Snorkel Aerial Work Platform A46JRT AB46JRT Parts Manual 0260193 2015
Brand: Snorkel
Type of Manual: Parts Manual, Electrcal Schematic, Hydraulic Schematic
Model: Snorkel A46JRT AB46JRT Aerial Work Platform
Serial Number: 000000 and after
Part Number: 0260193
Publication Date: 2015
Number of Pages: 940 Pages
Repair Parts
Tires Air Filled Standard
Tires Foam Filled Standard - Ce
Single Tire And Wheel Assembly
Front Axle Assembly - May 2017 And Before
Front Axle Assembly
Front Axle Assembly - Before October 2014
Front Axle Assembly - Dual Capacity
Chassis Assembly - Ansi - Sn A46jrt-04-00360 And Before Ce A46jrt-01-010859 And Before
Chassis Assembly Pg - October 2019 And After
Chassis Assembly - A46jrt - Pg - October 2019 And After - Dual Fuel
Chassis Assembly Pg O-Ring Flat Face
Chassis Assembly Pg - Dual Capacity
Chassis Assembly - Dual Fuel/Dual Capacity/Pf
Turntable Installation - Dual Capacity
Turntable Assembly - A46jrt-04-000360 - A46je-04-000158 Ansi A46je-01-010859 And Before
Turntable Assembly - Pg
Right Turntable Cover Kit - A46jrt/A46je
Left Turntable Cover Kit - A46jrt/A46je
Engine Assembly - May 2009 And Before - Kubota V1505t Tier 2
Engine Assembly - June 22, 2009 And After - Kubota V1505t Tier 3
Engine Assembly Dr - Ansi - Sn A46jrt-04-00201 And After - Kubota V1505-25hp
Engine Sub-Assembly - Pg/Ansi - Sn A46jrt-04-000361 And Sn After Ce A46jrt-01-010864 And After - Kubota V1505-25hp
Engine Sub-Assembly - Pg - Kubota - June 2024 And After
Engine Sub-Assembly Pg - A46jrt-04-181000975 To A46jrt-04-181100994 - Kubota V1505
Engine - Kubota V1505 Skl
Engine Speed Sensor Kit - Kubota V1505 Skl-1 V1505-25hp
Engine Mounting Kit - Kubota V1505t Tier 3
Engine Assembly - Sn A46jrt-04-000379 And After - Kubota Wg1605 Dual Fuel Pg
Engine Sub-Assembly Wg1605 Pg - August 2019 And After - Dual Fuel
Engine Replacement Parts - Kubota V1505 25hp
Engine Replacement Parts - Sn A46jrt-04-181100995 And After- Kubota V1505 Skl1
Engine Replacement Parts - Kubota Wg1605 Dual Fuel
Engine Replacement Parts - Wg1605 Dual Fuel
Engine Repalcement Parts - Kubota Turbo Tier 3
Lower Fan Kit Assembly - Kubota V1505 Skl-1 V1505-25hp Wg1605 Df
Bell Housing Assembly - Kubota
Fuel Filter Bracket Assembly
Radiator Assembly
Radiator Overflow Assembly - March 28, 2015 And Before
Radiator Overflow Reservoir - April 2015 And After
Radiator Overflow Assembly Pg - A46jrt-04-000361 And After Ce A46jrt-01-010864 And After
Radiator Overflow Assembly Dual Fuel - July 2016 And After
Radiator Assembly Dual Fuel - August 2017 And After
Air Cleaner Kit - Sn A46jrt-04-000379 And After - Kubota V1505 25hp Wg 1605 Df
Air Cleaner Kit - June 2009 And After - Kubota V1505t Tier 3
Air Cleaner Assembly - Sn A46jrt-04-000361 And After Ce Sn A46jrt-01-010864 And After
Air Cleaner Assembly - 45hp Cummins/65hp Ford Lrg/425 Gm Tier 3/2.4l/Kuboda V1505t Tier 3 V2403
Throttle Solenoid Assembly - Kubota
Diesel Fuel Tank Assembly Wide Neck
Diesel Fuel Tank Assembly - May 2010 And Before
Diesel Fuel Tank Assembly - June 2010 And After
Diesel Fuel Tank Assembly - August 2012 And After
Fuel Tank Assembly Dual Fuel - A46jrt-04-000361 And After
Hydraulic Tank Rt O-Ring Flat Face Pg Assembly - November 2016 And After
Hydraulic Tank Assembly
Hydraulic Reservoir Assembly O-Ring Flat Face - Dual Fuel
Hydraulic Tank Assembly - Sn A46jrt-04-000379 And After - Dual Fuel
Engine Cowling Assembly
Engine Cowling Assembly - Feburary 2017 And After - Dual Fuel Pg
Exhaust System - A46jrt-04-00201 And After - Kubota
Exhaust System Assembly - A46jrt-04-00200 And Before - Kubota V1505t Tier 2
Boom Installation - Pg - A46je/Jrt - A46jrt-04-210701285 And After
Boom Installation - Pg - A46je/Jrt - A46jrt-04-210601284 And Before
Lower Boom Sub-Assembly - August And After
Lower Boom Assembly Before Pg - July 2017 And After - O-Ring Flat Face
Top Boom Assebly Pg - Ansi - A46je-04-000159 And After And Pg Ce A46je-01-010860 And After
Upper Boom Assembly - Ansi/Ce - December 2019 And After
Upper Boom Assembly - Sn A46jrt-04-210701285 And After
Upper Boom Assembly O-Ring Flat Face - Sn A46jrt-04-210701285 After
Top Outer Boom Assembly - Dual Capacity
Top Outer Boom O-Ring Flat Face Pg Assembly - May 2008 And After
Top Outer Boom Assembly - A46jrt-04-220801392 And After A46je-04-220800633 And After
Carrier Track Replacement Links
Anti-Buckle Wear Pad Assembly - September 2008 And After
6' Jib Assembly - July 2018 And After
Bumpguard And Wrap Installation - Dual Capacity
8' Alumumum Platform Assembly Swing Gate 500lb - Ansi - April 2014 And After
6' Wide Platform Installation - Diesel
6' Platform Installation With Double Handrail
Platform Installation - 6' Wide
Platform Installation - 6' Wide - Short Guard - April 2026 And After
6' Steel Platform Assembly Gravity Gate With Overload - 500lb - Ce/Ansi/Pg - July 2019 And After
6' Steel Platform Assembly - April 2015 And After
6' Steel Platform Assembly Gravity Gate - 500lb Pg - Ansi - August 2019 And After
6' Steel Platform Assembly Gravity Gate With Overload - Pg - 500lb - Ansi - Feburary 2017 And After
6' Steel Platform Assembly With Bumpguard System And Pad - October 2019 And After
6' Steel Platform Assembly With Bumpguard System And Padding - August 2019 And After
6' Steel Platform Assembly With Bumpguard System Padding And Overload - September 2018 And After
6' Steel Platform Assembly With Bumpguard And Padded Double Handrails - October 2019 And After
6' Steel Platform Assembly With Padded Double Handrails And Overload - Ce - October 2019 And After
6' Steel Platform Assembly With Padded Double Handrail - August 2019 And After
6' Steel Platform Assembly With Padded Double Handrail Overload - August 2019 And After
6' Steel Platform Assembly With Padded Double Handrail Overload - Ce - August 2019 And After
6' Steel Platform Assembly Double Handrail - August 2019 And After
6' Steel Platform Assembly Double Handrail - April 2015 And After
5' Steel Platform Assembly Swing Gate Bumpguard System With Pad And Overload - August 2019 And After
5' Steel Platform Assembly Swing Gate Handrail With Pads - October 2019 And After
5' Steel Platform Assembly Swing Gate Bumpguard System With Pads - August 2019 And After
5' Steel Platform Assembly With Swing Gate Bumpguard System And Overload - April 2017 And After
5' Aluminum Platform Assembly Pg Swing Gate With Snorkel Guard 550lb - August 2019 And After
5' Aluminum Platform Assembly Gravity Gate - 500lb - October 2019 And After
5' Aluminum Platform Assembly Gravity Gate With Overload - 500lb - October 2019 And After
5' Alumumum Platform Assembly Gravity Gate - 550lb - Ansi - April 2014 And After
5' Aluminum Platform Assembly Gravity Gate - 500lb - Ce - October 2019 And After
5' Aluminum Platform Assembly Pg With Swing Gate Snorkel Guard Overload 550lb - August 2019 And After
5' Aluminum Platform Assembly Swing Gate With Snorkel Guard - 550lb - Ce - Pg - October 2019 And After
5' Alumumum Platform Snorkel Guard Assembly - November 2016 And After
Platform Assembly A46je/A46jrt - Pg/Ce - July 2016 And After
Snorkel Guard Kit - Ab46 Series - August 2015 And Before
Platform Rotator - Helac
Actuator - Sjh Rotator Kit - Sunji
Hengli Platform Rotator
Decal Installation - Ansi - May 2020 And Before
Decal Installation - Df/Ansi - May 2020 And Before
Decal Installation - Ansi 92.20 - June 2020 And After
Decal Installation - Df/Ansi 92.20 - June 2020 And After
Decals Installation - Dual Fuel/Dual Capacity
Decals/Placards Installation - French - September 2019 And After
Decal/Placard Installation - Ce
Decal Package - Non-Ansi - Spanish
Decal Installation - Dual Capacity
Decal Installation - Csa
Decal Package - Chinese
Language Kit - Spanish
Hydraulics
Gear Hub Assembly
Hydraulic Kit And Fittings Kit O-Ring Flat Face - Ansi/Ce - March 2017 And After
Manifold Assembly Jic - October 2016 And Before - Hydraforce
Manifold Assembly O-Ring Flat Face - November 2016 And After - Hydraforce
Chassis Assembly Hydraulic Hoses Pg - October 2019 And After
Chassis Assembly Hydraulic Hoses Pg - October 2019 And After - Dual Fuel
Chassis Hydraulic Hoses Assembly Pg O-Ring Flat Face
Drive Valve Assembly O-Ring Flat Face
Drive Motor Sauer - Sn A46jrt-04-170700685 And Before
Drive Motor - Sn A46jrt-04-170700686 And After - Hengli
Drive Motor Ss Assembly Front Jic - May 2008 And After
Drive Motor Front Assembly Jic - November 2019 And After - Hengli
Rear Drive Motor Ss Assembly Jic - April 2009 And After
Front Drive Motor Assembly O-Ring Flat Face
Rear Drive Motor O-Ring Flat Face Assembly
Hydraulic Bulkhead Assembly Jic - September 2009 And Before
Dual Proportional Valve - August 2014 And After - Fluid Tech
Brake Release Valve Assembly Jic
Brake Release Valve Jic - May 2013 And After
Brake Release Valve Assembly O-Ring Flat Face - February 2019 And After
Brake Release Valve O-Ring Flat Face - Feburary 2014 And After
Brake Valve Assembly Pg O-Ring Flat Face
Swing Drive Assembly - November 2015 And Before
Swing Drive A46 - December 2015 And After
Accumulator 300 Psi Assembly With O-Ring Flat Face - October 2016 And After
Accumulator Assembly 300 Psi With Jic Fittings - September 2016 And Before
Hydraulic Reservoir Weldment
Hydraulic Pressure Filter Assembly With Jic Fittings
Hydraulic Fluid Return Filter Assembly
Return Hydraulic Fluid Filter Assembly With O-Ring Flat Face - October 2016 And After
Hydraulic Pressure Filter Assembly With O-Ring Flat Face - November 2016 And After
Emergency Power Unit Assembly With Jic Fittings
Emergency Power Unit Assembly With O-Ring Flat Face - October 2016 And After
Emergency Power Unit Assembly - April 2016 And After
Hydrostatic Pump - Electric Assembly - Hengli - June 2024 And After
Hydrostatic Pump Eaton Replacement Parts - A46jrt-04-00201 And After
Hydrostatic Hydraulic Pump Replacement Parts - A46jrt-04-00200 And Before - Sauer Danfoss
Hydrostatic Drive Pump Assembly - A46jrt-04-00200 And Before - Sauer Danfoss
Hydrostatic Drive Pump Assembly - Eaton - A46jrt-04-00201 And After
Hydrostatic Hydraulic Pump Assembly - Eaton
Hydrostatic Pump Assembly O-Ring Flat Face - October 2016 And After - Eaton
Hydraulic Pump Assembly - Sn A46jrt-04-000360 And Before
Hydraulic Pump Assembly - A46jrt-04-000361 And After
Hydrostatic Pump Assembly O-Ring Flat Face - October 2019 And After - Hengli
Hydrostatic Pump Assembly - Hengli 40.6 Cc - June 2024 And After
Hydrostatic Pump - Hengli
Hydraulic Hosing - September 2008 And After
Hydraulic Hosing Ab46j - Feburary 2014 And After
Wuxi Deli Tandem Hydraulic Pump - January 2017 And After
Left Axle Cylinder Assembly - Jic
Left Axle Cylinder O-Ring Flat Face Assembly
Left Axle Cylinder Assembly - Dual Capacity
Right Axle Cylinder Assembly - Jic
Right Axle Cylinder O-Ring Flat Face Assembly
Right Axle Cylinder Assembly - Dual Capacity
Axle Cylinder
Primary Level Cylinder
Secondary Level Cylinder - Pb
Secondary Level Cylinder - Fisher/Rosenboom
Steering Cylinder
Raise Boom Lift Cylinder
Boom Extend Cylinder - Fisher/Hydratech/Rosenboom
Lift Cylinder - Riser Boom
Jib Boom Cylinder - Fisher
Jib Boom Cylinder - Hydratech/Fisher/Rosenboom
Electrical
Engine Harness Tier 3 - March 2014 And After - Kubota V1505t
Engine Harness Pg - Sn A46jrt-04-181000975 To A46jrt-04-181100994
Engine Harness A46jrt Pg
Engine Harness Dual Fuel Wg2503
Engine Harness - Pg - Ce - Sn A46jrt-01-0100860 And After
Engine Harness With Turbo - Pg - Ce - Sn A46jrt-01-0100860 And After
Engine Harness Wg1605 - March 2017 And After - Dual Fuel
Harness Internal Controls - A46jrt-04-000360 And Before
Harness Internal Platform Box - Pg - Ce - Sn A46je-04-010860 And After And - Ansi - Sn A46je-04-000156 And After
Chassis Assembly Electrical - Pg - October 2019 And After
Chassis Assembly Electrical - Pg - October 2019 And After - Dual Fuel
Chassis Electrical Assembly - Pg - O-Ring Flat Face
Chassis Harness - July 2008 And After - Kubota V1505t
Lower Control Box - Ansi - November 2013 And Before
Lower Control Box Evdr - Ansi - December 2013 And After
Lower Control Panel - Ce - September 2013 And After
Lower Control Box Assembly Rt - Ce - April 2014 And After
Lower Control Box - December 2014 And After - Kubota
Lower Control Box Assembly - Pg - December 2019 And Before
Lower Control Box Assembly - Pg - January 2020 And After
Lower Control Box Diesel
Lower Control Box Internal Harness - Pg
Lower Control Box Assembly - April 2018 And After - Dual Fuel - Pg
Lower Control Box Pg - Ansi - A46jrt-04-010864 And After - Pg Ce - A46jrt-01-010860 And After
Lower Control Box Dc Non-Keyed Installation
Lower Control Box - Dc Keyed Switch Installation
Lower Control Box Assembly - Keyed Switch - Dual Fuel/Dual Capacity
Lower Control Box Assembly - Non- Keyed - Dual Capacity
Lower Control Box Installation - Keyed Switch - Dual Fuel/Dual Capacity
Lower Control Box Assembly - Keyed Switch - Pg - Dual Fuel/Dual Capacity
Lower Control Box Installation - Non-Keyed Switch - Dual Fuel/Dual Capacity
Lower Control Box Assembly - Non-Keyed Switch - Pg - Dual Fuel/Dual Capacity
Lower Controls To Upper Controls Wiring Harness - July 2009 And After
Generator Toggle Switch Spst Harness
Valve Block Wiring Harness - November 2008 And Before
Valve Block Wiring Harness Evdr-7 - January 2014 And After
Pump Harness - October 2019 And After - Hengli
Level Sensor Wire Harness - January 2008
Hydrostatic Pump Wire Harness - September 2008 And After
Drive Block Wire Harness - January 2008 And After
Wire Harness Ext Limit Switch - June 2008 And After
Wire Harness Upper Controls 18/19 - July 2009 And After
Down Limit Switch Wiring Harness - January 2008 And After
Boom Switch Configurations Assembly - Ce - June 2009 And After
Boom Lift Limit Switch - Feburary 2014 And After
Riser Lift Limit Switch - Ce - June 2008 And After
Motion Alarm Wiring Harness - July 2016 And After
Platform Controls Harness - June 2016 And Before
Platform Controls Harness - Pg - A46jrt-04-000361 And After
Platform Ac Assembly Installation - Ansi
Platform Ac Power Assembly Installation - Ce
Upper Controls Wire Harness 12/8 - March 2014 And After
Upper Control Panel - Ansi - March 2014 And Before
Upper Control Box Assembly Ku Dr - Ansi - March 2014 And After
Upper Control Box Assembly - Ce - March 2014 And After
Upper Control Box Assembly - Dual Fuel - Pg
Upper Control Box Assembly - Dual Capacity - Pg
Upper Control Box Assembly - Pg
Upper Control Box Installation - Dual Fuel/Dual Capacity
Upper Control Box Assembly - Dual Fuel/Dual Capacity/Pg
Power To Platform Assembly With 90 Connector
Platform Foot Switch Assembly - Ansi
Platform Foot Switch Wiring Harness
Lower Controls Platform Overload Fault Detection
Upper Controls Platform Overload System - Ce
6' Bump Guard Sensors Harness
Platform Overload Module Wiring Harness
Wire Harness 110v Cable - Ansi Only
Horn Wire Harness - April 2008 And After
Joystick Controller Single Axis With Rocker Control Drive/Steer Pg-A46jrt-04-000361 And After
Options
Tires Non-Mark Air Filled 46jr
Turf Tires Air Filled
Trackunit To Control Box Boom Installation
Tow Package - July 2016 And Before
Tow Package - August 2016 And After
Airline To Aluminum Platform
Airline To 6' Steel Platform
Pinion Guard Installation
Grounding Loop
Water Line High-Pressure Installation
Hydraulic Warm Up Installation - Kubota
Hydraulic Warm Up Wire Harness
Hydraulic Warm Up Pg - Sn A46jrt-04-000361 And After
Block Heater - Ab46
Cold Weather Package - Kubota
Cold Weather Package Pg - Sn A46jrt-04-000361 And After
Cold Weather Package - Ku - Pg
Spark Arrestor - Kubota V1505
2kw Generator - December 2018 And After - Fabco
2kw Generator Harness - Ab46
2.4kw Hydraulic Generator Service Kit
2.5kw Generator
110 Hydraulic Generator - A46jrt-04-000360 And Before
110v Ac Generator Wiring Harness
Sandblast Kit
Boom Brush Kit
Lanyard Mount Installation Used On 1430080 - Platform Only
6' Steel Platform Fall Restraint Assembly
Swing Gate For Ab46 Steel Platform
Delux Aircraft Package - Ansi
Delux Aircraft Package - Ce
Motion Alarm - Ab46
Upper Control Box Modular Cover Assembly Installation - A46je/A46jrt
Upper Control Box Cover Assembly
Uper Control Box Modular Cover Narrow Assembly
Upper Control Box - Courtesy Light
Squawking Alarm - Kubota
Platform Enclosure Installation - A46je/Rt
Platform Half Height Enclosure Installation
Swing Gate Platform Installation
Bumpguard Installation - A46jrt - Diesel
3'x3' Platform Installation
Platform Control Box Cover
Platform Work Lights
36x96 Platform Assembly Bumpguard With Padding
36x96 Platform Assembly Bumpguard With Padding - March 2009 And After
6' Aircraft Package Installation
6' Deluxe Aircraft Package Installation
6' Bump Guard Installation
Bumpguard Padding Installation - 6'
Glazier Package Installation
Tool Tray
Pipe Rack Installation
Pipe Rack Boom Assembly
Beacon Light Installation
Driving Lights With Red Rear Taillights
Drive Lights Pg - Ansi - A46jrt-04-000361 And After Ce Ab46jrt-01-010864 And After
Light Package Installation Referance Drawing - Ab46
Light Package Led Pg - Ansi - Sn A46je-01-010860 And After And Pg Ansi Sn A46je-04-000360 And Pg Ce A46je-01-010860 And After
Head/Tail/Work Light - Pg
Light Package Led - Pg
Schematics
Electrical Schematic A26001ga V1505t - Kubota
Electrical Schematic A26001ha V1505t - Kubota
Electrical Schematic A26001ja V1505t - Updated Wiring On Joystick Controller 0260006 And 0260077 - Kubota
Electrical Schematic A26001ka V1505t - Kubota
Electrical Schematic A26001lb V1505t - Kubota
Electrical Schematic A26005da - Ce - Updated Wiring On Joystick Controller 0260006 And 0260077
Electrical Schematic A26005ca - Ce
Electrical Schematic A26005ea - Ce - Wiring Update
Electrical Schematic Pg A26041aa
Electrical Schematic Pg A26041ab - Added Axle Pressure Switch To Chassis For Ce
Electrical Schematic Pg A26041ac - Updated Hydraulic Warm-Up Wiring
Electricalschematic Pg A26041ae - Added Bump Guard
Electrical Schematic Pg A26041ah - Moved Gp400c P8-15 To Tbm B-
Electrical Schematic A46jrt Pg
Electrical Schematic Pg A26041al
Electrcal Schematic Pg - Dual Fuel A26042aa
Electrical Schematic Pg Dual Fuel A26042ab - Updated Throttle Circuit
Electrical Schematic Pg Dual Fuel A26042ad - Updated Boom Switch Logic
Electrical Schematic Pg Df
Electrical Schematic Pg Dual Fuel A26042af
Hydraulic Schematic A26003aa
Hydraulic Schematic A26003ba - Released Pump Controller And Changed Valve On Riser Boom Cylinder 116370-000
Hydraulic Schematic A26003ca
Hydraulic Schematic A26003da - Added Accumulator
Hydraulic Schematic A26003ee Hydraforce Manifold Assembly 0260219 - Psi Changed From 2750 To 3100 Psi
Hydraulic Schematic A26003ee - Added Orifice Check - February 2019 And After
Appendix A
ages Index
Appendix B
arts Index
Brand: Snorkel
Repair Parts
Front Axle Assembly
Radiator Assembly
Hydraulics
Gear Hub Assembly
Axle Cylinder
Steering Cylinder
Electrical
Options
Grounding Loop
Block Heater - Ab46
2.5kw Generator
Sandblast Kit
Boom Brush Kit
Motion Alarm - Ab46
Tool Tray
Schematics
Appendix A
Appendix B
