Snorkel Aerial Work Platform TB100J TB120 TB126J Maintenance Manual 0192736
Brand: Snorkel
Type of Manual: Maintenance Manual
Model: Snorkel TB100J TB120 TB126J Aerial Work Platform
Part Number: 0192736
Publication Date: 2018
Number of Pages: 50 Pages
Chapter 1 – General Information
Component Identification – TB100J
Working Envelope – TB100J
General Specifications – TB100J
Aerial Platform
Platform
Function Speed
Drive System
Tires
Ambient Air Temperature Operating Range
Maximum Wind Speed
Component Identification – TB120
Working Envelope – TB120
General Specifications – TB120
Aerial Platform
Platform
Function Speed
Drive System
Tires
Maximum Wind Speed
Component Identification – TB126J
Working Envelope – TB126J
General Specifications – TB126J
Aerial Platform
Platform
Function Speed
Drive System
Tires
Maximum Wind Speed
Engine Specifications
Engine Oil Viscosity
Serial Number Locations
Torque Wrench Use
Fastener Torque Chart – Standard System
Fastener Torque Chart – Metric System
Chapter 2 – Maintenance
Maintenance Schedules
Parts Replacement
Daily Prestart Inspection
Frequent Inspection and Maintenance
Frequent Maintenance
Annual Maintenance
Major Repairs
Lubrication Points
Lubrication
Rotation Bearing
Rotation Gear Teeth and Pinion
Tie Rods
Swing Drive
Gear Hubs
Hydraulic Oil Reservoir
Door Hinges and Latches
Platform Rotator
Hydraulic Oil Return Filter
Suction Strainer
Slide Pads
Batteries
Battery Care and Maintenance
Boom/Axle Interlock System Inspection
Boom/Axles Stowed Platform Interlock System
Limited Lift and Extend with Axle Retracted
Limited Lift and Extend with Axle Extended
and Not Pinned
Axle System Inoperative with Boom in
Working Position
Boom/Axles Switch Operation
Envelope Management System – EMS
Chapter 3 – Tires, Wheels and Torque Hub
Inspect Oil Level in Drive Torque Hubs
Towing the Machine
Chapter 4 – Engine
General Maintenance
Engine Model Identification
Engine Component Location
Fuel Line Air Bleeding – Kubota V2403-T
Open Bleeder Valve and Crank Engine
Fill the Fuel Filter
Operate Bleeder Pump
Fuel Line Air Bleeding Kubota V2403-CR-TIE4B
Chapter 5 – Hydraulic System
Hydraulic System Component Location
Chapter 6 – Electrical System
Electrical System Component Location
Appendix A – Glossary
Brand: Snorkel
Aerial Platform
Platform
Function Speed
Drive System
Tires
Maximum Wind Speed
Aerial Platform
Platform
Function Speed
Drive System
Tires
Maximum Wind Speed
Aerial Platform
Platform
Function Speed
Drive System
Tires
Maximum Wind Speed
Torque Wrench Use
Parts Replacement
Annual Maintenance
Major Repairs
Lubrication Points
Lubrication
Rotation Bearing
Tie Rods
Swing Drive
Gear Hubs
Platform Rotator
Suction Strainer
Slide Pads
Batteries
and Not Pinned
Working Position
Towing the Machine
Chapter 4 – Engine
General Maintenance
