Momed80
150
35,046
Snorkel Aerial Work Platform TB37 TB42J Parts Manual 0172378
Brand: Snorkel
Type of Manual: Parts Manual, Eletrical Schematic, Hydraulic Schematic
Model: Snorkel TB37 TB42J Aerial Work Platform
Part Number: 0172378
Publication Date: 2006
Number of Pages: 371 Pages
Chassis Hydraulics, 2 Wheel Drive
Chassis Hydraulics, 4 Wheel Drive
Turntable Hydraulics
Turntable Hydraulic Hoses
Non-Proportional Valve
Control Valve Package, Non-Proportional
Proportional Control Valve
Drive Motor
Drive Motor with Brake
Hydraulic Oil Reservoir
Drive/Motion Control Valve
Drive Valve
Check Valve Manifold Assembly
AC Generator Valve
Accumulator
Booms Selector Valve – TB42J
Centerpost and Fittings
Motion Control Valve, Drive
Cylinder, Extension – GBI
Cylinder, Extension – Green
Lift Cylinder
Cylinder, Lift – Rosenboom
Cylinder, Master Level – Rosenboom – TB37
Cylinder, Master Level – Green – TB42J
Slave Level Cylinder – TB37
Slave Level Cylinder – TB42J
Cylinder, Slave Level – Rosenboom – TB37
Cylinder, Slave Level – Green – TB42J
Cylinder, Steering – Rosenboom
Cylinder, Jib – Green – TB42J
Emergency Power Unit
Steering Float Valve
Hydraulic Pump and Fittings, Duetz Engines
Hydraulic Pump and Fittings, Cummins Engines
Hydraulic Pump and Fittings, GM Engines
Platform Rotator, Parker – TB37
Platform Rotator, Helac – TB42J
Range Valve
Section 3 – Electrical
Electrical Components – TB37
Electrical Components – TB42J
Engine Electrical, Deutz and Cummins
Engine Electrical, GM
Lower Control Box Mounting, Duetz and Cummins
Lower Control Box Mounting, GM Engine
Wiring Box/Instrument Panel
Wiring Box, TB37 Deutz and Cummins
Wiring Box, TB37 GM
Wiring Box, TB42J Deutz and Cummins
Wiring Box, TB42J GM
Wiring Box Panel
Upper Control Box, TB37
Upper Control Box, TB42J
Instrument Panel, Deutz and Cummins
Instrument Panel, GM Engine
Solenoid Switch Panel, Ford
GFCI 110 Volt Power
Boom Switch, Lower
Boom Switch, Upper – TB37
Boom Switch, Upper – TB42J
Extend Switch – TB42J
50 Degree Envelope Switch – TB42J
Controller, Drive/Steer
Controller, Lift/Swing
AC Generator Mounting
AC Generator
Air Inlet Heater, Deutz
Gasoline Engine
LP Fuel Engine
Headlights
Horn
Isolation Valve
Motion Alarm, Drive
Taillights
Tow Package
Upper Control Box Cover
Warning Light, Single Beacon
Work Lights
Section 5 – Maintenance
Maintenance
Prestart Inspection Checklist
Frequent Inspection and Maintenance
Annual Maintenance
Major Repairs
Lubrication Points
Fastener Torque Chart
Electrical Schematics
Hydraulic Schematics
