Snorkel Aerial Work Platform TB86J Parts Manual 0113771 2016
Brand: Snorkel
Model: Snorkel TB86J Aerial Work Platform
Part Number: 0113771
Publication Date: 2016
Number of Pages: 510 Pages
Repair Parts
Tires And Wheels
Power Wheel- Omni
4wheel Steer Fixed Axle Installation
4wheel Drive Installation Fixed Axle
Chassis And Turntable Installation
Chassis Cover Installation Fixed Axle
Brake Unit
Centerpost Sub-Assembly
Swing Drive Assembly
Lift Swing Counterweight Installation
Engine Sub-Assembly - November 2008 And After - Deutz
Engine Tray Assembly - Gm
Engine Mounting - Gm
Engine Sub-Assembly - Kubota
Engine With Radiator Replacement Parts - Kubota V2403-M-T-E3b-Kea-2f
Exhaust/Air Cleaner - Gm
Exhaust/Air Cleaner Installation - Kubota
Exhaust/Air Cleaner - Deutz
Air Cleaner Assembly
Air Cleaner
Air Cleaner And Exhaust - January 2020 And After - Kubota V2403 Tier 4 Final
Emergency Power Unit Assembly
Supertrapp Muffler Adapter
Hydraulic Fluid Reservoir Installation
Hydraulic Fluid Reservoir Assembly
Hydraulic Fluid Tank
Cowling Installation
Rear Steel Cowling Assembly
Front Steel Cowling Service Kit - Deutz
Booms Base End
Booms Assembly
Boom Assembly - Pg - Tb80/Tb85j/Tb86j
Boom Hose Carrier Jib Assembly For Plastic Track - April 2015 And Before
Booms Assembly For Plastic Track
Boom Hose Carrier Jib Assembly For Steel Track - May 2015 And After
Hose Carrier Assembly - April 2015 And Before
Hose Carrier Assembly For Steel Track - May 2015 And After
Hose Carrier Assembly Support
Extension Cylinder Assembly
6' Jib Assembly - Pg
6' Jib Assembly - Ce
Secondary Level Cylinder Assembly
Platform Mounting
Global Platform Assembly
8' Aluminum Platform Assembly With Gravity Gate
8' Aluminum Platform Assembly Two Swing Gates With Bumpguard System
Legacy Snorkel Guard Kit
Harness Internal Platform Hi Cap
Snorkel Guard Assembly
Platform Decal And Machine With Pg Assembly
Language Kit - Ansi - Spanish
Decal Installation - Kubota Tier 4 Final
Decals/Placards Installation - Kubota
Decals/Placards Installation - Kubota Gas Dual Fuel
Decals/Placards Installation - Tb80/Tb85j/Tb86j - German/Dutch/Swedish/Spanish/French/Ce
Upper Control Box Decal
Hydraulics
4wheel Drive Chassis Hydraulics
4wheel Steer Valve
Rear Transmission Valve Sub-Assembly
Front Transmission Valve Sub-Assembly
Chassis Accumulator
Flow Divider Sub-Assembly
Speed Shift Valve Assembly
Hydraulic Equipment Turntable
Pressure Manifold
Proportional Control Valve
Proportional Control Valve Sub-Assembly - October 2014 And After
Non-Proportional Four Section Valve - March 2006 And After
Non-Proportional Valve Assembly - January 2016 And After
Non-Proportional Control Valve
Pump Sub-Assembly - Kubota
Piston Pump - Hengli
Swing Drive Assembly - Omni
Swing Drive Perfection Or Auburn Gear
Swing Drive - Auburn
Hydraulic Fluid Return Filter
Platform Rotator Assembly
Platform Rotate Or Jib Selector Valve
Platform Rotate Or Jib Selector Valve Assembly
Primary Level Cylinder
Primary Level Cylinder - Rosenboom
Secondary Level Cylinder - Rosenboom
Steering Cylinder - Waltco
Steering Cylinder - Rosenboom
Lift Cylinder - Rosenboom
Lift Cylinder/Tube Assembly - Hengli
Lift Cylinder 8.00 33.75 4.00 Lift - Hengli
Extension Cylinder - Tb86j-04-0000054 And After - Hengli
Extension Cylinder - Before Tb86j-04-000054 - Gbi
Jib Cylinder - Tb86j-04-0000068 And After - Hengli
Jib Cylinder - Tb86j-04-0000067 And Before - Rosenboom
Electrical
Turntable Electrical Installation - Deutz
Engine Harness - Kubota
Engine Harness - Kubota Tier 4 Final
Wiring 4 R313i R313i 15 Blk
Wiring Box Assembly - Ansi/Ce - Cummins/Duetz
Lower Control Panel Assembly
Lower Control Panel Assembly - Cummins
Lower Control Panel Assembly - Deutz
Panel Sub-Assembly - Kubota
Boom Switch Assembly
Boom Electrical Installation
Drive Steer Controller
Platform Rotate Or Jib Selector Wire Assembly
Alternator Wire Assembly - Deutz
110 Volt Power To Platform Installation
Upper Control Box Assembly
Lift Swing Controller
Extend Retract Controller
E-Pump Signal Harness High Capacity
Snorkel Guard Wiring
Platform Foot Switch
Options
Tow Kit
Isolator Valve Installation
Ac Genarator Valve Sub-Assembly
12kw Generator Installation
12kw Generator Assembly Tb80fa/85jfa/86jfa - Tendaire
110 Volt Hydraulic Ac Generator Installation - September 2007 And Before
110 Volt Ac Hydraulic Generator Installation
110 Volt Ac Hydraulic Generator Sub-Assembly
220 Volt Hydraulic Ac Generator Assembly
Airline To Platform
Air Inlet Heater - Deutz 1011f
Spark Arrestor - Deutz
Extreme Cold Weather Package - Pg
Hydraulic Warm Up Installation
Sandblast Kit
Swing Gate End Mid-Rail
Gravity Gate Side Entry
Platform Control Cover
Platform Assembly 36 X 96 Steel Double Handrail On Padding September 2017 And After
36x96 Platform Assembly Bumpguard With Padding
36x96 Platform Assembly Bumpguard With Padding - March 2009 And After
Global Standard Platform Assembly
Platform Assembly With Mesh Enclosure- April 2016 And After
Overload Add On
39x96 Tri-Entry Steel Platform And 12k Generator And Brackets - 500lb
39x96 500lbs Tri-Entry Platform Assembly With 12k
Welder Installation - Lincoln
Welder Assembly - Lincoln
Aluminum Platform Assembly With 11kw Welder
Steel Platform Assembly With Welder
Cold Weather Package Pg - Kuboda
Block Heater - Kubota V2403t
Hydraulic Warm Up Installation - Pg
Platform Work Lights Global Installation
Platform Work Lights 2 Flood
Wire Harness Platform Work Lights
Led Work Lights - Pg
Dual Warning Light
Red Or Amber Beacon Installation
Tilt Alarm Light
Motion Alarm
All Motion Alarm Without Horn
Alarm And Mounting Assembly
Headlight Installation
Head/Taillights Installation
Led Drive And Taillights Pg
Harness Drive And Taillights
Light Package Installation
Led Light Package
Maintenance
Maintenance
Schematics
Tb85jfa/Tb86jfa - Hydraulic Schematic - Switched Hoses On Centerpost And Added Fm Stamp
Tb85j/Tb86j - Electrical Schematic - Deutz/Cummins
Tb85jfa/Tb86jfa - Electrical Schematic - Gm
Tb85jfa/Tb86jfa - Electrical Schematic - Updated Resistors In Wires 181a And 181b - Gm Tier 3 1.6l/2.4l
Tb85jfa/Tb86jfa - Electrical Schematic - Updated Routing Of Wire 170 - Gm Tier 3
Tb85jfa/Tb86jfa - Electrical Schematic - Ce - Deutz/Cummins
Tb85jfa/Tb86jfa - Electrical Schematic - Ce - Updated Routing Of Wires 213 And 214 - Deutz
Tb85jfa/Tb86jfa - Electrical Schematic - Ce - Updated Routing Of Wire 170 - Deutz/Cummins
Tb85jfa/Tb86jfa - Electrical Schematic - Ce - Added Glow Plug Timer Assembly And Related Wiring - Cummins Tier 3
Tb85jfa/Tb86jfa - Electrical Schematic - Ce - Updated Wires 213 214 And Added Steer Relay - Cummins Tier 3
Tb85jfa/Tb86jfa - Electrical Schematic - Ce - Updated Routing Of Wire 170 - Cummins Tier 3
Tb85jfa/Tb86jfa - Electrical Schematic - Added - Glow Plug Timer Assembly And Related Wiring - Cummins Tier 3
Tb85jfa/Tb86jfa - Electrical Schematic - Added Steer Relay - Cummins Tier 3
Tb85jfa/Tb86jfa - Electrical Schematic - Updated Routing Of Wire 170 - Cummins Tier 3
Appendix A
ages Index
Appendix B
arts Index
Brand: Snorkel
Repair Parts
Tires And Wheels
Power Wheel- Omni
Brake Unit
Air Cleaner
Booms Base End
Booms Assembly
Platform Mounting
Hydraulics
4wheel Steer Valve
Chassis Accumulator
Pressure Manifold
Electrical
Options
Tow Kit
Airline To Platform
Sandblast Kit
Overload Add On
Dual Warning Light
Tilt Alarm Light
Motion Alarm
Led Light Package
Maintenance
Maintenance
Schematics
Appendix A
Appendix B
