Snorkel Aerial Work Platform TB80 TB86J Operators Manual 0113787 2024
Brand: Snorkel
Model: Snorkel TB80 TB86J Aerial Work Platform
Serial Number: TB80 Serial number 170900008 and after, TB86J Serial number 170800201 and after
Part Number: 0113787
Publication Date: 2024
Number of Pages: 106 Pages
Chapter 1 – Introduction
Aerial Platform Features
Options
Operator’s Manual
Safety Alerts
Operation
Maintenance
Used Material Disposal
Manual of Responsibilities – ANSI
MEWP Safe Use – AS/NZS
AS/NZS 141810 Commissioning
CE Compliance
Additional Information
Chapter 2 – Specifications
Component Identification
Working Envelope – TB80
Working Envelope – TB86J Single Capacity
Working Envelope – TB86J Triple Capacity
General Specifications – TB80
General Specifications – TB86J Single Capacity
General Specifications – TB86J Triple Capacity
Engine Specifications
Engine Oil Viscosity
Chapter 3 – Safety
Electrocution Hazards
Minimum Safe Approach Distance – ANSI
Minimum Safe Approach Distance – AS/NZS
Platform Capacity
Manual Force
Wind Speeds
Prestart Inspection
Work Place Inspection and Practices
Operation
Tip-Over and Falling Hazards
Engine and Fuel Handling Precautions
Placards and Decals
General Safety Rules
Chapter 4 – Safety Devices
Emergency Stop Controls
Emergency Power System
Emergency Lowering – TB80 and TB86J
Single Capacity Only
Ground Operation Switch
Platform Foot Switch
Guardrails
Fall Protection Anchors
Ground Fault Circuit Interrupter
Platform Overload Sensing System
Boom/Drive Cut-out
Tilt Alarm/Warning Lights
Engine Protection Systems
High Engine Temperature Alarm
Low Oil Pressure Alarm
Engine Warning Light
Horn
Drive Motion Alarm
All Motion Alarm
Flashing Lights
Driving Lights
Platform Work Lights
Snorkel Guard
Chapter 5 – Gauges and Displays
Diagnostic Center Displays
Diagnostic Center LCD
Dual Fuel Engine Display
Diagnostic Center/Engine Display
Platform Overload/Tilt Warning Lights
Triple Platform Capacity System – Option
Engine Air Filter Gauge
Fuel Gauge
Engine Oil
Hydraulic Fluid Filter Gauge
Fluid Level and Temperature Gauge
Chapter 6 – Controls
Battery Disconnect Switch
Lower Controls
Start Button
Emergency Stop Button
Controls Selector Switch
Rotation Switch
Boom Elevation Switch
Boom Extension Switch
Boom Speed Knob
Jib Articulation Switch – TB86J Only
Platform Level Switch
Platform Rotation Switch
Engine/Emergency Power Switch
Fuel Switch
Platform Overload Warning Light
Tilt Alarm
Hydraulic Oil Warm-Up Switch
Circuit Breaker Reset Buttons
Upper Controls
Start Switch
Boom Joystick
Drive Joystick
Drive Range Switch
Steer Mode Switch
Platform Rotate Switch
Boom Extend/Retract Joystick
Horn Switch
Override Switch
Tilt Alarm
AC Generator Switch
Dual Fuel
Driving and Platform Work Lights
Chapter 7 – Prestart Inspection
Operator’s Manual Holder
Oil Level
Coolant
Fuel Line
Air Filter
Battery Fluid Level
Battery Terminals
Cables and Wiring Harness
Fluid Level
Fluid Filter
Hoses, Tubes, and Fittings
Tires and Wheels
Lower Control Station
Operating Controls
Emergency Stop
Emergency Power
Flashing Light
Sandblast Protection Kit
Structures
Weldments
Boom Slide Pads
Wire Ropes
Fasteners
Upper Control Station
Guardrail System
Operating Controls
Emergency Stop
Emergency Power
Horn Switch
Snorkel Guard
Level Sensor
Electrical Power Outlet
Platform Control Cover
Drive Motion Alarm
Air Line to Platform
Tow Kit
Platform Glazier Package
Platform Welder
Placards and Decals
Prestart Inspection Checklist
Inspection and Maintenance Schedules
Chapter 8 – Operation
Cold Weather Start-Up
Hydraulic System Cold Weather Warm-Up
Hydraulic System Warm-Up Switch
Manually Warming The Hydraulic System
Preparing for Operation
Lower Controls
Upper Controls
Boom Operation
Driving and Steering
Drive Speeds
Drive Motion Alarm
Boom/Drive Cut-out
Snorkel Guard
Override Switch
Gradeability
Percent vs Degree of Slope
Driving on a Slope
Calculating Percent Grade
Machine Gradeability
AC Generator
Dual Fuel
Air Line
Driving Lights
Platform Capacity
Platform Welder
Platform Capacity
Chapter 9 – Stowing and Transporting
Stowing
Tucked Stow – TB86J
Transporting
Driving
Winching
Hoisting
Securing for Transport
Storage
Chapter 10 – Emergency Operation
Lower Controls
Upper Controls
Override Switch
Emergency Lowering
TB80 and TB86J Single Capacity Only
Towing
Chapter 11 – Troubleshooting
Troubleshooting Chart
Fuel Line Air Bleeding – Kubota V2403-T
Open Bleeder Valve and Crank Engine
Fill the Fuel Filter
Operate Bleeder Pump
Kubota V2403-CR-TIE4B
Appendix A – Glossary
Appendix B – Inspection Checklists
Limited Warranty
Brand: Snorkel
Options
Operator’s Manual
Safety Alerts
Operation
Maintenance
CE Compliance
Chapter 3 – Safety
Platform Capacity
Manual Force
Wind Speeds
Prestart Inspection
Operation
Placards and Decals
Guardrails
Boom/Drive Cut-out
Horn
Drive Motion Alarm
All Motion Alarm
Flashing Lights
Driving Lights
Snorkel Guard
Fuel Gauge
Engine Oil
Lower Controls
Start Button
Rotation Switch
Boom Speed Knob
Fuel Switch
Tilt Alarm
Upper Controls
Start Switch
Boom Joystick
Drive Joystick
Drive Range Switch
Steer Mode Switch
Horn Switch
Override Switch
Tilt Alarm
AC Generator Switch
Dual Fuel
Oil Level
Coolant
Fuel Line
Air Filter
Battery Fluid Level
Battery Terminals
Fluid Level
Fluid Filter
Tires and Wheels
Operating Controls
Emergency Stop
Emergency Power
Flashing Light
Structures
Weldments
Boom Slide Pads
Wire Ropes
Fasteners
Guardrail System
Operating Controls
Emergency Stop
Emergency Power
Horn Switch
Snorkel Guard
Level Sensor
Drive Motion Alarm
Tow Kit
Platform Welder
Placards and Decals
Lower Controls
Upper Controls
Boom Operation
Drive Speeds
Drive Motion Alarm
Boom/Drive Cut-out
Snorkel Guard
Override Switch
Gradeability
Driving on a Slope
AC Generator
Dual Fuel
Air Line
Driving Lights
Platform Capacity
Platform Welder
Platform Capacity
Stowing
Tucked Stow – TB86J
Transporting
Driving
Winching
Hoisting
Storage
Lower Controls
Upper Controls
Override Switch
Emergency Lowering
Towing
Limited Warranty
