Momed80
150
35,046
Snorkel Aerial Work Platform TB126J T126J Operators Manual 0192519 2024
Brand: Snorkel
Model: Snorkel TB126J T126J Aerial Work Platform
Part Number: 0192519
Publication Date: 2024
Number of Pages: 106 Pages
Chapter 1 – Introduction
Aerial Platform Features
Options
Operator’s Manual
Safety Alerts
Operation
Maintenance
Used Material Disposal
Manual of Responsibilities – ANSI
MEWP Safe Use – AS/NZS
AS/NZS 141810 Commissioning
CE Compliance
Additional Information
Chapter 2 – Specifications
Component Identification
Working Envelope
General Specifications
Engine Oil Viscosity
General Motors 24L
Chapter 3 – Safety
Electrocution Hazards
Minimum Safe Approach Distance – ANSI
Minimum Safe Approach Distance – AS/NZS
Platform Capacity
Manual Force
Wind Speeds
Prestart Inspection
Work Place Inspection and Practices
Operation
Tip-Over and Falling Hazards
Engine and Fuel Handling Precautions
Placards and Decals
General Safety Rules
Chapter 4 – Safety Devices
Emergency Stop Controls
Emergency Power System
Emergency Bleed Down System
Emergency Lowering Knob
Axle/Boom Interlock
Ground Operation Switch
Platform Foot Switch
Guardrails
Fall Protection Anchors
Envelope Management System
Height Restriction
Ground Fault Circuit Interrupter
Platform Overload Sensing System
Tilt Alarm/Warning Light
Engine Protection Systems
High Engine Temperature Alarm
Low Oil Pressure Alarm
Horn
Drive Motion Alarm
Flashing Light
Driving Lights
Platform Work Lights
Snorkel Guard
Chapter 5 – Gauges and Displays
Hour Meter
Engine Temperature Gauge
Ammeter
Engine Air Filter Gauge
Dual Fuel Engine Display
Diagnostic Center/Engine Display
EMS Display
Platform Overload Warning Lights
Tilt Warning Light
Fuel Gauge
Engine Oil
Hydraulic Fluid Filter Gauge
Fluid Level and Temperature Gauge
Chapter 6 – Controls
Battery Disconnect Switch
Axle Controls
High Range Speed Selector – 4x4
Lower Controls
Start Switch
Emergency Stop Button
Controls Selector Switch
Boom/Axle Switch
Rotation Switch
Boom Elevation Switch
Boom Extension Switch
Boom Speed Knob
Jib Articulation Switch
Platform Level Switch
Platform Rotate Switch
Engine/Emergency Power Switch
Engine Speed Switch
Fuel Switch
Diagnostic Center/Dual Fuel Engine Display
Hydraulic Oil Warm-Up Switch
Circuit Breaker Reset Buttons
Height Restriction
Horn
Drive Motion Alarm
Flashing Light
Driving Lights
Snorkel Guard
Hour Meter
Ammeter
EMS Display
Tilt Warning Light
Fuel Gauge
Engine Oil
Axle Controls
Lower Controls
Start Switch
Boom/Axle Switch
Rotation Switch
Boom Speed Knob
Engine Speed Switch
Fuel Switch
Upper Controls
Start Switch
Boom Joystick
Drive Joystick
Drive Range Switch
Jib Articulation Joystick
Boom Extend/Retract Joystick
Throttle Switch
Horn Button
Override Switch
Tilt Alarm
Machine/Generator Switch
Dual Fuel
Driving and Platform Work Lights
Chapter 7 – Prestart Inspection
Operator’s Manual Holder
Oil Level
Coolant
Fuel Line
Air Filter
Charging System
Battery Fluid Level
Battery Terminals
Cables and Wiring Harness
Fluid Level
Fluid Filter
Hoses, Tubes, and Fittings
Tires and Wheels
Axle/Boom Interlock
Lower Control Station
Operating Controls
Emergency Stop
Emergency Power
Emergency Lowering
Level Sensor
Flashing Light
Structures
Weldments
Boom Slide Pads
Wire Ropes
Fasteners
Upper Control Station
Guardrail System
Operating Controls
Emergency Stop
Emergency Power
Horn
Snorkel Guard
Electrical Power Outlet
Platform Control Cover
Drive Motion Alarm
Sandblast Protection Kit
Air Line to Platform
Tow Kit
Platform Glazier Package
Platform Welder
Placards and Decals
Prestart Inspection Checklist
Inspection and Maintenance Schedules
Chapter 8 – Operation
Cold Weather Start-Up
Engine Cold Weather Start Kit
Cummins/Kubota – Block Heater
Cummins – Ether Injection
GM – Radiator Hose In-Line
Hydraulic System Cold Weather Warm-Up
Hydraulic System Warm-Up Switch
Manually Warming The Hydraulic System
Preparing for Operation
Lower Controls
Axle Controls
Extending The Rear Axles
Retracting The Rear Axles
Upper Controls
Boom Operation
Driving and Steering
Drive Speeds
Drive Motion Alarm
Four Wheel Drive
Snorkel Guard
Override Switch
AC Generator
Dual Fuel
Air Line
Driving Lights
Platform Capacity
Platform Welder
Platform Capacity
Chapter 9 – Stowing and Transporting
Stowing
Transporting
Driving
Winching
Hoisting
Securing for Transport
Storage
Chapter 10 – Emergency Operation
Lower Controls
Upper Controls
Override Switch
Electric Emergency Bleed Down System
Manual Emergency Bleed Down System
Towing
Chapter 11 – Troubleshooting
Troubleshooting Chart
Fuel Line Air Bleeding – Kubota V2403-T
Open Bleeder Valve and Crank Engine
Fill the Fuel Filter
Operate Bleeder Pump
Fuel Line Air Bleeding Kubota V2403-CR-TIE4B
Appendix A – Glossary
Appendix B – Inspection Checklists
Limited Warranty
