Snorkel Aerial Work Platform 600AJ Parts Manual 1680160-000
Brand: Snorkel
Type of Manual: Parts Manual, Electrical Schematic, Hydraulic Schematic
Model: Snorkel 600AJ Aerial Work Platform
Part Number: 1680160-000
Publication Date: 2024
Number of Pages: 394 Pages
600aj General Information
Repair Parts
Chassis Assembly
Chassis Covers Installation
Standard Tires And Wheels Installation
Front Axle And Drive System Installation
Front Axle Assembly
Gear Hub Assembly
Drive System Installation - Hydrostat
Slew Bearing Installation - July 2025 And Before
Tanks Installation
Fuel Tank Assembly
Fuel Tank Sub-Assembly
Hydraulic Fluid Reservoir Assembly
Hydraulic Fluid Reservoir Sub-Assembly
Emergency Lower Installation
Oil Cooler Installation
Engine Installation - Kubota 2403 Stage 5
Engine Assembly - Kubota Stage 5
Engine Tray Latch Assembly
Flywheel Coupling Assembly
Cowling Installation
Cowling Assembly - Rh
Cowling Assembly - Lh
Turntable Installation
Turntable/Riser Assembly
Turntable Counterweight Installation
Swing Drive Installation
Riser Installation
Riser/Boom Assembly
Main Boom Installation
Main Boom Assembly
Base Boom Assembly
Inner Boom Assembly
Hose Carrier Installation
Inner/Top Boom Wear Pad Assembly
Main Bottom Wear Pad Assembly
Side And Mid-Boom Wear Pad Assembly
66" Jib Installation
66" Jib Assembly
Rotary Actuator - High Capacity Jib 176 Degree
Jib Quad - Hi Capacity - Sensor Mount Assembly
Platform Jib Installation - 6' Wide
Decals Installation - Ansi - English
Decals Installation - French
Decals Installation - Bi-Lingual - English/French
600aj Decals Kit - English-French
Hydraulic
Chassis Hydraulics Installation - Hydrostat
Drive Motor - Hydraulic - Hengli 38cc/9.2cc
Gear Hub Assembly
Steer Cylinder
Oscillating Axle Cylinder - 3.5" Bore X 4.5" Stroke
Traction Manifold Assembly - Hydrostat
Centerpost Swivel Installation - Hydrostat
Centerpost Assembly - Hydrostat
Main Manifold Installation
Main Manifold Assembly
Turntable Hydraulic Hose Installation
Boom Hydraulics Installation
Tip Boom Manifold Assembly
Riser Cylinder Assembly
Riser Cylinder
Lift Cylinder Assembly
Lift Cylinder
Secondary Leveling Cylinder
Extend Cylinder Assembly
Jib Cylinder - High Capacity
Electrical
Engine Harness - Kubota V2403 Stage 5
Emergency Power Unit Assembly
Lower Control Box Installation
Lower Control Box Assembly
Lower Control Box Harness - Pg
Control Harness - Turntable
Push/Pull Assembly With Contact
Horn Assembly
Turntable/Riser Electrical Installation - Kubota Stage 5
Turntable Harness - Kubota Stage 5
Hydraulic Manifold Harness
Boom Electrical Installation - Effectivity Date July 26, 2026
Boom Limit Switches Harness
Jib High Capacity Harness
Jib Harness
Riser Harness
Power To Platform - Outlet Harness
Power To Platform - Turntable Inlet Harness
Snorkel Guard Harness
Overload Cable Harness
Boom Control Harness
Upper Control Box Installation
Upper Control Box Assembly - Pg
Upper Control Box - Pg
Upper Control Box Harness - Pg
Amber Running Light Harness
Options
Non-Directional Tires And Wheels Installation
Gray Non-Marking Tires And Wheels Installation
Extreme Cold Weather Package Installation
Cold Weather Package Installation - Kubota
Hydraulic Warm-Up Circuit Option
Block Heater - Kubota Stage 5 - Option
2.5kw Generator
Tow Kit Installation
Heater Manifold Harness
Extreme Environment Package
Extreme Environment - Brush Kit
Extreme Environment - Bellows Kit
Power To Platform Installation - Ansi
3'x3' Platform Jib Installation
8' Platform Jib Installation - Deutz Tier 4 Final
8' Platform Jib Installation - As
Airline To Platform Installation - Option
Aircraft Package Installation - 6' Platform - Steel
Aircraft Package Installation Option - 8' Platform - Steel
Deluxe Aircraft Package Installation Option - 8' Platform - Steel
Deluxe Aircraft Package Installation - 6' Platform
Personal Fall Arrest System Installation
Bumpguard Installation Option - 8' Steel
Bumpguard Padding Installation - 8'
Bumpguard Platform Installation- 6' Steel
Upper Bumpguard Installation Option - 8'
Bumpguard Sensors 6ft Platform Harness
Bumpguard Sensors Harness - 8' Platform Steel
Lanyard Mount Installation Option
Half Platform Mesh 8ft Option
Light Package Installation
Chassis Light Package Installation
Platform Light Package Installation
Drive Lights Harness
Schematics
Hydraulic Schematic - 600aj
Electrical Schematic - 600aj
Appendix A
ages Index
Appendix B
arts Index
Brand: Snorkel
Repair Parts
Chassis Assembly
Front Axle Assembly
Gear Hub Assembly
Tanks Installation
Fuel Tank Assembly
Riser Installation
Riser/Boom Assembly
Main Boom Assembly
Base Boom Assembly
Inner Boom Assembly
66" Jib Assembly
Hydraulic
Gear Hub Assembly
Steer Cylinder
Riser Cylinder
Lift Cylinder
Electrical
Horn Assembly
Jib Harness
Riser Harness
Options
2.5kw Generator
Schematics
Appendix A
Appendix B
