Snorkel Aerial Work Platform 600S 660SJ Parts Manual 1432679
Brand: Snorkel
Type of Manual: Repair Parts Manual
Model: Snorkel 600S 660SJ Oscillating Axle Aerial Work Platform
Serial Number: 00099 And Before
Part Number: 1432679
Publication Date: 2017
Number of Pages: 491 Pages
Repair Parts
Wheel And Tire Assembly
Standard Tires And Wheels Installation
Front Axle And Drive System Installation
Front Axle Assembly
Slew Bearing Installation
Drive System Rear Installation
Chassis Cover Installation
Chassis Counterweight Installation - 600s
Chassis Counterweight Installation - 660sj
Turntable Installation
Turntable Counterweight Installation
Turntable Counterweight Installation - 660sj
Swing Drive Installation - Kubota
Swing Drive Gearbox
Battery Tray Bracket
Battery Installation - July 2025 And Before
Engine Installation - Cummins 2.8l Tier 4 Final
Engine Assembly - Cummins 2.8l
Replacement Parts List - Cummins Diesel Qsf2.8l Tier 4 Final
Installation - 600s/660sj - Deutz Td2.9l Stage 5
Hydraulic Tank Installation
Hydraulic Tank Assembly
Hydraulic Motor To Knuckle Assembly - Lh
Hydraulic Motor To Knuckle Assembly - Rh
Hydraulic Motor Rear Assembly
Hydraulic Fluid Cooler Installation - Cummins
Rotary Swivel Installation - 660sj
Centerpost Assembly
Emergency Power Unit Installation
Main Manifold Installation
Oil Cooler Tray Assembly - Cummins
Pinion Guard Plt
Guard Weldment Pinion Gear
Air Filter - Cummins
Fuel Filter Primary
Fuel Filter Secondary
Radiator And Support Assembly
Tank Tray Installation
Diesel Fuel Tank Installation
Fuel Tank Low Fill
Horn Installation
Main Hydraulic Pump Installation
Lower Control Box Installation - 600s - Cummins
Lower Control Box - 600s - Cummins
Lower Control Box Installation - 660sj - Cummins
Lower Control Box - 660sj - Cummins
Cowling Installation - Cummins
Rear Door Assembly - Lh
Rear Door Assembly - Rh
Front Door Assembly - Lh
Front Door Assembly - Rh
Frame Assembly - Lh
Frame Assembly - Rh
Nose Cone - Rh
Nose Cone - Rh
Nose Cone - Lh
Nose Cone - Lh
Ware Pad Cable Anchor Update - Sn 660sj-11-161200002 To 660sj-11-170600039
Main Boom Installation
Main Boom Assembly
Inner/Top Boom Wear Pad Assembly
Top- To Mid-Boom Wear Pad Assembly
Main Boom Cylinder Support Assembly
Tip-Boom To Intermediate Boom Assembly
Tip-Boom Assembly - Dual Capacity
Top-Boom Assembly - 660sj
Tip- To Mid-Boom Assembly
Booms To Turntable Assembly
Extend Cylinder Assembly
Jib Installation - 460sj/660sj
78" Jib Assembly - January 2019 And Before
78" Jib Assembly - February 2019 And After
66" Jib Assembly
Cable Track Installation
Mid-Boom Carrier Support Assembly
Carrier Track Assembly - 600s/660sj
Platform Rotator Installation
Rotator Hose Fitting Installation - Helac
Quadrant Assembly
Platform Rotator Assembly - 460sj/660sj
Snorkel Guard Assembly
Decal Kit Installation - 600s - Ansi - Cummins
Decal Kit Installation - Ce/As
Decal Installation - Non-Ansi - Cummins
Decal Installation - French
Hydraulics
Gear Hub Assembly
Main Manifold Oscilating Assembly
Main Hydraulic Manifold Oscillating Axle - Hawe
Traction Manifold Assembly
Traction Manifold
Load Sense Pump - Hengli/Cummins
Pressure Filter Assembly
Chassis Hydraulic Hoses Installation
Chassis Hydraulic Hoses Installation - March 2021 And After
Turntable Hydraulic Hose Installation
Hydraulic Return Filter In Tank
Centerpost
Boom Hoses Installation - 600s
Boom Hoses Installation - 660sj
Primary Level Cylinder
Primary Level Cylinder Assembly - 600s/660sj - Rosenboom
Primary Level Cylinder - Rosenboom
Secondary Level Cylinder - Hengli
Secondary Level Cylinder - Rosenboom
Lift/Primary Level Cylinder Installation - 660sj
Lift Cylinder - Hengli
Lift Cylinder Assembly - 660sj
Lift Cylinder - Rosenboom
Selector Valve Assembly
Selector Valve Jib Rotate
Emergency Power Unit Assembly - April 2016 And After
Dual Counterbalance Valve Rotator - Helac
Axle Lock Cylinder - Hengli
Extend Cylinder - Rosenboom
Extend Cylinder - Hengli
Jib Cylinder - Hengli
Heater Valve
Electrical
Turntable Electrical Harness Installation
Engine Harness - Cummins Qsf 2.8l Ecu J2 To J8
Engine Ecu Harness - Cummins Qsf 2.8l J2 To J8
Lower Control To Limit Switch Harness
Lower Control Box To Amber Light Harness
Lower Control To Pressure Switch Harness
Elevation Switch To Dt06-4s Harness
Hydraulic Cooler Fan Harness
Main Manifold Harness - 660sj - Cummins
Temperature Switch Assembly
Generator Toggle Switch Harness Spst
Boom Electrical Installation - 600s
Boom Electrical Installation - 660sj
Platform Mount Assembly
Platform Installation - Ansi - Ce/Csa
Platform Round Tube Assembly Components
Platform Assembly
Upper Cable Assembly - 600s
Upper Cable Assembly - 660sj
Upper Control Box Installation - 600s - Cummins
Upper Control Box Assembly - 600s - Cummins
Upper Control Box Installation - 660sj - Cummins
Upper Control Box Assembly - 660sj - Cummins
Horn Assembly
Overload Cable Harness
Snorkel Guard Cable M12 X 2m L
Joystick Controller Turntable Swing
Joystick Controller Single Axis Platform Swing And Telescope
Two Axis Jib And Platform Joystick Controller
Foot Switch
Foot Switch Wide Tredle Assembly
Foot Switch Harness
Options
Airline To Platform Installation - 600s
Airline To Platform Installation - 660sj
Biodegradable Oil Installation
Cold Weather Package Installation - Ansi/Csa
Extreme Cold Weather Package Installation - Ansi/Csa
Toggle Electrical Cold Weather Package Installation
Accessory Switch Enclosure Installation
Battery Blanket Installation
Heater Valve Installation - 660sj
Hydraulic Warm Up Circuit Installation
Hydraulic Heater Valve Hose Installation
Block Heater Installation - Cummins 2.8l
Air Hose Assembly - 600s
Air Hose Assembly - 660sj
Generator Installation - Cummins/Fabco Qsf2.8l
Ac Power To Platform Installation - 600s - Ansi
Ac Power To Platform Installation - 600s - Non-Ansi
Ac Power To Platform Installation - 660sj - Ansi
Ac Power To Platform Installation - 660sj - Non-Ansi
110 Volt Receptacle Assembly
Amber Beacon Installation
Amber Running Light Harness
Beacon Light Harness
Maintenance
Maintenance
Schematics
Electrical Schematic - Cummins
Hydraulic Schematics
Appendix A
ages Index
Appendix B
arts Index
Brand: Snorkel
Repair Parts
Front Axle Assembly
Swing Drive Gearbox
Centerpost Assembly
Pinion Guard Plt
Fuel Filter Primary
Fuel Tank Low Fill
Horn Installation
Frame Assembly - Lh
Frame Assembly - Rh
Nose Cone - Rh
Nose Cone - Rh
Nose Cone - Lh
Nose Cone - Lh
Main Boom Assembly
66" Jib Assembly
Quadrant Assembly
Hydraulics
Gear Hub Assembly
Traction Manifold
Centerpost
Heater Valve
Electrical
Platform Assembly
Horn Assembly
Foot Switch
Foot Switch Harness
Options
Maintenance
Maintenance
Schematics
Appendix A
Appendix B
