Momed80
150
35,046
Snorkel Aerial Work Platform S4740E Operators Manual 1503332 2025
Brand: Snorkel
Model: Snorkel S4740E Aerial Work Platform
Part Number: 1503332
Publication Date: 2025
Number of Pages: 80 Pages
Chapter 1 – Introduction
Aerial Platform Features
Options
Operator’s Manual
Safety Alerts
Operation
Maintenance
Used Material Disposal
Manual of Responsibilities – ANSI
MEWP Safe Use – AS/NZS
AS/NZS 141810 Commissioning
CE Compliance
Additional Information
Chapter 2 – Specifications
Component Identification
General Specifications – S4740E
General Specifications – S4740E Electric Drive
Chapter 3 – Safety
Electrocution Hazards
Minimum Safe Approach Distance – ANSI
Minimum Safe Approach Distance – AS/NZS
Platform Capacity
Manual Force
Wind Speeds
Prestart Inspection
Work Place Inspection and Practices
Operation
Tip-Over and Falling Hazards
Placards and Decals
General Safety Rules
Chapter 4 – Safety Devices
Emergency Stop Controls
Control Select/Ground Operation Switch
Upper Control Interlock Switch
Drive Motion Alarm
Pothole Protector Skids
Drive/Lift Pothole Protector Interlock
Drive/Lift Level Sensor Interlock
Progressive Tilt
Lowering Alarm
Emergency Lowering Handle
Safety Prop
Guardrails
Ground Fault Circuit Interrupter
Tilt Alarm
Chapter 5 – Gauges and Displays
Battery Charge Indicator – Pylon
Battery Condition Indicator
Diagnostic Center Display
Chapter 6 – Batteries
General Maintenance
Charging
Chapter 7 – Controls
Battery Disconnect
Lower Controls
Emergency Stop Button
Control Selector/Ground Operation Switch
Platform Raise/Lower Switch
Upper Controls
Drive/Lift Selector Switch
Joystick
Interlock Switch
Steer Switch
Drive Range Switch
Horn Button
Loading Controls
Interlock Button
Drive Switch
Steer Switch
Override Button
Chapter 8 – Prestart Inspection
Operator’s Manual
Battery Fluid Level
Battery Terminals
Battery Charger
Safety Prop
Cables and Wiring Harness
Fluid Level
Hoses, Tubes, and Fittings
Brake Release/Free-Wheeling Valve
Tires and Wheels
Ground Strap
Lower Control Station
Operating Controls
Emergency Stop
Lowering Alarm
Emergency Lowering System
Structures
Weldments
Rollers and Slide Blocks
Fasteners
Upper Control Station
Guardrail System
Platform Extension
Operating Controls
Emergency Stop
Horn Button
Lowering Alarm
Drive Alarm
Electrical Power Outlet
Flashing Light
Perimeter Lights
Pipe Rack
Panel Carrier
Placards and Decals
Prestart Inspection Checklist
Chapter 9 – Operation
Preparing for Operation
Lower Controls
Upper Controls
Removable Upper Controls/Side Drive
Platform
Raising and Lowering
Lowering Interrupt – CE/AS/NZS
Overload Protection
Extending
Fold Down Guardrails
Driving and Steering
Drive Range Switch
Drive Speeds
Progressive Tilt
Swing-Out Trays
Pipe Rack
Snorkel Guard
Override Button
Snorkel OnSite
Perimeter Lights
After Use Each Day
Chapter 10 – Stowing and Transporting
Stowing
Transporting
Lifting With a Forklift
Winching
Driving
Hoisting
Securing for Transport
Storage
Chapter 11 – Emergency Operation
Emergency Lowering
Towing
Chapter 12 – Troubleshooting
Troubleshooting Chart
Appendix A – Glossary
Appendix B – Inspection Checklists
Limited Warranty
