Snorkel Aerial Work Platform 4606SJ Parts Manual 1434878
Brand: Snorkel
Type of Manual: Parts Manual, Electrical Schematic, Hydraulic Schematic
Model: Snorkel 4606SJ Aerial Work Platform
Serial Number: 000000 and after
Part Number: 1434878
Publication Date: 2020
Number of Pages: 321 Pages
Repair Parts
Chassis Covers Installation
Turntable Installation
Turntable Counterweight Installation
Turntable Hoods Installation
Standard Tires And Wheels Installation
Rear Drive System Installation
Front Axle And Drive System Installation
Front Axle Assembly
Slew Bearing Installation - July 2025 And Before
Swing Drive Installation
Swing Drive Gearbox
Pinion Guard Installation
Centerpost Installation - Deutz
Engine Installation With Prox Sense Slew - Deutz Tier 4 Final Dual Capacity
Engine With Tray Installation - Deutz D2.9 Tier 4 Final - October 2024 And Before
Engine Assembly - Deutz D2.9 Tier 4 Final - October 2024 And Before
Engine - Deutz D2.9 L4 Non-Turbo
Engine Tray Lower Latch Assembly
Hydraulic Tank Installation - Kubota
Hydraulic Tank - March 2018 And Before - Deutz/Kubota
Hydraulic Cooler - Iea
Diesel Tank Installation - Deutz
Diesel Tank
Main Bottom Wear Pad Assembly
Inner To Base Boom Installation
Main Boom Installation
Main Boom Assembly
Carrier Track Installation
Carrier Track Replacement Links
Carrier Track Rh/Lh Single Link - Dynatect
Inner Boom Assembly
Lift/Primary Level Cylinder Installation - Hengli
Primary Level Cylinder - Hengli
Pre-Filter To Pump Hose Assembly - Deutz
Fuel Return Line Hose Return
Tank To Pre-Filter Hose Assembly
Emergency Power Unit Installation
78" Jib Installation - May 2019 And After
78" Jib Installation - April 2019 And Before
78" Jib Assembly - February 2019 And After
Quadrant Assembly
Decal Installation - Ansi
Hydraulic
Chassis Hydraulic Hoses Installation - February 2021 And Before
Chassis Hydraulic Hoses Installation - March 2021 And After
Drive Motor - Hydraulic - Hengli 38cc/9.2cc
Gear Hub Assembly
Main Manifold Installation Assembly - Oscillating Axle
Main Manifold Assembly
Traction Manifold Gen 2
Pump Installation - Hengli 45cc
Emergency Lowering Kit Installation
Turntable Hose Installation - February 2020 And After - Deutz
Chassis Hose Kit
Boom Hose Kit
Boom Hoses Installation - Dual Capacity
Emergency Power Unit Assembly - April 2016 And After
Steer Cylinder
Oscilating Axle Cylinder
Cylinder Main Boom Extend
Secondary Level Cylinder - Hengli
Jib Cylinder - Hengli
Extend Cylinder Assembly
Rotary Actuator - September 2019 And After - Sunji
Actuator - Sjh Rotator Kit - Sunji
Electrical
Turntable Electrical Harnesses Installation Non-Turbo - Duetz 2.9 Tier 4 Final
Main Manifold Harness Assembly - Cummins
Generator Toggle Switch Spst Harness
Glow Plug Power Harness - Deutz
Selector Valve Harness
Elevation Switch To Dt06-4s Harness
Engine Harness - Deutz D2.9 L4
Harness Sq Platform Lights
Lower Control Box Installation - Deutz Tier 4 Final
Lower Conrol Box Assembly - Deutz Tier 4 Final
Lower Control Box Harness To Amber Beacon
Lower Control To Pressure Switch Harness
Lower Control To Limit Switch Harness
Boom Electrical Installation
Upper Control Box Installation - Deutz Tier 4 Final
Upper Control Box Assembly - Duetz Tier 4 Final
Horn Installation
Horn Assembly
Amber Beacon Installation
Beacon Light Harness
Foot Switch Wide Tredle Assembly
Options
Gray Non-Marking Tires And Wheels Installation
Gray Non-Marking Tires And Wheels Assembly - Exmile
Gray Non-Marking Tires And Wheels Assembly - Over The Road
Base Welder Package Installation
8' Platform Jib Installation - As
Ac Power To Platform Installation - Ansi
10kw Generator Installation - Deutz
Light Package Kit
Light Package - Square Platform
Maintenance
Maintenance
Schematics
Electrical Schematic - Removed Fuse And Rerouted E-Pump - Deutz D2.9
Hydraulic Schematic
Appendix A
ages Index
Appendix B
arts Index
Brand: Snorkel
Repair Parts
Front Axle Assembly
Swing Drive Gearbox
Diesel Tank
Main Boom Assembly
Inner Boom Assembly
Quadrant Assembly
Hydraulic
Gear Hub Assembly
Chassis Hose Kit
Boom Hose Kit
Steer Cylinder
Electrical
Horn Installation
Horn Assembly
Options
Light Package Kit
Maintenance
Maintenance
Schematics
Hydraulic Schematic
Appendix A
Appendix B
