Snorkel Aerial Work Platform S9033RT S9043RT S9053RT Operators Manual 1442308 2026
Brand: Snorkel
Model: Snorkel S9033RT S9043RT S9053RT Aerial Work Platform
Serial Number: 000000 and after
Part Number: 1442308
Publication Date: 2026
Number of Pages: 88 Pages
Chapter 1 – Introduction
Aerial Platform Features
Options
Operator’s Manual
Safety Alerts
Operation
Maintenance
Used Material Disposal
Manual of Responsibilities – ANSI
MEWP Safe Use – AS/NZS
AS/NZS 141810 Commissioning
CE Compliance
Additional Information
Chapter 2 – Specifications
Component Identification
General Specifications – S9033RT
General Specifications – S9043RT
General Specifications – S9053RT
Engine Specifications
Engine Oil Viscosity
Chapter 3 – Safety
Electrocution Hazards
Minimum Safe Approach Distance – ANSI
Minimum Safe Approach Distance – AS/NZS
Platform Capacity
Manual Force
Wind Speeds
Prestart Inspection
Work Place Inspection and Practices
Operation
Tip-Over and Falling Hazards
Engine and Fuel Handling Precautions
Placards and Decals
General Safety Rules
Chapter 4 – Safety Devices
Emergency Stop Controls
Emergency Power System
Ground Operation Button/Switch
Upper Control Interlock Switch
Guardrails
Fall Protection Anchors
Ground Fault Circuit Interrupter
Overload Protection
ANSI/CSA Machines
CE/AS/NZS Machines
Platform Raise/Lower Light
Platform Overload/Tilt Warning Lights
Engine Protection Systems
High Engine Temperature Alarm
Low Oil Pressure Alarm
Stabilizers
Stabilizer Down/Lift Interlock
Emergency Lowering
PG Control System
Parker Control System
Safety Prop
Horn
Flashing Light
Snorkel Guard
Chapter 5 – Gauges and Displays
Diagnostic Center Display
Platform Overload/Tilt Warning Indicators
Diesel Particulate Filter Warning Light
Engine Warning Lights
Fuel
Engine Oil
Hydraulic Fluid Filter Gauge
Hydraulic Fluid Level/Temperature Gauge
Chapter 6 – Controls
Battery Disconnect
Lower Controls
Diagnostic Center LCD Display
Emergency Stop Button
Control Selector Switch
Engine Start Button – PG Control System
Start/Emergency Power/Ground Operation Switc
– Parker Control System
Engine Start Switch
Stabilizer Controls – Auto Level/Stow
Button/Switch
Platform Raise/Lower Button/Switch
Platform Extension Deck Retract Button
– PG Control System
Platform Extension Deck Switch
Diesel Particulate Filter Switch
Dual Fuel
Upper Controls
Engine/Emergency Power Switch
Drive/Lift Selector Switch
Dual Fuel
Drive Range Switch
Joystick
Interlock Switch
Steer Switch
Platform Extension Deck Selector Switch
Stabilizer Controls – Manual
Horn Button
AC Generator Switch
Hydraulic System Warm-Up Switch
– Diesel Option
Chapter 7 – Prestart Inspection
Operator’s Manual
Oil Level
Coolant
Fuel Line
Battery Fluid Level
Battery Terminals
Safety Prop
Cables and Wiring Harness
Fluid Level
Hoses, Tubes, and Fittings
Tires and Wheels
Lower Control Station
Operating Controls
Emergency Stop
Stabilizer Interlock Test
Stabilizer Locked Out When Platform is Elevated
Platform Raise Locked Out When Axle
is Not Locked
Platform Raise Locked Out When Chassis Tilted
Emergency Lowering – PG System
Emergency Lowering – Parker System
Structures
Weldments
Rollers and Slide Blocks
Fasteners
Upper Control Station
Guardrail System
Operating Controls
Emergency Stop
Emergency Power
Horn Button
Snorkel Guard
Electrical Power Outlet
Flashing Lights
Placards and Decals
Prestart Inspection Checklist
Chapter 8 – Operation
Cold Weather Start-Up
Hydraulic System Cold Weather Warm-Up
Manually Warming The Hydraulic System
Preparing for Operation
Lower Controls
Upper Controls
Stabilizers
Auto Level – All
Manual Level – Individual
Platform
Raising and Lowering
Platform Extension Deck – Powered
Overload Protection
ANSI/CSA Machines
CE/AS/NZS Machines
Fold Down Guardrails
Driving and Steering
Drive Range Switch
Drive Speeds
Pivoting Front Axle
Machine in Stowed Position
Machine Not in Stowed Position
Drive/Lift Level Sensor Interlock
Snorkel Guard
Override Button
Gradeability
Percent vs Degree of Slope
Driving on a Slope
Calculating Percent Grade
Machine Gradeability
Diesel Particulate Filter Regeneration
AC Generator
Dual Fuel
After Use Each Day
Chapter 9 – Stowing and Transporting
Stowing
Transporting
Driving
Winching
Lifting With a Forklift
Securing for Transport
Storage
Chapter 10 – Emergency Operation
Upper Controls
Override Button
Towing
Chapter 11 – Troubleshooting
Troubleshooting Chart
Appendix A – Glossary
Appendix B – Inspection Checklists
Limited Warranty
Brand: Snorkel
Options
Operator’s Manual
Safety Alerts
Operation
Maintenance
CE Compliance
Chapter 3 – Safety
Platform Capacity
Manual Force
Wind Speeds
Prestart Inspection
Operation
Placards and Decals
Guardrails
Overload Protection
ANSI/CSA Machines
CE/AS/NZS Machines
Stabilizers
Emergency Lowering
PG Control System
Safety Prop
Horn
Flashing Light
Snorkel Guard
Fuel
Engine Oil
Battery Disconnect
Lower Controls
Engine Start Switch
Button/Switch
– PG Control System
Dual Fuel
Upper Controls
Dual Fuel
Drive Range Switch
Joystick
Interlock Switch
Steer Switch
Horn Button
AC Generator Switch
– Diesel Option
Operator’s Manual
Oil Level
Coolant
Fuel Line
Battery Fluid Level
Battery Terminals
Safety Prop
Fluid Level
Tires and Wheels
Operating Controls
Emergency Stop
is Not Locked
Structures
Weldments
Fasteners
Guardrail System
Operating Controls
Emergency Stop
Emergency Power
Horn Button
Snorkel Guard
Flashing Lights
Placards and Decals
Lower Controls
Upper Controls
Stabilizers
Auto Level – All
Platform
Overload Protection
ANSI/CSA Machines
CE/AS/NZS Machines
Drive Range Switch
Drive Speeds
Pivoting Front Axle
Snorkel Guard
Override Button
Gradeability
Driving on a Slope
AC Generator
Dual Fuel
After Use Each Day
Stowing
Transporting
Driving
Winching
Storage
Upper Controls
Override Button
Towing
Limited Warranty
