Hyundai
86
176,834
Sany Crawler Crane SCC800C Parts Catalog EN ZH
Language: English, Chinese
Brand: Sany
Type of Machine: Crawler Crane
Model: Sany SCC800C Crawler Crane
Number of Pages: 261 Pages
1. 履带起重机总成 Crawler Crane Assembly
10079389 履带起重机总成 Crawler Crane Assembly Q80C(A.9)​
2.履带行走装置 Crawler Traveling System
□10100512 左履带总成 Left Crawler Assembly Q80C.1(G.2)​
21022785 驱动装置 Driving Mechanism Q80.1.6(C.2)​
10100519 履带组件 Crawler Subassembly Q80C.1.2(C.4)​
21022782 托轮总成 Support Roller Assembly Q80.1.4(B.2)​
21022783 支重轮总成 Track Roller Assembly Q80.1.5(B.2)​
21022781 张紧机构 Tensioning Mechanism Q80.1.3(C.2)​
10083649 脚踏总成 Folding Step Assembly Q150.1.11(F.2)​
□10107180 左履带总成 Left Crawler Assembly Q80C.1(a)(A.8)​
21024389 驱动装置 Driving Mechanism Q80.1.2(B.4)​
□10107183 左履带总成 Left Crawler Assembly Q80C.1(b)(H.2)​
21033622 驱动装置 Driving Mechanism Q80.1(b).2(B.2)​
□10507493 左履带总成 Left Crawler Assembly Q80C.1(d)(B.2)​
10507227 驱动装置 Driving Mechanism Q80C.1(d) (B.3)​
□10107186 右履带总成 Right Crawler Assembly Q80C.2(F.2)​
□10107187 右履带总成 Right Crawler Assembly Q80C.2(a) (A.9)​
□10107190 右履带总成 Right Crawler Assembly Q80C.2(b) (G.2)​
□10507494 右履带总成 Right Crawler Assembly Q80C.2(d) (B.2)​
10080196 底座 Chassis Q80C.3(K.5)​
3.转台部分 Platform
□10142583 主平台 Main Platform Q80C.10(B)(K.3)​
10134260 主平台 Main Platform Q80C.10(I.3)​
10100991 左平台 Left Platform Q80C .11(b)(H.3)​
10101100 右平台 Right Platform Q80C.12(A)(H.7)​
4. 机动设备 Engine System
□10211576 机动设备 Engine System Q80C.20(a) (D.2)​
10078480 冷却系统 Cooling System Q100C.20(a).1 (I.2)​
21033058 燃油系统 Fuel System Q100.20(a).2 (F.3)​
10078530 进气系统 Air Inlet System Q100C.20(a).3 (F.3)​
10078534 排气系统 Exhaust System Q100C.20(a).4 (E.2)​
10211498 柴油机安装 Installation of Diesel Engine Q80C.20(a).2(E.2)​
□10211800 机动设备 Engine System Q80C.20(E.3)​
10211796 柴油机安装 Installation of Diesel Engine Q80C.20.1(K.2)​
21022364 排气系统 Exhaust System Q80C.20.2(D.2)​
21022365 进气系统 Air Inlet System Q80C.20.3(E.4)​
□10530117 机动设备 Engine System Q80C.20(B) (B.3)​
10530113 进气系统 Air Inlet System Q80C.20(B).1(C.4)​
□10530118 机动设备 Engine System Q80C.20(c) (C.2)​
10078480 冷却系统 Cooling System Q100C.20(a).1 ( I.2)​
10530114 进气系统 Air Inlet System Q80C.20(C).1(A.2)​
21033812 柴油机安装 Installation of Diesel Engine Q100.20(C).1(C.3)​
5. 联轴器安装 Shaft Coupling Installation
□10211665 联轴器安装 Shaft Coupling Installation Q80C.21(A.2)​
□10211666 联轴器安装 Shaft Coupling Installation Q80C.21(a)(E.6)​
□10211667 联轴器安装 Shaft Coupling Installation Q80C.21(b)(A.2)​
□10211668 联轴器安装 Shaft Coupling Installation Q80C.21(c)(D.3)​
6.覆盖件 Covers
10131125 操纵总成 Controls Assembly Q150.24(E.4)​
10110675 司机室 Operator's Cab Q150.25(G.4)​
10208211 覆盖件 Covers Q80C.26(E.3)​
□10208533 护栏 Guardrail Q80C.29(D.2)​
□10208620 护栏 Guardrail Q80C.29(a) (D.2)​
7. 空调总成 Air Conditioning System
□10701133 空调总成 Air Conditioning System Q80.27(c)(B.4)​
10701126 空调总成 Air Conditioning System Q80.27(c).1(C.4)​
□10701707 空调总成 Air Conditioning System Q80.27(d)(B.2)​
10701703 空调总成 Air Conditioning System Q80.27(d).1(C.2)​
8. 机构 Mechanism
□21023659 回转机构 Slewing Mechanism Q80.30(G.4)​
□21014877 回转机构 Slewing Mechanism Q80.30(a)(G.5)​
□21023693 主提升带自由落钩 Main Hoisting with Free Fall Q80.31(a) (G.2)​
□21030007 主提升机构 Main Hoisting Mechanism Q80.31(c) (F.2)​
□21032814 主提升机构 Main Hoisting Mechanism Q80.31(d) ( G.2)​
□21038460 主提升带自由落钩 Main Hoisting with Free Fall Q80.31(e) (G.3)​
21038473 制动器 Brake Q80.31(e).2(E.2)​
21038474 离合器 Clutch Q80.31(e).3(I.3)​
□21030012 副提升机构 Auxiliary Hoisting Mechanism Q80.32(b) (E.2)​
□21032817 副提升机构 Auxiliary Hoisting Mechanism Q80.32(c) (H.2)​
□21023706 变幅机构 Luffing Mechanism Q80.33(G.2)​
□21026347 变幅机构 Luffing Mechanism Q80.33(a)(J.2)​
9.配重块 Counterweight Blocks
10081277 配重块 Counterweight Blocks Q80C.41(I.4)​
10.A型架 A-Frame
21023939 A型架 A-Frame Q80.50(D.2)​
21023941 人字架装置 A-Frame Q80.50.1(D.3)​
21023942 横梁装置 Cross Beam Q80.50.2(C.3)​
21023943 下滑轮架装置 Inner Bridle Q80.50.3(E.2)​
21023944 上滑轮架装置 Outer Bridle Q80.50.4(B.3)​
11.作业设备 Operation Equipment
□21037936 主臂基本臂 Basic Boom Q80.60(D.4)​
21022921 上节臂 Boom Tip Q80.60.3(J.5)​
21022925 下节臂 Boom Base Q80.60.4(D.3)​
□10116723 主臂基本臂 Basic Boom Q80C.60(C.4)​
21022921 上节臂 Boom Tip Q80C.60.3(J.5)​
21022925 下节臂 Boom Base Q80C.60.4(D.3)​
21022924 3m 中间臂 3m (9'10") Boom Insert Q80.61(E.4)​
21022923 6m 中间臂 6m (19'8") Boom Insert Q80.62(E.4)​
21022922 9m 中间臂 9m (29'6") Boom Insert Q80.63(E.4)​
□21037937 固定副臂基本臂 Basic Fixed Jib Q80.75(E.2)​
21023115 上节臂 Jib Tip Q80.75.10(F.2)​
21023116 撑杆 Jib Strut Q80.75.5(F.2)​
□21037938 4.5m(14'9")固定副臂 Fixed Jib Q80.80(C.2)​
□21023345 加长臂 Extension Jib Q80.97(G.2)​
12.起重钩 Hook Block
□10456689 80t(88UST)吊钩Hook Block DG80C.25(D.2)​
□10780217 50t(55UST)吊钩Hook Block DG80C.23(D.2)​
□10787279 25t(27.5UST)吊钩Hook Block DG80C.19(D.2)​
□10782701 9t(9.9UST)吊钩Hook Block DG80C.11(D.3)​
13. 电气系统 Electrical System
□10169451 平台电气 Platform Electrical Circuit Q80C.101(J.2)​
□10205788 平台电气 Platform Electrical Circuit Q80C.101(a) (J.2)​
10167636 主臂电气 Main Boom Electrical Circuit Q80C.102(F.3)​
□10167640 固定副臂电气 Fixed Jib Electrical Circuit Q80C.104(C.2)​
□10144403 加长臂电气 Extension Jib Electrical Circuit Q150C.105(a)(D.3)​
10177025 下车电气 Lowerworks Electrical Circuit Q80C.108(H.2)​
□10169827 力限器系统 Load Moment Limiter System Q80C.110(D.2)​
□10166564 力限器系统 Load Moment Limiter System Q80C.110(a)(C.2)​
□10217950 力限器系统 Load Moment Limiter System Q80C.110(b)(A.2)​
□10216574 驾驶室电气 Cab Electrical Circuit (Free Fall) Q80C.111(a) (F.2)​
□10216576 驾驶室电气 Cab Electrical Circuit Q80C.111(b) (F.2)​
14. 液压系统 Hydraulic System
□10138503 上车液压系统Ⅰ Upperworks Hydraulic SystemⅠQ80C.122(H.3)​
□10112347 上车液压系统Ⅰ Upperworks Hydraulic SystemⅠQ80C.122(a)(J.3)​
□10111576 上车液压系统 Ⅱ Upperworks Hydraulic System ⅡQ80C.123(F.2)​
□10112348 上车液压系统 Ⅱ Upperworks Hydraulic System ⅡQ80C.123(a)(H.3)​
□10186218 上车液压系统 Ⅱ Upperworks Hydraulic System ⅡQ80C.123(b)(E.3)​
□10144434 伺服控制系统 Servo Hydraulic System Q80C.133(G.4)​
□10101240 伺服控制系统 Servo Hydraulic System Q80C.133(b)(G.4)​
□10111933 主提升液压系统 Main Hoist Hydraulic Circuit Q80C.125(E.3)​
□10111934 主提升液压系统 Main Hoist Hydraulic Circuit Q80C.125(a)(G.3)​
□10101239 主提升液压系统 Main Hoist Hydraulic Circuit Q80C.125(b)(G.2)​
□10179436 主提升液压系统 Main Hoist Hydraulic Circuit Q80C.125(c)(G.2)​
□10184444 主提升液压系统 Main Hoist Hydraulic Circuit Q80C.125(d)(E.2)​
□10206993 主提升液压系统 Main Hoist Hydraulic Circuit Q80C.125(f)(E.3)​
□10263703 主提升液压系统 Main Hoist Hydraulic Circuit Q80C.125(g)(F.3)​
10072932 辅助液压 Auxiliary Hydraulic Circuit Q80C.134(E.2)​
10076372 散热液压 Radiating Hydraulic Circuit Q80C.136(H.2)​
10067596 液压油箱 Hydraulic Oil Tank Q80C.124(H.2)​
10076379 下车辅助液压 Lowerworks Main Hoist Hydraulic Circuit Q80C.131(I.2)​
□10076383 下车行走液压 Lowerworks Traveling Hydraulic System Q80C.130(a)(J.3)​
□10081715 下车行走液压 Lowerworks Traveling Hydraulic System Q80C.130(b)(J.4)​
□10471745 下车行走液压 Lowerworks Traveling Hydraulic System Q80C.130(d)(D.3)​
□10106435 下车行走液压 Lowerworks Traveling Hydraulic System Q80C.130(c) (I.3)​
15. 标牌Nameplate
□10208318 标牌Nameplate Q80C.142(G.2)​
□10210984 标牌 Nameplate Q80C.142(b)(G.2)​
□10210983 标牌 Nameplate Q80C.142(a)(G.2)​
16. 附录 Appendices
A型架销轴汇总 Summary Table of Pins Used on A-frame​
主臂基本臂销轴汇总 Summary Table of Pins Used on Basic Boom​
固定副臂基本臂销轴汇总 Summary Table of Pins Used on Basic Fixed Jib​
