Momed80
150
35,046
Snorkel Aerial Work Platform TB65J T65RT Parts Manual 0084803-2 2015
Brand: Snorkel
Type of Manual: Parts Manual, Electrical Schematic, Hydraulic Schematic
Model: Snorkel TB65J T65RT Aerial Work Platform
Part Number: 0084803-2
Publication Date: 2015
Number of Pages: 787 Pages
Repair Parts
4x4 Front Wheel Drive
4x2/4x4 Drive Installation - October 2006 And Before
4x2/4x4 Drive Installation - November 2006 And After
4x2 Steering Installation - Tb60/Tb65j/Tb66j
4x4 Chassis Cover Installation
Chassis Turntable Mounting
Counterweight Sub-Assembly
Turntable Assembly - Kubota
Lift Swing Counterweight
Engine Tray Assembly - Cummins 3.3 Tier 3
Engine And Radiator Assembly - July 2008 And Before - Cummins
Engine And Radiator Assembly - August 2008 And After - Cummins 3.3 Tier 3
Radiator Assembly - Cummins 3.3
Air Cleaner Assembly - Cummins/Ford/Kubota/Gm
Engine Mounting - Deutz F4l1011f Tier 3
Engine Assembly - Before March 2007 And Before - Deutz F4l-1011f
Engine Assembly - April 2007 And After - Deutz F4l1011f
Engine Sub-Assembly - February 2009 And After - Deutz F4l1011f
Engine Installation - Gm Tier 3
Radiator Assembly - Gm
Engine Sub-Assembly - Gm Tier 3
Engine Mounting With Ecm - Ford Lrg 425
Engine Sub-Assembly - Ford Lrg 425
Engine Mounting With Epm - Ford Lrg 425
Engine With Radiator Replacement Parts - Kubota V2403-M-T-E3b-Kea-2f
Engine Sub-Assembly - December 2021 And Before - Kubota V2403
Engine Sub-Assembly - January 2022 And After - Kubota V2403
Exhaust/Air Cleaner Installation - May 2014 And Before - Deutz
Exhaust/Air Cleaner Installation - November 2004 And Before - Ford
Exhaust/Air Cleaner Installation - December 2004 And After - Ford With Catalytic Converter
Exhaust/Air Cleaner Installation - Kubota
Air Cleaner Installation - Gm
Air Cleaner Installation - Gm Tier 3
Air Cleaner - Deutz
Supertrapp Muffler Adapter
Drive Lift Swing Valve Assembly
Hydraulic Fluid Reservoir Assembly
Hydraulic Fluid Reservior Assembly
Fuel Tank Installation
Plastic Cowling Installation - Tb60/Tb66j - Cummins/Ford/Gm
Plastic Cowling Installation - Before October 2006 - Deutz
Plastic Cowling Installation - October 2006 Through September 2014 - Deutz
Plastic Cowling Installation - October 2014 And After - Deutz
Steel Cowling - May 2011 And After - Ford/Cummins/Gm/Kubota
Steel Cowling Installation - April 2015 And After - Ford/Cummins/Gm/Kubota
Rear Cowling Steel Assembly
Steel Cowling Service Kit - Gm/For/Cummins/Kubota
Steel Cowling Service Kit - Deutz
Boom Installation
Boom Hose Carrier Assembly
Boom Assembly
Extension Cylinder Assembly
5' Jib Assembly
Platform Rotator Assembly - January 2018 And Before - Helac
Platform Rotator Assembly With Overload - Helac
Platform Installation With Rotator - Helac
Platform Aluminum Gravity Gate Parker Rotator Installation - Ce
8' Aluminum Platform Assembly With Swing Gate
8' Steel Platform Tri-Entry Assembly
Snorkel Guard Legacy Assembly
Decals/Placard - December 2006 And Before
Decals/Placard - January 2007 And After
Decals/Placard - May 2008 And After
Hydraulics
4x4 Chassis Hydraulic Equipment - November 2006 And After
4x2 Chassis Hydraulic Equipment - January 2001 And Before
4x4 Drive Motor Front W/O Brake
Drive Motor With Integral Brake Rear
Gear Hub High-Torque Auburn Gear - Tb60-04-000114 And Before
Flow Divider Valve Sub-Assembly
Drive Valve Sub-Assembly
4x2 Drive Valve Sub-Assembly
Left Hand Drive Sequence Valve
Right Hand Drive Sequence Valve
4x4 Left Hand Series Package Valve
4x4 Right Hand Series Package Valve
Range Valve Sub-Assembly
Flow Divider Valve Assembly
Drive Lift Swing Control Valve
Motion Control Valve Drive Assembly
4x2 Selector Valve Assembly
4x4 Selector Valve Assembly
Selector Valve Left Hand Assembly
Selector Valve Right Hand Assembly
Anti Cavitation Valve Assembly
Turntable Hydraulic Equipment - January 2001 And After
Turntable Hydraulic Equipment - April 2007 And After
Emergency Power Unit - March 2016 And Before
Emergency Power Unit Assembly - April 2016 And After
Non-Proportional Control Valve Assembly - January 2001 And After - Vickers
Non-Proportional Control Valve - January 2001 And After - Vickers
Non-Proportional Control Valve Assembly - October 2007 And After - Fluid Tech
Non-Proportional Control Valve - October 2007 And After - Fluid Tech
Accumulator Assembly - 300 Psi
Check Valve
Hydraulic Pump Assembly - May 2018 And Before
Hydraulic Pump Assembly - June 2018 And After
Piston Pump - Hengli
Dump Valve
Swing Drive - April 2006 And After
Swing Drive Assembly -
Motion Control Valve Turntable Swing - Fluid Tech
Motion Control Valve Turntable Swing - Williams
Centerpost Weldment
Centerpost And Fittings Sub-Assembly - October 2017 And Before
Jib Platform Selector Valve Assembly
Primary Level Cylinder Assembly - January 2001 And After - Rosenboom
Primary Level Cylinder - Rosenboom
Secondary Level Cylinder - Rosenboom/Green
Level Or Steering Cylinder - Rosenboom
Lift Cylinder Assembly
Lift Cylinder - Gbi
Lift Cylinder - Rosenboom
Extension Cylinder Gbi
Extension Cylinder - Rosenboom
Extension Cylinder - Seabee
Jib Cylinder Assembly
Dual Crossover Relief Valve
Platform Rotator - Helac
Rotator Assembly - Hengli
Electrical
Turntable Electrical Installation - Tb60/Tb66j - May 2008 And Before - Cummins Tier 3
Turntable Electrical Installation - June 2008 And After - Cummins 3.3
Turntable Electrical Installation - November 2006 And After - Deutz F4l-1011f
Turntable Electrical Installation - February 2008 And After - Deutz F4l-1011f
Turntable Electrical Installation - January 2001 And After - Ford
Turntable Electrical Installation - January 2006 And After - Ford Lrg-425
Turntable Electrical Installation - Kubota
Diode Resistor Wire Assembly
Engine Harness Assembly - January 2001 And After - Cummins
Engine Harness - January 2001 And After - Deutz
Engine Harness - April 2004 And After - Ford Efi 425
Engine Harness - Gm 2.4l Tier 3
Engine Harness - Kubota V2403
Wiring Box Assembly - January 2009 And Before - Cummins/Deutz/Ford/Addco 3 Speed
Wiring Box Assembly - February 2009 And After - Cummins/Deutz/Ford/Addco 3 Speed
Wiring Box Assembly - October 2008 And After - Tb60/B66j - Cummins/Deutz/Ford
Wiring Box Assembly - September 2006 And After - Ford Lrg-425
Wiring Box Panel - September 2003 And After - Ford Lrg-425
Wiring Box Assembly - July 2007 And Before - Gm Tier 3
Wiring Box Panel - Gm Tier 3
Wiring Box Assembly - June 2014 And After - Kubota
Wiring Box Panel - June 2015 And After - Kubota
Wiring Box Panel - January 2001 And After - Cummins/Deutz 3 Speed
Wiring Box Panel - August 2008 And After - Cummins/Deutz
Lower Control Panel Assembly - Cummins 3.3
Lower Control Panel Sub-Assembly - Cummins 3.3
Lower Control Panel - April 2006 And Before - Deutz F4l-1011f
Lower Control Panel - May 2006 And After - Deutz F4l-1011f
Lower Control Panel - April 2006 And Before - Ford Lrg-425
Lower Control Panel - Gm Tier 3
Lower Control Panel - Kubota
Lower Control Panel Assembly - Sn Tb66j-04-000100 And After - Kubota
Lower Control Panel Assembly - Ce - Kubota
Panel Sub-Assembly - March 2008 And Before
Panel Sub-Assembly - October January 2001 And After - Cummins/Deutz 3 Speed
Boom Switch Assembly
Boom Electrical Installation - Tb60/Tb66j - August 2008 And Before
Boom Electric Installation - September 2008 And After
Boom Electrical Installation - Ce - May 2008 And After
110v Power To Platform Installation
110/220 Power To Platform Installation
Upper Control Foot Switch Assembly
Upper Control Box Assembly Vickers Valve - March 2008 And Before - Duetz/Cummins
Upper Control Box Assembly Vickers Valve - April 2008 And After - Duetz/Cummins
Upper Control Box Assembly Hydraforce Valve - May 2008 And After - Cummins/Duetz/Kubota
Upper Control Box Assembly Vickers Valve - October 2008 And After - Duetz/Cummins
Upper Control Box Assembly - October 2007 And After - Gm
Upper Control Box Assembly - Sn Tb66j-04-000100 And After - Kubota
Upper Control Box Assembly - Ce - Kubota
Joystick Controller - 33hz Lift Swing
Controller 33hz Drive Steer
Options
4x4 Flotation Tires - Tb60/Tb66j
Floation Tire Assembly
4x4 Non-Marking Foam Filled Tires
4x4 Foam Filled Tires - Tb60/Tb66j
Tow Package
Alarm And Mounting Assembly
Motion Alarm Drive
All Motion Alarm With Out Horn
Lower Control Door Assembly
Hydraulic Warm-Up Valve
Hydraulic Warm Up With Symplified Hydraulics
Air Inlet Heater - Deutz
Csa Package
Cold Weather Package - Deutz
Cold Weather Package - Cummins
Cold Weather Package - Tb60/Tb66j - Gm
Extreme Cold Weather Package - Deutz
Extreme Cold Weather Package - Gm
Extreme Cold Weather Package - Kubota
Extreme Enviroment Package - Duetz
Extreme Enviroment Package - Cummins
Isolation Valve Installation
Oil Biodegradeable
Airline To Platform
Sub-Assembly - Ford Lrg 425 Dual Fuel
110 Volt Hydraulic Ac Generator Installation
110 Volt Ac Hydraulic Generator Sub-Assembly
220 Volt Ac Generator Installation - Tb60/Tb66j
220 Volt Hydraulic Ac Generator Assembly
2.4kw Hydraulic Generator Service Kit
11kw Welder Generator Auminum Platform
12kw Generator Installation
12kw Generator Wiring Box Assembly
12kw Generator Circuit Breaker Wiring
12kw Generator Valve Assembly
12kw Generator Assembly - Tendaire
12kw Generator Boom Electrical Installation
12kw Boom Hose Carrier Assembly
12kw Generator Hose Carrier Assembly
12kw Generator Platform Control Box
12kw Generator Hose Cable Clamp Installation
Dual Fuel - April 2006 And After - Gm Tier 2
Dual Fuel - September 2007 And After - Gm Tier 3
Dual Fuel – Ford Lrg-425
Lp Only - September 2007 And After - Gm Tier 3
Lp Fuel Only - Ford Lrg 425
Engine Sub-Assembly - Ford Lrg 425 Dual Fuel
Spark Arrestor Muffler - Deutz
Scrubber - Deutz Diesel
Sandblast Kit
Horn Installation
Upper Control Box Cover - Tb/Atb
Global Standard Platform Assembly
Swing Gate Side Midrail Aluminum Platform - October 2007 And After
Gravity Gate Side Entry Steel Platform
Platform Bumpguard - September 2003 And Before
Platform Bumpguard - October 2003 And After
Lanyard Mount Used On 1430080 Platform Only
Personal Fall Arrest System
Glazier Package Platform With 1.7" Toe Board Installation
Glazier Tray Assembly
Glazier Package World Platform With 2" Toe Board Installation
Glazier Tray Assembly 3 Entry Platform
Welder Steel Platform
Welder Assembly - Lincoln
Welder Assembly
Driving And Taillights - June 2010 And Before
Driving And Taillights - July 2010 And After
Warning Lights Amber
Light Package
Platform Work Lights
Platform Work Lights 4 Halogen
Platform Work Lights Global Installation
Tilt Alarm Light - July 2005 And After
Upper Control Box - Courtesy Light
Maintenance
Maintenance
Schematics
Electricalschematic - Cummins Tier 3
Electrical Schematic - Updated To Replace Addco With Solenoid - Cummins Tier 3
Electrical Schematic - Ce - Added Load Sense
Electrical Schematic - Ce - Updated Load Lense Ground Lamp Connection Add Boom Angle Switch Add Override Jumper Update Load Sensor Drive Bypass Enable Relay Power
Electrical Schematic - Ce - Deutz
Electrical Schematic Added Glow Plug Timer Assembly - Ce - Cummins
Hydraulic Schematic - Pro66/Tb65j/Tb66j
Hydraulic Schematic - Pro65/Tb65j/Pro66/Tb66j
Hydraulic Schematic 4wheel Drive - Tb60/Tb60p/Pro65/Tb65j/Pro66/Tb66j
Hydraulic Schematic - 2wheel Drive - Tb60/Pro65/Tb65j/Pro66/Tb66j
Hydraulic Schematics - Tb66j
Appendix A:pages Index
Appendix B:parts Index
