Snorkel Aerial Work Platform A46JRTE Operators Manual 516786-000 2022
Brand: Snorkel
Model: Snorkel A46JRTE Aerial Work Platform
Part Number: 516786-000
Publication Date: 2022
Number of Pages: 92 Pages
Electrical Danger Inside Front Cover
Proposition 65 Warning Inside Front Cover
Danger Symbols Inside Front Cover
Fall Restraint Lanyard Anchor Points Inside Front Cover
Safety Rules Inside Front Cover
Chapter 1 – Introduction
Aerial Platform Features
Options
Operator’s Manual
Safety Alerts
Operation
Maintenance
Used Material Disposal
Manual of Responsibilities – ANSI
MEWP Safe Use – AS/NZS
AS/NZS 141810 Commissioning
CE Compliance
Additional Information
Chapter 2 – Specifications
Component Identification
Working Envelope – Single Capacity
Working Envelope – Dual Capacity
General Specifications – Single Capacity
General Specifications – Dual Capacity
Chapter 3 – Safety
Electrocution Hazards
Minimum Safe Approach Distance – ANSI
Minimum Safe Approach Distance – AS/NZS
Platform Capacity
Manual Force
Wind Speeds
Prestart Inspection
Work Place Inspection and Practices
Operation
Tip-Over and Falling Hazards
Placards and Decals
General Safety Rules
Chapter 4 – Safety Devices
Emergency Stop Controls
Emergency Power System
Ground Operation Switch
Platform Foot Switch
Guardrails
Fall Protection Anchors
Ground Fault Circuit Interrupter (ANSI Only)
Platform Overload Sensing System
Boom/Drive Cut-out
Tilt Alarm/Warning Lights
Horn
Power Preservation System
Drive Motion Alarm
All Motion Alarm
Flashing Lights
Driving Lights
Platform Work Lights
Snorkel Guard
Chapter 5 – Gauges and Displays
Diagnostic Center Displays
Diagnostic Center LCD
Battery Charge Indicator
Platform Overload/Tilt Warning Lights
Dual Platform Capacity System
Hydraulic Fluid Filter Gauge
Hydraulic Fluid Level Sight Gauge
Power System Run LED
Power System Fault
Chapter 6 – Controls
Battery Disconnect Switch
Lower Controls
Start Button
Emergency Stop Button
Controls Selector Switch
Rotation Switch
Riser Switch
Boom Elevation Switch
Boom Extension Switch
Jib Articulation Switch
Platform Level Switch
Platform Rotation Switch
Emergency Power Switch
Platform Overload Warning Light
Dual Platform Capacity System – Option
Power LED
Circuit Breaker Reset Buttons (ANSI Only)
Upper Controls
Start Button
Drive Joystick
Steer Switch
Drive Range Switch
Boom Speed Knob
Rotation Switch
Riser Switch
Horn Switch
Override Switch
Platform Foot Switch29Table of Contents
A46JRTE – 516786-000
Tilt Alarm
Driving and Platform Work Lights
Chapter 7 – Prestart Inspection
Operator’s Manual Holder
Electric Motor / Batteries
Normal Operation
Battery Charge Point
Charging Status Indicators
Emergency Electrical System
Power System Fault
Battery Fluid Levels
Battery Terminals
Cables and Wiring Harness
Fluid Level
Fluid Filter
Hoses, Tubes, and Fittings
Tires and Wheels
Air Filled
Foam Filled
Lower Control Station
Operating Controls
Emergency Stop
Emergency Power
Flashing Lights
Structures
Weldments
Boom Slide Pads
Fasteners
Upper Control Station
Guardrail System
Operating Controls
Emergency Stop
Emergency Power
Horn Switch
Snorkel Guard
Level Sensor
Electrostatic Discharge Strap
Drive Motion Alarm
All Motion Alarm
Sandblast Protection Kit
Air Line to Platform
Tow Kit
Platform Glazier Package
Platform Welder
Placards and Decals
Prestart Inspection Checklist
Inspection and Maintenance Schedules
Chapter 8 – Operation
Cold Weather Start-Up
Manually Warming The Hydraulic System
Preparing for Operation
Lower Controls
Upper Controls
Boom Operation
Driving and Steering
Drive Speeds
Pivoting Front Axle
Drive Motion Alarm
Boom/Drive Cut-out
Snorkel Guard
Override Switch
Gradeability
Percent vs Degree of Slope
Driving on a Slope
Calculating Percent Grade
Machine Gradeability
Battery charge indicator
No signal received
Normal Operation
Battery Fault
Motor Fault
Power System Fault
Electrical Power Outlet (optional)
Air Line (Optional)
Driving Lights
Chapter 9 – Stowing and Transporting
Stowing
Transporting
Driving
Winching
Hoisting
Securing for Transport
Storage
Chapter 10 – Emergency Operation
Lower Controls
Upper Controls
Override Switch
Towing
Chapter 11 – Troubleshooting
Troubleshooting Chart
Appendix A – Glossary
Appendix C – Inspection Checklists
Limited Warranty
Brand: Snorkel
Options
Operator’s Manual
Safety Alerts
Operation
Maintenance
CE Compliance
Chapter 3 – Safety
Platform Capacity
Manual Force
Wind Speeds
Prestart Inspection
Operation
Placards and Decals
Guardrails
Boom/Drive Cut-out
Horn
Drive Motion Alarm
All Motion Alarm
Flashing Lights
Driving Lights
Snorkel Guard
Power System Fault
Lower Controls
Start Button
Rotation Switch
Riser Switch
Power LED
Upper Controls
Start Button
Drive Joystick
Steer Switch
Drive Range Switch
Boom Speed Knob
Rotation Switch
Riser Switch
Horn Switch
Override Switch
Tilt Alarm
Normal Operation
Power System Fault
Battery Terminals
Fluid Level
Fluid Filter
Tires and Wheels
Air Filled
Foam Filled
Operating Controls
Emergency Stop
Emergency Power
Flashing Lights
Structures
Weldments
Boom Slide Pads
Fasteners
Guardrail System
Operating Controls
Emergency Stop
Emergency Power
Horn Switch
Snorkel Guard
Level Sensor
Drive Motion Alarm
All Motion Alarm
Tow Kit
Platform Welder
Placards and Decals
Lower Controls
Upper Controls
Boom Operation
Drive Speeds
Pivoting Front Axle
Drive Motion Alarm
Boom/Drive Cut-out
Snorkel Guard
Override Switch
Gradeability
Driving on a Slope
No signal received
Normal Operation
Battery Fault
Motor Fault
Power System Fault
Air Line (Optional)
Driving Lights
Stowing
Transporting
Driving
Winching
Hoisting
Storage
Lower Controls
Upper Controls
Override Switch
Towing
Limited Warranty
