Snorkel Aerial Work Platform TL39 Service Maintenance Manual 1480127-000 2025
Brand: Snorkel
Type of Manual: Service Maintenance Manual
Model: Snorkel TL39 Aerial Work Platform
Part Number: 1480127-000
Publication Date: 2025
Number of Pages: 148 Pages
Section 1 General Information
Component Identification
Serial Number Locations
Working Envelope
Safety Precautions
Operator’s Manual Procedures
Technical Bulletins
Abbreviations List
Section 2 Specifications
General Specifications
Surge Brake Coupler
Engine Specifications
Engine Operated Gear Pump
6 Volt Battery
12 Volt Battery
Battery Charger Specifications
Fastener Torque Chart
Standard System
Metric System
Section 3 Hydraulic Components
Hydraulic Component Location
Right Side
Center
Left Side
Coupler with Surge Brake
Top View
Bottom View
Hydraulic Pump and Coupler
Swing Drive
Outriggers
Cylinder
Manifold
24 Volt DC Electric Power Unit
Hydraulic Fluid Reservoir
Function Manifold
Riser Boom Lift Cylinder
Main Boom Lift Cylinder
Main Boom Extend Cylinder
Master and Slave Level Cylinder
Platform Rotate Cylinder
Section 4 Electrical Components
Right Side
Left Side
Center
Outrigger Limit Switch
Outrigger Control Panel
External Components
Internal Components
Matrix Board Pinouts
Wiring
Lower Control Box
External Components
Internal Components
Terminal Board Module
Wiring
Control Board and Pinouts
Battery Charger
24 Volt Battery Bank
DC Converter
Boom Electrical Components
Main Boom Lift Limit Switch
Riser Boom Limit switch
Upper Control Box
External Components
Internal Components
Matrix Board and Pinouts
Wiring
Honda Gas Engine
24 Volt
24 Volt Bi-Energy
Harnesses
Outrigger Control Box to Outrigger Manifold
Outrigger Leg Switch - J3-A Harness
Lower Control Box to Function Manifold
Harness
Plug Components
Pinouts
Lower Control Box to Upper Control Box
Lower Control Box to Trailer
Lower Control Box to Honda Gas Engine
Lower Control Box to Main Boom Limit Switch Harness
Honda Gasoline Engine Harness
Lower Control Box to Riser Boom Limit Switch
J5 Boom Bleed Down / Engine / Boom Limit Switch Harness
Section 5 Engine Components
Honda Engine
Section 6 Trailer Components
Jockey Wheel
Axle
Rotation Bearing
Section 7 Outriggers
Outrigger Location
Outrigger Components
Section 8 Booms
Boom Components
Boom Assembly Components
Section 9 Platform
Platform Components
Section 10 Options
240 Volt AC Pump And Motor
Section 11 Procedures & Adjustments
Recommended Tools
Surge Brake Procedures
Filling and Bleeding Surge Brake
Surge Brake Maintenance
Testing Surge Brake Systems
Switch Adjustments
Pressure Adjustments
Function Manifold
Section 12 Maintenance
General Maintenance
Lubrication Points
Battery Care and Maintenance
Maintenance Schedule
Prestart Inspection Checklist
Daily Check
Weekly Check
Monthly Check
6-Month Check
Major Repairs
Filter Service Intervals
Section 13 Schematics
Hydraulic Schematic
Bi-Energy
Electric Schematic
Outrigger Controls
Lower Controls
24 Volt
Bi-Energy
Gasoline
Lower Controls to Function Manifold
Upper Controls
24 Volt
Bi-Energy
Gasoline
Section 14 Appendix
Appendix A - Glossary
Brand: Snorkel
Working Envelope
Safety Precautions
Technical Bulletins
Abbreviations List
Surge Brake Coupler
6 Volt Battery
12 Volt Battery
Standard System
Metric System
Right Side
Center
Left Side
Top View
Bottom View
Swing Drive
Outriggers
Cylinder
Manifold
Function Manifold
Right Side
Left Side
Center
External Components
Internal Components
Wiring
Lower Control Box
External Components
Internal Components
Wiring
Battery Charger
DC Converter
Upper Control Box
External Components
Internal Components
Wiring
Honda Gas Engine
24 Volt
24 Volt Bi-Energy
Harnesses
Harness
Plug Components
Pinouts
Honda Engine
Jockey Wheel
Axle
Rotation Bearing
Outrigger Location
Section 8 Booms
Boom Components
Section 9 Platform
Platform Components
Section 10 Options
Recommended Tools
Switch Adjustments
Function Manifold
General Maintenance
Lubrication Points
Daily Check
Weekly Check
Monthly Check
6-Month Check
Major Repairs
Hydraulic Schematic
Bi-Energy
Electric Schematic
Outrigger Controls
Lower Controls
24 Volt
Bi-Energy
Gasoline
Upper Controls
24 Volt
Bi-Energy
Gasoline
Section 14 Appendix
