Snorkel Aerial Work Platform A46JRT Operators Manual 0261534-000 2023
Brand: Snorkel
Model: Snorkel A46JRT Tier 3 and Tier 4 Final Aerial Work Platform
Part Number: 0261534-000
Publication Date: 2023
Number of Pages: 92 Pages
Electrical Danger Inside Front Cover
Proposition 65 Warning Inside Front Cover
Danger Symbols Inside Front Cover
Fall Restraint Lanyard Anchor Points Inside Front Cover
Safety Rules Inside Front Cover
Chapter 1 – Introduction
Aerial Platform Features
Operator’s Manual
Safety Alerts
Operation
Maintenance
Used Material Disposal
Manual of Responsibilities – ANSI
MEWP Safe Use – AS/NZS
AS/NZS 141810 Commissioning
CE Compliance
Additional Information
Chapter 2 – Specifications
Component Identification
Working Envelope
General Specifications
Engine Specifications
Engine Oil Viscosity
Chapter 3 – Safety
Electrocution Hazards
Minimum Safe Approach Distance – ANSI
Minimum Safe Approach Distance – AS/NZS
Platform Capacity
Manual Force
Wind Speeds
Prestart Inspection
Work Place Inspection and Practices
Operation
Tip-Over and Falling Hazards
Engine and Fuel Handling Precautions
Placards and Decals
General Safety Rules
Chapter 4 – Safety Devices
Emergency Stop Controls
Emergency Power System
Ground Operation Switch
Platform Foot Switch
Guardrails
Fall Protection Anchors
Personal Fall Arrest System
Ground Fault Circuit Interrupter
Platform Overload Sensing System
Boom/Drive Cut-out
Tilt Alarm/Warning Lights
Engine Protection Systems
High Engine Temperature Alarm
Low Oil Pressure Alarm
Horn
Drive Motion Alarm
All Motion Alarm
Flashing Lights
Driving Lights
Platform Work Lights
Snorkel Guard
Bumpguard System
Chapter 5 – Gauges and Displays
Diagnostic Center LCD
Platform Overload/Tilt Warning Lights
Dual Platform Capacity System
Bumpguard Indicator Light
Fuel Gauge
Engine Oil
Hydraulic Fluid Filter Gauge
Hydraulic Fluid Level Sight Gauge
Chapter 6 – Controls
Battery Disconnect Switch
Lower Controls
Start/Emergency Power/Ground Operation Switch
Emergency Stop Button
Controls Selector Switch
Rotation Switch
Riser Switch
Boom Elevation Switch
Boom Extension Switch
Jib Articulation Switch
Platform Level Switch
Platform Rotation Switch
Hydraulic Oil Warm-Up Switch
Platform Overload Warning Light
Tilt Alarm
Diagnostic Center Display
Circuit Breaker Reset Buttons
Upper Controls
Start Switch
Drive Joystick
Steer Switch
Drive Range Switch
Boom Speed Knob
Rotation Switch
Riser Switch
Engine/Emergency Power Switch
Horn Switch
Override Switch
Platform Overload Warning Light27Table of Contents
A46JRT – 0265134-000
Tilt Alarm
Upper Control Panel Lights
Driving and Platform Work Lights
Chapter 7 – Prestart Inspection
Operator’s Manual Holder
Oil Level
Coolant
Fuel Line
Battery Fluid Level
Battery Terminals
Cables and Wiring Harness
Fluid Level
Fluid Filter
Hoses, Tubes, and Fittings
Tires and Wheels
Lower Control Station
Operating Controls
Emergency Stop
Emergency Power
Flashing Lights
Structures
Weldments
Boom Slide Pads
Fasteners
Upper Control Station
Guardrail System
Operating Controls
Emergency Stop
Emergency Power
Horn Switch
Snorkel Guard
Electrical Power Outlet
Level Sensor
Drive Motion Alarm
All Motion Alarm
Sandblast Protection Kit
Air Line to Platform
Tow Kit
Lights
Bumpguard System
Battery Blanket
Block Heater
Placards and Decals
Prestart Inspection Checklist
Inspection and Maintenance Schedules
Chapter 8 – Operation
Cold Weather Start-Up
Hydraulic System Cold Weather Warm-Up
Hydraulic System Warm-Up Switch
Manually Warming The Hydraulic System
Preparing for Operation
Lower Controls
Upper Controls
Boom Operation
Driving and Steering
Drive Speeds
Pivoting Front Axle
Drive Motion Alarm
Boom/Drive Cut-out
Snorkel Guard
Override Switch
Gradeability
Percent vs Degree of Slope
Driving on a Slope
Calculating Percent Grade
Machine Gradeability
Air Line
Driving Lights
Chapter 9 – Stowing and Transporting
Stowing
Transporting
Driving
Winching
Hoisting
Securing for Transport
Storage
Chapter 10 – Emergency Operation
Lower Controls
Upper Controls
Override Switch
Towing
Chapter 11 – Troubleshooting
Troubleshooting Chart
Appendix A – Glossary
Appendix B – EC Declaration of Conformity
Appendix C – Inspection Checklists
Limited Warranty
Brand: Snorkel
Operator’s Manual
Safety Alerts
Operation
Maintenance
CE Compliance
Working Envelope
Chapter 3 – Safety
Platform Capacity
Manual Force
Wind Speeds
Prestart Inspection
Operation
Placards and Decals
Guardrails
Boom/Drive Cut-out
Horn
Drive Motion Alarm
All Motion Alarm
Flashing Lights
Driving Lights
Snorkel Guard
Bumpguard System
Fuel Gauge
Engine Oil
Lower Controls
Rotation Switch
Riser Switch
Tilt Alarm
Upper Controls
Start Switch
Drive Joystick
Steer Switch
Drive Range Switch
Boom Speed Knob
Rotation Switch
Riser Switch
Horn Switch
Override Switch
Tilt Alarm
Oil Level
Coolant
Fuel Line
Battery Fluid Level
Battery Terminals
Fluid Level
Fluid Filter
Tires and Wheels
Operating Controls
Emergency Stop
Emergency Power
Flashing Lights
Structures
Weldments
Boom Slide Pads
Fasteners
Guardrail System
Operating Controls
Emergency Stop
Emergency Power
Horn Switch
Snorkel Guard
Level Sensor
Drive Motion Alarm
All Motion Alarm
Tow Kit
Lights
Bumpguard System
Battery Blanket
Block Heater
Placards and Decals
Lower Controls
Upper Controls
Boom Operation
Drive Speeds
Pivoting Front Axle
Drive Motion Alarm
Boom/Drive Cut-out
Snorkel Guard
Override Switch
Gradeability
Driving on a Slope
Air Line
Driving Lights
Stowing
Transporting
Driving
Winching
Hoisting
Storage
Lower Controls
Upper Controls
Override Switch
Towing
Limited Warranty
