Snorkel Aerial Work Platform TL37J Service Maintenance Manual 1480125-000 2025
Brand: Snorkel
Type of Manual: Service Maintenance Manual, Electrical Schematic, Hydraulic Schematic
Model: Snorkel TL37J Aerial Work Platform
Part Number: 1480125-000
Publication Date: 2025
Number of Pages: 136 Pages
Section 1 General Information
Component Identification
Serial Number Locations
Working Envelope
Safety Precautions
Operator’s Manual Procedures
Technical Bulletins
Wire Code and Function Chart
Abbreviations List
Section 2 Specifications
General Specifications
Surge Brake Coupler
Engine Specifications
Engine Operated Gear Pump
6 Volt Battery
12 Volt Battery
Battery Charger Specifications
Fastener Torque Chart
Standard System
Metric System
Section 3 Hydraulic Components
Hydraulic Component Location
Right Side
Left Side
Coupler with Surge Brakes
Top View
Bottom View
Hydraulic Pump and Coupler
Rotation Bearing and Mounting
Outriggers
Cylinder
Manifold
24 Volt Power Unit and Hydraulic Oil Tank
Power Unit Components
Hydraulic Oil Tank Components
Lower and Upper Control Manifold
Selector Valve and Diverter Valve
Riser Boom Lift Cylinder
Main Boom Lift Cylinder
Jib Cylinder
Platform Rotate Cylinder
Section 4 Electrical Components
Left Side
Right Side
Outrigger Limit switch
Lower Control Box
External Components
Internal Components
Wiring
Control Board
Can Tilt Cable
Battery Charger
24 Volt Battery Bank
Boom Electrical Components
Boom Lift Limit Switch
Overload Switch
Upper Controls
Electrical Panel
Upper Control to Lower Control Cable
Wiring
Section 5 Engine Components
Honda Engine
Section 6 Trailer Components
Jockey Wheel
Axle
Hub and Brake Assembly
Brakes
Section 7 Outriggers
Outrigger Location
Outrigger Components
Section 8 Booms
Boom Components
Section 9 Platform
Platform Components
Upper Controls
Components
Section 10 Options
Friction Drive
Section 11 Procedures & Adjustments
Recommended Tools
Surge Brake Procedures
Filling and Bleeding Surge Brake
Surge Brake Maintenance
Testing Surge Brake Systems
Switch Adjustments
Outrigger Limit Switch
Overload Limit Switch
Pressure Adjustments
24 Volt System
Outriggers
Lower Boom Controls Valve
Upper Controls Valve
Gas Engine System
Pump Pressure
Outriggers
Lower Control Valve
Upper Control Valve
Section 12 Maintenance
General Maintenance
Lubrication Points
Battery Care and Maintenance
Maintenance Schedule
Prestart Inspection Checklist
Daily Check
Weekly Check
Monthly Check
6-Month Check
Major Repairs
Filter Service Intervals
Section 13 Schematics
Hydraulic Schematic
24 VDC
BI-Energy
Gas Engine
Electric Schematic
24 VDC
BI-Energy
Gas Engine
Section 14 Appendix
Appendix A - Glossary
Brand: Snorkel
Working Envelope
Safety Precautions
Technical Bulletins
Abbreviations List
Surge Brake Coupler
6 Volt Battery
12 Volt Battery
Standard System
Metric System
Right Side
Left Side
Top View
Bottom View
Outriggers
Cylinder
Manifold
Jib Cylinder
Left Side
Right Side
Lower Control Box
External Components
Internal Components
Wiring
Control Board
Can Tilt Cable
Battery Charger
Overload Switch
Upper Controls
Electrical Panel
Wiring
Honda Engine
Jockey Wheel
Axle
Brakes
Outrigger Location
Section 8 Booms
Boom Components
Section 9 Platform
Platform Components
Upper Controls
Components
Section 10 Options
Friction Drive
Recommended Tools
Switch Adjustments
24 Volt System
Outriggers
Gas Engine System
Pump Pressure
Outriggers
Lower Control Valve
Upper Control Valve
General Maintenance
Lubrication Points
Daily Check
Weekly Check
Monthly Check
6-Month Check
Major Repairs
Hydraulic Schematic
24 VDC
BI-Energy
Gas Engine
Electric Schematic
24 VDC
BI-Energy
Gas Engine
Section 14 Appendix
