Momed80
150
35,046
Snorkel Aerial Work Platform S3970RT S3370RT S2770RT Parts Manual 13579-2 2012
Brand: Snorkel
Type of Manual: Parts Manual, Electrical Schematic, Hydraulic Schematic
Model: Snorkel S3970BE, S3370BE, S2770BE, S3970RT, S3370RT, S2770RT Aerial Work Platform
Serial Number: NZ110203 and after
Part Number: 13579-2
Publication Date: 2012
Number of Pages: 130 Pages
Table of Contents
General Specifications
Maintenance Information
Auto Level System
Section 1. - Repair Parts
Section 2. - Hydraulics
Section 3. - Electrical
Section 4. - General Options
Section 4. - 24Volt DC Option
Section 1
Chassis assembly 1-2
Chassis assembly drawing 1-3
Chassis assembly drawing, no stabilisers 1-4
Chassis assembly no stabilisers 1-5
Steer axle assembly 1-6
Steer axle assembly drawing 1-7
Articulating axle assembly drawing 1-8
Articulating axle assembly 1-9
Control & hydraulic cabinet assembly 1-10
Control & hydraulic cabinet assemblydrawing 1-11
Engine cabinet assembly drawing 1-12
Engine cabinet assembly 1-13
Emergency lower S3970RT, S3370RT 1-14
Emergency lower drawing, S3970RT, S3370RT 1-15
Emergency lower S2770RT 1-16
Emergency lower drawing, S2770RT 1-17
Scissor stack tees S3970RT, & S3370RT 1-19
Scissor stack assembly S3970RT 1-20
Scissor stack assembly drawing S3970RT 1-21
Scissor stack assembly drawing S3370RT 1-22
Scissor stack assembly S3370RT 1-23
Scissor stack assembly S2770RT 1-24
Scissor stack assembly drawing S2770RT 1-25
Stabiliser assembly 1-28
Stabiliser assembly drawing 1-29
Platform assembly drawing 1-30
Platform assembly 1-31
Platform assembly, rails permanently attached 1-32
Platform assembly drawing(Rails permanently attached) 1-33
Base, stack, platform, assembly drawing 1-34
Base, stack, platform assembly 1-35
Fuel tank assembly, diesel fuel 1-36
Upper control box mounting assembly 1-37
Placards and decals installation 1-38
Placards and decals drawing 1-39
Cabinet assembly 1-40
Cabinet assembly drawing 1-41
Engine assembly drawing,Kubota D902 with Hayes coupling 1-42
Engine assembly, Kubota, Hayes coupling 1-43
Engine assembly, Kubota, Guardian coupling 1-44
Engine assembly drawing,Kubota D902 with Guardian coupling 1-45
Section 2
Hydraulic assembly 2-2
4 wheel drive hydraulic schematic drawing 2-3
Hose Part Numbers and Colour Codes 2-5
Hose part numbers and colour codes 2-5
Manifold assembly, main 2-6
Manifold assembly, main drawing 2-7
Manifold assembly, 4 wheel drive 2-8
Manifold assembly, stabilisers 2-9
Hydraulic oil tank assembly 2-10
Hydraulic oil tank assembly drawing 2-11
Steer axle cylinder 2-12
Axle cylinder 2-13
Main lift cylinder assembly 2-14
Stabiliser Cylinder 2-15
Section 3
Looms 3-2
Electrical schematic drawing,auto level & overload 3-3
Colour coded wiring circuit 3-4
Ground control box assembly drawing 3-6
Ground control box assembly 3-7
Ground box 3-8
Ground box drawing - sheet 1 3-9
Ground box drawing - sheet 2 3-10
Platform control box assembly 3-12
Platform Control Box Assembly drawingSheet 1 3-13
Platform Control Box Assembly drawingSheet 2 3-14
Section 4
AC outlet at platform, 230 volt 4-2
AC outlet at platform 230V drawing 4-3
Flashing light installation 4-4
Fuel gauge option 4-5
4-6
24Volt DC Option 4-7
Colour coded wiring schematic,24VDC option 4-9
Control & hydraulic cabinet assembly - 24VDC 4-10
Control & hydraulic cabinet assemblydrawing, 24VDC option 4-11
Battery box assembly drawing, 24VDC option 4-12
Battery box assembly - 24VDC option 4-13
Battery box mounting - 24VDC option 4-14
Emergency bleed down mounting, 24VDC 4-15
Relay box assembly, 24VDC option 4-16
Relay box assembly drawing, 24VDC option 4-17
Unloader valve 24VDC option 4-18
Parts index - Page locator
