Momed80
150
35,046
Snorkel Aerial Work Platform TB86J Parts Manual 0113772 2016
Brand: Snorkel
Type of Manual: Parts Manual, Electrical Schematic, Hydraulic Schematic
Model: Snorkel TB86J Aerial Work Platform
Serial Number: 000200 and after
Part Number: 0113772
Publication Date: 2016
Number of Pages: 773 Pages
Repair Parts
Tires And Wheels
Non-Directional Wheels Installation
Gray Non-Marking Foam Filled Tires
Brake Unit
Chassis Cover Installation Fixed Axle
Chassis And Turntable Installation
Chassis Assembly - Tb80/Tb86j - Pg
Gear Hub
Gear Hub - Omni
Diesel Oxidation Catalyst Muffler - Kubota V2403 Cr T4b
Emergency Power Unit Assembly
Wiring 4 R313i R313i 15 Blk
Supertrapp Muffler Adapter
Turntable Assembly - Pg
Turntable Assembly - Kubota
Turntable Assembly - Kubota V2403 Tier 4 Final
Turntable Assembly - Kubota 12k Tier 4 Final
Turntable Assembly - Dual Fuel
Turntable Assembly - High Capacity - April 2024 And After
Centerpost Sub-Assembly
Engine Sub-Assembly With Throttle Solenoid - January 2022 And After - Kubota V2403 Tier 4 Final
Engine Export With Radiator Replacement Parts - Kubota V2403-M-T-E3-Kea-2e
Engine Sub-Assembly Pg With Actuator - Sn Tb86j-04-170800305 And After - Kubota V2403 Tier 4 Final
Engine With Radiator Replacement Parts - Kubota V2403t
Radiator Kit - Kubota Tier 4 Final
Engine With Radiator Replacement Parts - Kubota Wg2503 Dual Fuel
Engine Sub-Assembly - Sn Tb86j-04-170400250 And After - Wg2503
Engine Replacement Parts - Kubota V2403-Cr Tier 4b
Engine Ku Assembly - Sn Tb86j-04-170400250 And After - Wg2503 Dual Fuel
Cooling System - Kubota V2403 Cr T1
Fuel System Assembly - Kubota V2403 Tier 4 Final
Exhaust/Air Cleaner Installation - Kubota
Air Cleaner Assembly
Air Cleaner
Air Cleaner And Exhaust Assembly - Dual Fuel
Air Cleaner And Exhaust - January 2020 And After - Kubota V2403 Tier 4 Final
Hydraulic Fluid Reservoir Installation
Hydraulic Fluid Reservoir Assembly
Hydraulic Fluid Tank
Hydraulic Fluid Return Filter
Oil Cooler Installation
Fuel Tank Installation
Steel Cowling Installation Assembly - High Capacity
Cowling Installation - Df
Cowling Installation Page 1 Of 4
Cowling Installation Page 2 Of 4
Cowling Installation Page 3 Of 4
Cowling Installation Page 4 Of 4
Steel Cowling Installation 1 Of 4 - Pg Kubota
Steel Cowling Installation 2 Of 4 - Pg Kubota
Steel Cowling Installation 3 Of 4 - Pg Kubota
Steel Cowling Installation 4 Of 4 - Pg Kubota
Steel Cowling Page 1 Of 2 - Kubota Tier 4 Final
Steel Cowling Page 2 Of 2 - Kubota Tier 4 Final
Front Steel Cowling Service Kit - Deutz
Rear Steel Cowling Assembly
Extend Cylinder Sub-Assembly
Boom Installation - Triple Capacity - April 2024 And After
Boom Assembly - High Capacity - April 2024 And After
Boom Assembly Hose Carrier And Jib Pg
Boom Assembly Hose Carier And Jib - Pg/Ce
Boom Hose Carrier And Jib Assembly Pg
Boom Assembly Pg - Tb80/Tb85j/Tb86j
Hose Carrier Assembly Pg With 12k
Hose Carrier Assembly Support
Carrier Track Replacement Links - Brevetti
Carrier Track Replacement Links - Dynatect
Mid Boom Assembly - Triple Capacity - April 2024 And After
Mid To Base Boom Assembly - Triple Capacity - April 2024 And After
Tip To Mid Boom Assembly - High Capacity - April 2024 And After
Tip Boom Assembly - High Capacity - April 2024 And After
5.5' Jib Assembly - Sn Tb86j-04-24040798 And After
6' Jib Assembly Pg
6' Jib Assembly - July 2018 And After
6' Jib Assembly - 660sj - Ce - February 2019 And After
Jib Inner Quadrant
Jib Quadrant Assembly - Triple Capacity - April 2024 And After
Platform Installation
Global Platform Assembly
Triple Capacity Platform Assembly - Sn Tb86j-04-24040798
Platform Rotator Assembly With Overload
Platform Rotator Assembly With Overload - Helac
Snorkel Guard Legacy Assembly
Legacy Snorkel Guard Kit
Decals Installation - Tb86j - High Capacity
Decals/Placards Installation - Ansi 92.20 - Kubota
Decals/Placards
Decals/Placards Installation - Tb80/Tb85j/Tb86j - German/Dutch/Swedish/Spanish/French/Ce
Decals/Placards Installation - Ansi - May 2020 And Before - Kubota Tier 4 Final
Decals/Placards Installation - Ansi 92.20 - June 2020 And After - Kubota Tier 4 Final
Decals/Placards Installation - Ansi 92.20 - June 2020 And After - Kubota Gas Dual Fuel
Decals/Placards Installation - Ce/Ansi 92.20 - June 2020 And After
Language Kit - Spanish
Language Kit - Ansi - Spanish
Language Kit - Ansi 92.20 - June 2020 And After - Spanish
French Language Kit
Hydraulics
Accumulator Sub-Assembly - 300 Psi
Chassis Accumulator
Chassis Assembly Hosing
Rear Transmission Valve Sub-Assembly
Front Transmission Valve Assembly
Transmission Valve Package
Four Wheel Steer Valve
Flow Divider Sub-Assembly
Emergency Power Unit Assembly - April 2016 And Before
Emergency Power Unit Assembly - April 2016 And After
Emergency Power Unit - Sn Tb86j-04-240400798 And After
Proportional Control Valve Pg Sub-Assembly - June 2017 And After
Proportional Control Valve - High Capacity Sub-Assembly - Sn Tb86j-04-24040798 And After
Non-Proportional Control Valve
Non-Proportional Control Valve Assembly - Fluid Tech Tier 3
Non-Proportional Valve Assembly - Fluid Tech - April 2024 And After
Hydraulic Pump - June 2018 And After
Hydraulic Pump Sub-Assembly
Piston Pump - Hengli
Swing Drive Perfection Or Auburn Gear
Swing Drive Assembly - Omni
Swing Motion Control Valve Assembly - May 2007 And After
Pressure Manifold
Sense Line Dump Valve
Speed Shift Valve Assembly
Platform And Jib Selector Valve Assembly
Primary Level Cylinder
Secondary Level Cylinder
Secondary Level Cylinder Assembly
Steering Cylinder - Hengli
Steering Cylinder - Rosenboom
Lift Cylinder - Rosenboom
Lift Cylinder/Tube Assembly - Hengli
Lift Cylinder 8.00 33.75 4.00 Lift - Hengli
Lift Cylinder Hengli - Tb86j-04-0000067 And After
Lift Cylinder Assembly
Extension Cylinder - Tb86j-04-0000054 And After - Hengli
Extend Cylinder Gbi - Tb86j-04-000054 And Before
Jib Cylinder - Tb86j-04-0000067 And Before - Rosenboom
Jib Cylinder - Tb86j-04-0000068 And After - Hengli
Tip Manifold Assembly - Triple Capacity - Sn Tb86j-04-24040798 And After
Rotary Actuator - Tb86j/Tb126j - September 2019 And After - Sunji
Rotary Actuator - Sunji
Rotator Assembly - Hengli
Electrical
Turntable Wire Assembly - Pg
Turntable Wiring Assembly - Cummins/Deutz/Gm
Electrical System Assembly - Tier 4 Final
Harness Power To Platform
Engine Harness - Kubota - Pg
Engine Harness - Kubota Tier 4 Final
Engine Harness - Kubota Tier 4 Final High Capacity
Engine Harness - Feburary 2019 And After - Kubota Tier 4 Final
Engine Harness Dual Fuel Wg2503
Wire Assembly Lift Swing Speed Valve
110 Volt Power To Platform - Pg
Cable 12ga/3 Conductor 110' Long
E-Pump Signal Harness High Capacity
Overload Cable Harness
Lower Control Panel Assembly - December 2007 And After - Deutz
Lower Control Panel Assembly - Pg
Lower Control Box Assembly - Kubota Tier 4 Final
Lower Control Box Harness - Kubota Tier 4 Final
Lower Control Box Assembly - High Capacity - Sn Tb86j-04-24040798 And After
Lower Control Box Assembly - Dual Fuel
Lower Control Box - Triple Capacity Harness
Boom Switch Assembly
Boom Switch Assembly Lift Swing
Boom Switch Wire Assembly
Platform Jib Selector Harness
Platform Jib Selector Wire Assembly
Jib High Capacity Harness
Upper Control Box Assembly - Tri-Capacity - 5 Degree - Sn Tb86j-04-251000809 And After
Upper Control Box Assembly - Tri-Capacity - Sn Tb86j-04-251000808 And Before
Upper Control Box Assembly - Tri-Capacity - Hawe I/O Mod - 5 Degree - Sn Tb86j-04-251000808 And Before
Upper Control Box High Capacity Installation -Sn Tb86j-04-251000808 And Before
Upper Control Box Assembly - Tri-Capacity - Hawe I/O Mod - Sn Tb86j-04-251000808 And Before
Upper Control Box Assembly - Dual Fuel
Upper Control Box Assembly - Pg
Upper Control Box Assembly - Pg With 12kw
Foot Switch Assembly - Pg
Options
Tow Kit
Scrubber - Kubota V2403
Isolator Valve Installation
Belt Generator - April 2019 And Before - Kubota 2.4kw V2403/Wg2503
Belt Generator - May 2019 And After - Kubota 2.4kw V2403/Wg2503
110 Volt Hydraulic Ac Generator Installation - Pg
110 Volt Ac Hydraulic Generator Installation
110 Volt Ac Hydraulic Generator Sub-Assembly
220 Volt Hydraulic Ac Generator Installation - Pg
220v Ac 50hz Hydraulic Ac Generator Sub-Assembly
2kw Generator Single V-Belt Assembly - Fabco
2.4kw Hydraulic Generator Service Kit
2.4kw Belt Generator
12kw Generator Installation
12kw Generator Circuit Breaker Wiring
12kw Generator Assembly
12kw Generator Valve Assembly
12kw Generator Wire Assembly
12kw Generator Wiring Box Assembly
12kw Generator Circuit Breaker Wiring Assembly
12kw Generator Junction Box Assembly
Trackunit To Control Box Boom Installation
Airline To Platform
Hydraulic Warm Up Installation - Pg
Hydraulic Warm-Up Installation
Extreme Cold Weather Package - Pg
Extreme Environment Package
6' Jib Sandblast Kit
Bumpguard Installation
Platform Bumpguard With Padding Assembly
36x96 Platform Assembly Bumpguard With Padding
36x96 Platform Assembly Bumpguard With Padding - March 2009 And After
Platform Assembly With Mesh Enclosure - April 2018 And After
Platform Assembly With Mesh Enclosure- April 2016 And After
8' Aluminum Platform Assembly With Gravity Gate
8' Platform Bumpguard Installation
8' Platform Harness Bumpguard
Steel Platform Assembly With Welder
Aluminum Platform Assembly With 11kw Welder
Welder Installation - Lincoln
Welder Assembly - Lincoln
Global Standard Platform Assembly
Platform Assembly 36 X 96 Steel Double Handrail On Padding September 2017 And After
Upper Control Box Cover
Csa Certification
Glazier Package Installation
Glazier Package World Platform With 2" Toe Board Installation
Glazier Tray Assembly
Tool Tray
Overload Add On
Pipe Rack Installation
Pipe Rack Boom Assembly
Lanyard Mount Installation Option
Platform Work Lights Global Installation
Wire Harness Platform Work Lights
Amber Beacon Single
Harness Amber Beacon
Alarm And Mounting Assembly
Dual Warning Light
Light Package Installation
Light Package
Harness Driving Taillights
Schematics
Tb86j - Hydraulic Schematic - Tri-Capacity - 5 Degree - Sn Tb86j-04-251000809 And After
Tb86j - Electrical Schematic - Tri-Capacity - 5 Degree - Sn Tb86j-04-251000809 And After
Tb86j - Electrical Schematic Pg - Kubota Tier 4 Final
Tb86j - Electrical Schematic - Added Relay Into Upper Control Box To Use Pg Board Signal To Provide Positive Signal To Engine - Kubota Tier 4 Final
Tb85j/Tb86j - Electrical Schematic - Deutz/Cummins
Tb85jfa/Tb86jfa - Hydraulic Schematic - Switched Hoses On Centerpost And Added Fm Stamp
Appendix A:pages Index
Appendix B:parts Index
