical, Ford
Turntable electrical, Kubota
Platform electrical
Wiring box, Ford
Wiring box, Kubota
Wiring box panel, Ford
Wiring box panel, Kubota
Upper control box, Ford
Upper control box, Kubota
Engine gauge panel, Ford
Engine gauge panel, Kubota
Platform foot switch
Boom switch, Ford
Boom switch, Kubota
Steer switch, left hand
Steer switch, right hand
Power to Platform, 125 volt
Controller, drive
Section 4 - Factory installed options
Hydraulic AC generator
AC generator
Airline to platform
Driving lights and taillights
Dual fuel, Ford
Dual fuel engine, Ford
LP fuel only, Ford
LP fuel engine, Ford
Engine block heater
Lanyard anchor, dual
Lanyard anchor, platform floor
Motion alarm
Operator horn
Tool tray
Tow package
Warning lights
Work lights
Upper control box cover
