Snorkel Aerial Work Platform 660SJ Parts Manual 1432068-R 2017
Brand: Snorkel
Type of Manual: Repair Parts Manual
Model: Snorkel 660SJ Rigid Axle Aerial Work Platform
Serial Number: 00099 And Before
Part Number: 1432068-R
Publication Date: 2017
Number of Pages: 302 Pages
Repair Parts
Chassis Assembly
Hydraulic Motor To Knuckle
Hydraulic Motor Rear Assembly
Hydraulic Tank Module Assembly
Hydraulic Tank Assembly
Steer Link Assembly
Turntable To Chassis Sub-Assembly
Turntable Components Assembly
Hp Filter Assembly
Throttle Bracket Assembly
Radiator Kit - Kubota V2403
Radiator Shroud Assembly
Air Cleaner
Flywheel Coupling Assembly
Engine Swing Out Assembly
Diesel Engine Assembly - Kubota
Diesel Engine Turbo - Kubota V2403
Installation - 600s/660sj - Deutz Td2.9l Stage 5
Selector Valve Assembly
Cowling Installation - Kubota
Frame Assembly - Lh
Left Hand Rear Door Assembly
Front Door Assembly - Lh
Frame Assembly - Rh
Rear Door Assembly - Rh
Right Hand Front Door Assembly
Nose Cone - Lh
Nose Cone - Lh
Nose Cone - Rh
Nose Cone - Rh
Booms To Turntable Assembly
Hose Carrier Tube Guide Assembly
Extend Cylinder Assembly
Carrier Track Installation
Carrier Track Pre-Assembly
Carrier Track Assembly - 600s/660sj
Cylinder Support Assembly
Tip-Boom To Intermediate Boom Assembly
Quadrant Assembly
78" Jib Assembly - 460sj/660sj
Counterweight To Turntable Assembly
Base Boom To Turntable Sub-Assembly
Platform Rotator Assembly - 460sj/660sj
Platform Jib To Boom Assembly
Platform And Mount Assembly
Platform Assembly
Platform Assembly
Snorkel Guard Legacy Assembly
Snorkel Guard Assembly - Sn 01-000104 And Before
Boom Turntable Drive Controller - 600s/660sj
Single Axis Telescope Controller - 600s/660sj
Two Axis Jib/Platform Controller
Horn Assembly
Decal Installation - 600sj/660sj Osc Cu
Decal Kit - English
Decal Kit-Rigid - Korean
Hydraulics
Drive Manifold
Gear Hub Assembly
Main Manifold Assembly
Traction Manifold Assembly
Hydraulic Motor Drive - 38cc
Hydraulic Hose Diagram Kit
Steer Cylinder - Hydratech
Float Valve
Hydraulic Manifold
Load Sense Pump - Hengli/Cummins
Emergency Power Unit Assembly - April 2016 And After
7 Port Centerpost Assembly
Centerpost
Swing Drive Gearbox
Primary Level Cylinder - Rosenboom
Pressure Filter Assembly
Filter In-Tank Return
Extend Cylinder - Rosenboom
Secondary Level Cylinder - Rosenboom
Lift Cylinder - Rosenboom
Jib Cylinder - Hengli
Selector Valve Jib Rotate
Dual Counterbalance Valve Rotator - Helac
Electrical
Battery Control Panel Assembly - Kubota
Main Manifold Harness - Gen 1
Lower Control Box Assembly - Sj Diesel
Lower Control Box To Amber Light Harness
Lower Control To Limit Switch Harness
Lower Cable Assembly
Cable Harness Rigid Ku
Solenoid Din To Dt Plug Harness
Engine Cable Assembly Installation
Upper Cable Assembly
Elevation Switch To Dt06-4s Harness
Upper Control Assembly
Selector Valve Harness
Beacon Light Harness
Amber Running Light Harness
Foot Switch Wide Tredle Assembly
Foot Switch
Foot Switch Harness
Options
Tow Package Installation - 660sj-11-000002
Valve/Hose Tow Package Installation
Maintenance
Maintenance
Schematics
Hydraulic Schematic - Ku
Electric Schematic - Kubota
Appendix A
ages Index
Appendix B
arts Index
Brand: Snorkel
Repair Parts
Chassis Assembly
Steer Link Assembly
Hp Filter Assembly
Air Cleaner
Frame Assembly - Lh
Frame Assembly - Rh
Nose Cone - Lh
Nose Cone - Lh
Nose Cone - Rh
Nose Cone - Rh
Quadrant Assembly
Platform Assembly
Platform Assembly
Horn Assembly
Decal Kit - English
Hydraulics
Drive Manifold
Gear Hub Assembly
Float Valve
Hydraulic Manifold
Centerpost
Swing Drive Gearbox
Electrical
Foot Switch
Foot Switch Harness
Options
Maintenance
Maintenance
Schematics
Appendix A
Appendix B
