Snorkel Aerial Work Platform 4606SJ Operators Manual 1434786 2024
Brand: Snorkel
Model: Snorkel 4606SJ Aerial Work Platform
Serial Number: 000000 and after
Part Number: 1434786
Publication Date: 2024
Number of Pages: 80 Pages
Electrical Danger Inside Front Cover
Proposition 65 Warning Inside Front Cover
Wheel Orientation Warning Inside Front Cover
Chapter 1 – Introduction
Aerial Platform Features
Options
Operator’s Manual
Safety Alerts
Operation
Maintenance
Manual of Responsibilities – ANSI
MEWP Safe Use – AS/NZS
AS/NZS 141810 Commissioning
CE Compliance
Additional Information
Chapter 2 – Specifications
Component Identification
Working Envelope
General Specifications
Engine Specifications
Engine Oil Viscosity
Chapter 3 – Safety
Electrocution Hazards
Minimum Safe Approach Distance – ANSI
Minimum Safe Approach Distance – AS/NZS
Platform Capacity
Manual Force
Wind Speeds
Prestart Inspection
Work Place Inspection and Practices
Operation
Tip-Over and Falling Hazards
Engine and Fuel Handling Precautions
Placards and Decals
General Safety Rules
Chapter 4 – Safety Devices
Emergency Stop Controls
Emergency Power System
Emergency Lowering Knob
Ground Operation Switch
Platform Foot Switch
Guardrails
Fall Protection Anchors
Ground Fault Circuit Interrupter
Platform Overload Sensing System
Boom/Drive Cut-out
Tilt Alarm/Warning Lights
Engine Protection Systems
High Engine Temperature Alarm
Low Oil Pressure Alarm
Horn
Drive Motion Alarm
All Motion Alarm
Flashing Lights
Driving Lights
Platform Work Lights
Snorkel Guard
Chapter 5 – Gauges and Displays
Diagnostic Center Display
Platform Overload/Tilt Warning Lights
Engine Warning Lights
Fuel
Fluid Level and Temperature Gauge
Engine Oil
Chapter 6 – Controls
Battery Disconnect Switch
Lower Controls
Start/Emergency Power/Ground Operation Switch
Emergency Stop Button
Controls Selector Switch
Rotation Switch
Boom Elevation Switch
Boom Extension Switch
Jib Articulation Switch
Platform Level Switch
Platform Rotation Switch
Platform Overload Warning Light
Tilt Alarm
Hydraulic Oil Warm-Up Switch
Circuit Breaker Reset Buttons
Upper Controls
Start Switch
Drive Joystick
Drive Range Switch
Boom Joystick
Boom Extension Joystick
Jib/Platform Rotate Joystick
Emergency Power Switch
Horn Switch
Override Switch
Tilt Alarm
AC Generator Switch
Driving and Platform Work Lights25Table of Contents
4606SJ – 1434786
Chapter 7 – Prestart Inspection
Operator’s Manual Holder
Oil Level
Coolant
Fuel Line
Battery Terminals
Cables and Wiring Harness
Fluid Level
Fluid Filter
Hoses, Tubes, and Fittings
Tires and Wheels
Lower Control Station
Operating Controls
Emergency Stop
Emergency Power
Emergency Lowering
Flashing Lights
Structures
Weldments
Boom Slide Pads
Fasteners
Upper Control Station
Guardrail System
Operating Controls
Emergency Stop
Emergency Power
Horn Switch
Snorkel Guard
Electrical Power Outlet
Panel Carrier
All Motion Alarm
Sandblast Protection Kit
Air Line to Platform
Tow Kit
Platform Glazier Package
Platform Welder
Drive Motion Alarm
Placards and Decals
Prestart Inspection Checklist
Inspection and Maintenance Schedules
Chapter 8 – Operation
Cold Weather Start-Up
Hydraulic System Cold Weather Warm-Up
Hydraulic System Warm-Up Switch
Manually Warming The Hydraulic System
Preparing for Operation
Lower Controls
Upper Controls
Boom Operation
Driving and Steering
Drive Speeds
Pivoting Front Axle
Machine in Stowed Position
Machine Not in Stowed Position
Boom and Turntable Position/Axle and Drive Speeds
Drive Motion Alarm
Boom/Drive Cut-out
Snorkel Guard
Override Switch
Gradeability
Percent vs Degree of Slope
Driving on a Slope
Calculating Percent Grade
Machine Gradeability
AC Generator
Panel Carrier
Platform Capacity
Air Line
Driving Lights
Platform Capacity
Platform Welder
Platform Capacity
After Use Each Day
Chapter 9 – Stowing and Transporting
Stowing
Transporting
Driving
Winching
Hoisting
Securing for Transport
Storage
Chapter 10 – Emergency Operation
Lower Controls
Upper Controls
Override Switch
Emergency Lowering
Towing
Chapter 11 – Troubleshooting
Troubleshooting Chart
Appendix A – Glossary
Limited Warranty
Brand: Snorkel
Options
Operator’s Manual
Safety Alerts
Operation
Maintenance
CE Compliance
Working Envelope
Chapter 3 – Safety
Platform Capacity
Manual Force
Wind Speeds
Prestart Inspection
Operation
Placards and Decals
Guardrails
Boom/Drive Cut-out
Horn
Drive Motion Alarm
All Motion Alarm
Flashing Lights
Driving Lights
Snorkel Guard
Fuel
Engine Oil
Lower Controls
Rotation Switch
Tilt Alarm
Upper Controls
Start Switch
Drive Joystick
Drive Range Switch
Boom Joystick
Horn Switch
Override Switch
Tilt Alarm
AC Generator Switch
4606SJ – 1434786
Oil Level
Coolant
Fuel Line
Battery Terminals
Fluid Level
Fluid Filter
Tires and Wheels
Operating Controls
Emergency Stop
Emergency Power
Emergency Lowering
Flashing Lights
Structures
Weldments
Boom Slide Pads
Fasteners
Guardrail System
Operating Controls
Emergency Stop
Emergency Power
Horn Switch
Snorkel Guard
Panel Carrier
All Motion Alarm
Tow Kit
Platform Welder
Drive Motion Alarm
Placards and Decals
Lower Controls
Upper Controls
Boom Operation
Drive Speeds
Pivoting Front Axle
Drive Motion Alarm
Boom/Drive Cut-out
Snorkel Guard
Override Switch
Gradeability
Driving on a Slope
AC Generator
Panel Carrier
Platform Capacity
Air Line
Driving Lights
Platform Capacity
Platform Welder
Platform Capacity
After Use Each Day
Stowing
Transporting
Driving
Winching
Hoisting
Storage
Lower Controls
Upper Controls
Override Switch
Emergency Lowering
Towing
Limited Warranty
