Snorkel Aerial Work Platform A46JRT Service Maintenance Manual 0261631-000 2023
Brand: Snorkel
Type of Manual: Service Maintenance Manual, Electrical Schematic, Hydraulic Schematic
Model: Snorkel A46JRT Aerial Work Platform
Part Number: 0261631-000
Publication Date: 2023
Number of Pages: 192 Pages
Section 1 General Information
Component Identification
Chassis Component Location
Serial Number Locations
Working Envelope
Single Capacity
Dual Capacity
Wire Code and Function Chart
Abbreviations List
Operator’s Manual Procedures
Section 2 Specifications
General Specifications
Single Capacity
Dual Capacity
Engine Specifications
Kubota V1505 Diesel
Kubota WG1605 Dual Fuel
Hydrostatic Pump Specifications
Drive Motor Specifications
Swing Drive Specifications
Fastener Torque Chart
Standard System
Metric System
Section 3 Hydraulic Components
Chassis Hydraulic Component Location
Hydrostatic Drive Pump
Right View
Left View
2 Section Function Pump
Brake Release Valve
Steer Cylinder
Turntable and Booms Hydraulic Component Location
Turntable Component Location
Swing Drive
Function Manifold
Riser and Main Boom Lift Cylinder
Master Level Cylinder
Extend Cylinder
Jib Boom Cylinder
Slave Level Cylinder
Section 4 Electrical Components
Chassis Electrical Component Location
Engine Relay Panel
Kubota V1505 Diesel
Turntable and Booms Electrical Component Location
Lower Control Box
Single Capacity Outside View
Dual Capacity Outside View
Single and Dual Capacity Inside View
Valve Current Control Module
Display
GP400 Controller
Terminal Board Module
Platform Electrical Components
Upper Control Box
Single Capacity Inside View
GP440 Controller
Foot Switch
Harnesses
Hydrostatic Pump Harness
V1505 Kubota Diesel Engine Harness
WG1605 Kubota Dual Fuel Engine Harness
Hydraulic Control Harness
Function Manifold Wiring Harness
Lower Control Box Internal Harness
Lower Control Box to Upper Control Box Harness
Boom Extend Switch Harness
Boom Extend Switch Wiring
Boom Down Switch Harness
Boom Down Limit Switch Wiring
Upper Controls Internal Harness
Joystick Harness CE
Joystick Harness ANSI
Section 5 Engine Components
Right View
Left View
Right View
Left View
Throttle Solenoid
Bell Housing
Section 6 Drive System Components
Drive Motor Hengli
Power Wheel
Section 7 Booms
Booms
Riser Boom
Main Boom
Jib Boom
Section 8 Platform
Platform
Snorkel Guard
Rotator
Section 9 Options
Tow Kit
2K Belt Driven Generator
Lights
Bumpguard
Section 10 Procedures & Adjustments
Recommended Tools
Torque Hubs
Check Articulating Axle Lock Cylinder Operation
Tow Bar Adjustment
Throttle Adjustment - V1505 Kubota Diesel Engine
Check and Adjust Speed Sensor
Serial Number A46JRT-04-181100995 and After
Horsepower Limiter ECU V1505
Serial Number A46JRT-04-181100994 and Before
Low Pressure Relief Valve Adjustment
Neutral Adjustment Screw
GP400
Module Navigation
Fault and Flash Codes
Help Messages With Flash Codes
Help Messages Without Flash Codes
MVP-132 Engine Monitor – WG1605 Kubota Engine
Front Display Navigation
Setting Engine Throttle Kubota WG1605
Back Connector Pin Outs
Engine Codes
Check and Adjust Boom Down Switch
Check and Adjust Extend Switch
Check Inputs to GP400 Board for Switches
Boom Pressure Settings
Booms Disassembly / Extend Cylinder Removal
Cylinder Removal
Riser Boom
Main Boom
Jib Boom
Rotator
Bleeding Procedure
Assembly and Disassembly Procedure
Troubleshooting Guide
Section 11 Maintenance
General Maintenance
Lubrication Points
Battery Care and Maintenance
Maintenance Schedule
Prestart Inspection Checklist
Frequent Inspection and Maintenance – Every 90 Days or 150 Hours
Frequent Maintenance – Every 90 Days or 150 Hours
Annual Maintenance – Every 500 Hours
Major Repairs
Filter Service Intervals
Section 12 Schematics
Hydraulic Schematic
Added Values to Pilot Valves
Added Orifice Check and Accumulator
Added Tow Package Steer
V1505 KUBOTA Diesel Engine
Added Axle Pressure Switch
Corrected Hydraulic Warm-Up Wiring
Moved GP400 P8-15 to TBM B
Added Telematics Option
Updated Throttle Circuit
Updated Boom Switch Logic
Removed CE Note from Load Cell
Section 13 Appendix
Appendix A - Glossary
Brand: Snorkel
Working Envelope
Single Capacity
Dual Capacity
Abbreviations List
Single Capacity
Dual Capacity
Kubota V1505 Diesel
Standard System
Metric System
Right View
Left View
Brake Release Valve
Steer Cylinder
Swing Drive
Function Manifold
Extend Cylinder
Jib Boom Cylinder
Engine Relay Panel
Kubota V1505 Diesel
Lower Control Box
Display
GP400 Controller
Upper Control Box
GP440 Controller
Foot Switch
Harnesses
Joystick Harness CE
Right View
Left View
Right View
Left View
Throttle Solenoid
Bell Housing
Drive Motor Hengli
Power Wheel
Section 7 Booms
Booms
Riser Boom
Main Boom
Jib Boom
Section 8 Platform
Platform
Snorkel Guard
Rotator
Section 9 Options
Tow Kit
Lights
Bumpguard
Recommended Tools
Torque Hubs
Tow Bar Adjustment
GP400
Module Navigation
Engine Codes
Cylinder Removal
Riser Boom
Main Boom
Jib Boom
Rotator
Bleeding Procedure
General Maintenance
Lubrication Points
Major Repairs
Hydraulic Schematic
Section 13 Appendix
