Snorkel Aerial Work Platform TB126J T126J Parts Manual 0192648 2016
Brand: Snorkel
Type of Manual: Parts Manual, Electrical Schematic, Hydraulic Schematic
Model: Snorkel TB126J T126J Aerial Work Platform
Part Number: 0192648
Publication Date: 2016
Number of Pages: 1121 Pages
Repair Parts
Tires 4x4 Standard - Tb120/Tb126j
Chassis Sub-Assembly
Chassis Axle Assembly - Tb120/Tb26j
Chassis Turntable Installation
Axle Installation
Axle Stop Installation
Steering Installation
Gear Hub
Gear Hub - Auburn
Gear Hub - Fairfield
Pinion Guard
Turntable Sub-Assembly - Cummins Tier 3
Turntable Assembly - Kubota Tier 4 Final
Turntable Assembly - Ce - Kubota
Turntable Assembly - November 2019 And After - Dual Fuel
Engine Installation - July 2008 And After - Cummins Tier 3 Non-Turbo
Engine Assembly - July 2008 And After - Cummins 3.3 Tier 3 Non-Turbo
Engine Tray Assembly - June 2008 And Before - Cummins 3.3 Turbo 85hp
Engine Replacement Parts - Cummins 3.3 Turbo 85hp
Engine Tray Assembly - July 2008 And After - Cummins 3.3 Tier 3 Non-Turbo
Engine Sub-Assembly - January 2022 And After - Kubota V2403 Tier 4 Final
Engine Sub-Assembly - Kubota V2403 Cr Tier 4 Final
Engine Radiator Installation - Gm
Engine Sub-Assembly - Tb100j/Tb120/Tb126j - Gm
Engine Replacement Parts - Kubota V2403-Cr Tier 4b
Engine Replacement Parts - Kubota V2403 Cr Tier 4 Final
Lift Swing And Counterweight Installation - March 2015 And After
Lift Swing Counterweight Installation - Sn Tb126j-04-180200155 And Before
Centerpost Assembly - Complete With Fittings
Centerpost Weldment
Fuel System Assembly - Kubota V2403 Tier 4 Final
Engine Radiator - Kubota Tier 4 Final
Engine With Radiator Replacement Parts - Kubota Wg2503 Dual Fuel
Engine With Radiator Replacement Parts - Kubota Wg2503 - Dual Fuel
Engine Dual Fuel Assembly - November 2019 And After - Kubota Wg2503
Engine Fuel Line Assembly - November 2019 And After - Kubota Wg2502
Radiator Kit - Kubota V2403
Radiator Kit - Kubota Tier 4 Final
Radiator Mounting - Cummins Tier 3 With Turbo/Gm
Air Cleaner Installation Tb100j/Tb120/Tb126j - March 2006 And After - Gm
Air Cleaner Exhaust Installation - Kubota
Air Cleaner Assembly
Air Cleaner Exhaust - January 2020 And After - Kuboda Tier 4 Final
Air Cleaner Nelson - Cummins With Turbo
Air Cleaner Assembly - Cummins 65 Hp/Cummins 65 Hp/Ford Lrg 425/Gm Tier 3 2.4l/Kuboda V2403
Diesel Oxidation Catalyst Muffler - Kubota V2403 Cr T4b
Lp Gas Hose Assembly - Kubota Wg2503 Dual Fuel
Cooling System - Kubota V2403 Cr T1
Fuel Tank Installation Tier 3 - December 2016 And Before
Fuel Tank Installation Tier 3 - January 2017 And After
Intake Exhaust Assembly - Tb120/Tb126 - November 2019 And After
Hydraulic Fluid Reservior Installation - March 2000 And After
Hydraulic Fluid Reservoir Assembly
Hydraulic Reservior Mounting Metal Cowling Or Plastic Cowling
Cowling Installation - March 2017 And After - Cummins/Gm
Cowling Installation - February 2017 And Before
Cowling Assembly Installation - Kubota Tier 4 Final
Cowling Dual Fuel Assembly - Tb126j/Tb120 - October 2019 And After
Rear Cowling Steel Assembly
Boom Installation - Tb125j/Tb126j - Kubota
Boom Installation Slider
Boom Installation Non-Slider
Boom Assembly - With Plastic Track
Boom Assembly - May 2014 And After
Boom Assembly
Boom Hose Carrier And Jib Assembly - March 2016 And After
Boom Hose Carrier Assembly Non-Slider - June 2005 And After
Boom Angle Sensor Assembly
Boom Hose Carrier Assembly Slider - June 2005 And After
Boom Length Sensor Assembly
Boom And Jib Sub-Assembly
Hose Carrier Assembly - March 2016 And After
Hose Carrier Assembly - June 2005 And After
Extension Cylinder Assembly
Jib Boom Aluminium Assembly - May 2015 And Before
78" Jib Assembly - February 2019 And After
6' Jib Assembly - June 2016 And Before
6' Jib Assembly - July 2016 And After
6' Jib Assembly - July 2018 And After
Global Platform Assembly
Platform Installation - Rotator Non-Slider - Helac
Platform Slider With Gravity Gate Installation
Platform Slider With Swing Gate Installation
8' Aluminum Platform Assembly With Swing Gate - May 2013 And After
8' Aluminum Platform Installation With Swing Gate
Platform Assembly 36 X 96 Steel Double Handrail On Padding September 2017 And After
Platform Rotator Assembly - February 2018 And After
Snorkel Guard Legacy Assembly
Legacy Snorkel Guard Assembly
Legacy Snorkel Guard And Snorkel Guard Wiring
Decals/Placards Common - Tb100/Tb120/Tb126j
Decals/Placards Installation - Csa - September 2019 And After
Decals/Placards Installation - Tb100/Tb120/Tb126j - Csa/Ansi 92.20 - Tier 4 Final
Decals/Placards Add On - Csa
Decals/Placards Installation - Kubota
Decals/Placards Installation - Tier 4 Final
Decals/Placards - Tb100/Tb120/Tb126 - French
Language Kit - French - Kubota
Language Kit - September 2019 And After - Spanish
Language Kit - Spanish
Hydraulics
Chassis Hydraulic Installation
Chassis Hydraulic Equipment
Turntable Hydraulic Equipment - Kubota
Turntable Hydraulic Equipment With Hoses
Turntable Hydraulic Equipment - January 2001 And After - Cummins
Turntable Hydraulic Hoses Installation - November 2019 And After - Dual Fuel
Drive Motor With Brake - Von Ruden
Drive Valve Sub-Assembly
Manifold Sub-Assembly
Axle Jacking Control Valve Assembly
Axle Interlock Valve Installation - Ce
Axle Interlock Valve Sub-Assembly - Ce
Axle Interlock Sub-Assembly
Cam Valve
Shuttle Valve Assembly
Steer Cut Outvalve 4wheel Drive
Anti-Caviation Valve Sub-Assembly - November 2015 And Before
Anti-Caviation Valve Sub-Assembly - December 2015 And After
4x4 Right Hand Series Package Valve
4x4 Left Hand Series Package Valve
4x2 Right Hand Dual Sequence Valve
4x2 Left Hand Dual Sequence Valve
High-Range Speed Selector Valve
4 Stage Blocking Valve - Weco - October 2014 And Before
4 Stage Blocking Valve Sub-Assembly - November 2014 And After
4 Stage Blocking - November 2014 And After - Fluid Tech
Centerpost Sub-Assembly - October 2017 And Before
Centerpost Sub-Assembly - November 2017 And After
Swing Drive Assembly Perfection Or Auburn Gear
Swing Drive Assembly - Omni
Check Valve Manifold Sub-Assembly
Check Valve Manifold - Fluid Tech
Hydraulic Pump Assembly - January 2001 And After
Hydraulic Pump Sub-Assembly - September 2019 And Before
Left Hand Emergency Power Unit
Right Hand Emergency Power Unit
Emergency Power Unit Assembly - April 2016 And After
Non-Proportional Valve Assembly - Complete With Fittings And Hardware - January 2001 And After
Non-Proportional Four Station Valve - January 2001 And After
Non-Proportional Valve Assembly - Complete With Fittings And Hardware - March 2006 And After
Non-Proportional Four Section Valve - March 2006 And After
Proportional Control Valve Assembly Complete With Fittings And Hardware - January 2001 And After
Proportional Valve - Apitech
Proportional Control Valve Assembly - April 2015 And Before
Proportional Control Valve Assembly Complete With Fittings And Hardware - May 2015 And After
Proportional Control Valve - May 2015 And After
Boom Limit Switch Setting Procedure
Hydraulic Fluid Return Filter
Accumulator Charged
Pump Control Valve Assembly
Motion Control Valve Swing
Platform Jib Selector Valve Assembly
Axle Extend Cylinder - October 2016 And Before
Axle Extend Cylinder - November 2016 And After - Hengli
Jack Cylinder - Rosenboom
Jacking Cylinder Sub-Assembly
Jack Cylinder - Hengli
Primary Level Cylinder - Rosenboom
Secondary Level Cylinder Assembly
Secondary Level Cylinder - Rosenboom
Secondary Level Cylinder Sub-Assembly
Lift Cylinder Sub-Assembly
Lift Cylinder - Hengli
Lift Cylinder - Gbi
Level And Steer Cylinder - Rosenboom
Extension Cylinder - Gbi
Extension Cylinder - Hengli
Jib Boom Cylinder Assembly - January 2001 And After
Jib Boom Cylinder - Rosenboom
Jib Boom Cylinder - Hengli
Platform Sliding Cylinder Green
Platform Rotator - Parker
Platform Rotator Assembly - January 2018 And Before - Helac
Platform Rotator
Dual Holding Valve
Rotary Actuator - Tb86j/Tb126j - September 2019 And After - Sunji
Rotator Assembly - Hengli
Electrical
Turntable Electrical Installation - July 2008 And After - Cummins Tier 3
Turntable Electrical - Cummins/Kubota
Turntable Electrical - December 2005 And Before - Cummins
Turntable Electrical - June 2015 And After - Kubota
Turntable Electrical - Tb100/Tb126j - Gm
Turntable Electrical - November 2019 And After - Dual Fuel
Turntable Wire Assembly
Electrical - Ce - Cummins
Electrical - Csa - Kubota
Electrical - Kubota V2403 Cr Tier 4 Final
Battery Isolator Harness - November 2019 And After
Diode Resistor Wire Assembly
Fuel Manifold Harness - November 2019 And After - Kubota Wg2503
Engine Wire Assembly - Cummins
Engine Harness Assembly - Cummins Tier 3
Engine Harness - Kubota
Engine Harness - Kubota Tier 4 Final
Engine Harness - November 2019 And After - Kubota Wg2503
Harness Instrument Panel
Boom Electrical
Wiring Box Panel Sub-Assembly - January 2005 And After
Wiring Box And Lower Control Assembly
Wiring Box Panel - December 2015 And Before
Wiring Box Panel Sub-Assembly - Kubota
Wiring Panel Assembly - August 2017 And After - Tier 4 Final
Wiring Box And Lower Control Assembly - October 2014 And Before - Cummins Pro126
Wiring Box And Lower Control Assembly - November 2014 And After - Kubota
Wiring Box And Lower Control Assembly - February 2015 And After - Kubota
Ground Panel Assembly - October 2019 And After - Dual Fuel
Junction Box Assembly - Tier 4 Final - Ansi 92.20
Junction Box Assembly - January 2005 And After
Junction Box With Murphy Controls - Sn Tb126j-04-00047 And After
Junction Box Panel Assembly - Sn Tb126-04-170400140 And After
Lower Control Box Assembly - Tier 4 Final
Lower Control Box Assembly - October 2018 And After - Kubota Tier 4 Final
Lower Control Box Assembly - Ansi 92.20 - June 2020 And After - Tier 4 Final
Wire Assembly Ems Primary - March 2005 And After
Dual Fuel Ground Box - October 2019 And After
Extend Cutout Switch
Extend Cutout Switch Assembly
Boom Calibration Switch Assembly - August 2008 And After
Wire Assembly Ems Back Up - March 2005 And After
Boom Lift Switch Assembly
Boom Speed Switch Assembly - Roller Lever
Boom Speed Switch Assembly - Roller Wheel
Drive Speed Cutout Switch Sub-Assembly
Drive Range Switch - Telemecanique Only
Safety Interlock With Sliding Platform
110 Volt Power To Platform Installation
110 Volt Power To Platform With Slider
110 Volt Power To Platform Slider - June 2005 And After
110 Volt Power To Platform Slider - October 2019 And After
110 Volt Power To Platform Non-Slider
Platform Jib Selector Wire Assembly
Platform Foot Switch Assembly
Platform Foot Switch Self Stowing Platform
Alarm Motion Drive Only
Alarm And Mounting Assembly
Upper Control Box Assembly With Slider
Upper Control Box Assembly Non-Sliding
Upper Control Box New - Ems/Ce - July 2008 And Before
Upper Control Box New - Ems/Ce - August 2008 And After
Upper Control Box Assembly - Sliding Platform - November 2014 And After - Kuboda
Upper Control Box Assembly Non-Slider - February 2015 And After - Kubota
Upper Control Box Assembly - September 2017 And After - Tier 4 Final
Upper Control Box Assembly With Overload - October 2018 And After - Kubota
Upper Control Box Assembly - October 2019 And After - Dual Fuel
Upper Control Box Assembly - April 2020 And After - Tier 4 Final
Upper Control Box Internal Wire Assembly - Ansi 92.20 - June 2020 And After
Joystick Controller - 33hz Drive Steer
Controller Extend Retract
Controller Lift Swing
Controller Jib Elevation
Options
Tires 4x4 Standard - Over The Road - Tb120/Tb126
Trackunit To Control Box Boom Installation
Tow Package
Hydraulic Warm Up
Block Heater - Cummins 3.3
Block Heater - Kubota V2403t
Cold Weather Package - Cummins
Cold Weather Start - Gm
Cold Weather Package - Gm
Cold Weather Package - Kubota
Extreme Cold Weather Package - Cummins
Extreme Cold Weather Package - Gm
Extreme Cold Weather Package - Kubota
Extreme Environment Package
Hydraulic Fluid Cold Climate Iso 15
Hydraulic Fluid Cooler - Tb100j/Tb120/Tb126j
Oil Enviromental Friendly
Isolation Valve Installation
Fuel System Gas Only Installation - Tb100j/Tb120/Tb126j - Gm
Fuel System Lp Only - Tb100j/Tb120/Tb126j - Gm
Fuel System - Tb100j/Tb120/Tb126j - Gm Dual Fuel
Electrical Installation With 12k
12kw Generator Installation - June 2018 And Before
12kw Generator Assembly - Tb120/Tb126j - April 2008 And Before
12kw Generator Assembly - May 2008 And After
12kw Hydraulic Generator Installation
12kw Generator Valve Assembly
12kw Generator With Welder Package
12kw Generator Circuit Breaker Wiring
12kw Turntable Generator With Air Line
110 Volt Hydraulic Ac Generator Installation
110 Volt Hydraulic Ac Generator Sub-Assembly
220v Ac 50hz Hydraulic Ac Generator Sub-Assembly
Belt Generator - April 2019 And Before - Kubota 2.4kw V2403/Wg2503
2.4kw Belt Generator
2kw Generator Single V-Belt Assembly - Fabco
Belt Generator - May 2019 And After - Kubota 2.4kw V2403/Wg2503
Valve Hydraulic Motor Flow Control
Spark Arrestor - Cummins
Supertrapp Muffler Adapter
Airline To Platform
6' Jib Sandblast Kit
Sandblast Kit Pro 126
Boom Hose Carrier Jib Assembly With 12k And Air Line
Boom And Hose Carrier Assembly With Jib And Overload
Hose Carrier Assembly With 12kw Generator And Air Line
Upper Control Box - Courtesy Light
Upper Control Box Assembly - Kubota With Overload
Upper Control Box Assembly With Swing Gate And 12kw Generator
Upper Control Box Cover
Tool Tray
Deluxe Aircraft Package
Platform Assembly With Snorkel Guard
36x96 Fall Anchorage Installation
36x96 Platform Assembly Bumpguard With Padding
36x96 Platform Assembly Bumpguard With Padding - March 2009 And After
36x96 Platform Bumpguard With Padding
Platform Assembly With Mesh Enclosure With 12kw Generator And Decals
11kw Welder Generator Auminum Platform
Glazier Package Platform With 1.7" Toe Board Installation
Glazier Tray Assembly
Glazier Package World Platform With 2" Toe Board Installation
Glazier Tray Assembly 3 Entry Platform
Swing Gate Side Midrail Aluminum Platform - October 2007 And After
Certification - Csa
5' Aluminum Platform With Swing Gate Non-Sliding And Bumpguard - 500lb
5' Aluminum Platform With Swing Gate Non-Sliding - 650lb
8' Aluminum Platform Non-Sliding - 600lb
8' Aluminum Platform Sliding - 500lb
8' Aluminum Platform Sliding And Swing Gate - 500lb
8' Aluminum Platform With Gravity Gate And 12kw Generator Slider - 500lb
8' Aluminum Platform Slider With Swing Gate And 12kw Generator - 500lb
8' Aluminum Platform With Swing Gate Non-Sliding - 600lb - Ce
39x96 Tri-Entry Steel Platform With Snorkel Guard - 500lb
39x96 Tri-Entry Steel Platform And 12k Generator And Brackets - 500lb
39x96 Tri-Entry Steel Platform With 12k Generator - 500lb
Global Standard Platform Assembly
Platform Assembly With Mesh Enclosure - April 2018 And After
Pipe Rack Installation
Pipe Rack Boom Assembly
Dual Amber Beacon Installation
Lights Platform Box Installation
Light Package
Led Light Package
Head/Tail Lights
Head/Tail Lights Plastic Cowl
Platform Work Lights Global Installation
Decal Installation - Csa
Maintenance
Maintenance
Schematics
Electrical Schematic - Gm
Electrical Schematic Updated Wiring And Added Capacitor Wire Assembly To Upper Control Box - Gm
Electrical Schematic Updated Wiring And Added Capacitor Wire Assembly To Upper Control Box - Cummins 3.3
Electrical Schematic Glow Plug Wiring - Tb125j/Tb126j - Cummins 3.3
Electrical Schematic - Non-Sliding - Cummins Tier 3
Electrical Schematic Non-Slider Added Load Sense Capabilities - Ce - Cummins
Electrical Schematic Non-Slider Updated Proximity Switches To Mechanical Limit Switches - Ce - Cummins
Electrical Schematic Non-Slider Updated Power To Range Switch - Ce - Cummins
Electrical Schematic Includes Ems - Ce - Cummins 3.3 Tier 3
Electrical Schematic Shows New Overload Fault Detection - Ce - Cummins 3.3 Tier 3
Electrical Schematic Updated Wiring - Cummins 3.3 Tier 3
Electrical Schematic Added Glow Plug Wiring - Ce - Cummins 3.3 Tier 3
Electrical Schematic - Kubota
Electrical Schematic - Ansi - May 2020 And Before - Tier 4 Final
Electrical Schematic - Ansi 92.20 - June 2020 And After - Tier 4 Final
Hydraulic Schematic With 6' Jib
Hydraulic Schematic - Tb125j/Tb126j
Hydraulic Schematic - Tb80/Tb100j/Tb125j/Tb126j
Appendix A
ages Index
Appendix B
arts Index
Brand: Snorkel
Repair Parts
Axle Installation
Gear Hub
Gear Hub - Auburn
Pinion Guard
Centerpost Weldment
Boom Assembly
Hydraulics
Cam Valve
Accumulator Charged
Lift Cylinder - Gbi
Platform Rotator
Dual Holding Valve
Electrical
Boom Electrical
Options
Tow Package
Hydraulic Warm Up
Airline To Platform
Tool Tray
Certification - Csa
Light Package
Led Light Package
Head/Tail Lights
Maintenance
Maintenance
Schematics
Appendix A
Appendix B
