Momed80
150
35,046
Snorkel Aerial Work Platform S2770RT to S3970RT Operators Manual 15124-1 2024
Brand: Snorkel
Model: Snorkel S3970RT, S3370RT, S2770RT, S3970BE, S3370BE, S2770BE Aerial Work Platform
Part Number: 15124-1
Publication Date: 2024
Number of Pages: 78 Pages
Chapter 1 – Introduction
Aerial Platform Features
Options
Operator’s Manual
Safety Alerts
Operation
Maintenance
Manual of Responsibilities – ANSI
MEWP Safe Use – AS/NZS
AS/NZS 141810 Commissioning
CE Compliance
Additional Information
Chapter 2 – Specifi cations
Component Identifi cation
General Specifi cations – S2770RT
General Specifi cations – S3370RT
General Specifi cations – S3970RT
Chapter 3 – Safety
Electrocution Hazards
Minimum Safe Approach Distance – ANSI
Minimum Safe Approach Distance – AS/NZS
Platform Capacity
Manual Force
Wind Speeds
Prestart Inspection
Work Place Inspection and Practices
Operation
Tip-Over and Falling Hazards
Placards and Decals
General Safety Rules
Engine and Fuel Handling Precautions
Chapter 4 – Safety Devices
Safety Device Information
Emergency Stop Switches
Upper Controls
Lower Controls
Alarms
Lowering
Drive (reverse)
Drive (forward)
Load Sensing System
Level Sensor
Dual Tilt Limits
Primary Fall Restraint System
Safety Prop
Swinging Gate
Interlock Switch
Bubble Level
Operator Horn
Stabilisers
Rough Terrain Scissor Interlock Test
Enable Switch (Lower Controls Only)
RCD/ELCB Outlet (Option)
Electrical Power Outlet (Option)
Flashing Light
Fall Restraint Lanyard Anchor Points
Chapter 5 – Gauges and Displays
Diagnostic Center Display
Platform Overload/Lift Enable Lights
Warning Light
Hydraulic Oil Tank
Chapter 6 – Controls
Battery Disconnect
Lower Controls
Emergency Stop Button
Control Selector
Ground Operation Switch
Platform Raise/Lower Switch
Lift Indicator Light
Platform Overload Indicator Light
Choke Switch/Glow Plug Switch
Start Switch
Fuel/Electric Switch
Upper Controls
Drive/Lift Selector Switch
Joystick
Interlock Switch
Steer Switch
Drive Range Switch
Horn Button
Stabiliser Manual Switches
Auto Level/Stow Switch
Drive Indicator Light
Warning Light
Start Switch
Chapter 7 – Prestart Inspection
Operator’s Manual
Safety Prop
Cables and Wiring Harness
Fluid Level
Hoses, Tubes, and Fittings
Free-Wheeling Valve
Tires and Wheels
Lower Control Station
Operating Controls
Emergency Stop
Lowering Alarm
Stabiliser Interlock Test
Stabiliser Locked Out When Platform Elevated
Elevation Locked Out When Axles Not Stowed
Elevation Locked Out When Tilted Test
Emergency Lowering System
Structures
Weldments
Rollers and Slide Blocks
Fasteners
Upper Control Station
Guardrail System
Platform Extension
Operating Controls
Emergency Stop
Horn Button
Lowering Alarm
Drive Alarm
Flashing Light
Placards and Decals
Prestart Inspection Checklist
Chapter 8 – Operation
Preparing for Operation
Lower Controls
Upper Controls
Platform
Raising and Lowering
Lowering Interrupt – CE/AS/NZS
Overload Protection
Extending
Fold Down Guardrails
Driving and Steering
Drive Range Switch
Drive Speeds
Drive/Lift Pothole Protector Interlock
Drive/Lift Level Sensor Interlock
After Use Each Day
Stabilisers
Operating The Stabilisers Manually
To Set The Stabilisers
To Raise The Stabilisers
Operating The Auto Level System
Setting The Stabilisers Automatically
Raising The Stabilisers Automatically
The Risk Of Operating Outriggers On Slopes
Snorkel OnSite
Chapter 9 – Stowing and Transporting
Stowing
Transporting
Lifting With a Forklift
Winching
Driving
Hoisting
Securing for Transport
Storage
Chapter 10 – Emergency Operation
Emergency Lowering
Towing
Chapter 11 – Troubleshooting
Troubleshooting Chart
Appendix A – Glossary
Appendix B – Inspection Checklists
Limited Warranty
