Momed80
150
35,046
Snorkel Aerial Work Platform 660SJ Operators Manual 1432633 2024
Brand: Snorkel
Model: Snorkel 660SJ Aerial Work Platform
Serial Number: 000034 and after
Part Number: 1432633
Publication Date: 2024
Number of Pages: 108 Pages
Electrical Danger Inside Front Cover
Proposition 65 Warning Inside Front Cover
Danger Symbols Inside Front Cover
Wheel Orientation Warning Inside Front Cover
Safety Rules Inside Front Cover
Chapter 1 – Introduction
Aerial Platform Features
Options
Operator’s Manual
Safety Alerts
Operation
Maintenance
Used Material Disposal
Manual of Responsibilities – ANSI
MEWP Safe Use – AS/NZS
AS/NZS 141810 Commissioning
CE Compliance
Additional Information
Chapter 2 – Specifications
Component Identification
Working Envelope – Single Capacity
Working Envelope – Dual Capacity
General Specifications
Engine Specifications
Engine Oil Viscosity
Chapter 3 – Safety
Electrocution Hazards
Minimum Safe Approach Distance – ANSI
Minimum Safe Approach Distance – AS/NZS
Platform Capacity
Manual Force
Wind Speeds
Prestart Inspection
Work Place Inspection and Practices
Operation
Tip-Over and Falling Hazards
Engine and Fuel Handling Precautions
Placards and Decals
General Safety Rules
Chapter 4 – Safety Devices
Emergency Stop Controls
Emergency Power System
Emergency Lowering Knob
– Single Platform Capacity Machines Only
Ground Operation Switch
Platform Foot Switch
Guardrails
Fall Protection Anchors
Ground Fault Circuit Interrupter
Platform Overload Sensing System
Boom/Drive Cut-out
Tilt Alarm/Warning Lights
Engine Protection Systems
High Engine Temperature Alarm
Low Oil Pressure Alarm
Horn
Drive Motion Alarm
All Motion Alarm
Flashing Lights
Driving Lights
Platform Work Lights
Snorkel Guard
Tire Pressure Monitoring System
– Flotation Tires Only
Chapter 5 – Gauges and Displays
Diagnostic Center Display
Platform Overload/Tilt Warning Lights
Cummins
Deutz/Kubota
Cummins
Deutz/Kubota
Dual Platform Capacity System
Engine Warning Lights
Diesel Particulate Filter Warning Light
Fuel
Fluid Level and Temperature Gauge
Engine Oil
System – Flotation Tires Only
Chapter 6 – Controls
Battery Disconnect Switch
Lower Controls
Start/Emergency Power/Ground Operation Switch
Emergency Stop Button
Controls Selector Switch
Rotation Switch
Boom Elevation Switch
Boom Extension Switch
Jib Articulation Switch
Platform Level Switch
Platform Rotation Switch
Fuel Switch
Platform Overload Warning Light
Diesel Particulate Filter Switch
Tilt Alarm
Hydraulic Oil Warm-Up Switch
Circuit Breaker Reset Buttons
Upper Controls
Start Switch
Drive Joystick
Drive Range Switch
Boom Joystick
Boom Extension Joystick
Jib/Platform Rotate Joystick
Emergency Power Switch
Horn Switch
Engine Speed Switch
Override Switch
Tilt Alarm
AC Generator Switch
AC 20 kW Generator Switch – Platform Welder
Dual Fuel
Driving and Platform Work Lights
Chapter 7 – Prestart Inspection
Operator’s Manual Holder 37Table of Contents
660SJ – 1432633
Oil Level
Coolant
Fuel Line
Battery Terminals
Cables and Wiring Harness
Fluid Level
Fluid Filter
Hoses, Tubes, and Fittings
Tires and Wheels
Lower Control Station
Operating Controls
Emergency Stop
Emergency Power
Flashing Lights
Structures
Weldments
Boom Slide Pads
Wire Ropes
Fasteners
Upper Control Station
Guardrail System
Operating Controls
Emergency Stop
Emergency Power
Horn Switch
Snorkel Guard
Electrical Power Outlet
Level Sensor
Panel Carrier
All Motion Alarm
Sandblast Protection Kit
Air Line to Platform
Tow Kit
Platform Glazier Package
Platform Welder
Pipe Rack
Drive Motion Alarm
Placards and Decals
Prestart Inspection Checklist
Inspection and Maintenance Schedules
Chapter 8 – Operation
Cold Weather Start-Up
Hydraulic System Cold Weather Warm-Up
Hydraulic System Warm-Up Switch
Manually Warming The Hydraulic System
Preparing for Operation
Lower Controls
Upper Controls
Engine Speed Switch
Boom Operation
Jib and Boom Simultaneous Operation
Driving and Steering
Drive Speeds
Pivoting Front Axle
Machine in Stowed Position
Machine Not in Stowed Position
Boom and Turntable Position/Axle
and Drive Speeds
Drive Motion Alarm
Boom/Drive Cut-out
Snorkel Guard
Override Switch
Gradeability
Percent vs Degree of Slope
Driving on a Slope
Calculating Percent Grade
Machine Gradeability
AC Generator
Dual Fuel
Panel Carrier
Platform Capacity
Diesel Particulate Filter Regeneration
Air Line
Driving Lights
Platform Capacity
Platform Welder
Platform Capacity
Pressure Washer
Pipe Rack
Snorkel OnSite
After Use Each Day
Chapter 9 – Stowing and Transporting
Stowing
Transporting
Driving
Winching
Hoisting
Securing for Transport
Storage
Chapter 10 – Emergency Operation
Lower Controls
Upper Controls
Override Switch
Towing
Chapter 11 – Troubleshooting
Troubleshooting Chart
AC 20 kW Generator – Platform Welder
Engine RPM
Output Voltage
Frequency
Appendix A – Glossary
Appendix B – Inspection Checklists
Limited Warranty
