Momed80
150
35,046
Snorkel Aerial Work Platform TB85J T85J Parts Manual 0113770 2016
Brand: Snorkel
Type of Manual: Parts Manual, Electrical Schematic, Hydraulic Schematic
Model: Snorkel TB85J T85J Aerial Work Platform
Serial Number: 110811047 and after
Part Number: 0113770
Publication Date: 2016
Number of Pages: 573 Pages
Repair Parts
Tires And Wheels
4wheel Steer Fixed Axle Installation
4wheel Drive Fixed Axle Installation
Chassis And Turntable Installation
Chassis Cover Installation Fixed Axle
Brake Unit
Gear Hub - Omni
Gear Hub - Auburn
Fixed Axle Kit Installation - Tb80/Tb85j
Turntable Assembly - Kubota V2403 Tier 4 Final
Lift Swing Counterweight Installation
Centerpost Sub-Assembly
Engine Tray Assembly Actuator - Cummins 3.3 T3 With Addco
Engine Tray Assembly - Cummins 3.3 T3
Engine Sub-Assembly - Deutz
Engine Tray Assembly - Gm
Engine Installation - Deutz F4l1011
Exhaust/Air Cleaner Installation
Exhaust Air Cleaner Installation - Tb80/Tb85j - Gm Tier 3
Exhaust/Air Cleaner Installation - Kubota
Air Cleaner - Deutz
Air Cleaner Assembly
Air Cleaner Assembly - Cummins 65 Hp/Cummins 65 Hp/Ford Lrg 425/Gm Tier 3 2.4l/Kuboda V2403
Engine Radiator Installation - Gm Tier 3 Final
Radiator Assembly - Gm
Engine Sub-Assembly With Throttle Solenoid - December 2021 And Before - Kubota V2403 Tier 4 Final
Engine Sub-Assembly With Throttle Solenoid - January 2022 And After - Kubota V2403 Tier 4 Final
Engine Export With Radiator Replacement Parts - Kubota V2403-M-T-E3-Kea-2e
Engine With Radiator Replacement Parts - Kubota V2403-M-T-E3b-Kea-2f
Supertrapp Muffler Adapter
Oil Cooler Installation
Fuel Tank Installation
Hydraulic Fluid Reservoir Installation
Hydraulic Fluid Reservoir Assembly
Cowling Installation - Tb80/Tb85j - Page 1 Of 4
Cowling Installation - Tb80/Tb85j - Page 2 Of 4
Cowling Installation - Tb80/Tb85j - Page 3 Of 4
Cowling Installation - Tb80/Tb85j - Page 4 Of 4
Plastic Cowling - Deutz
Plastic Cowling - Gm/Cummins
Front Steel Cowling Service Kit - Deutz
Front Cowling Service Kit - Cummins
Counterweight Modification Installation
Boom Installation
Booms Base End
Boom And Hose Carrier Assembly
Boom Assembly - Pg - Tb80/Tb85j/Tb86j
Hose Carrier Asssembly
Hose Carrier Support Assembly
Extension Cylinder Assembly
5' Jib Assembly
Jib - Inner Quadrant
Platform Rotator Assembly
8' Aluminum Platform Assembly With Swing Gate And Bumpers
Snorkel Guard Tri-Entry Kit
Snorkel Guard Legacy Kit And Wiring
Snorkel Guard Legacy Assembly
Decals/Placards Installation - Tb85jfa - Cummins
Decals/Placards Installation - Tb80/Tb85j/Tb86j - German/Dutch/Swedish/Spanish/French/Ce
Hydraulics
Chassis Accumulator Sub-Assembly
Front Transmission Valve Sub-Assembly
Rear Transmission Valve Sub-Assembly
Flow Divider Sub-Assembly
4wheel Steer Valve
Hydraulic Turntable Equipment
Pressure Manifold - Fluid Tech
Swing Drive Perfection Gear With Brake
Piston Pump - Hengli
Proportional Control Valve Sub-Assembly
Proportional Control Valve - Apitech
Non-Proportional Control Valve
Non-Proportional Control Valve - Fluid Tech
Non-Proportional Valve Assembly - January 2016 And After
Sense Line Dump Valve Assembly
Motion Control Valve Turntable Rotation
Speed Shift Valve Assembly
Emergency Power Unit Sub-Assembly - Service Use 007294028
Emergency Power Unit Assembly - April 2016 And After
Hydraulic Pump Sub-Assembly
Hydraulic Fluid Return Filter
Valve Dual Counterbalance Rotator - Helac
Platform Jib Selector Valve Assembly
Steering Cylinder - Waltco
Primary Level Cylinder - Sn Tb66j-04-000100 And After - Rosenboom
Primary Level Cylinder - Green Mfg
Secondary Level Cylinder - Rosenboom
Lift Cylinder Assembly
Lift Cylinder - Rosenboom
Lift Cylinder - Hengli
Extension Cylinder - Gbi
Extension Cylinder - Hengli
Jib Cylinder - Hengli
Jib Cylinder - Rosenboom
Jib Cylinder - Tb86j-04-0000068 And After - Hengli
Electrical
Turntable Electrical Installation - Cummins
Turntable Electrical Installation - Duetz
Turntable Electrical Installation - Deutz
Turntable Electrical Installation - Dz/Ce
Turntable Electrical Installation - Gm Tier 3
Turntable Wiring Assembly - Cummins/Deutz/Gm
Turntable Wire Assembly - Gm Tier 3
Engine Harness - Cummins T3
Engine Harness - Deutz
Engine Harness - Gm 2.4l Tier 3
Engine Harness - Pg
Wiring Box Assembly - Kubota
Wiring Box Assembly - Ansi/Ce - Cummins/Duetz
Wiring 4 R313i R313i 15 Blk
Boom Electrical Installation
Boom Electrical Installation - Ce
Boom Electrical Installation - Kubota
Boom Switch Assembly
Alternator Wire Assembly - Duetz
E-Pump Signal Harness High Capacity
Lower Control Assembly Panel - Cummins
Lower Control Panel Assembly - Ce
Lower Control Panel Assembly - Duetz
Lower Control Panel Assembly - Kubota
Lower Control Panel Assembly - Gm Tier 3
Panel Sub-Assembly - Kubota
Panel Sub-Assembly - Gm Tier 3
Platform Foot Switch
Platform Jib Selector Wire Assembly
Upper Control Box Assembly
Upper Control Box Assembly - Ce Only
Upper Control Box Assembly Dz/Cu - Ce Only
Upper Control Box Assembly - Kubota
Joystick Controller - 33hz Lift Swing
Joystick Controller - 33hz Drive Steer
Extend Retract Controller Single Axis - 63hz
Options
Tow Kit
Isolator Valve Installation
110 Volt Ac Hydraulic Generator Installation
110 Volt Ac Hydraulic Generator Sub-Assembly
110v Power To Platform Installation
220 Vac Hydraulic Generator Installation Pg
220 Volt Ac 50hz Hydraulic Ac Generator Sub-Assembly
12kw Hydraulic Generator Assembly - Fabco
12kw Hydraulic Generator Assembly - Tendaire
12kw Generator Wiring Box Assembly
12kw Generator Boom Electric Modifcation
Airline To Platform
Air Inlet Heater - Duetz 1011f
Ac Generator Valve Sub-Assembly
Hydraulic Warm Up Installation
Extreme Cold Weather Package - Ansi/Csa - Kubota
Spark Arrestor - Duetz
Sandblast Kit
Warning Light Single Becon
Dual Warning Light
Alarm And Mounting Assembly
Motion Alarm Drive
All Motion Alarm With Out Horn
Head/Tail Lights Installation
Headlight Installation
Overload Add On
11kw Welder Generator Auminum Platform
Welder Assembly - Lincoln
Welder Steel Platform
Platform Work Lights
Platform Work Lights Global Installation
Tilt Alarm Light
Tilt Alarm Light - July 2005 And After
Platform Gate
Gravity Gate Side Entry Steel Platform
Swing Gate End Mid-Rail Aluminum Platform - September 2007 And Before
Swing Gate Side Midrail Aluminum Platform - October 2007 And After
Upper Control Box Cover Installation
Maintenance
Maintenance
Schematics
Tb85j/Tb86j - Electrical Schematic - Deutz/Cummins
Tb85jfa/Tb86jfa - Electrical Schematic - Gm
Tb85jfa/Tb86jfa - Electrical Schematic - Updated Resistors In Wires 181a And 181b - Gm Tier 3 1.6l/2.4l
Tb85jfa/Tb86jfa - Electrical Schematic - Updated Routing Of Wire 170 - Gm Tier 3
Tb85jfa/Tb86jfa - Electrical Schematic - Ce - Deutz/Cummins
Tb85jfa/Tb86jfa - Electrical Schematic - Ce - Updated Routing Of Wires 213 And 214 - Deutz
Tb85jfa/Tb86jfa - Electrical Schematic - Ce - Updated Routing Of Wire 170 - Deutz/Cummins
Tb85jfa Electrical Schematic - Kubota
Tb85jfa Electrical Schematic - Added Glow Plug Timer Assembly And Related Wiring - Kubota
Tb85jfa Electrical Schematic - Added Steer Relay - Deutz
Tb85jfa Electrical Schematic - Changed Routing Of Wire 170 - Deutz
Tb85jfa/Tb86jfa - Electrical Schematic - Ce - Added Glow Plug Timer Assembly And Related Wiring - Cummins Tier 3
Tb85jfa/Tb86jfa - Electrical Schematic - Ce - Updated Wires 213 214 And Added Steer Relay - Cummins Tier 3
Tb85jfa/Tb86jfa - Electrical Schematic - Ce - Updated Routing Of Wire 170 - Cummins Tier 3
Tb85jfa/Tb86jfa - Electrical Schematic - Added - Glow Plug Timer Assembly And Related Wiring - Cummins Tier 3
Tb85jfa/Tb86jfa - Electrical Schematic - Added Steer Relay - Cummins Tier 3
Tb85jfa/Tb86jfa - Electrical Schematic - Updated Routing Of Wire 170 - Cummins Tier 3
Tb80fa/Tb85jfa Hydraulic Schematic
Tb80fa/Tb85jfa Hydraulic Schematic - Updated Hoses On Centerpost And Added Fm Stamp
Tb80fa/Tb85jfa Hydraulic Schematic - Updated Hose Routing
Tb80fa/Tb85jfa Hydraulic Schematic - Added Warm-Up Valve
Tb80fa/Tb85jfa/Tb86j - Hydraulic Schematic Updated Hosing For Shift Lines
Appendix A:pages Index
Appendix B:parts Index
