Snorkel Aerial Work Platform TB42 TB50 TB47J Parts Manual 0075896 2016
Brand: Snorkel
Type of Manual: Parts Manual, Electrical Schematic, Hydraulic Schematic
Model: Snorkel TB42 TB50 TB47J Aerial Work Platform
Part Number: 0075896
Publication Date: 2016
Number of Pages: 713 Pages
Repair Parts
Tires And Wheels
Chassis Turntable Installation
4x4 Chassis Assembly
4x4 Steering Installation
Drive Installation
Gear Hub
Turntable Hydraulic Assembly - Deutz/Smiflified
Lift Swing Counterweight Installation
Swing Drive Assembly -
Swing Drive - April 2006 And After
Engine - Ford
Engine Mounting - Ford
Engine - Gm
Engine Mounting - Gm
Engine - Cummins
Engine Mounting - Cummins 3.3
Engine With Radiator Replacement Parts - Kubota V2403-M-T-E3b-Kea-2f
Engine With Radiator Replacement Parts - Kubota V1505
Engine Mounting - Deutz
Engine Sub-Assembly - Kubota V2403
Engine Sub-Assembly - February 2015 And After - Kubota V1505
Engine Replacement Parts - Kubota V1505 25hp
Engine Sub-Assembly - August 2008 And Before - Deutz
Engine Sub-Assembly - Deutz
Fuel System - Gasoline Fuel Only - Gm
Supertrapp Muffler Adapter
Exhaust/Air Cleaner - Deutz
Air Cleaner - Deutz
Air Cleaner - Deutz
Air Cleaner - Kubota V1505
Air Cleaner
Exhaust/Air Cleaner - Ford
Exhaust/Air Cleaner Installation - Kubota
Exhaust/Air Cleaner - Gm
Air Cleaner Assembly
Fan Kit Assembly
Bell Housing Assembly - Kubota
Fuel Tank Installation - Deutz/Cummins/Ford
Fuel Tank Steel 20 Gal
Prop, Rod And Cowling Stop Installation - 1 Of 3
Prop, Rod And Cowling Stop Installation - 2 Of 3
Prop, Rod And Cowling Stop Installation - 3 Of 3
Prop, Rod And Cowling Stop With Front Latch Installation - 1 Of 3 - February 2015 And After
Prop, Rod And Cowling Stop Installation With Front Latch - 2 Of 3 - February 2015 And After
Prop, Rod And Cowling Stop Installation With Front Latch - 3 Of 3 - February 2015 And After
Cowling Installation - Deutz
Cowling Installation Tb42/Tb50/Tb47j - Kubota Dr
Front Cowling Assembly Steel
Rear Cowling Assembly Steel
Boom/Hose Carrier Assembly
Boom Assembly - Kubota
Boom Assembly Sim Hyd
Boom/Hose Carrier Assembly - Tb47j - May 2015 And After
Boom/Hose Carrier Jib Assembly - May 2015 And After
Boom/Hose Carrier Assembly - April 2014 And Before
Hose Carrier Assembly - Steel Track - May 2015 And After
Boom Assembly - August 2015 And After
Boom Assembly - October 2015 And After
Hose Carrier Assembly - Steel Track - November 2015 And After
Boom Assembly - Tb47j
Boom Assembly - Tb47j - Ce
Boom Assembly - Tb42 - Ce
Boom Assembly - Tb47j - February 2014 And Before
Boom Assembly Simplified Hydraulics - Ce
Hose Carrier - Plastic Track - February 2014 And Before
Extension Cylinder
Extend Cylinder And Support Sub-Assembly
5' Jib Assembly
Push Tube Hose Carrier Assembly
Rebuild - Weldment Hose Tube Bracket
Slide Pad Kit
Platform Mounting - High Mount - Tb50
Platform Mounting
Platform Rotator - Tb42 - Before August 2019
Platform Rotator Assembly With Overload - Helac
Platform Rotator Assembly - August 2019 And After - Helac
5' Steel Platform Sub-Assembly With Swing Gate
Platform Gate
Platform Rotator Assembly - After February 2015
Global Platform Assembly
36x96 Platform With Bumpguard And Pad Assembly
Snorkel Guard Assembly - Sn 01-000104 And Before
Snorkel Guard Legacy Kit And Wiring
Snorkel Guard Legacy Assembly
Lower Control Panel Assembly - Tb42
Decal Kit - Kubota Dr
Decals/Placards - Tb42 50 420 - Common
Decals/Placards - Cummins 4x4
Decals/Placards - Deutz 4x4
Decals/Placards
Decals/Placards
Hydraulics
4wheel Drive Chassis Equipment
2wheel Drive Chassis Hydraulics
Simplified Hydraulics - Deutz 4x4
Hydraulic Fluid Reservoir Installation
Hydraulic Fluid Reservoir Sub-Assembly
Hydraulic Pump Sub-Assembly - Tb42/Tb50
Hydraulic Pump Sub-Assembly - Tb42/Tb47j/Tb50
Drive Motor Front
Drive Motor With Integral Brake Rear
Drive Valve Sub-Assembly
Drive Valve And Motion Control Valve Sub-Assembly
Motion Control Valve-Drive
Motion Control Valve Swing - April 2006 And After
Turntable Hydraulics
Turntable Hydraulic Hoses
Proportional Valve Assembly - Tb42/Tb47j
Non-Proportional Control Valve - October 2007 And After - Fluid Tech
Non-Proportional Valve Sub-Assembly
Dump Valve Assembly
Boom Simplified Hydraulic Installation - Tb42
Selector Valve Assembly Booms
Range Valve Assembly
Check Valve Manifold Assembly
Accumulator Assembly
Swing Drive Perfection
Swing Drive - Auburn
Centerpost Sub-Assembly
Motion Control Valve Swing - June 2015 And Before
Motion Control Valve Swing - July 2015 And After
Dual Holding Valve Platform Rotation
Emergency Power Unit Assembly - April 2016 And Before
Emergency Power Unit Assembly - April 2016 And After
Platform Rotator Valve
Platform Rotator - Parker
Platform Rotator
Platform Rotator
Primary Level Cylinder - Rosenboom
Secondary Level Cylinder - Rosenboom
Steering Cylinder - Rosenboom
Lift Cylinder - Rosenboom
Lift Cylinder - Gbi
Extend Cylinder - Rosenboom
Jib Cylinder
Electrical
Turntable Wire Assembly
Turntable Wire Assembly - Fluid Tech
Wiring Box - Ford
Wiring Box - Cummins/Duetz
Wiring Box - Gm
Wiring Box - January 2015 And Before - Kubota
Wiring Box - February 2015 And After - Kubota
Wiring Box Panel Sub-Assembly - Tb42/Tb47j
Wiring Box Panel Sub-Assembly - Kubota
Lower Control Panel Assembly Dz Sim Hydraulic
Lower Controls Panel Sub-Assembly - Kubota
Engine Lower Controls - Ford
Engine Electrical And Controls - August 2008 And Before - Deutz
Engine Electrical And Controls - September 2008 And After - Deutz
Engine Electrical And Controls - Cummins
Engine Electrical Controls - Cummins
Engine Electrical And Controls Installation - Duetz
Engine Electrical And Controls - Ford
Engine Electrical Control - Ford
Engine Electrical And Controls - Tb42/Tb50 - Gm
Engine Electrical And Controls - Gm
Engine Lower Controls - Gm
Engine Turntable Sub-Assembly - Kubota
Engine Harness Assembly - Tb42/Tb47j - Kubota
Engine Lower Controls - April 2006 And Before - Tb42 - Cummins And Duetz
Engine Lower Controls Panel - May 2006 And After - Tb42 - Cummins/Duetz
Engine Lower Controls - April 2006 And Before - Cummins/Duetz
Engine Lower Controls - May 2006 And After - Cummins/Duetz
Engine Lower Controls Panel Assembly - Kubota
Electrical Components Installation - Gm
Electrical Components - October 2008 And Before - Deutz/Cummins
Electrical Components - November 2008 And After - Deutz/Cummins
Electrical Components - Ford
Electrical Components - Kubota
Electrical Components Installation - Tb42/Tb50/Tb420 - Gm
Electrical Componets Installation - January 2015 And Before - Tb42 - Deutz/Cummins
Electrical Components Installation - February 2015 And After - Tb42 - Deutz/Cummins
Boom Switch Drive Speed
110 Volt Gfci Installation
110v Power To Platform Installation
Platform Control Box Assembly - Tb42/Tb50
Platform Jib Selector Wire Assembly
Upper Control Box Assembly - Kubota
Upper Control Box Assembly - September 2008 And Before - Deutz/Cummins
Upper Control Box Assembly - October 2008 And After - Duetz/Cummins
Lift/Swing Controller
Drive Steer Controller
Foot Switch
Options
Tow Package
Isolation Valve
110 Volt Ac Generator - January 2015 And After
110 Volt Ac Generator - December 2014 And Before
110 Volt Ac Hydraulic Generator Sub-Assembly
220 Volt Ac Generator Installation
220 Volt Ac 50hz Hydraulic Ac Generator Sub-Assembly
Ac Generator Valve Sub-Assembly
12kw Generator Installation
12kw Generator Assembly
12kw Check Valve Manifold Assembly
12kw Generator Valve Assembly
12kw Generator Circuit Breaker Box
12kw Boom And Hose Carrier Assembly
12kw Platform Box Assembly Generator
12kw Generator Electrical Componet Installation
Upper Control Box Assembly- 12kw
Air Reel Installation
Hydraulic Warm Up
Hydraulic Warm-Up Valve
Engine Block Heater
Air Inlet Heater Installation - March 2008 And Before - Duetz
Air Inlet Heater Installation - April 2008 And After - Duetz
Sandblast Kit
Spark Arrestor - Duetz
Lp Fuel Only - Ford
11kw Welder Generator Auminum Platform
Welder Steel Platform
Welder Assembly - Lincoln
Horn Installation
All Motion Alarm With Out Horn
Alarm And Mounting Assembly
Motion Alarm Drive
Upper Control Box Cover
36x96 Platform Assembly Bumpguard With Padding
Platform Assembly 36 X 96 Steel Double Handrail On Padding September 2017 And After
Global Standard Platform Assembly
Upper Control Box - Courtesy Light
Warning Light Single Becon
Head/Tail Lights Installation
Platform Work Lights Global Installation
Maintenance
Maintenance
Schematics
Electrical Schematic Simplified Hydraulics - Deutz/Cummins
Electrical Schematic - Simplified Hydraulics - Ford
Electrical Schematic - Gm 1.6l Tier 3
Electrical Schematic - Added Glow Plug Timer Assembly And Related Wiring - Cummins Tier 3
Electrical Schematic Added Glow Plug Timer Assembly And Related Wiring - Ce - Cummins Tier 3
Electrical Schematic - Updated Platform Wiring - Kubota
Electrical Schematic Added Fuel Filter For Ku1505 Dr - Kubota
Electrical Schematic - Ce - Deutz
Electrical Schematic - Kubota
Electrical Schematic - Cummins/Deutz
Electrical Schematic - Ford
Electrical Schematic - Added Glow Plug Timer Assembly And Related Wiring - Tb42/Tb50 - Cummins Tier 3
Electrical Schematic - Tb42/Tb50 - Gm Tier 3
Electrical Schematic - Updated Switch Wiring - Tb42/Tb50 - Gm Tier 3
Electrical Schematic - Tb42/Tb50 - Ford 425
Electrical Schematic Ce Updated Limit Switch Ground Lamp Connection Added Boom Angle Switch - Updated Load Sense Drive Bypass Enable Relay Power -Tb42/Tb50 - Cummins/Deutz
Hydraulic Schematic - Changed To Fluid Tech
Hydraulic Schematic - Revised Drive Valve Psi
Hydraulic Schematic
Hydraulic Schematic - Tb42/Tb50
Hydraulic Schematic - Tb42/Tb50 - Updated Valve
Appendix A
ages Index
Appendix B
arts Index
Brand: Snorkel
Repair Parts
Tires And Wheels
Drive Installation
Gear Hub
Engine - Ford
Engine - Gm
Engine - Cummins
Air Cleaner - Deutz
Air Cleaner - Deutz
Air Cleaner
Fan Kit Assembly
Extension Cylinder
5' Jib Assembly
Slide Pad Kit
Platform Mounting
Platform Gate
Decals/Placards
Decals/Placards
Hydraulics
Drive Motor Front
Dump Valve Assembly
Platform Rotator
Platform Rotator
Lift Cylinder - Gbi
Jib Cylinder
Electrical
Wiring Box - Ford
Wiring Box - Gm
Foot Switch
Options
Tow Package
Isolation Valve
Hydraulic Warm Up
Engine Block Heater
Sandblast Kit
Lp Fuel Only - Ford
Horn Installation
Motion Alarm Drive
Maintenance
Maintenance
Schematics
Hydraulic Schematic
Appendix A
Appendix B
