Momed80
150
35,046
Snorkel Aerial Work Platform 600S 660SJ Parts Manual 1432925
Brand: Snorkel
Type of Manual: Parts Manual, Electrical Schematic, Hydraulic Schematic
Model: Snorkel 600S 660SJ Oscillating Axle Aerial Work Platform
Serial Number: 00100 And After
Part Number: 1432925
Publication Date: 2017
Number of Pages: 1484 Pages
600s/660sj
Repair Parts
Rear Drive System Installation
Front Axle And Drive System Installation
Front Axle Assembly
Gear Hub Assembly
Gray Non-Marking Tires And Wheels Assembly - Exmile
Gray Non-Marking Over The Road Tire And Wheel Assembly
Slew Bearing Installation - July 2025 And Before
Standard Tires And Wheels Installation
Chassis Counterweight Installation
Chassis Counterweight Installation - 660sj
Chassis Counterweight Installation - 660sj - July 2022 And Before - Dual Capacity
Chassis Counterweight Installation - 660sj - August 2022 And After - Dual Capacity
Chassis Covers Installation
Exhaust Support Plt
Rib Exhaust Support Plt
Turntable Installation
Turntable Counterweight Installation - 600s
Turntable Counterweight Installation - 660sj - July 2022 And Before
Turntable Counterweight Installation - 660sj - August 2022 And Before
Swing Drive Installation - Kubota
Swing Drive Gearbox
Turntable Hoods Installation
Pinion Guard Installation
Centerpost Assembly - 660sj
Centerpost Swivel Installation - Kubota Dual Fuel
Centerpost Swivel Assembly - Kubota Dual Fuel
Centerpost Swivel Installation - Hydrostat
Centerpost Assembly - Hydrostat
Engine Installation - Cummins 2.8l Tier 4 Final
Engine Assembly - Cummins 2.8l
Engine Installation - Deutz Tier 4 Final
Engine Installation - Deutz Td2.9l Stage 5
Engine Installation - November 2019 And After - Kubota
Engine Assembly - 660sj - November 2019 And After - Kubota
Engine Installation - September 2023 And After - Deutz Td2.9/Emr5 Diesel Tier 4 Final
Engine Installation - 660sj - Kubota Stage 5
Engine Assembly - 660sj - Kubota Stage 5
Engine Installation - Kubota Wg2503 Dual Fuel
Engine Dual Fuel Assembly - Kubota Wg2503 Dual Fuel
Engine Kit Turbo Diesel - November 2019 And After - Kubota V2403
Engine Replacement Parts - Kubota V2403-M-T-E3b-Eu-Xb
Engine Diesel Replacement Parts - Cummins 2.8l Qsf Tier 4 Final
Engine With Radiator Replacement Parts - Kubota Wg2503 - Dual Fuel
Engine Swing Out Assembly
Engine Tray Lower Latch Assembly
Air Filter - Cummins
Battery Tray Bracket
Target Bracket - Weld Assembly - Kubota Stage 5 - 660sj
Battery Installation - July 2025 And Before
Radiator And Support Assembly
Lpg Tanks Installation
Tank Tray Installation
Chassis Lpg Tap Blocks Installation
Gasoline Tank Installation - Kubota Dual Fuel
Gasoline Tank Assembly - Kubota Dual Fuel
Fuel Tank Low Fill
Diesel Tank Installation - February 2019 And After - Deutz
Diesel Tank Installation - Kubota/Cummins
Hydraulic Tank Installation - Deutz
Cowling Installation - Cummins
Frame Assembly - Lh
Frame Assembly - Rh
Rear Door Assembly - Lh
Rear Door Assembly - Rh
Front Door Assembly - Lh
Front Door Assembly - Rh
Heater Valve
Pressure Filter Assembly
Main Boom Installation
Main Boom Installation - Dual Capacity
Top-Boom Assembly - 660sj
Main Boom Cylinder Support Assembly
Mid-Boom Assembly - 660sj
Base Boom Assembly - 660sj
Extend Cylinder Assembly
Tube Clamp Assembly Service Use Sp
Cable Track Installation With 4x4 Tube - Used Only On Sn 660sj-04-220401105 - 660sj-04-220601114, 660sj-04-220601117 And 660sj-04-220601118
Carrier Track Assembly - 2.00" - 3.50" Camber - Dynatect
Carrier Track Assembly - Brevetti
Cable Track Installation - 4x2
Mid-Boom Carrier Support Assembly
Tip- To Mid-Boom Assembly - Dual Capacity
Tip-Boom Assembly - Dual Capacity
Tip-Boom Assembly - July 2019 And Before
Tip-Boom Assembly - August 2019 And After
Tip- To Mid-Boom Assembly - March 2020 And After
Mid-Boom And Tip-End Wear Pad Assembly
Side And Mid-Boom Wear Pad Assembly
Top-Boom Assembly - 660sj - March 2020 And After
Quadrant Assembly
66" Jib Installation
66" Jib Assembly
6' Jib Assembly - Ce
6' Jib Assembly - 660sj - Ce - February 2019 And After
78" Jib Installation - April 2019 And Before
78" Jib Installation - May 2019 And After
78" Jib Assembly - January 2019 And Before
78" Jib Assembly - February 2019 And After
Platform Rotator Installation
Platform Rotator Installation - April 2019 And Before
Platform Rotator - Helac
Platform Rotator Assembly - Sn 660sj-11-180800163 And 660sj-04-200401001 And After - Dual Capacity
Platform Jib Installation - 6' Wide
Platform Installation - 6' Wide
Platform Round Tube Assembly Components
Platform Square Tube Assembly Components
Platform Mount Assembly
Pinch Rail 1.5" Round Platform Installation
Pinch Rail 1.38" Round Platform Installation
Snorkel Guard Assembly
Saloon Gate Assembly
Locking Gate Assembly
Rotator Hose Fitting Installation - Helac
Rotary Actuator - September 2019 And After - Sunji
Rotary Jib Actuator - Before Sn 660sj-04-200401001 Excluding 600sj-11-180800163
Decals Installation - 600s - Kubota Dual Fuel
Decals Installation - 660sj - Kubota Dual Fuel
Decal Installation Dual Capacity 660sj
Decal Installation - 600sj - Dual Capacity
Decal Kit Installation - 600s - Ansi - Cummins
Decal Kit Installation - 660sj - Ansi - Cummins
Decal Kit Installation - Ce/As
Decal Kit Installation - 660sj - Ce/As
Decals Installation - Dual Fuel - French
Decals Installation - 660sj High Capacity - French
Decal Kit Installation - 660sj - French
Decal Kit Installation - 660sj - German
Decal Kit Installation - 660sj - Cu - Spanish
Decal Kit Installation - 660sj - Swedish
Hydraulics
Drive Motor - Hydraulic - Hengli 38cc/9.2cc
Gear Hub Assembly
Main Manifold Installation
Main Manifold Oscilating Assembly
Main Manifold Installation - Dual Capacity
Main Manifold Assembly
Main Manifold - Oscillating Axle - Dual Capacity
Selector Valve Assembly
Shuttle Valve Assembly
Main Manifold Oscilating Control Valve
Main Manifold Harness - 660sj - Cummins
Main Manifold Check Valve Installation - 600s/660sj - Dual Fuel
Main Manifold In-Line Check Valve Assembly - 600s/660sj
Traction Manifold
Traction Manifold Assembly
Traction Manifold Assembly - Hydrostat
Drive System Installation - Hydrostat
Chassis Hydraulic Hoses Installation - February 2021 And Before
Chassis Hydraulic Hoses Installation - March 2021 And After
Chassis Hydraulics Installation - Hydrostat
Turntable Hydraulic Installation - June 2019 And After
Turntable Hydraulic Installation - Deutz
Turntable Hydraulic Installation - Dual Capacity
Main Hydraulic Pump Installation - 660sj - Cummins
Main Hydraulic Pump Installation - 660sj - Dual Capacity
Main Hydraulic Pump Installation - Deutz
Main Hydraulic Pump With Generator Installation - Cummins
Hydraulic Pump Installation - 600s/660sj - Kubota Dual Fuel
Hydraulic Pump Installation - November 2019 And After - Kubota
Load Sense Pump - Hengli/Cummins
Hydraulic Cooler Installation - January 2020 And Before
Hydraulic Cooler Installation - Feburary 2020 And After
Hydraulic Return Filter In Tank
Tip Boom Manifold Assembly
Boom Hoses Installation - 600s - June 2021 And Before
Boom Hoses Installation - 600s - July 2021 And After - Dual Capacity
Boom Hoses Installation - 660sj - Cummins
Boom Hoses Installation - 660sj - Deutz
Extend Cylinder - Hengli
Extend Cylinder - Rosenboom
Primary Level Cylinder - Hengli
Primary Level Cylinder Assembly - 600s/660sj - Rosenboom
Lift/Primary Level Cylinder Installation - 600s/660sj
Lift/Primary Level Cylinder Installation - 660sj
Lift Cylinder - Hengli
Lift Cylinder Assembly - 600s
Lift Cylinder Assembly - 660sj
Lift Cylinder - Rosenboom
Secondary Level Cylinder - Rosenboom
Secondary Level Cylinder - Hengli
Jib Cylinder - Rosenboom/Waltco
Jib Cylinder - Hengli
Jib Boom Cylinder - Fisher
Jib Boom Cylinder - Hydratech/Fisher/Rosenboom
Emergency Power Unit Installation - July 2025 And Before
Emergency Power Unit Assembly - April 2016 And After
Jib Cylinder - Hydratech
Steer Cylinder
Oscilating Axle Cylinder
Oscillating Axle Cylinder - 3.5" Bore X 4.5" Stroke
Electrical
Gp400c Adjustments Setups Version 6.0
Engine Harness - Kubota V2403 Stage 5
Engine Harness - Cummins Qsf 2.8l Ecu J2 To J8
Engine Harness - Cummins 2.8l Tier 4 Final
Engine Harness - 600s/660sj - November 2019 And After - Kubota Tier 3 And 4
Engine Harness - Deutz Tier 4 Final
Engine Harness - Deutz Td2.9 Stage 5
Turntable Electrical Harnesses Installation - Turbo
Turntable Electrical Harnesses Installation - Cummins
Turntable Electrical Installation - November 2019 And After - Kubota
Turntable Electrical Harness Installation - 600/660 - Deutz Tier 4 Final
Turntable Electrical Harness - 600/660 - August 2023 And Before - Deutz Tier 4 Final Dual Capacity
Turntable Electrical Harness Installation - Deutz Stage 5
Turntable Electrical Installation - September 2023 And After - Deutz Tier 4 Final Emr5 Dual Capacity
Turntable Electrical Installation - Deutz Stage 5 Dual Capacity
Turntable Electrical Installation - 600s/660sj - Kubota Dual Fuel
Engine Harness - 660sj - Kubota Dual Fuel
Turntable Electrical Harness - 600/660 - September 2023 After - Deutz Tier 4 Final Dual Capacity
Boom Function Harness
Boom Electrical Installation - 600s
Boom Electrical Installation - 600s - Deutz Stage 5
Boom Electrical Installation - 600s - Dual Capacity
Boom Electrical Installation - Dual Capacity
Boom Electrical Installation - 660sj
Lower Control Box Installation - 600s - Kubota Dual Fuel
Lower Control Box Assembly - 400s/600s - Kubota Dual Fuel
Lower Control Box Installation - 600s - Cummins
Lower Control Box Assembly - 600s - Cummins
Lower Control Box Installation - 600s - Tier 4 Final
Lower Control Box Assembly - 400/600 - Kubota Tier 4 Final
Lower Control Box Installation - Tier 4 Final
Lower Control Box Assembly - Deutz Tier 4 Final Dual Capacity
Lower Control Box Installation - 600s - Deutz Tier 4 Final
Lower Control Box Assembly - February 2020 And After - Deutz Tier 4 Final
Lower Control Box Installation - 600s - Deutz Stage 5
Lower Control Box Assembly - 400s/600s - Deutz Stage 5
Lower Control Box Installation - 600 - Duetz Stage 5
Lower Control Box Assembly - 400/600 - Duetz Stage 5
Lower Control Box Installation - Deutz Tier 4 Final
Lower Control Box Installation - Stage 5
Lower Control Box Assembly - Deutz Stage 5
Lower Control Box Installation - 660sj - Cummins
Lower Control Box Assembly - 660sj - Cummins
Lower Control Box Installation - 660sj - Kubota Dual Fuel
Lower Control Box Assembly - Kubota Dual Fuel
Lower Control Box Installation - 660sj - Deutz Stage 5
Lower Control Box To Amber Light Harness
Lower Control To Limit Switch Harness
Hydraulic Cooler Harness
Angle Proximity Harness
Generator Toggle Switch Spst Harness
Ac Power To Platform Installation - Ansi
Harness Sq Platform Lights
200psi Switch And Harness With Female Connector - Deutsch
Angle Sensor Harness - 600s
Elevation Switch To Dt06 4s Harness
Platform To Ground Control Harness
Ac Power To Platform Installation - 50hz - 110v - Tier 4 Final Dual Capacity - 660sj
Upper Cable Assembly - 600s
Upper Cable Assembly - 660sj
Selector Valve Harness
110v Power Outlet
Upper Control Box Installation - 400s/600s - Deutz Tier 4 Final
Upper Control Box Assembly - Deutz Tier 4 Final
Upper Control Box Installation - 400s/600s - Tier 4 Final
Upper Control Box Assembly Base - Deutz/Kubota Tier 4 Final Stage 5
Upper Control Box Installation - 400s/600s - Deutz Stage 5
Upper Control Box Assembly - 400s/600s - Deutz Stage 5
Upper Control Box Installation - 400s/600s - Deutz Stage 5 Dual Capacity
Upper Control Box Installation - 660sj - Cummins
Upper Control Box Assembly - 660sj - Cummins
Upper Control Box Installation - March 2020 And After - Deutz Tier 4 Final
Upper Control Box Assembly - Duetz Tier 4 Final
Upper Control Box Installation - 460/660 - Deutz Stage 5
Upper Control Box Assembly - 460sj/660sj - May 2019 And After - Deutz Stage 5
Upper Control Box Installation - 600s - Kubota Dual Fuel
Upper Control Box Assembly - 400s/600s - Kubota Dual Fuel
Upper Control Box Installation - Deutz Dual Capacity Stage 5
Upper Control Box Assembly - Deutz Dual Capacity Stage 5
Upper Control Box Assembly - 600s - Cummins
Upper Control Box Assembly - 600s - Cummins Dual Capacity
Upper Control Box Installation - 660sj - Kubota Dual Fuel
Upper Control Box Assembly - Kubota Dual Fuel
Upper Control Box Assembly - 600s - Dual Capacity
Upper Control Box Installation - Deutz Tier 4 Final Dual Capacity
Upper Control Box Assembly - Dual Capacity - Duetz/Cummins/Kubota - Tier 4 Final
Horn Installation
Horn Assembly
Joystick Controller Single Axis With Rocker Control Drive/Steer Pg-A46jrt-04-000361 And After
Push/Pull Assembly With Contact
Overload Cable Harness
Accessory Switch Enclosure Installation
Bumpguard Sensors 6ft Platform Harness
Proximity Sensor Harness - 600s
Harness 2 Conductor 18 Awg 80" Lg
Amber Beacon Installation
Amber Running Light Harness
Beacon Light Harness
Foot Switch Wide Tredle Assembly
Foot Switch Wide Tredle Harness
Foot Switch
Options
Gray Non-Marking Tires And Wheels Installation
Gray Non-Marking Track Installation
Gray Non-Marking Track Factory Assembly
Flotation Tire Installation
Non-Directional Tires And Wheels Installation
All-Terrain Tracks Installation
Rear Track Assembly
Front Right Track Assembly
Front Left Track Assembly
Track Weldment Service Kit
Track Field Installation Kit - Sn 660sj-04-240601270 And After
Track Field Installation Kit - Before Sn 660sj-04-240601270
Front Axle And Drive System Track Factory Installation
Front Axle Assembly Track Factory - 660sj-04-240601270 And After
Front Axle Assembly Track Factory - Before Sn 660sj-04-240601270
Rear Drive System Track Factory Installation - Sn 660sj-04-240601270 And After
Rear Drive System Track Factory Installation - 600s - Deutz Tier 4 Final All-Terrain Dual Capacity - Before Sn 660sj-04-240601270
Cold Weather Package Installation - Ansi
Cold Weather Package Installation - 600s/660sj - Kubota Dual Fuel
Cold Weather Package Installation - Deutz Dual Capacity
Extreme Cold Weather Package Installation - 600s/660sj - Kubota Dual Fuel
Extreme Cold Weather Package Installation - Deutz Dual Capacity
Extreme Cold Weather Package Installation - Ansi/Csa - December 2019 And After
Trackunit To Control Box Boom Installation
Track Steer Cylinder
Track Sprocket Assembly
Front Right Subframe Assembly
Front Left Subframe Assembly
Rear Subframe Assembly
Grounding Loops Installation - Ansi - Ce/Csa/As
Installation Tow Kit - 660sj
Airline To Platform Installation - 600s - Ansi - Ce/Csa/As
Airline To Platform Installation - 660sj - Ansi - Ce/Csa/As
Biodegradable Oil Installation
Drive Lights Harness
Led Light Assembly
Water To Platform Installiation - Ansi - Ce/Csa/As
Water Hose To Platform Installation - 600s - Ansi - Ce/Csa/As
Hydraulic Hose Heater Valve Installation
Hydraulic Warm Up Circuit Installation
Block Heater Installation - Cummins 2.8l
Cold Weather Upper Toggle Harness
Toggle Electrical Cold Weather Package Installation
Battery Blanket Installation
Engine Low Speed Switch
Extreme Environment Package - 600s - Deutz Tier 4 Final
Extreme Environment Package Bellows Installation - 600s
Extreme Environment Package Installation - 660sj - Ansi - Ce/Csa/As
Extreme Environment Package Installation - 660sj - Deutz
Extreme Environment Package Bellows Installation - 660sj - Deutz
Extreme Environment Package Brush Kit - 600s/660sj - Deutz
Power To Platform Installation - 600s - 50hz - Tier 4 Final Dual Capacity
Ac Power To Platform Installation - 600s - Ce/As
Ac Power To Platform Installation - 660sj - Ce/As
Generator Installation - Fabco/Cummins Qsf2.8l Tier 4 Final
2kw Generator Single V-Belt Assembly - Fabco
2.5kw Generator Sub-Assembly With 4 Pin Deutsch Connector - October 2019 And After
2.5kw Generator Installation - Kubota Stage 5 Dual Fuel
2.5kw Generator Installation - October 2019 And After - Deutz D2.9
2.5kw Generator 50hz 110v - Deutz Tier 4 Final Dual Capacity
2.5kw Generator - Deutz - Tier 4 Final Dual Capacity
2.5kw Generator Harness
7.5kw Generator Variable Displacement Installation
7.5kw Generator Assembly
10kw Generator Installation - Cummins - Deutz
10kw Generator Kit - Shawnee Power
10kw Generator - 400s/460sj/600s/660sj
10kw Generator Installation With Welders Package
10kw Generator Ac Power Cable Installation
10kw Generator Inverter Power Service Information
10kw Generator With Welder Kit And Brackets Installation
10kw Generator With Vfd Installation
10kw Generator Harness
20kw Generator Junction Box Assembly
20kw Generator Assembly
20kw Generator Enclosure Assembly
110v Female Plug - Awg 12/3 Cond - 72" Lg Harness
Pressure Washer Assembly
Pressure Washer
Water Tank Assembly
Water Tank Drain Assembly
Charge Pump Assembly - December 2019 And Before
Charge Pump Assembly - January 2020 And After
3'x3' Platform Jib Installation
11' Platform Installation
8' Platform Installation - Ansi - Ce/Csa - October 2019 And Before
8' Platform Installation - Ansi/Ce/Csa - November 2019 And After
8' Platform Jib Installation - Deutz Tier 4 Final
8' Platform Jib Installation - As
8' Platform Installation - As - November 2019 And After
8' Platform Bumpguard Installation
8' Platform Harness Bumpguard Upper Control Box
Deluxe Aircraft Package Installation - 6' Platform
Bumpguard Platform Installation- 6' Steel
Aircraft Package Installation - 6' Platform - Steel
Glazier Package Installation - Round Tubing Platforms Only
Glazier Package Installation - Square Tubing Platforms Only
Upper Control Box Cover Installation - Round
Upper Control Box Cover Installation - Square
Safety Rail Add On
Utility Lamp Control Box Harness
Personal Fall Arrest System Installation
Top Rail Installation
Base Welder Package Installation
Welder Installation - Lincoln
Welder Assembly - Lincoln
400a Welder Factory Installation - Lincoln Dual Capacity - 660sj
400a Welder Installation - 660sj - January 2020 And After - Lincoln
Electrode Holder Wire Assembly
Pipe Rack Installation
Pipe Rack Boom Assembly
Platform Tool Tray Installation - Ansi - Ce/Csa/As
Lanyard Mount Installation Option
Chassis Light Package Installation
Platform Light Package Installation
Light Package Installation - Ansi - Ce/Csa/As
Light Package - Square Platform
Schematics
Electrical Schematic - Kubota Stage 5 - 660sj
Electrical Schematic Tier 3 Through Stage 5 - Deutz/Cummins/Kubota Dual Capacity
Electrical Schematic Qsf - Cummins
Electrical Schematic Qsf - After November 1, 2017 - Updated Main Manifold Wiring - Cummins
Electrical Schematic Qsf - After November 13, 2017 Updated Wiring - Cummins
Electrical Schematic Qsf - After December 15, 2017 Added Length And Angle Sensor - Cummins
Electrical Schematic 1432993f Qsf - After June 20, 2018 Updated Alternator Wiring And Fuse - Cummins
Electrical Schematic Qsf - After June 20, 2018 Updated Alternator Wiring And Fuse - Cummins
Electrical Schematic Qsf - After August 2, 2018 Wire J2-5 Updated Starter Switch Wiring - Cummins
Hydraulic Schematic - Kubota Stage 5 - 600s 660sj
Hydraulic Schematic - Kubota Dual Capacity
Hydraulic Schematic - Dual Capacity
Hydraulic Schematic
Appendix A:pages Index
Appendix B:parts Index
