Snorkel Aerial Work Platform TB80 T80 Parts Manual 0113769 2016
Brand: Snorkel
Type of Manual: Parts Manual, Electrical Schematic, Hydraulic Schematic
Model: Snorkel TB80 T80 Aerial Work Platform
Serial Number: 110811047 and after
Part Number: 0113769
Publication Date: 2016
Number of Pages: 778 Pages
Repair Parts
Tires And Wheels
4wheel Steer Fixed Axle Installation
4wheel Drive Fixed Axle Installation
Fixed Axle Kit Installation - Tb80/Tb85j
Brake Unit
Gear Hub
Gear Hub - Omni
Chassis And Turntable Installation
4x4x4 Chassis Assembly
Chassis Assembly - Tb80/Tb86j - Pg
Chassis Cover Installation Fixed Axle
Counterweight Modification Installation
Turntable Assembly - Deutz
Turntable Assembly - Gm Tier 3
Turntable Assembly - Kubota
Turntable Assembly - Kubota Pg
Turntable Assembly - Kubota Tier 4 Final Pg
Turntable Assembly - Kubota Dual Fuel Pg
Turntable Assembly - Cummins
Turntable Assembly With 12kw Generator - Kubota Pg
Fuel System Assembly - Kubota V2403 Tier 4 Final
Lift Swing Counterweight - Tb80/Tb80fa
Lift Swing Counterweight Installation
Centerpost Sub-Assembly
Engine Tray Installation - Cummins 3.3 Tier 3
Engine Assembly With Radiator - Cummins 3.3 T3
Engine Installation - Deutz F4l1011
Engine Tray Assembly - April 2007 And Before - Cummins 3.3 T3
Engine Tray Assembly With Addco Actuator - Feburary 2013 And After - Cummins 3.3 Tier 3
Engine With Radiator Replacement Parts - Kubota Wg2503 - Dual Fuel
Engine Sub-Assembly - Kubota - Export Pg
Exhaust/Air Cleaner Installation - June 2010 And After - Deutz
Air Cleaner - Deutz
Radiator Assembly - Cummins 3.3
Engine Mounting - September 2000 And Before - Deutz
Engine Sub-Assembly - October 2007 And Before - Deutz
Engine Sub-Assembly - November 2008 And After - Deutz
Engine Radiator Installation - Gm Tier 3 Final
Engine Tray Assembly - Gm
Radiator Assembly - Gm
Air Cleaner Assembly - 45hp Cummins/65hp Ford Lrg/425 Gm Tier 3/2.4l/Kuboda V1505t Tier 3 V2403
Engine With Radiator Replacement Parts - Kubota V1505
Engine Sub-Assembly With Throttle Solenoid - December 2021 And Before - Kubota V2403 Tier 4 Final
Engine Sub-Assembly With Throttle Solenoid - January 2022 And After - Kubota V2403 Tier 4 Final
Engine Export With Radiator Replacement Parts - Kubota V2403-M-T-E3-Kea-2e
Engine With Radiator Replacement Parts - Kubota V2403-M-T-E3b-Kea-2f
Exhaust Air Cleaner Installation - Tb80/Tb85j - Gm Tier 3
Exhaust Air Cleaner Installation - Kubota
Air Cleaner And Exhaust - January 2020 And After - Kubota V2403 Tier 4 Final
Supertrapp Muffler Adapter
Cooling System - Kubota V2403 Tier 4 Final
Radiator Kit - Kubota Tier 4 Final
Oil Cooler Installation
Fuel Tank Installation
Hydraulic Fluid Reservoir Installation
Hydraulic Fluid Reservoir Assembly
Rear Cowling Steel Assembly
Plastic Cowling - Deutz
Front Steel Cowling Service Kit - Deutz
Front Cowling Service Kit - Cummins
Cowling Installation - Tb80/Tb85j - Page 1 Of 4
Cowling Installation - Tb80/Tb85j - Page 2 Of 4
Cowling Installation - Tb80/Tb85j - Page 3 Of 4
Cowling Installation - Tb80/Tb85j - Page 4 Of 4
Plastic Cowling - Gm/Cummins
Booms Simplified Hydraulics - November 2009 And After
Booms Assembly - April 2015 And After
Boom Assembly - Pg - Tb80/Tb85j/Tb86j
Booms Assembly - March 2009 And Before
Booms Base End
Boom Hose Carrier Smiplified Hydraulic Assembly - Tb80/Tb80fa - November 2009 And After
Hose Carrier Assembly
Extension Cylinder Assembly
Boom Hose Carrier Assembly - April 2015 And After
Steel Hose Carrier Assembly
Carrier Track Replacement Links - Brevetti
Carrier Track Replacement Links - Dynatect
Hose Carrier Support Assembly
Rotator With Out Platform Stop Installation - September 2006 And After
Platform Rotator Assembly
Platform Rotator Installation - March 2015 And After - Helac
Platform Rotator Assembly - October 2017 And After - Helac
Platform Rotator Assembly - August 2019 And After - Helac
Platform Mounting - High Mount - Tb50
Platform Rotator Assembly With Overload
Platform Rotator Assembly With Overload - Helac
Platform Installation With Rotator - Helac
Platform Assembly Steel Tri-Entry – Helac Rotator
Platform Decal And Machine With Pg Assembly
Global Platform Assembly
Steel Platform Assembly - July 2007 And After
Snorkel Guard Tri-Entry Kit
Snorkel Guard Legacy Assembly
36x96 Platform Assembly Bumpguard With Padding
Platform Assembly 36 X 96 Steel Double Handrail On Padding September 2017 And After
Decals/Placards Installation - Tb80/Tb85j/Tb86j - German/Dutch/Swedish/Spanish/French/Ce
Decal Installation - Kubota Tier 4 Final
Decal Installation - Ansi - May 2020 And Before - Kubota Tier 4 Final
Decal Installation - Ansi 92.20 - June 2020 And After - Kubota Tier 4 Final
Decals/Placards Installation - Ansi 92.20 - June 2020 And After - Kubota 4x4
Langauge Kit - Spanish
Hydraulics
Hydraulic Turntable Equipment
Turntable Hydraulic Equipment Tb80fa/Tb85jfa - December 2008 And Before - Gm Tier 3 Final
4wheel Drive Chassis Hydraulics
Front And Rear Transmission Valve Package
Front Transmission Valve Assembly
Rear Transmission Valve Sub-Assembly - Fluid Tech
Flow Divider Sub-Assembly
Accumulator Sub-Assembly 300 Psi Charged Chassis
Accumulator Sub-Assembly 300 Psi Charged Turntable
Hydraulic Fluid Return Filter
Swing Drive Perfection Or Auburn Gear
Emergency Power Unit - March 2016 And Before
Hydraulic Pump Sub-Assembly
Piston Pump - Hengli
Pressure Manifold - Fluid Tech
Proportional Control Valve Sub-Assembly - October 2014 And After
Proportional Control Valve - Apitech
Proportional Control Valve Pg Sub-Assembly - June 2017 And After
Non-Proportional Valve Assembly - Fluid Tech
Non-Proportional Control Valve - Fluid Tech
Non-Proportional Control Valve Assembly - Fluid Tech Tier 3
4wheel Steer Valve
Speed Shift Valve Assembly
Sense Line Dump Valve
Motion Control Valve Swing - March 2007 And Before
Motion Control Valve Assembly - After May 2007
Hydraulic Warm-Up Valve
Ac Generator Valve Assembly
Dual Counterbalance Valve Rotator - Helac
Primary Level Cylinder - Green Mfg
Extend Cylinder Sub-Assembly
Extension Cylinder - Gbi
Primary Level Cylinder - Sn Tb66j-04-000100 And After - Rosenboom
Secondary Level Cylinder - Rosenboom
Lift Cylinder - Rosenboom
Lift Cylinder Assembly
Lift Cylinder - Hengli
Steering Cylinder - Waltco
Steering Cylinder - Rosenboom
Steering Cylinder - Hengli
Electrical
Turntable Electrical Installation - November 2013 And After - Deutz
Turntable Electrical Installation - Gm Tier 3
Turntable Electrical Installation - Cummins
Turntable Electrical Installation - Cummins Tier 3
Turntable Wire Assembly - Cummins Tier 3/Gm Tier 3
Turntable Wire Assembly - Pg - Tb80fa/Tb86jfa - April 2019 And Before
Engine Wire Assembly - Cummins
Engine Wire Assembly - Deutz
Engine Harness - Gm 2.4l Tier 3
Engine Harness - Kubota Pg
Engine Harness - Kubota V2403
Boom Electrical Installation
Boom Switch Assembly
110v Power To Platform Installation
110 Volt Gfci Installation
Wiring Box Assembly - Kubota
Wiring Box Assembly - Ansi/Ce - Cummins/Duetz
Lower Control Assembly - Gm Tier 3
Lower Control Panel Assembly - Cummins
Lower Control Panel Assembly - December 2007 And After - Deutz
Lower Control Panel - December 2007 And After
Lower Control Box Assembly - Dual Fuel
Lower Control Panel Pg Assembly - March 2018 And After
Lower Control Panel Pg Assembly - March 2018 And After - Tier 4 Final
Lower Control Panel Assembly - Kubota
Panel Sub-Assembly - Gm Tier 3
Panel Sub-Assembly - Ansi/Ce - Cummins/Duetz
Panel Sub-Assembly - May 2017 And After - Kubota
Upper Control Box Assembly - Tb80fa
Upper Control Box Assembly - Ford
Upper Control Box Assembly - Feburary 2015 And After - Kubota
Upper Control Box Pg Assembly - November 2017 And After
Upper Control Box Assembly Df
Controller 33hz Drive Steer
Controller Lift/Swing
Extend Retract Controller Single Axis - 63hz
Upper Control Foot Switch Assembly
Options
Fuel System Lp Only - Gm Tier 3
Fuel System Gas Only - Gm Tier 3
Fuel System Dual Fuel - Gm Tier 3
Air Inlet Heater - Duetz 1011f
Spark Arrestor - Duetz
110 Volt Power To Platform Pg
Trackunit To Control Box Boom Installation
Tilt Alarm Light
Motion Alarm Drive
All Motion Alarm With Out Horn
Alarm And Mounting Assembly
Isolator Valve Installation
Extreme Cold Weather Package Tb - Kubota
110 Vac Hydraulic Ac Generator
220 Vac Hydraulic Generator Installation Pg
220 Volt Ac 50hz Hydraulic Ac Generator Sub-Assembly
2.4kw Hydraulic Generator Service Kit
11kw Generator Wiring Box Assembly
11kw Welder Generator Auminum Platform
12kw Generator Installation
12kw Generator Assembly - Tendaire
12kw Generator Circuit Breaker Wiring
12kw Generator Valve Assembly
12kw Generator Junction Box Assembly
12kw Hydraulic Generator Assembly - Fabco
12kw Generator Circuit Breaker Wiring Assembly
12kw Generator Boom Electric Modifcation
Welder Steel Platform
Welder Assembly - Lincoln
Airline To Platform
Sandblast Kit Installation
Hydraulic Warm Up Installation
Upper Control Box Cover
Gravity Gate Side Entry Steel Platform
Platform Assembly With Mesh Enclosure - April 2018 And After
Platform Gate
Global Standard Platform Assembly
Platform Assembly With Mesh Enclosure- April 2016 And After
Swing Gate End Mid-Rail Aluminum Platform - September 2007 And Before
Swing Gate Side Midrail Aluminum Platform - October 2007 And After
Pipe Rack Installation
Pipe Rack Boom Assembly
Wire Harness Platform Work Lights
Harness Driving/Taillights
Tilt Alarm Light
Red Or Amber Beacon Installation
Dual Warning Light
Led Light Package
Led Work Lights - Pg
Led Drive And Taillights Pg
Light Package Installation
Head/Tail Lights Installation
Headlight Installation
Maintenance
Maintenance
Schematics
Electrical Schematic - Gm Tier3
Electrical Schematic - Change To Resistors In Wires 181a And 181b At Malfunction Switch - Gm Tier3
Electrical Schematic - Changed Routing Of 170 Wire - Gm Tier3
Electrical Schematic - Correct Wiring To Accomodate New Platform Rotate And Jib Function Valve - Cummins/Deutz
Electrical Schematic - Changed Route Of 170 Wire - Cummins/Deutz
Electrical Schematic - Added Glow Plug Timer Assembly Amd Related Wiring - Cummins Tier3
Electrical Schematic - Changed Routing Of 170 Wire - Cummins Tier3
Tb80fa/Tb85jfa Hydraulic Schematic
Tb80fa/Tb85jfa Hydraulic Schematic - Updated Hoses On Centerpost And Added Fm Stamp
Tb80fa/Tb85jfa Hydraulic Schematic - Updated Hose Routing
Tb80fa/Tb85jfa Hydraulic Schematic - Added Warm-Up Valve
Tb80fa/Tb85jfa/Tb86j - Hydraulic Schematic Updated Hosing For Shift Lines
Appendix A
ages Index
Appendix B
arts Index
Brand: Snorkel
Repair Parts
Tires And Wheels
Brake Unit
Gear Hub
Gear Hub - Omni
Air Cleaner - Deutz
Booms Base End
Hydraulics
4wheel Steer Valve
Electrical
Options
Tilt Alarm Light
Motion Alarm Drive
Airline To Platform
Platform Gate
Tilt Alarm Light
Dual Warning Light
Led Light Package
Maintenance
Maintenance
Schematics
Appendix A
Appendix B
