Momed80
150
35,046
Snorkel Aerial Work Platform S2755BE to S2255RT Repair Parts Manual 13715-2
Brand: Snorkel
Type of Manual: Repair Parts Manual, Electrical Diagram
Model: Snorkel S2755BE S2255BE S2755RT S2255RT Aerial Work Platform
Serial Number: S2755RT-07-000001 and after
Part Number: 13715-2
Publication Date: 2012
Number of Pages: 112 Pages
Table of Contents
General Specifications
Maintenance Information
Auto Level System
Section 1. - Repair Parts
Section 2. - Hydraulics
Section 3. - Electrical
Section 4. - Options
Section 4 - 24VDC Option
Section 1
Cabinet assembly 1-2
Cabinet assembly drawing 1-3
Steer axle assembly drawing 1-4
Steer axle assembly 1-5
Articulating axle assembly 1-6
Articulating axle assembly drawing 1-7
Control cabinet assembly drawing 1-8
Control cabinet assembly 1-9
Fuel cabinet assembly 1-10
Fuel cabinet assembly drawing 1-11
Engine assembly drawing, Kubota D902 1-12
Engine assembly, Kubota D902 1-13
Cable operated emergency bleed down 1-14
Cable operated bleed down drawing 1-15
Scissor stack S2255RT 1-16
Scissor atack drawing, SR2255 1-17
Scissor stack drawing, SR2755 1-18
Scissor stack S2755RT 1-19
Stabiliser assembly 1-20
Stabiliser assembly drawing 1-21
Platform assembly drawing 1-22
Platform assembly 1-23
Engine cabinet assembly 1-24
Engine cabinet assembly drawing 1-25
Fuel tank assembly, diesel fuel 1-26
Upper control box mounting assembly 1-27
Placards and decals installation 1-28
Placards and decals drawing 1-29
Section 2
Hose part numbers and colour codes 2-3
Hydraulic assembly 2-4
Hydraulic schematic drawing 2-5
Manifold assembly 2-8
Manifold assembly 2-9
Manifold assembly, 4WD 2-10
Manifold assembly, stabilisers 2-11
Hydraulic oil tank assembly 2-12
Hydraulic oil tank assembly drawing 2-13
Steer axle cylinder 2-14
Axle cylinder 2-15
Main lift cylinder assembly 2-16
Stabiliser Cylinder 2-17
Section 3
Looms 3-2
Electrical schematic drawing, auto level 3-3
Colour coded wiring circuit auto level 3-4
Ground control box assembly drawing 3-6
Ground control box assembly 3-7
Ground box 3-8
Ground box drawing - sheet 1 3-9
Ground box drawing - sheet 2 3-10
Platform control box assembly 3-12
Platform Control Box Assembly drawingSheet 1 3-13
Platform Control Box Assembly drawingSheet 2 3-14
Section 4
AC outlet at platform, 230 volt 4-2
AC outlet at platform 230V drawing 4-3
Flashing light installation 4-4
24VDC Option 4-5
Colour coded wiring schematic,24VDC option 4-7
Control & hydraulic cabinet assembly - 24VDC 4-8
Control & hydraulic cabinet assemblydrawing 24VDC option 4-9
Battery box assembly drawing, 24VDC option 4-10
Battery box assembly - 24VDC option 4-11
Battery box mounting - 24VDC option 4-12
Emergency bleed down mounting, 24VDC 4-13
Relay box assembly, 24VDC option 4-14
Relay box assembly drawing, 24VDC option 4-15
Unloader valve 24VDC option 4-16
Parts index - Page locator
A
D
G
I
J
K
L
M
N
O
P
S
T
W
