Momed80
150
35,046
Snorkel Aerial Work Platform AB80J AB85J Operators Manual 0420453 2024
Brand: Snorkel
Model: Snorkel AB80J AB85J Aerial Work Platform
Part Number: 0420453
Publication Date: 2024
Number of Pages: 106 Pages
Electrical Danger Inside Front Cover
Proposition 65 Warning Inside Front Cover
Danger Symbols Inside Front Cover
Fall Restraint Lanyard Anchor Points Inside Front Cover
Safety Rules Inside Front Cover
Chapter 1 – Introduction
Aerial Platform Features
Options
Operator’s Manual
Safety Alerts
Operation
Maintenance
Used Material Disposal
Manual of Responsibilities – ANSI
MEWP Safe Use – AS/NZS
AS/NZS 141810 Commissioning
CE Compliance
Additional Information
Chapter 2 – Specifications
Component Identification
Working Envelope – AB80J
Working Envelope – AB85J
General Specifications – AB80J
General Specifications – AB85J
Engine Specifications
Engine Oil Viscosity
Chapter 3 – Safety
Electrocution Hazards
Minimum Safe Approach Distance – ANSI
Minimum Safe Approach Distance – AS/NZS
Platform Capacity
Manual Force
Wind Speeds
Prestart Inspection
Work Place Inspection and Practices
Operation
Tip-Over and Falling Hazards
Engine and Fuel Handling Precautions
Placards and Decals
General Safety Rules
Chapter 4 – Safety Devices
Emergency Stop Controls
Emergency Power System
Manual Emergency Lowering Pump
Ground Operation Switch
Platform Foot Switch
Guardrails
Fall Protection Anchors
Ground Fault Circuit Interrupter
Platform Overload Sensing System
Tilt Alarm/Warning Lights
Engine Protection Systems
High Engine Temperature Alarm
Low Oil Pressure Alarm
Engine Warning Light
Horn
Drive Motion Alarm
All Motion Alarm
Flashing Lights
Driving Lights
Platform Work Lights
Snorkel Guard
Chapter 5 – Gauges and Displays
Diagnostic Center/Engine Display
Hour Meter
Platform Overload/Tilt Warning Lights
Engine Temperature Gauge
Ammeter
Voltmeter – GM Engines
Engine Air Filter Gauge
Fuel Gauge
Engine Oil
Hydraulic Fluid Filter Gauge
Fluid Level and Temperature Gauge
Chapter 6 – Controls
Battery Disconnect Switch
Lower Controls
Start Switch
Emergency Stop Button
Controls Selector Switch
Rotation Switch
Riser Switch
Boom Elevation Switch
Boom Extension Switch
Boom Speed Knob
Jib Rotation Switch – AB85J Only
Jib Articulation Switch
Platform Level Switch
Platform Rotation Switch
Engine/Emergency Power Switch
Engine Speed Switch
Fuel Switch
Platform Overload Warning Light
Tilt Alarm
Manifold Air Inlet Heater – Deutz Only
Hydraulic Oil Warm-Up Switch
Circuit Breaker Reset Buttons 32Table of Contents
AB80J/AB85J – 0420453
Upper Controls
Start Switch
Boom Joystick
Boom Extend Joystick – AB80J
Jib Rotation/Boom Extend Joystick – AB85J
Drive Joystick
Drive Range Switch
Steer Mode Switch
Platform Rotate Switch
Throttle Switch
Horn Button
Override Switch
Tilt Alarm
AC Generator Switch
Driving and Platform Work Lights
Chapter 7 – Prestart Inspection
Operator’s Manual Holder
Tray Latch
Oil Level
Liquid Cooled Engines
Air Cooled Engines
Fuel Line
Air Filter
Charging System
Cold Weather Start Kit
Battery Fluid Level
Battery Terminals
Cables and Wiring Harness
Fluid Level
Fluid Filter
Hoses, Tubes, and Fittings
Tires and Wheels
Lower Control Station
Operating Controls
Emergency Stop
Emergency Power
Level Sensor
Flashing Light
Sandblast Protection Kit
Structures
Weldments
Boom Slide Pads
Extension Cylinder Slide Pads – AB85J
Fasteners
Upper Control Station
Guardrail System
Operating Controls
Emergency Stop
Emergency Power
Horn Switch
Snorkel Guard
Electrical Power Outlet
Platform Control Cover
Drive Motion Alarm
Air Line to Platform
Tow Kit
Platform Glazier Package
Platform Welder
Placards and Decals
Inspection and Maintenance Schedules
Prestart Inspection Checklist
Chapter 8 – Operation
Cold Weather Start-Up
Engine Cold Weather Start Kit
Cummins — Block Heater
Deutz — Manifold Preheater
GM — Radiator Hose In-Line
Hydraulic System Cold Weather Warm-Up
Hydraulic System Warm-Up Switch
Manually Warming The Hydraulic System
Preparing for Operation
Lower Controls
Upper Controls
Boom Operation
Driving and Steering
Drive Speeds
Drive Motion Alarm
Snorkel Guard
Override Switch
Gradeability
Percent vs Degree of Slope
Driving on a Slope
Calculating Percent Grade
Machine Gradeability
AC Generator
Dual Fuel
Air Line
Driving Lights
Platform Capacity
Platform Welder
Platform Capacity
