Momed80
150
35,046
Snorkel Aerial Work Platform S2255RTE S2755RTE Operations Manual 15382-1
Brand: Snorkel
Type of Manual: Manual
Model: Snorkel S2255RTE S2755RTE Lithium-Ion V1 Operations Aerial Work Platform
Part Number: 15382-1
Publication Date: 2024
Number of Pages: 78 Pages
Chapter 1 – Introduction
Aerial Platform Features
Options
Operator’s Manual
Safety Alerts
Operation
Maintenance
Manual of Responsibilities – ANSI
MEWP Safe Use – AS/NZS
AS/NZS 141810 Commissioning
Additional Information
Chapter 2 – Specifi cations
Component Identifi cation
General Specifi cations – S2255RTE
General Specifi cations – S2755RTE
Chapter 3 – Safety
Electrocution Hazards
Minimum Safe Approach Distance – ANSI
Minimum Safe Approach Distance – AS/NZS
Platform Capacity
Manual Force
Wind Speeds
Prestart Inspection
Work Place Inspection and Practices
Operation
Tip-Over and Falling Hazards
Placards and Decals
General Safety Rules
Chapter 4 – Safety Devices
Safety Device Information
Emergency Stop Switches
Upper Controls
Lower Controls
Alarms
Lowering
Drive (reverse)
Drive (forward)
Load Sensing System
Level Sensor
Dual Tilt Limits
Primary Fall Restraint System
Safety Prop
Swinging Gate
Interlock Switch
Bubble Level
Operator Horn
Stabilisers
Rough Terrain Scissor Interlock Test
Enable Switch (Lower Controls Only)
RCD/ELCB Outlet (Option)
Chapter 5 – Gauges and Displays
Diagnostic Center Display
Platform Overload/Lift Enable Lights
Warning Light
Hydraulic Oil Tank
Chapter 6 – Batteries
General Maintenance
Charging
Chapter 7 – Controls
Battery Disconnect
Lower Controls
Emergency Stop Button
Control Selector
Ground Operation Switch
Platform Raise/Lower Switch
Lift Indicator Light
Platform Overload Indicator Light
Upper Controls
Drive/Lift Selector Switch
Joystick
Interlock Switch
Steer Switch
Drive Range Switch
Horn Button
Battery Condition/State Of Charge Indicator
Stabiliser Manual Switches
Auto Level/Stow Switch
Drive Indicator Light
Warning Light
Chapter 8 – Prestart Inspection
Operator’s Manual
Battery Terminals
Battery Charger
Safety Prop
Cables and Wiring Harness
Fluid Level
Hoses, Tubes, and Fittings
Free-Wheeling Valve
Tires and Wheels
Lower Control Station
Operating Controls
Emergency Stop
Lowering Alarm
Stabiliser Interlock Test
Stabiliser Locked Out When Platform Elevated
Elevation Locked Out When Axles Not Stowed
Elevation Locked Out When Axles Tilted
Emergency Lowering System
Structures
Weldments
Rollers and Slide Blocks
Fasteners
Upper Control Station
Guardrail System
Platform Extension
Operating Controls
Emergency Stop
Horn Button
Lowering Alarm
Drive Alarm
Electrical Power Outlet
Flashing Light
Placards and Decals
Prestart Inspection Checklist
Chapter 9 – Operation
Preparing for Operation
Lower Controls
Upper Controls
Platform
Raising and Lowering
Lowering Interrupt – CE/AS/NZS
Overload Protection
Extending
Fold Down Guardrails
Driving and Steering
Drive Range Switch
Drive Speeds
Drive/Lift Pothole Protector Interlock
Drive/Lift Level Sensor Interlock
After Use Each Day
Stabilisers
Operating The Stabilisers Manually
To Set The Stabilsers
To Raise The Stabilsers
Operating The Auto Level System
Setting The Stabilisers Automatically
Raising The Stabilisers Automatically
The Risk Of Operating Outriggers On Slopes
Snorkel OnSite
Chapter 10 – Stowing and Transportin
Stowing
Transporting
Lifting With a Forklift
Winching
Driving
Hoisting
Securing for Transport
Storage
Chapter 11 – Emergency Operation
Emergency Lowering
Towing
Chapter 12 – Troubleshooting
Troubleshooting Chart
Appendix A – Glossary
Appendix B – Inspection Checklists
Limited Warranty
