Snorkel Aerial Work Platform 660SJ Parts Manual 1435613-000 2025
Brand: Snorkel
Model: Snorkel 660SJ Aerial Work Platform
Serial Number: 1500 And After
Part Number: 1435613-000
Publication Date: 2025
Number of Pages: 473 Pages
General Information - 660sj - Sn1500 And After
Repair Parts
Chassis Assembly
Front Axle And Drive System Installation
Front Axle Assembly
Gear Hub Assembly
Standard Tires And Wheels Installation
Rotation Bearing Installation
Chassis Counterweight Installation - Dual Capacity
Chassis Covers Installation
Turntable Installation - Gravity Down Cylinder
Centerpost Swivel Installation - Hydrostat
Centerpost Assembly - Hydrostat
Turntable Counterweight Installation
Engine Installation - Kubota - Stage 5
Engine Assembly - 660sj - Kubota Stage 5
Engine Tray Latch Assembly
Swing Drive Installation
Swing Drive Assembly - Omni
Tanks Installation
Fuel Tank Assembly
Fuel Tank Sub-Assembly
Hydraulic Fluid Reservoir Assembly
Hydraulic Fluid Reservoir Sub-Assembly
Oil Cooler Tray Installation
Cowling Installation
Frame Assembly - Lh
Frame Assembly - Rh
Rear Door Assembly - Rh
Rear Door Assembly - Lh
Front Door Assembly - Rh
Front Door Assembly - Lh
Boom Assembly - Kubota Stage 5 - 660sj
Carrier Track Installation With 4x4 Tube
Carrier Track Assembly - 2.00" - 3.50" Camber - Dynatect
Main Boom Installation - Kubota Stage 5 - 660sj
Main Boom Assembly 600s/660sj
Main Boom Cylinder Support Assembly
Wear Pad Assembly - Top - Base Boom
Base Boom Assembly - 660sj
Tip- To Mid-Boom Assembly - Dual Capacity
Top- To Mid-Boom Wear Pad Assembly
Mid-Boom And Tip-End Wear Pad Assembly
Mid-Boom Assembly - 660sj
Tip-Boom Assembly - Dual Capacity
Wear Pad Assembly - Upper - Tip Boom
Extend Cylinder Assembly
66" Jib Installation
66" Jib Assembly
Jib Quad - Hi Capacity - Sensor Mount Assembly
Platform Jib Installation - 6' Wide
Decals Installation - High Capacity - 660sj
Hydraulic
Drive Motor - Hydraulic - Hengli 38cc/9.2cc
Steer Cylinder
Oscillating Axle Cylinder - 3.5" Bore X 4.5" Stroke
Drive System Installation - Hydrostat
Traction Manifold Assembly - Hydrostat
Chassis Hydraulics Installation - Hydrostat
Hydrostat 28cc Ls Pump Assembly - Kubota Stage 5
Main Manifold Installation - Kubota Stage 5 - 660sj
Main Manifold Assembly - Kubota Stage 5- 660sj
Turntable Hydraulic Hose Installation - Kubota Stage 5 - 660sj
Tip Boom Manifold Assembly
Lift Cylinder Assembly
Extend Cylinder - Hengli
Extend Cylinder - Rosenboom
Secondary Level Cylinder - Dual Capacity
Jib Cylinder - High Capacity
Rotator Assembly - Hengli
Boom Hydraulic Installation - Kubota Stage 5 - 660sj
Electrical
Engine Harness - Kubota V2403 Stage 5
Emergency Power Unit Installation
Hydraulic Manifold Harness
Lower Control Box Installation - Kubota - Stage 5 - 660sj
Lower Control Box Assembly - Kubota - Stage 5 - 660sj
Lower Control Box Harness - Pg
Turntable Electrical Installation - Kubota V2403 Stage 5
Turntable Harness - Kubota Stage 5
Boom Electrical Installation - Kubota Stage 5 - 660sj
Boom Function Harness
Jib High Capacity Harness
Platform To Ground Control Harness
Horn Assembly
Platform Electrical Installation - Kubota Stage 5 - 660sj
Upper Control Box Assembly - Kubota Stage 5 - 660sj
Upper Control Box Assembly - Pg
Push/Pull Assembly With Contact
Upper Control Box Harness - Pg
Foot Switch Wide Tredle Assembly
Beacon Light Harness
Options
Gray Non-Marking Tires And Wheels Installation
Flotation Tire Installation Option
Non-Directional Tires And Wheels Installation
All-Terrain Tracks Installation
Track Factory Assembly
Front Axle Assembly Track Factory
Front Axle And Drive System Track Factory Installation
Rear Drive System Track Factory Installation
Installation Tow Kit - 660sj
Pressure Washer Option
Water Tank Drain Assembly
Charge Pump Assembly - January 2020 And After
Pipe Rack Installation
Pipe Rack Boom Assembly
2.5kw Generator 50hz 110v - Deutz Tier 4 Final Dual Capacity
2.5k Generator - 50hz 110v - Assembly
2.5kw Generator Harness - 50hz 110v
7.5kw Generator Variable Displacement Installation
7.5kw Generator Assembly
Cold Weather Package Installation - Deutz Dual Capacity
20kw Generator Installation - Kubota Stage 5
Hydraulic Main Pump With 20k Generator Installation
Toggle Switch - Spst - Harness - 20kw Generator
Harness - 2 Conductor, 18 Awg, 60" Lg
Accessory Switch Enclosure Installation
Hydraulic Hose Heater Valve Installation
Toggle Electrical Cold Weather Package Installation
Extreme Cold Weather Package Installation - Deutz Dual Capacity
Extreme Environment Package Installation - 660sj - Deutz
Extreme Environment Package Bellows Installation - 660sj - Deutz
Airline To Platform Installation - 660sj - Ansi - Ce/Csa/As
3'x3' Platform Jib Installation
8' Platform Jib Installation - Deutz Tier 4 Final
8' Platform Jib Installation - As
11' Platform Installation
Platform Tool Tray Installation - Ansi - Ce/Csa/As
Aircraft Package Installation - 6' Platform - Steel
Aircraft Package Installation Option - 8' Platform - Steel
Deluxe Aircraft Package Installation - 6' Platform
Deluxe Aircraft Package Installation Option - 8' Platform - Steel
Bumpguard Installation Option - 8' Steel
Bumpguard Padding Installation - 8'
Bumpguard Platform Installation- 6' Steel
Bumpguard Padding Installation - 6'
Upper Bumpguard Installation Option - 8'
Bumpguard Sensors Harness - 8' Platform Steel
Bumpguard Sensors Harness - 6' Platform - Steel
Personal Fall Arrest System Installation
Platform Step Installation
Light Package Installation
Platform Light Package Installation
Chassis Light Package Installation
Drive Lights Harness
Led Light Assembly
Jumper Harness - Chassis Light Package
Harness Sq Platform Lights
Upper Control Box Utility Lamp With Harness
Upper Control Box Cover Installation - Round
Glazier Package Installation - Square Tubing Platforms Only
Schematics
Electrical Schematic - Kubota Stage 5 - 660sj
Hydraulic Schematic - Kubota Stage 5 - 600s 660sj
Appendix A
ages Index
Appendix B
arts Index
Brand: Snorkel
Repair Parts
Chassis Assembly
Front Axle Assembly
Gear Hub Assembly
Tanks Installation
Fuel Tank Assembly
Frame Assembly - Lh
Frame Assembly - Rh
66" Jib Assembly
Hydraulic
Steer Cylinder
Electrical
Horn Assembly
Options
Led Light Assembly
Schematics
Appendix A
Appendix B
