Snorkel Aerial Work Platform AB60J Operators Manual 0181972 2024
Brand: Snorkel
Model: Snorkel AB60J Aerial Work Platform
Part Number: 0181972
Publication Date: 2024
Number of Pages: 100 Pages
Electrical Danger Inside Front Cover
Proposition 65 Warning Inside Front Cover
Danger Symbols Inside Front Cover
Fall Restraint Lanyard Anchor Points Inside Front Cover
Safety Rules Inside Front Cover
Chapter 1 – Introduction
Aerial Platform Features
Options
Operator’s Manual
Safety Alerts
Operation
Maintenance
Used Material Disposal
Manual of Responsibilities – ANSI
MEWP Safe Use – AS/NZS
AS/NZS 141810 Commissioning
CE Compliance
Additional Information
Chapter 2 – Specifications
Component Identification
Working Envelope
General Specifications
Engine Specifications
Engine Oil Viscosity
Chapter 3 – Safety
Electrocution Hazards
Minimum Safe Approach Distance – ANSI
Minimum Safe Approach Distance – AS/NZS
Platform Capacity
Manual Force
Wind Speeds
Prestart Inspection
Work Place Inspection and Practices
Operation
Tip-Over and Falling Hazards
Engine and Fuel Handling Precautions
Placards and Decals
General Safety Rules
Chapter 4 – Safety Devices
Emergency Stop Controls
Emergency Power System
Emergency Lowering Knobs
Ground Operation Switch
Platform Foot Switch
Guardrails
Fall Protection Anchors
Ground Fault Circuit Interrupter
Platform Overload Sensing System
Tilt Alarm/Warning Lights
Engine Protection Systems
High Engine Temperature Alarm
Low Oil Pressure Alarm
Horn
All Motion Alarm
Flashing Lights
Driving Lights
Platform Work Lights
Bumpguard System
Snorkel Guard
Chapter 5 – Gauges and Displays
Diagnostic Center Displays
Dual Fuel Engine Display
Diagnostic Center/Engine Display
Hour Meter
Engine Temperature Gauge
Ammeter – Continental, Cummins, Ford
and Hatz Engines
Voltmeter – General Motors Engines
Engine Warning Light
Engine Air Filter Gauge
Fuel Gauge
Engine Oil
Hydraulic Fluid Filter Gauge
Fluid Level and Temperature Gauge
Chapter 6 – Controls
Battery Disconnect Switch
Lower Controls
Emergency Stop Button
Control Selector Switch
Start Switch
Rotation Switch
Riser Boom Elevation Switch
Main Boom Elevation Switch
Boom Extension Switch
Jib Articulation Switch
Boom Speed Knob
Platform Level Switch
Platform Rotation Switch
Engine/Emergency Power Switch
Throttle Switch
Fuel Switch
Hydraulic System Warm-up Switch
Circuit Breaker Reset Buttons
Upper Controls
Start Switch
Drive Joystick
Drive Range Switch
Boom Joystick
Platform Rotation Switch 34Table of Contents
AB60J – 0181972
Boom Speed Knob
Throttle Switch
Horn
Platform Overload Warning Light
Override Switch
Machine/Generator Switch
Dual Fuel
Driving and Platform Work Lights
Chapter 7 – Prestart Inspection
Operator’s Manual Holder
Oil Level
Coolant
Fuel Line
Air Filter
Charging System
Cold Weather Start Kit
Battery Fluid Level
Battery Terminals
Cables and Wiring Harness
Fluid Level
Fluid Filter
Hoses, Tubes, and Fittings
Tires and Wheels
Lower Control Station
Operating Controls
Emergency Stop
Emergency Power
Emergency Lowering
Level Sensor
Flashing Lights
Sandblast Protection Kit
Structures
Weldments
Boom Slide Pads
Fasteners
Pins
Lower Lift Cylinder Pin
Upper Control Station
Guardrail System
Operating Controls
Emergency Stop
Emergency Power
Horn
Snorkel Guard
Electrical Power Outlet
All Motion Alarm
Air Line to Platform
Tow Kit
Platform Glazier Package
Platform Control Cover
Placards and Decals
Inspection and Maintenance Schedules
Prestart Inspection Checklist
Chapter 8 – Operation
Cold Weather Start Up
Engine Cold Weather Start Kit
and Kubota— Block Heater
General Motors — Radiator Hose In-Line
Hydraulic System Cold Weather Warm-Up
Manually Warming The Hydraulic System
Preparing for Operation
Lower Controls
Upper Controls
Boom Operation
Driving and Steering
Drive Speeds
Snorkel Guard
Override Switch
Gradeability
Percent vs Degree of Slope
Driving on a Slope
Calculating Percent Grade
Machine Gradeability
All Motion Alarm
Four Wheel Drive
AC Generator
Dual Fuel
Air Line
Driving Lights
Platform Capacity
Bumpguard System
Chapter 9 – Stowing and Transporting
Stowing
Transporting
Driving
Winching
Hoisting
Securing for Transport
Storage
Chapter 10 – Emergency Operation
Lower Controls
Upper Controls
Override Switch
Riser Boom
Main Boom
Towing
Brand: Snorkel
Options
Operator’s Manual
Safety Alerts
Operation
Maintenance
CE Compliance
Working Envelope
Chapter 3 – Safety
Platform Capacity
Manual Force
Wind Speeds
Prestart Inspection
Operation
Placards and Decals
Guardrails
Horn
All Motion Alarm
Flashing Lights
Driving Lights
Bumpguard System
Snorkel Guard
Hour Meter
and Hatz Engines
Fuel Gauge
Engine Oil
Lower Controls
Start Switch
Rotation Switch
Boom Speed Knob
Throttle Switch
Fuel Switch
Upper Controls
Start Switch
Drive Joystick
Drive Range Switch
Boom Joystick
AB60J – 0181972
Boom Speed Knob
Throttle Switch
Horn
Override Switch
Dual Fuel
Oil Level
Coolant
Fuel Line
Air Filter
Charging System
Battery Fluid Level
Battery Terminals
Fluid Level
Fluid Filter
Tires and Wheels
Operating Controls
Emergency Stop
Emergency Power
Emergency Lowering
Level Sensor
Flashing Lights
Structures
Weldments
Boom Slide Pads
Fasteners
Pins
Guardrail System
Operating Controls
Emergency Stop
Emergency Power
Horn
Snorkel Guard
All Motion Alarm
Tow Kit
Placards and Decals
Lower Controls
Upper Controls
Boom Operation
Drive Speeds
Snorkel Guard
Override Switch
Gradeability
Driving on a Slope
All Motion Alarm
Four Wheel Drive
AC Generator
Dual Fuel
Air Line
Driving Lights
Platform Capacity
Bumpguard System
Stowing
Transporting
Driving
Winching
Hoisting
Storage
Lower Controls
Upper Controls
Override Switch
Riser Boom
Main Boom
Towing
