Momed80
150
35,046
Snorkel Aerial Work Platform S2255RT S2255BE S2755R S2755BE Operators Manual 14047-1
Brand: Snorkel
Model: Snorkel S2255RT S2255BE S2755R S2755BE Aerial Work Platform
Serial Number: S2255RT-07-000100, S2755RT-07-000100 and after
Part Number: 14047-1
Publication Date: August 201 (Rev B)
Number of Pages: 79 Pages
Electrical Hazard
Electrical Hazard Warning
Introduction
Standard S3970RT/S3370RT/S2770RT Version I
Options
Operation Manual
Photographs
Safety Alerts
Operation
Maintenance
Responsibilities of Parties
Product Warranty
Additional Information
1 Safety
Safe Operation
Electrocution Hazards
Pre-start Inspection
Workplace Inspection and Practices
Operation
Tipover and Falling Hazards
General Safety Precautions
Hydraulic System Precautions
Fire / Explosion Prevention
Engine and Fuel Handling Precautions
Batteries
Safety Placards and Decals
Safety Placards and Decals Location
2 Safety Devices
Safety Device Information
Emergency Stop Switches
At platform control box
At ground control box
Alarms
Lowering
High temperature
Low oil pressure
Alternator not charging
Drive (reverse)
Drive (forward)
Load Sensing System
Level sensor
Primary Fall Restraint System
Safety Prop
Swinging Gate
Safety Control
Bubble Level
Operator Horn
Stabilisers (Option)
Rough Terrain Scissor Interlock Tests
Enable switch
RCD / ELCB AC Outlet (Option)
Flashing Light
Fall Restraint Lanyard Anchor Points (Option)
3 Specifications
General Specifications Standard Machine
S3970RT
S3370RT
S2770RT
Engine Data
DF752 (option)
D902
Machine Component Identification
4 Gauges
EZCal LCD Display
Water
Oil Pressure
Hours
Work time
Total time
Engine Oil
Hydraulic Oil Level
Bubble level
5 Automatic Shut-offs and Circuit Breakers
Automatic Shut-offs
Level sensor
Engine Temperature
Engine oil pressure
Platform height vs drive speed
Dynamic brakes
Load sensing system
Stabilisers
Fuses
RCD / ELCB outlet (option)
6 Controls
Controls
Hydraulic Compartment
Ground Control Box
Platform Control Box
7 Daily Inspection and Maintenance
Daily Inspection and Maintenance Table
Stabiliser locked out when platform not
elevated test
Elevation locked out when axles not
stowed test
Elevation locked out when tilted test
Fuel Level
Fuel filter (diesel engines only)
Fuel Leaks
Engine Oil
Engine Coolant
Radiator Cap
Swinging Gate
Wiring Harnesses and Connectors
Battery Terminals
Battery fluid level
Hydraulic Oil Tank
Hydraulic tank cap
Hydraulic oil level
Hydraulic Oil Leaks
Tires and Wheels
Bolts and Fasteners
Structural Damage and Welds
Bubble Level
Guides, Rollers and Slides
Ground Controls
Flashing Light
Platform Controls
Emergency Lowering
RCD / ELCB (Option)
Safety Prop
Non-Slip Tread Grip
Wrist Support
Operator Manual
Placards and Decals
8 Operation
Operating Procedures
Control Stations
Emergency Stopping
Operation Considerations
Operating From The Ground Control Box
Raising the platform
Operating From The Platform Control Box
Driving
Variable maximum drive speed
Ramp off
Stabilisers
Operating The Stabilisers Manually
To set the stabilisers
To raise the stabilisers
Operating The Auto Level System
Setting the stabilisers automatically
Raising the stabilisers automatically
The Risk of Operating Scissor Lifts on
Outriggers on Ramps and Slopes
Extending The Multi-Position Platform
9 Emergency Operation
Emergency Operation Procedures
Emergency Stop
Emergency Bleed Down
Pushing / Towing
10 Stowing and Transporting
Stowing
To lock the machine
Transporting
Trailering
Securing to a transport vehicle
Towing
Lifting
Pushing
Winching procedure
Long Term Storage
11 Options
Bi-Energy Option
DC motor
DC motor operation
Master battery isolator switches
Batteries
Battery charger
Batteries - general maintenance
Batteries - charging
Gasoline / LPG Fuel Option
Fuel level
LPG tank gauges and fuel level
RCD / ELCB Outlet
Electrical Outlet
Non-Marking Tyres
Alternative Power Options
Stabilisers
12 Fire Fighting and Chemical Containment
Hazardous Components
Antifreeze (UN 1993)
Battery lead / acid (UN 2794)
Diesel fuel (NA 1993)
Foam in tyres
Gasoline (UN 1203)
Hydraulic oil (UN 1270)
Liquefied petroleum gas (UN 1075)
Motor oil (UN 1270)
