Snorkel Aerial Work Platform TB60 TB60RT Parts Manual 0083735 2022
Brand: Snorkel
Type of Manual: Parts Manual, Electrical Schematic, Hydraulic Schematic
Model: Snorkel TB60 TB60RT Aerial Work Platform
Part Number: 0083735
Publication Date: 2022
Number of Pages: 868 Pages
Repair Parts
4x4 Front Wheel Drive
4x2 Steering Installation - Tb60/Tb65j/Tb66j
Drive Installation - January 2001 And After
Gear Hub High-Torque Auburn Gear - Tb60-04-000114 And Before
Gear Hub High-Torque Omni Gear - Tb60-04-000114 And After
4x4 Chassis Cover Installation
Chassis Turntable Mounting
Lift Swing Counterweight Installation - November 2014 And After
Swing Drive - April 2006 And After
Swing Drive Assembly -
Engine Tray Assembly - September 2008 And After - Cummins 3.3 Tier 3
Engine Tray Assembly - Cummins 3.3 T3
Engine Installation - Cummins
Engine Assembly With Radiator - August 2008 And Before - Cummins Tier 3
Engine And Radiator Assembly - July 2007 And After - Cummins 3.3 Tier 3
Radiator Assembly - Cummins 3.3
Engine Installation - Gm Tier 3
Radiator Assembly - Gm
Engine Mounting - March 2004 And Before - Ford Lrg 425 With Ecm
Engine Sub-Assembly - Ford Lrg 425
Engine Mounting - April 2004 And After - Ford Lrg 425 With Catalytic Convertor And Epm
Engine Installation - January 2008 And After - Deutz Tier 3 F4l1011
Engine Sub-Assembly - February 2009 And After - Deutz F4l1011f
Engine Sub-Assembly - Gm Tier 3
Engine With Radiator Replacement Parts - Kubota V2403-M-T-E3b-Kea-2f
Engine With Radiator Replacement Parts - Kubota Wg2503 - Dual Fuel
Engine Sub-Assembly - December 2021 And Before - Kubota V2403
Engine Sub-Assembly - January 2022 And After - Kubota V2403
Exhaust/Air Cleaner Installation - Deutz
Air Cleaner - Deutz Only
Exhaust/Air Cleaner Installation - November 2004 And Before - Ford
Exhaust/Air Cleaner Installation - December 2004 And After - Ford With Catalytic Converter
Exhaust/Air Cleaner Installation - Kubota
Air Cleaner Installation - Gm
Air Cleaner - Cummins/Ford/Gm
Air Cleaner Assembly
Supertrapp Muffler Adapter
Radiator Kit - Kubota Tier 4 Final
Fuel Tank Installation
Hydraulic Fluid Reservior Assembly
Hydraulic Fluid Reservoir Assembly
Plastic Cowling Installation - Tb60/Tb66j - Cummins/Ford/Gm
Plastic Cowling Installation - September 2006 And Before - Deutz
Plastic Cowling Installation - November 2006 And After - Deutz
Steel Cowling Installation - June 2011 And Before - Cummings/Ford
Steel Cowling Installation - May 2015 And After - Cummins/Ford/Gm/Kubota
Steel Cowling - After April 2015 - Ford/Cummins/Gm/Kubota
Steel Cowling Service Kit - Gm/For/Cummins/Kubota
Steel Cowling Service Kit - Deutz
Rear Cowling Steel Assembly
Extension Cylinder Assembly - February 2000 And Before
Counterweight Modification Installation
Boom Installation
Boom/Hose Carrier Assembly - March 2015 And Before
Boom Assembly - April 2015 And Before
Boom Assembly - May 2015 And After
Boom Hose Carrier Assembly - May 2015 And After
Hose Carrier Assembly Steel Track - April 2015 And After
Hose Carrier Tube Guide Assembly - Rebuild
Extension Cylinder Assembly - March 2000 And After
Platform Rotator Assembly - March 2006 And Before
Platform Rotator Sub-Assembly - January 2018 And Before - Helac
Platform Rotator Parker Assembly
Platform Rotator Assembly - August 2019 And After - Helac
Platform Rotator Assembly - January 2015 And After - Helac
Platform Mount - Helac
Platform Gate
8' Aluminum Platform Installation With Swing Gate
8' Aluminum Platform Assembly With Gravity Gate
8' Alumimum Platform Assembly - 600lb Capacity
8' Aluminum Platform With Swing Gate
Aluminum Platform Assembly With Swing Gate And Parker Rotator
Steel Platform Assembly Tri-Entry With Rotator - Helac
5' Steel Platform 500lbs Dual Handrails With Swing Gate - Tb60/Atb60
3' X 8' Platform Steel - 500lb
Global Platform Assembly
Platform Installation With Rotator - Helac
Platform Installation With Parker Rotator
Platform Rotator Assembly - March 2006 And After
Platform Installation Steel With Gravity Gate And Parker Rotator
Platform Installation Aluminum Gravity Gate - Ce - Parker Rotator
8' Steel Platform Sub-Assembly With Swing Gate
Rebuild Push Tube Stl Carrier Track
Snorkel Guard Legacy Kit And Wiring
Snorkel Guard Legacy Assembly
Decals/Placards - Tb60 - Kubota 4x4
Decals/Placards Installation - Tb60/Tb66j - May 2015 - Cummins/Gm/Kubota
Decals/Placards Installation - Tb60/Tb66j - November 2006 And Before
Decals/Placards Installation - Tb60/Tb66j - October 2006 And After
Decals/Placards Installation - Tb60/Tb66j - October 2007 And After
Decals/Placards Installation - Tb60/Tb66j - December 2007 And After
Decals/Placards Installation - Tb60/Tb66j - Feburary 2008 And After
Decals/Placards Installation Tb60/Tb66j - May 2015 And After
Hydraulics
4x2 Chassis Hydraulic Equipment - January 2001 And Before
4x4 Chassis Hydraulic Equipment - February 2001 And After
4x4 Chassis Hydraulic Equipment - November 2006 And After
Drive Motor
Drive Motor With Integral Brake Rear
4x4 Drive Valve Sub-Assembly
4x2 Drive Valve Sub-Assembly
Left Hand Drive Sequence Valve
Right Hand Drive Sequence Valve
Anti Cavitation Valve Sub-Assembly - March 2005 And Before
Anti-Cavitation Valve Sub-Assembly - July 2005 And After
Flow Divider Valve
Flow Divider Valve Sub-Assembly
4x2 Selector Valve
4x4 Selector Valve
Right Hand Selector Valve
Left Hand Selector Valve
4x4 Right Hand Series Parallel Package Valve
4x4 Left Hand Series Package Valve
Turntable Hydraulic Equipment Vickers - April 2007 And Before
Turntable Hydraulic Equipment - January 2008 And After - Fluid Tech
Emergency Power Unit - March 2016 And Before
Emergency Power Unit Assembly - April 2016 And After
Non-Proportional Control Valve - January 2001 And After - Vickers
Non-Proportional Control Valve - February 2008 And After - Fluid Tech
Hydraulic Pump And Fittings - Deutz/Cummins
Hydraulic Pump Assembly - June 2018 And After
Piston Pump - Hengli
Centerpost And Fittings Sub-Assembly - October 2017 And Before
Swing Drive Perfection
Swing Drive Tulsa Winch
Swing Drive Auburn Gear
Accumulator Assembly - 300 Psi
Motion Control Valve Drive Assembly
Motion Control Valve Drive Sub-Assembly
Motion Control Valve Turntable Swing - Williams
Motion Control Valve - Fluid Tech
Drive Lift Swing Valve Assembly
Drive Lift Swing Control Valve
Check Valve
Dual Crossover Relief Valve
Dump Valve
Range Valve Sub-Assembly
Hydraulic Fluid Reservoir - August 1999 And Before
Hydraulic Fluid Reservoir - July 2006 And After
Primary Level Cylinder - Rosenboom
Secondary Level Cylinder Assembly
Secondary Level Cylinder - Rosenboom
Steering And Leveling Cylinder - Rosenboom
Lift Cylinder Assembly
Lift Cylinder - Gbi
Lift Cylinder - Rosenboom
Extension Cylinder - Gbi
Extension Cylinder - Seabee
Extension Cylinder - Rosenboom
Platform Rotator - Parker
Platform Rotator Assembly - October 2014 And After - Helac
Platform Rotation Valve
Electrical
Turntable Electrical Installation - Tb60/Tb66j - May 2008 And Before - Cummins Tier 3
Turntable Electrical Installation - June 2008 And After - Cummins 3.3
Turntable Electrical - March 2008 And Before - Cummins 3.3
Turntable Electrical Installation - April 2008 And After - Cummins
Turntable Electrical Installation - August 2008 And Before Tb60 - Deutz
Turntable Electrical Installation - September 2008 And After Tb60 - Deutz
Turntable Electrical Installation - Feburary 2009 And After Tb60 - Deutz
Turntable Electrical Installation - January 2001 And After - Ford
Turntable Electrical - Ford Lrg 425
Turntable Electrical Assembly - Kubota
Diode Resistor Wire Assembly
Engine Harness Assembly - January 2001 And After - Cummins
Engine Harness - January 2001 And After - Deutz
Engine Harness - April 2004 And After - Ford Efi 425
Engine Harness - Gm 2.4l Tier 3
Engine Harness - Kubota V2403
Wiring Box Assembly - October 2008 And After - Tb60/B66j - Cummins/Deutz/Ford
Wiring Box Assembly - January 2001 And After - Cummins/Duetz/Addco 3 Speed
Wiring Box Assembly - January 2009 And Before - Cummins/Deutz/Ford/Addco 3 Speed
Wiring Box Assembly - August 2006 And Before - Ford Lrg-425
Wiring Box Assembly - July 2007 And Before - Gm Tier 3
Wiring Box Assembly - June 2014 And After - Kubota
Wiring Box Assembly - Ce - April 2015 And After - Kubota
Wiring Box Panel - January 2001 And After - Cummins/Deutz 3 Speed
Lower Control Panel Assembly - Feburary 2008 And After - Tb60 - Deutz
Lower Control Panel Assembly - January 2001 And After - Tb60 - Cummins/Duetz
Lower Control Panel Assembly - Cummins/Deutz
Lower Control Panel Assembly - Ford
Lower Control Panel Assembly - Gm Tier 3
Lower Control Panel Assembly - Kubota
Panel Sub-Assembly - October January 2001 And After - Cummins/Deutz 3 Speed
Panel Sub-Assembly - September 2003 And After - Ford Lrg-425
Panel Sub-Assembly - August 2008 And Before - Cummins/Deutz/Addco 3 Speed
Panel Sub-Assembly - October 2007 And Before - Gm Tier 3
Panel Sub-Assembly - June 2015 And After - Kubota
Ground Box Assembly - Kubota
Boom Switch Assembly
Boom Electrical Installation - Tb60/Tb66 - October 2007 And After - Fluid Tech
Boom Electrical Installation - January 2009 And Before
Boom Electrical Installation - February 2009 And After
110 Volt Gfci Installation
110/220 Power To Platform Installation
Upper Control Box Sub-Assembly - January 2001 And After
Upper Control Box Sub-Assembly - May 2007 And After
Upper Control Box - November 2007 And After - Cummins/Deutz/Kubota
Upper Control Box - February 2009 And After - Cummins/Duetz/Kubota
Upper Control Box - February 2009 And After - Cummins/Deutz/Kubota
Upper Control Foot Switch Assembly
Joystick Controller - 33hz Drive Steer
Controller Lift/Swing
Foot Switch Wide Tredle Assembly
Options
4x4 Foam Filled Tires - Tb60/Tb66j
4x4 Non-Marking Foam Filled Tires
Floation Tire Assembly
4x4 Flotation Tires - Tb60/Tb66j
Tow Package
Oil Cooler 12kw Installation - Tb60/Tb65j/Tb66j - Deutz
Engine Sub-Assembly - Ford Lrg 425 Dual Fuel
Lp Fuel Only - Ford Lrg-425
Dual Fuel - Ford Lrg-425
Dual Fuel - April 2006 And After - Gm Tier 2
Dual Fuel - August 2007 And After - Gm Tier 3
Gasoline Only - August 2007 And After - Gm Tier 3
Lp Only - September 2007 And After - Gm Tier 3
Spark Arrestor Muffler - Deutz
Scrubber - Deutz Diesel
Hydraulic Warm Up With Symplified Hydraulics
Hydraulic Warm Up Valve
Warm Up With Simplified Hydraulics
Cold Weather Start - Gm
Cold Weather Hydraulic Fluid
Cold Weather Package - Cummins
Cold Weather Package - Deutz
Cold Weather Package - Tb60/66j - Gm
Extreme Cold Weather Package - Deutz
Extreme Cold Weather Package - Gm
Extreme Cold Weather Package - Kubota
Extreme Cold Weather Package - Cummins
Extreme Enviroment Package - Deutz
Extreme Enviroment Package - Cummins
Upper Control Box Cover
Sandblast Kit
Sandblast Installation Only - Deutz
Boom Brush Kit
110 Volt Ac Generator Installation - March 2007 And Before
110 Volt Ac Generator Installation - April 2007 And After
220 Volt Ac Generator Installation - Tb60/Tb66j
220v Ac 50hz Hydraulic Ac Generator Sub-Assembly
220 Volt Hydraulic Ac Generator Assembly
2.4kw Hydraulic Generator Service Kit
12kw Generator Installation
12kw Generator Assembly - Tendaire
12kw Generator Valve Assembly
12kw Generator Circuit Breaker Wiring
12kw Generator Wiring Box Assembly
12kw Generator Hose Carrier Assembly
12kw Generator Boom Electrical Installation
12kw Generator Platform Control Box
12kw Generator Assembly - Fabco
Hydraulic Ac Generator Valve Sub-Assembly
Hydraulic Ac Generator With Motion Alarm Modification
Isolation Valve Installation
Platform Assembly 36 X 96 Steel Double Handrail On Padding September 2017 And After
Swing Gate Side Midrail Aluminum Platform - October 2007 And After
Gravity Gate Side Entry Steel Platform
Upper Control Box - Courtesy Light
Tilt Alarm Light - July 2005 And After
Platform Control Cover Vinyl
Proportional Extend/Retract
Motion Alarm Drive
Air Reel Installation
Platform Bumpguard
Lanyard Mount
Personal Fall Arrest Anchorage Installation
Glazier Package Platform With 1.7" Toe Board Installation
Glazier Tray Assembly
Glazier Package World Platform With 2" Toe Board Installation
Glazier Tray Assembly 3 Entry Platform
11kw Welder Generator Auminum Platform
Welder Steel Platform
Welder Assembly
Welder Assembly - Lincoln
Csa Package
All Motion Alarm With Out Horn
Alarm And Mounting Assembly
Horn Installation
Amber Beacon Single
Light Package
Driving And Taillights - May 2015 And Before
Driving And Taillights - June 2015 And After
Platform Work Lights
Platform Work Lights Global Installation
Platform Work Lights 4 Halogen
Maintenance
Maintenance
Schematics
Electrical Schematic Cummins - Tb60
Electrical Schematic Cummins Tier 3 Added Glow Plug Timer Assembly With Related Wiring - Tb60
Electrical Schematic Cummins Tier 3 Replaced Addco Actuator With Solenoid - Tb60
Electrical Schematic Deutz - Added Hard Start Solenoid - Tb60
Electrical Schematic Deutz - Replaced Addco Actuator With Solenoid - Tb60
Electrical Schematic - Gm - Tb60
Electrical Schematic - Gm 2.4l Tier 3 - Tb60
Electrical Schematic - Gm Tier 3 Added Fluid Tech Non-Proportional Valve - Tb60
Electrical Schematic Added Hydraforce Controller Wiring - Tb60 - Gm Tier 3
Electrical Schematic - Ce - Deutz - Tb60
Electrical Schematic - Gm - Updated Wiring Harness - Tb60
Electrical Schematic - Ce - Deutz - Added Load Sense - Tb60
Electrical Schematic - Ce - Deutz - Added Boom Angle Switch And Updated Drive Bypass Relay Power - Tb60
Electrical Schematic - Ce - Deutz - 1d Wiring Connection In Wiring Box Updated Load Sense Control Box Mount Screws To Self Tapping Platform Ac Power Installation And 220v Ac Gen Option Updated Power To Range Switch - Tb60
Electrical Schematic - Ce - Cummins Tier 3 - Added Glow Plug Timer Assembly With Related Wiring - Tb60
Hydraulic Schematic - 2wheel Drive - Tb60/Pro65/Tb65j/Pro66/Tb66j
Hydraulic Schematic 4wheel Drive - Tb60/Tb60p/Pro65/Tb65j/Pro66/Tb66j
Hydraulic Schematic - Tb60
Appendix A
ages Index
Appendix B
arts Index
Brand: Snorkel
Repair Parts
Boom Installation
Platform Gate
Hydraulics
Drive Motor
Flow Divider Valve
4x2 Selector Valve
4x4 Selector Valve
Check Valve
Dump Valve
Lift Cylinder - Gbi
Electrical
Options
Tow Package
Sandblast Kit
Boom Brush Kit
Motion Alarm Drive
Platform Bumpguard
Lanyard Mount
Welder Assembly
Csa Package
Horn Installation
Amber Beacon Single
Light Package
Maintenance
Maintenance
Schematics
Appendix A
Appendix B
