Momed80
150
35,046
Snorkel Aerial Work Platform TB42J Operators Manual 0172310
Brand: Snorkel
Model: Snorkel TB42J Aerial Work Platform
Part Number: 0172310
Number of Pages: 68 Pages
Chapter 1 – Introduction
Aerial Platform Features
Options
Operator’s Manual
Safety Alerts
Operation
Maintenance
Manual of Responsibilities
Additional Information
Chapter 2 – Specifications
Component Identification
Working Envelope
General Specifications
Aerial Platform
Platform
Function Speed
Drive System
Tires
Fuel Tank Capacity
Ambient Air Temperature Operating Range
Maximum Wind Speed
Engine Specifications
Engine Oil Viscosity
Cummins B33
Deutz F3L-2011F
Chapter 3 – Safety
Electrocution Hazards
Minimum Safe Approach Distance
Prestart Inspection
Work Place Inspection and Practices
Operation
Tip-Over and Falling Hazards
Engine and Fuel Handling Precautions
Placards and Decals
Chapter 4 – Safety Devices
Emergency Stop Controls
Emergency Power System
Emergency Lowering Knob
Ground Controls Switch
Platform Foot Switch
Guardrails
Lanyard Anchors
Ground Fault Circuit Interrupter
Tilt Alarm
Envelope Restriction
Engine Protection Systems
High Engine Temperature Alarm
Low Oil Pressure Alarm
Horn
Drive Motion Alarm
Flashing Light
Driving Lights
Platform Work Lights
Chapter 5 – Gauges and Displays
Hour Meter
Engine Temperature Gauge
Ammeter
Engine Air Filter Gauge
Fuel
Engine Oil
Hydraulic Fluid Filter Gauge
Fluid Level and Temperature Gauge
Chapter 6 – Controls
Battery Disconnect Switch
Lower Controls
Start Switch
Emergency Stop Switch
Controls Switch
Rotation Switch
Boom Elevation Switch
Boom Switch
Jib Articulation Switch
Platform Level Switch
Platform Rotator Switch
Engine/Emergency Power Switch
Throttle Switch
Circuit Breaker Reset Buttons
Upper Controls
Master Start Switch
Emergency Stop Button
Speed Knob
Boom Joystick
Drive Joystick
Drive Range Switch
Boom Extend/Retract Switch
Throttle Switch
Platform Rotate Switch
Horn Button
Machine/Generator Switch
Driving and Platform Work Lights
Chapter 7 – Prestart Inspection
Operator’s Manual
Oil Level
Coolant
Fuel Line
Air Filter
Charging System
Cold Weather Start Kit—Block Heater
Emergency Power Battery
Battery Fluid Level
Battery Terminals
Cables and Wiring Harness
Fluid Level
Fluid Filter
Hoses, Tubes, and Fittings
Tires and Wheels
Air Filled
Foam Filled
Lower Control Station
Operating Controls
Emergency Stop
Emergency Power
Emergency Lowering
Level Sensor
Flashing Light
Sandblast Protection Kit
Structures
Weldments
Slide Pads
Fasteners
Upper Control Station
Guardrail System
Lanyard Anchors
Operating Controls
Emergency Stop
Emergency Power
Horn
Electrical Power Outlet
Drive Motion Alarm
Driving and Work Lights
Platform Control Cover
Tow Kit
Placards and Decals
Prestart Inspection Checklist
Chapter 8 – Operation
Cold Weather Start-Up
Engine Cold Weather Start Kit
Cummins — Block Heater
Deutz — Manifold Preheater
Hydraulic System Cold Weather Warm-Up
Preparing for Operation
Lower Controls
Upper Controls
Boom Operation
Driving and Steering
Drive Speeds
Motion Warning Alarm
Four Wheel Drive
AC Generator
Driving Lights
Chapter 9 – Stowing and Transporting
Stowing
Tucked Stow
Transporting
Driving
Winching
Hoisting
Securing for Transport
Chapter 10 – Emergency Operation
Lower Controls
Upper Controls
Emergency Lowering
Towing
Chapter 11 – Troubleshooting
Troubleshooting Chart
Appendix A – Glossary
Limited Warranty
