Snorkel Aerial Work Platform TB47J Parts Manual 0075898
Brand: Snorkel
Type of Manual: Parts Manual, Electrical Schematic, Hydraulic Schematic
Model: Snorkel TB47J Aerial Work Platform
Part Number: 0075898
Number of Pages: 538 Pages
Repair Parts
Tires And Wheels
4wheel Drive Chassis Equipment
Chassis Turntable Installation
4x4 Steering Installation
Drive Installation
Gear Hub
Lift Swing Counterweight Installation
Swing Drive - April 2006 And After
Swing Drive Assembly -
Swing Drive Perfection
Swing Drive – Auburn Gear
Engine - Ford
Engine Mounting - Ford
Engine Mounting - Deutz
Engine Sub-Assembly - Deutz
Engine - Gm
Engine Mounting - Gm
Engine Mounting - Cummins 3.3
Engine - Cummins
Engine Sub-Assembly - Kubota V2403
Engine With Radiator Replacement Parts - Kubota V2403t
Engine Replacement Parts - Kubota V1505 25hp
Engine Sub-Assembly - February 2015 And After - Kubota V1505
Lower Fan Kit Assembly - Kubota V1505 Skl-1 V1505-25hp Wg1605 Df
Bell Housing Assembly - Kubota
Fuel Tank Installation - Deutz/Cummins/Ford
Fuel System - Gasoline Fuel Only - Gm
Exhaust/Air Cleaner - Ford
Exhaust/Air Cleaner - Gm
Air Cleaner Assembly
Exhaust/Air Cleaner - Deutz
Air Cleaner - Deutz
Exhaust/Air Cleaner Installation - May 2014 And After - Kubota
Air Cleaner
Air Cleaner Assembly - 45hp Cummins/65hp Ford Lrg/425 Gm Tier 3/2.4l/Kuboda V1505t Tier 3 V2403
Exhaust/Air Cleaner Installation - Kubota
Prop, Rod And Cowling Stop Installation - 1 Of 3
Prop, Rod And Cowling Stop Installation - 2 Of 3
Prop, Rod And Cowling Stop Installation - 3 Of 3
Prop, Rod, Stop Installation With Front Latch - May 2014 And After
Prop, Rod And Cowling Stop With Front Latch Installation - 1 Of 3 - February 2015 And After
Prop, Rod And Cowling Stop Installation With Front Latch - 2 Of 3 - February 2015 And After
Prop, Rod And Cowling Stop Installation With Front Latch - 3 Of 3 - February 2015 And After
Cowling Installation
Boom Assembly - Tb47j
Boom Assembly - Tb47j - Ce
Boom Assembly - Kubota
Boom Assembly - Tb47j - February 2014 And Before
Boom/Hose Carrier Jib Assembly - December 2014 And Before
Boom/Hose Carrier Jib Assembly - May 2015 And After
Boom/Hose Carrier Assembly
Hose Carrier Assembly - Steel Track - November 2015 And After
Extension Cylinder
5' Jib Assembly
Mount Platform Assembly – Polaris
Platform Installation - Rotator Non-Slider - Helac
Rotator Platform Assembly
Platform Gate
Snorkel Guard Legacy Assembly
Snorkel Guard Legacy Kit And Wiring
Decal Kit - Kubota Dr
Decals/Placards - Cummins 4x4
Decals/Placards - Deutz 4x4
Hydraulic
Drive Motor With Integral Brake Rear
4x4 Drive Motor Front W/O Brake
Drive Valve Sub-Assembly
Drive Valve And Motion Control Valve Sub-Assembly
Turntable Hydraulics
Turntable Hydraulic Hoses
Emergency Power Unit Assembly - April 2016 And Before
Emergency Power Unit Assembly - April 2016 And After
Proportional Valve Assembly - Tb42/Tb47j
Non-Proportional Valve Sub-Assembly
Non-Proportional Control Valve - October 2007 And After - Fluid Tech
Hydraulic Fluid Reservoir Installation
Hydraulic Fluid Reservoir Sub-Assembly
Hydraulic Pump Sub-Assembly - Tb42/Tb50
Hydraulic Pump Sub-Assembly - Tb42/Tb47j/Tb50
Dump Valve Assembly
Selector Valve Assembly Booms
Range Valve Assembly
Check Valve Manifold Assembly
Accumulator Assembly
Centerpost Sub-Assembly
Motion Control Valve-Drive
Motion Control Valve Swing - April 2006 And After
Motion Control Valve Swing - June 2015 And Before
Motion Control Valve Swing - July 2015 And After
Dual Counterbalance Valve Rotator - Helac
Platform Rotator
Primary Level Cylinder - Rosenboom
Secondary Level Cylinder - Rosenboom/Green
Secondary Level Cylinder Assembly
Steer Cylinder - Rosenboom
Lift Cylinder - Gbi
Lift Cylinder - Rosenboom
Extend Cylinder - Rosenboom
Extend Cylinder And Support Sub-Assembly
Jib Cylinder
Electrical
Electrical Components - Ford
Electrical Components Installation - Gm
Electrical Components - Kubota
Electrical Components - October 2008 And Before - Deutz/Cummins
Electrical Components - November 2008 And After - Deutz/Cummins
Engine Electrical Control - Ford
Engine Electrical And Controls - Cummins
Engine Electrical And Controls Installation - Duetz
Engine Electrical And Controls - Gm
Engine Lower Controls - Gm
Turntable Wire Assembly
Turntable Wire Assembly - Fluid Tech
Engine Turntable Sub-Assembly - Kubota
Engine Harness Assembly - Tb42/Tb47j - Kubota
Engine Lower Controls - Ford
Engine Lower Controls Panel Assembly - Kubota
Engine Lower Controls - April 2006 And Before - Cummins/Duetz
Engine Lower Controls - May 2006 And After - Cummins/Duetz
Lower Controls Panel Sub-Assembly - Kubota
Wiring Box - Gm
Wiring Box - Ford
Wiring Box - Cummins/Duetz
Wiring Box Panel Sub-Assembly - Tb42/Tb47j
Wiring Box Panel Sub-Assembly - Kubota
Wiring Box - February 2015 And After - Kubota
Wiring Box - January 2015 And Before - Kubota
Boom Switch Drive Speed
Platform Jib Selector Wire Assembly
110v Power To Platform Installation
110 Volt Gfci Installation
Upper Control Box Assembly - September 2008 And Before - Deutz/Cummins
Upper Control Box Assembly - October 2008 And After - Duetz/Cummins
Upper Control Box Assembly - Kubota
Drive Steer Controller
Lift/Swing Controller
Foot Switch
Options
Tow Package
Isolation Valve
Ac Generator Valve Sub-Assembly
Hydraulic Warm Up
Hydraulic Warm-Up Valve
110 Volt Ac Generator - December 2014 And Before
110 Volt Ac Generator - January 2015 And After
110 Volt Ac Hydraulic Generator Sub-Assembly
220 Volt Ac Generator Installation
220 Volt Ac 50hz Hydraulic Ac Generator Sub-Assembly
12kw Generator Installation
12kw Generator Valve Assembly
12kw Generator Assembly
12kw Generator Circuit Breaker Box
12kw Generator Electrical Componet Installation
Upper Control Box Assembly- 12kw
12kw Check Valve Manifold Assembly
Motion Alarm Drive
All Motion Alarm With Out Horn
Lp Fuel Only - Ford
36x96 Platform With Bumpguard And Pad Assembly
Air Inlet Heater Installation - March 2008 And Before - Duetz
Air Inlet Heater Installation - April 2008 And After - Duetz
11kw Welder Generator Auminum Platform
Welder Assembly - Lincoln
Welder Steel Platform
Sandblast Kit
Platform Work Lights
Upper Control Box Cover
Upper Control Box - Courtesy Light
Horn Installation
Head/Tail Lights Installation
Schematics
Electrical Schematic Simplified Hydraulics - Deutz/Cummins
Electrical Schematic - Simplified Hydraulics - Ford
Electrical Schematic - Gm 1.6l Tier 3
Electrical Schematic - Updated Platform Wiring - Kubota
Electrical Schematic Added Fuel Filter For Ku1505 Dr - Kubota
Electrical Schematic - Added Glow Plug Timer Assembly And Related Wiring - Cummins Tier 3
Electrical Schematic Added Glow Plug Timer Assembly And Related Wiring - Ce - Cummins Tier 3
Electrical Schematic - Ce - Deutz
Hydraulic Schematic - Revised Drive Valve Psi
Hydraulic Schematic - Changed To Fluid Tech
Hydraulic Schematic
Appendix A
ages Index
Appendix B
arts Index
Brand: Snorkel
Repair Parts
Tires And Wheels
Drive Installation
Gear Hub
Engine - Ford
Engine - Gm
Engine - Cummins
Air Cleaner - Deutz
Air Cleaner
Extension Cylinder
5' Jib Assembly
Platform Gate
Hydraulic
Dump Valve Assembly
Platform Rotator
Lift Cylinder - Gbi
Jib Cylinder
Electrical
Wiring Box - Gm
Wiring Box - Ford
Foot Switch
Options
Tow Package
Isolation Valve
Hydraulic Warm Up
Motion Alarm Drive
Lp Fuel Only - Ford
Sandblast Kit
Horn Installation
Schematics
Hydraulic Schematic
Appendix A
Appendix B
