Snorkel Aerial Work Platform TB80 TB85J Operators Manual 0112477
Brand: Snorkel
Model: Snorkel TB80 TB85J Aerial Work Platform
Part Number: 0112477
Publication Date: 2001
Number of Pages: 76 Pages
Chapter 1 – Introduction
Aerial Platform Features
Options
Operator’s Manual
Safety Alerts
Operation
Maintenance
Manual of Responsibilities
Additional Information
Chapter 2 – Specifications
Component Identification – TB80
Component Identification – TB85J
Working Envelope – TB80
Working Envelope – TB85J
General Specifications – TB80
General Specifications – TB85J
Engine Specifications
Engine Oil Viscosity
Chapter 3 – Safety
Electrocution Hazards
Minimum Safe Approach Distance
Prestart Inspection
Work Place Inspection and Practices
Operation
Tip-Over and Falling Hazards
Engine and Fuel Handling Precautions
Placards and Decals
Chapter 4 – Safety Devices
Emergency Stop Controls
Emergency Power System
Emergency Lowering Knob
Axle/Boom Interlock
Ground Operation Switch
Platform Foot Switch
Guardrails
Lanyard Anchors
Ground Fault Circuit Interrupter
Tilt Alarm
Engine Protection Systems
High Engine Temperature Alarm
Low Oil PressureAlarm
Horn
Drive Motion Alarm
Flashing Light
Driving Lights
Platform Work Lights
Chapter 5 – Gauges and Displays
Hour Meter
Engine Temperature Gauge
Ammeter
Engine Air Filter Gauge
Fuel
Engine Oil
Hydraulic Fluid Filter Gauge
Fluid Level and Temperature Gauge
Chapter 6 – Controls
Battery Disconnect Switch
Axle Controls
High Range Speed Selector – 4x4
Lower Controls
Start Switch
Emergency Stop Button
Controls Selector Switch
Boom/Axle Switch
Rotation Switch
Boom Elevation Switch
Boom Extension Switch
Boom Speed Knob
Jib Articulation Switch – TB85J Only
Platform Level Switch
Platform Rotate Switch
Engine/Emergency Power Switch
Engine Speed Switch
Fuel Switch
Ether Injection Switch – Cummins Only
Manifold Air Inlet Heater – Deutz Only
Hydraulic System Warm-up Switch
Circuit Breaker Reset Buttons
Upper Controls
Start Switch
Boom Joystick
Drive Joystick
Drive Range Switch
Boom Extend/Retract Joystick
Throttle Switch
Horn Button
Machine/Generator Switch
Dual Fuel
Driving and Platform Work Lights
Chapter 7 – Prestart Inspection
Operator’s Manual
Oil Level
Coolant
Fuel Line
Air Filter
Charging System
Cold Weather Start Kit—Block Heater
Emergency Power Battery
Battery Fluid Level
Battery Terminals
Cables and Wiring Harness
Fluid Level
Fluid Filter
Hoses, Tubes, and Fittings
Tires and Wheels
Axle/Boom Interlock
Lower Control Station
Operating Controls
Emergency Stop
Emergency Power
Emergency Lowering
Level Sensor
Flashing Light
Sandblast Protection Kit
Structures
Weldments
Slide Pads
Wire Ropes
Fasteners
Upper Control Station
Guardrail System
Lanyard Anchors
Operating Controls
Emergency Stop
Emergency Power
Horn
Electrical Power Outlet
Drive Motion Alarm
Driving and Work Lights
Platform Control Cover
Tow Kit
Placards and Decals
Prestart Inspection Checklist
Chapter 8 – Operation
Cold Weather Start-Up
Engine Cold Weather Start Kit
Cummins, Ford, and Continental—Block Heater
Cummins — Ether Injection
Deutz — Manifold Preheater
Hydraulic System Cold Weather Warm-Up
Manually Warming The Hydraulic System
Preparing for Operation
Lower Controls
Axle Controls
Extending The Rear Axles
Retracting The RearAxles
Upper Controls
Boom Operation
Driving and Steering
Drive Speeds
Motion WarningAlarm
Four Wheel Drive
AC Generator
Dual Fuel
Air Line
Driving Lights
Chapter 9 – Stowing and Transporting
Stowing
Tucked Stow – TB85J
Transporting
Driving
Winching
Hoisting
Securing for Transport
Chapter 10 – Emergency Operation
Lower Controls
Upper Controls
Emergency Lowering
Towing
Chapter 11 – Troubleshooting
Troubleshooting Chart
Appendix A – Glossary
Limited Warranty
Brand: Snorkel
Options
Operator’s Manual
Safety Alerts
Operation
Maintenance
Chapter 3 – Safety
Prestart Inspection
Operation
Placards and Decals
Axle/Boom Interlock
Guardrails
Lanyard Anchors
Tilt Alarm
Horn
Drive Motion Alarm
Flashing Light
Driving Lights
Hour Meter
Ammeter
Fuel
Engine Oil
Axle Controls
Lower Controls
Start Switch
Boom/Axle Switch
Rotation Switch
Boom Speed Knob
Engine Speed Switch
Fuel Switch
Upper Controls
Start Switch
Boom Joystick
Drive Joystick
Drive Range Switch
Throttle Switch
Horn Button
Dual Fuel
Operator’s Manual
Oil Level
Coolant
Fuel Line
Air Filter
Charging System
Battery Fluid Level
Battery Terminals
Fluid Level
Fluid Filter
Tires and Wheels
Axle/Boom Interlock
Operating Controls
Emergency Stop
Emergency Power
Emergency Lowering
Level Sensor
Flashing Light
Structures
Weldments
Slide Pads
Wire Ropes
Fasteners
Guardrail System
Lanyard Anchors
Operating Controls
Emergency Stop
Emergency Power
Horn
Drive Motion Alarm
Tow Kit
Placards and Decals
Lower Controls
Axle Controls
Upper Controls
Boom Operation
Drive Speeds
Motion WarningAlarm
Four Wheel Drive
AC Generator
Dual Fuel
Air Line
Driving Lights
Stowing
Tucked Stow – TB85J
Transporting
Driving
Winching
Hoisting
Lower Controls
Upper Controls
Emergency Lowering
Towing
Limited Warranty
