Momed80
150
35,046
Snorkel Aerial Work Platform TB65J Operators Manual 0084248 2011
Brand: Snorkel
Model: Snorkel TB65J Aerial Work Platform
Serial Number: 000000 and after
Part Number: 0084248
Publication Date: 2011
Number of Pages: 74 Pages
Chapter 1 – Introduction
Aerial Platform Features
Options
Operator’s Manual
Safety Alerts
Operation
Maintenance
Manual of Responsibilities
Additional Information
Chapter 2 – Specifications
Component Identification
General Specifications
Engine Specifications
Engine Oil Viscosity
Chapter 3 – Safety
Electrocution Hazards
Minimum Safe Approach Distance
Prestart Inspection
Work Place Inspection and Practices
Operation
Tip-Over and Falling Hazards
Engine and Fuel Handling Precautions
Placards and Decals
Chapter 4 – Safety Devices
Emergency Stop Controls
Emergency Power System
Emergency Lowering Knob
Ground Operation Switch
Platform Foot Switch
Guardrails
Lanyard Anchors
Ground Fault Circuit Interrupter
Tilt Alarm
Engine Protection Systems
High Engine Temperature Alarm
Low Oil Pressure Alarm
All Motion Alarm
Horn
Drive Motion Alarm
Flashing Light
Driving Lights
Platform Work Lights
Chapter 5 – Gauges and Displays
Hour Meter
Engine Temperature Gauge
Ammeter
Voltmeter – GM Engines
Engine Air Filter Gauge
Fuel Gauge
Engine Oil
Hydraulic Fluid Filter Gauge
Fluid Level and Temperature Gauge
Chapter 6 – Controls
Battery Disconnect Switch
Lower Controls
Start Switch
Emergency Stop Button
Controls Selector Switch
Rotation Switch
Boom Elevation Switch
Boom Extension Switch
Boom Speed Knob
Jib Articulation Switch
Platform Level Switch
Platform Rotation Switch
Engine/Emergency Power Switch
Engine Speed Switch
Manifold Air Inlet Heater – Deutz Only
Fuel Switch
Hydraulic Oil Warm-Up Switch
Circuit Breaker Reset Buttons
Upper Controls
Start Switch
Boom Joystick
Drive Joystick
Drive Range Switch
Boom Speed Knob
Throttle Switch
Horn Button
Machine/Generator Switch
Driving and Platform Work Lights
Chapter 7 – Prestart Inspection
Operator’s Manual Holder
Oil Level
Coolant
Fuel Line
Air Filter
Charging System
Cold Weather Start Kit
Battery Fluid Level
Battery Terminals
Cables and Wiring Harness
Fluid Level
Fluid Filter
Hoses, Tubes, and Fittings
Tires and Wheels
Lower Control Station
Operating Controls
Emergency Stop
Emergency Power
Emergency Lowering
Level Sensor
Structures
Weldments
Boom Slide Pads
Extension Cylinder Slide Pads
Wire Ropes
Fasteners
Upper Control Station
Guardrail System
Lanyard Anchors
Operating Controls
Emergency Stop
Emergency Power
All Motion Alarm
Horn Button
Electrical Power Outlet
Platform Control Cover
Drive Motion Alarm
Flashing Light
Sandblast Protection Kit
Driving and Work Lights
Platform Glazier Package
Placards and Decals
Prestart Inspection Checklist
Chapter 8 – Operation
Cold Weather Start-Up
Engine Cold Weather Start Kit
Cummins — Block Heater
Deutz — Manifold Preheater
GM — Radiator Hose In-Line
Hydraulic System Cold Weather Warm-Up
Hydraulic System Warm-Up Switch
Manually Warming The Hydraulic System
Preparing for Operation
Lower Controls
Upper Controls
Boom Operation
Driving and Steering
Drive Speeds
Gradeability
Theoretical Gradeability
Actual Gradeability
Percent vs Degree of Slope
Driving on a Slope
Calculating Percent Grade
Machine Gradeability
AC Generator
Dual Fuel
LP Fuel Tank
Air Line
Driving Lights
Glazier Package
Platform Capacity
Platform Welder
Platform Capacity
Chapter 9 – Stowing and Transporting
Stowing
Tucked Stow
Transporting
Driving
Winching
Hoisting
Securing for Transport
Chapter 10 – Emergency Operation
Lower Controls
Upper Controls
Emergency Lowering
Towing
Chapter 11 – Troubleshooting
Troubleshooting Chart
Appendix A – Glossary
Limited Warranty
