Snorkel Aerial Work Platform A46JRTE Operators Manual 0261665-000 2024
Brand: Snorkel
Model: Snorkel A46JRTE Aerial Work Platform
Part Number: 0261665-000
Publication Date: 2024
Number of Pages: 94 Pages
Electrical Danger Inside Front Cover
Proposition 65 Warning Inside Front Cover
Danger Symbols Inside Front Cover
Fall Restraint Lanyard Anchor Points Inside Front Cover
Safety Rules Inside Front Cover
Chapter 1 – Introduction
Aerial Platform Features
Options
Operator’s Manual
Safety Alerts
Operation
Maintenance
Used Material Disposal
Manual of Responsibilities – ANSI
MEWP Safe Use – AS/NZS
AS/NZS 141810 Commissioning
CE Compliance
Additional Information
Chapter 2 – Specifications
Component Identification
Working Envelope – Dual Capacity
General Specifications
Chapter 3 – Safety
Electrocution Hazards
Minimum Safe Approach Distance – ANSI
Minimum Safe Approach Distance – AS/NZS
Platform Capacity
Manual Force
Wind Speeds
Prestart Inspection
Work Place Inspection and Practices
Operation
Tip-Over and Falling Hazards
Lead Acid Batteries
Lithium-Ion Batteries
Placards and Decals
General Safety Rules
Chapter 4 – Safety Devices
Emergency Stop Controls
Emergency Power System
Ground Operation Switch
Platform Foot Switch
Guardrails
Fall Protection Anchors
Ground Fault Circuit Interrupter
Platform Overload Sensing System
Boom/Drive Cut-out
35 Degree Slope Sensor Alarm Setting
5 Degree Slope Sensor Alarm Setting – Option
Tilt Alarm/Warning Lights
Power Preservation System
Horn
Drive Motion Alarm
All Motion Alarm
Flashing Lights
Driving Lights
Platform Work Lights
Snorkel Guard
Bumpguard System
Chapter 5 – Gauges and Displays
Diagnostic Center LCD
Platform Overload/Tilt Warning Lights
Dual Platform Capacity System
Bumpguard Indicator Light
Hydraulic Fluid Filter Gauge
Hydraulic Fluid Level Sight Gauge
Power System Fault
Chapter 6 – Batteries
General Maintenance
Charging
Lithium Battery Maintenance
Chapter 7 – Controls
Battery Disconnect Switch
Lower Controls
Emergency Stop Button
Controls Selector Switch
Emergency Power/Ground Operation Switch
Emergency Power
Ground Operation
Rotation Switch
Riser Switch
Boom Elevation Switch
Boom Extension Switch
Jib Articulation Switch
Platform Level Switch
Platform Rotation Switch
Platform Overload Warning Light
Dual Platform Capacity System – Option
Tilt Alarm
Diagnostic Center Display
Hydraulic Oil Warm-Up Switch
Circuit Breaker Reset Buttons
Upper Controls
Drive Joystick
Steer Switch
Drive Range Switch
Boom Speed Knob
Rotation Switch
Riser Switch
Emergency Power Switch
Horn Switch
Override Switch28Table of Contents
A46JRTE – 0261665-000
Tilt Alarm
AC Generator Switch
Upper Control Panel Lights
Driving and Platform Work Lights
Chapter 8 – Prestart Inspection
Operator’s Manual Holder
Electric Motor Compartment
Battery Fluid Level
Battery Terminals
Cables and Wiring Harness
Main Electrical System
Fluid Level
Fluid Filter
Hoses, Tubes, and Fittings
Tires and Wheels
Air Filled
Foam Filled
Lower Control Station
Operating Controls
Emergency Stop
Emergency Power
Flashing Lights
Structures
Weldments
Boom Slide Pads
Fasteners
Upper Control Station
Guardrail System
Operating Controls
Emergency Stop
Emergency Power
Horn Switch
Snorkel Guard
Electrical Power Outlet
Level Sensor
Drive Motion Alarm
All Motion Alarm
Sandblast Protection Kit
Air Line to Platform
Tow Kit
Lights
Personal Fall Arrest System
Bumpguard System
Battery Blanket
Platform Glazier Package
Platform Welder
Placards and Decals
Prestart Inspection Checklist
Inspection and Maintenance Schedules
Chapter 9 – Operation
Cold Weather Start-Up
Hydraulic System Cold Weather Warm-Up
Hydraulic System Warm-Up Switch
Manually Warming The Hydraulic System
Preparing for Operation
Lower Controls
Upper Controls
Boom Operation
Driving and Steering
Drive Speeds
Pivoting Front Axle
Drive Motion Alarm
Boom/Drive Cut-out
Snorkel Guard
Override Switch
Gradeability
Percent vs Degree of Slope
Driving on a Slope
Calculating Percent Grade
Machine Gradeability
AC Generator
Air Line
Driving Lights
Chapter 10 – Stowing and Transporting
Stowing
Transporting
Driving
Winching
Hoisting
Securing for Transport
Storage
Chapter 11 – Emergency Operation
Lower Controls
Upper Controls
Override Switch
Towing
Chapter 12 – Troubleshooting
Troubleshooting Chart
Appendix A – Glossary
Appendix B – Inspection Checklists
Limited Warranty
Brand: Snorkel
Options
Operator’s Manual
Safety Alerts
Operation
Maintenance
CE Compliance
Chapter 3 – Safety
Platform Capacity
Manual Force
Wind Speeds
Prestart Inspection
Operation
Lead Acid Batteries
Placards and Decals
Guardrails
Boom/Drive Cut-out
Horn
Drive Motion Alarm
All Motion Alarm
Flashing Lights
Driving Lights
Snorkel Guard
Bumpguard System
Power System Fault
General Maintenance
Charging
Lower Controls
Emergency Power
Ground Operation
Rotation Switch
Riser Switch
Tilt Alarm
Upper Controls
Drive Joystick
Steer Switch
Drive Range Switch
Boom Speed Knob
Rotation Switch
Riser Switch
Horn Switch
Tilt Alarm
AC Generator Switch
Battery Fluid Level
Battery Terminals
Fluid Level
Fluid Filter
Tires and Wheels
Air Filled
Foam Filled
Operating Controls
Emergency Stop
Emergency Power
Flashing Lights
Structures
Weldments
Boom Slide Pads
Fasteners
Guardrail System
Operating Controls
Emergency Stop
Emergency Power
Horn Switch
Snorkel Guard
Level Sensor
Drive Motion Alarm
All Motion Alarm
Tow Kit
Lights
Bumpguard System
Battery Blanket
Platform Welder
Placards and Decals
Lower Controls
Upper Controls
Boom Operation
Drive Speeds
Pivoting Front Axle
Drive Motion Alarm
Boom/Drive Cut-out
Snorkel Guard
Override Switch
Gradeability
Driving on a Slope
AC Generator
Air Line
Driving Lights
Stowing
Transporting
Driving
Winching
Hoisting
Storage
Lower Controls
Upper Controls
Override Switch
Towing
Limited Warranty
