Snorkel Aerial Work Platform AB85J A85JRT - CE Operators Manual 0421590 2014
Brand: Snorkel
Model: Snorkel AB85J A85JRT - CE Aerial Work Platform
Serial Number: 000000 and after
Part Number: 0421590
Publication Date: 2014
Number of Pages: 26 Pages
Chapter 1 – Introduction
Aerial Platform Features
Options
Operator’s Manual
Safety Alerts
Operation
Maintenance
Manual of Responsibilities
Additional Information
Chapter 2 – Specifications
Component Identification
Working Envelope
General Specifications
Aerial Platform
Platform
Function Speed
Drive System
Tires
Ambient Air Temperature Operating Range
Maximum Wind Speed
Electrocution Hazards
Minimum Safe Approach Distance
Prestart Inspection
Work Place Inspection and Practices
Operation
Tip-Over and Falling Hazards
Placards and Decals
Chapter 4 – Safety Devices
Emergency Stop Controls
Emergency Power System
Ground Operation Switch
Platform Foot Switch
Guardrails
Lanyard Anchors
Tilt Alarm
Ground Fault Circuit Interrupter
Horn
Drive Motion Alarm
Lowering Alarm
Flashing Light
Chapter 5 – Gauges and Displays
Hour Meter
Battery Level Indicator
Battery Charge Indicator
Hydraulic Fluid Filter Gauge
Fluid Level Sight Gauge
Chapter 6 – Batteries
General Maintenance
Charging
Chapter 7 – Controls
Battery Disconnect Switch
Lower Controls
Start Switch
Emergency Stop Button
Controls Selector Switch
Rotation Switch
Riser Switch
Boom Elevation Switch
Boom Extension Switch
Jib Articulation Switch
Platform Level Switch
Platform Rotation Switch
Emergency Power Switch
Circuit Breaker Reset Buttons
Upper Controls
Start Switch
Drive Joystick
Drive Range Switch
Boom Speed Knob
Rotation Switch
Riser Switch
Horn
Operator’s Manual Holder
Battery Fluid Level
Battery Terminals
Battery Charger
Cables and Wiring Harness
Fluid Level
Fluid Filter
Hoses, Tubes, and Fittings
Tires and Wheels
Air Filled
Foam Filled
Lower Control Station
Operating Controls
Emergency Stop
Emergency Power
Level Sensor
Flashing Light
Structures
Weldments
Boom Slide Pads
Fasteners
Upper Control Station
Guardrail System
Lanyard Anchors
Operating Controls
Emergency Stop
Emergency Power
Horn
Electrical Power Outlet
Drive Motion Alarm
Lowering Alarm
Placards and Decals
Prestart Inspection Checklist
Chapter 9 – Operation
Cold Weather Start-Up
Manually Warming the Hydraulic System
Preparing for Operation
Lower Controls
Upper Controls
Boom Operation
Driving and Steering
Drive Speeds
Motion Warning Alarm
Gradeability
Theoretical Gradeability
Actual Gradeability
Percent vs. Degree of Slope
Driving on a Slope
Calculating Percent Grade
Machine Gradeability
Air Line
Chapter 10 – Stowing and Transporting
Stowing
Transporting
Driving
Winching
Hoisting
Securing for Transport
Lower Controls
Upper Controls
Towing
Chapter 12 – Troubleshooting
Troubleshooting Chart
Options
Operator’s Manual
Safety Alerts
Operation
Maintenance
Working Envelope
Aerial Platform
Platform
Function Speed
Drive System
Tires
Maximum Wind Speed
Prestart Inspection
Operation
Placards and Decals
Guardrails
Lanyard Anchors
Tilt Alarm
Horn
Drive Motion Alarm
Lowering Alarm
Flashing Light
Hour Meter
General Maintenance
Charging
Lower Controls
Start Switch
Rotation Switch
Riser Switch
Upper Controls
Start Switch
Drive Joystick
Drive Range Switch
Boom Speed Knob
Rotation Switch
Riser Switch
Horn
Battery Fluid Level
Battery Terminals
Battery Charger
Fluid Level
Fluid Filter
Tires and Wheels
Air Filled
Foam Filled
Operating Controls
Emergency Stop
Emergency Power
Level Sensor
Flashing Light
Structures
Weldments
Boom Slide Pads
Fasteners
Guardrail System
Lanyard Anchors
Operating Controls
Emergency Stop
Emergency Power
Horn
Drive Motion Alarm
Lowering Alarm
Placards and Decals
Lower Controls
Upper Controls
Boom Operation
Drive Speeds
Gradeability
Actual Gradeability
Driving on a Slope
Air Line
Stowing
Transporting
Driving
Winching
Hoisting
Lower Controls
Upper Controls
Towing
Options
Operator’s Manual
Safety Alerts
Operation
Maintenance
Working Envelope
Aerial Platform
Platform
Function Speed
Drive System
Tires
Maximum Wind Speed
Prestart Inspection
Operation
Placards and Decals
Guardrails
Lanyard Anchors
Tilt Alarm
Horn
Drive Motion Alarm
Lowering Alarm
Flashing Light
Hour Meter
General Maintenance
Charging
Lower Controls
Start Switch
Rotation Switch
Riser Switch
Upper Controls
Start Switch
Drive Joystick
Drive Range Switch
Boom Speed Knob
Rotation Switch
Riser Switch
Horn
Battery Fluid Level
Battery Terminals
Battery Charger
Fluid Level
Fluid Filter
Tires and Wheels
Air Filled
Foam Filled
Operating Controls
Emergency Stop
Emergency Power
Level Sensor
Flashing Light
Structures
Weldments
Boom Slide Pads
Fasteners
Guardrail System
Lanyard Anchors
Operating Controls
Emergency Stop
Emergency Power
Horn
Drive Motion Alarm
Lowering Alarm
Placards and Decals
Lower Controls
Upper Controls
Boom Operation
Drive Speeds
Gradeability
Actual Gradeability
Driving on a Slope
Air Line
Stowing
Transporting
Driving
Winching
Hoisting
Lower Controls
Upper Controls
Towing
Options
Operator’s Manual
Safety Alerts
Operation
Maintenance
Working Envelope
Aerial Platform
Platform
Function Speed
Drive System
Tires
Maximum Wind Speed
Prestart Inspection
Operation
Placards and Decals
Guardrails
Lanyard Anchors
Tilt Alarm
Horn
Drive Motion Alarm
Lowering Alarm
Flashing Light
Hour Meter
General Maintenance
Charging
Lower Controls
Start Switch
Rotation Switch
Riser Switch
Upper Controls
Start Switch
Drive Joystick
Drive Range Switch
Boom Speed Knob
Rotation Switch
Riser Switch
Horn
Battery Fluid Level
Battery Terminals
Battery Charger
Fluid Level
Fluid Filter
Tires and Wheels
Air Filled
Foam Filled
Operating Controls
Emergency Stop
Emergency Power
Level Sensor
Flashing Light
Structures
Weldments
Boom Slide Pads
Fasteners
Guardrail System
Lanyard Anchors
Operating Controls
Emergency Stop
Emergency Power
Horn
Drive Motion Alarm
Lowering Alarm
Placards and Decals
Lower Controls
Upper Controls
Boom Operation
Drive Speeds
Gradeability
Actual Gradeability
Driving on a Slope
Air Line
Stowing
Transporting
Driving
Winching
Hoisting
Lower Controls
Upper Controls
Towing
Introduction
Special Limitations
Platform Capacity
Manual Force
Platform Overload Sensing System
Beaufort Scale
Controls and Indicators
Figure 2 – Battery Disconnect Switch
Figure 3 – Lower Controls and Indicators
Figure 4 – Upper Controls and Indicators
Pre-Operation Safety Inspection
System Function Inspection
Operation
Engine Cold Weather Start Kit
Hydraulic System Cold Weather Warm-Up
Lower Controls
Upper Controls
Boom Operation
Drive Speeds
AC Generator
Air Line
Driving Lights
Platform Work Lights
Emergency Lowering
After Use Each Day
Transporting the Machine
Preparing for Transportation
By Crane
By Truck
Maintenance
Hydraulic Fluid
Check Hydraulic Fluid
Oil Level
Battery Maintenance
Inspection and Maintenance Schedule
Daily Preventative Maintenance Checklist
Preventative Maintenance Report
Decal Location
Specifications
Aerial Platform
Platform
Function Speed
Drive System
Tires
Fuel Tank Capacity
Maximum Wind Speed
Working Envelope
Brand: Snorkel
Options
Operator’s Manual
Safety Alerts
Operation
Maintenance
Working Envelope
Aerial Platform
Platform
Function Speed
Drive System
Tires
Maximum Wind Speed
Prestart Inspection
Operation
Placards and Decals
Guardrails
Lanyard Anchors
Tilt Alarm
Horn
Drive Motion Alarm
Lowering Alarm
Flashing Light
Hour Meter
General Maintenance
Charging
Lower Controls
Start Switch
Rotation Switch
Riser Switch
Upper Controls
Start Switch
Drive Joystick
Drive Range Switch
Boom Speed Knob
Rotation Switch
Riser Switch
Horn
Battery Fluid Level
Battery Terminals
Battery Charger
Fluid Level
Fluid Filter
Tires and Wheels
Air Filled
Foam Filled
Operating Controls
Emergency Stop
Emergency Power
Level Sensor
Flashing Light
Structures
Weldments
Boom Slide Pads
Fasteners
Guardrail System
Lanyard Anchors
Operating Controls
Emergency Stop
Emergency Power
Horn
Drive Motion Alarm
Lowering Alarm
Placards and Decals
Lower Controls
Upper Controls
Boom Operation
Drive Speeds
Gradeability
Actual Gradeability
Driving on a Slope
Air Line
Stowing
Transporting
Driving
Winching
Hoisting
Lower Controls
Upper Controls
Towing
Options
Operator’s Manual
Safety Alerts
Operation
Maintenance
Working Envelope
Aerial Platform
Platform
Function Speed
Drive System
Tires
Maximum Wind Speed
Prestart Inspection
Operation
Placards and Decals
Guardrails
Lanyard Anchors
Tilt Alarm
Horn
Drive Motion Alarm
Lowering Alarm
Flashing Light
Hour Meter
General Maintenance
Charging
Lower Controls
Start Switch
Rotation Switch
Riser Switch
Upper Controls
Start Switch
Drive Joystick
Drive Range Switch
Boom Speed Knob
Rotation Switch
Riser Switch
Horn
Battery Fluid Level
Battery Terminals
Battery Charger
Fluid Level
Fluid Filter
Tires and Wheels
Air Filled
Foam Filled
Operating Controls
Emergency Stop
Emergency Power
Level Sensor
Flashing Light
Structures
Weldments
Boom Slide Pads
Fasteners
Guardrail System
Lanyard Anchors
Operating Controls
Emergency Stop
Emergency Power
Horn
Drive Motion Alarm
Lowering Alarm
Placards and Decals
Lower Controls
Upper Controls
Boom Operation
Drive Speeds
Gradeability
Actual Gradeability
Driving on a Slope
Air Line
Stowing
Transporting
Driving
Winching
Hoisting
Lower Controls
Upper Controls
Towing
Options
Operator’s Manual
Safety Alerts
Operation
Maintenance
Working Envelope
Aerial Platform
Platform
Function Speed
Drive System
Tires
Maximum Wind Speed
Prestart Inspection
Operation
Placards and Decals
Guardrails
Lanyard Anchors
Tilt Alarm
Horn
Drive Motion Alarm
Lowering Alarm
Flashing Light
Hour Meter
General Maintenance
Charging
Lower Controls
Start Switch
Rotation Switch
Riser Switch
Upper Controls
Start Switch
Drive Joystick
Drive Range Switch
Boom Speed Knob
Rotation Switch
Riser Switch
Horn
Battery Fluid Level
Battery Terminals
Battery Charger
Fluid Level
Fluid Filter
Tires and Wheels
Air Filled
Foam Filled
Operating Controls
Emergency Stop
Emergency Power
Level Sensor
Flashing Light
Structures
Weldments
Boom Slide Pads
Fasteners
Guardrail System
Lanyard Anchors
Operating Controls
Emergency Stop
Emergency Power
Horn
Drive Motion Alarm
Lowering Alarm
Placards and Decals
Lower Controls
Upper Controls
Boom Operation
Drive Speeds
Gradeability
Actual Gradeability
Driving on a Slope
Air Line
Stowing
Transporting
Driving
Winching
Hoisting
Lower Controls
Upper Controls
Towing
Options
Operator’s Manual
Safety Alerts
Operation
Maintenance
Working Envelope
Aerial Platform
Platform
Function Speed
Drive System
Tires
Maximum Wind Speed
Prestart Inspection
Operation
Placards and Decals
Guardrails
Lanyard Anchors
Tilt Alarm
Horn
Drive Motion Alarm
Lowering Alarm
Flashing Light
Hour Meter
General Maintenance
Charging
Lower Controls
Start Switch
Rotation Switch
Riser Switch
Upper Controls
Start Switch
Drive Joystick
Drive Range Switch
Boom Speed Knob
Rotation Switch
Riser Switch
Horn
Battery Fluid Level
Battery Terminals
Battery Charger
Fluid Level
Fluid Filter
Tires and Wheels
Air Filled
Foam Filled
Operating Controls
Emergency Stop
Emergency Power
Level Sensor
Flashing Light
Structures
Weldments
Boom Slide Pads
Fasteners
Guardrail System
Lanyard Anchors
Operating Controls
Emergency Stop
Emergency Power
Horn
Drive Motion Alarm
Lowering Alarm
Placards and Decals
Lower Controls
Upper Controls
Boom Operation
Drive Speeds
Gradeability
Actual Gradeability
Driving on a Slope
Air Line
Stowing
Transporting
Driving
Winching
Hoisting
Lower Controls
Upper Controls
Towing
Introduction
Special Limitations
Platform Capacity
Manual Force
Beaufort Scale
Operation
Lower Controls
Upper Controls
Boom Operation
Drive Speeds
AC Generator
Air Line
Driving Lights
Emergency Lowering
After Use Each Day
By Crane
By Truck
Maintenance
Hydraulic Fluid
Oil Level
Battery Maintenance
Decal Location
Specifications
Aerial Platform
Platform
Function Speed
Drive System
Tires
Fuel Tank Capacity
Maximum Wind Speed
Working Envelope
