Sany Crawler Crane SCC600A-5 Operation Manual
Brand: Sany
Type of Machine: Crawler Crane
Model: Sany SCC600A-5 Crawler Crane
Number of Pages: 526 Pages
1 Introduction
Brand: Sany
1 Introduction
1.1 Overview
1.2 Documentation Contents
1.3 Documentation Storage
1.4 Recommendations on using the documentation
1.5 Your Sany Machine
1.5.1 New Machine Break-in
1.5.2 Operation During the Break-in Period
1.6 Machine Direction Reference
1.7 Machine Information
2 Safety2.1 Safety Alert Information and Machine decal
2.1.1 Overview
2.1.2 Safety alert information
2.1.3 Machine Decals
2.2 Operation Range and Liability
2.2.1 Proper Use
2.2.2 Examples of Improper Use
2.2.3 Liability Distribution
2.2.4 Liabilities of Manufacturer and Crane Owner
2.2.5 Crane Operator
2.2.6 Liabilities and Hand Signals of Signal Person
2.2.7 Liabilities of the Operation Crew
2.2.8 Liabilities of Managing Personnel
2.3 Operation Conditions and Service Life of the Crane
2.3.1 Introduction
2.3.2 Design Grade and Rated Load
2.3.3 Necessary Environment Conditions
2.3.4 Service Life
2.4 Safety Rules
2.4.1 Personal protection equipment (PPE)
2.4.2 Safety requirements
2.4.3 Special Dangers of the Crane
2.4.4 Selecting the Operation Site
2.4.5 Combined operation by two or more cranes
2.4.6 Preparation for crane operation
2.4.7 Crane operation process
2.4.8 After crane operation
2.5 Safety parts
2.6 Safety exit
2.7 Fire extinguishers in the cab
2.8 Maintenance and Service Safety Information
2.8.1 Operation Safety
2.8.2 Maintenance Safety
2.9 Using a Chain Sling Safety
3 System Function3.1 Machine Terms
3.2 Cab Layout
3.3 Operation and Display Device Layout
3.3.1 Operation and Display Device Layout
3.3.2 Function Lockout Control Lever
3.3.3 Winch Control Lever
3.3.4 Function Buttons on the Right Control Lever
3.3.5 Function Buttons on the Left Control Levers
3.3.6 Travel Control Lever
3.3.7 Free Fall Control Pedal(s) (Optional)
3.3.8 Foot Throttle Control Pedal
3.4 Switches and Pedal Functions
3.4.1 Switches and Panel Overview
3.4.2 Right Front Indicator Panel
3.4.3 Right Console Switch Panel
3.4.4 Left Console Switch Panel
3.5 Display and Operation System
3.5.1 Display and Operation System
3.5.2 Operating Condition Setting
3.5.3 Parameters Display 1
3.5.4 Display Function Description
3.5.5 Configuration Details
3.5.6 Menu Function Setting
3.5.7 Parameters Display 2
3.5.8 Ground Pressure and Levelness Display
3.6 Menu Function Setting
3.6.1 Menu Function Setting Overview
3.6.2 System Setting
3.6.3 Auxiliary Function
3.6.4 Information Inquiry
3.6.5 Language and Unit Setting
3.6.6 Air Conditioner
3.6.7 FM Radio
3.7 Swing Limit Device (Optional)
3.7.1 Swing Limit Device Overview
3.7.2 Description on the Swing Limit Area Parameters (Not Available)
3.7.3 Swing Limit Mode
3.7.4 Mode Setting Function
3.7.5 A Mode Setting
3.7.6 L+A Mode Setting
3.7.7 Example Introduction
3.8 Monitoring System
4 Operation4.1 Basic Operation of Crane
4.1.1 Basic Operation of Crane
4.1.2 Adjust seat
4.1.3 Enter In and Exit of the Cab
4.1.4 Start and Stop Engine
4.1.5 Function Lockout Control Lever
4.2 Travel Operation
4.2.1 Travel Preparation
4.2.2 Traveling Speed Adjustment
4.2.3 Traveling Direction (Optional)
4.2.4 Travel with Load
4.2.5 Travel On/Off a Slope
4.3 Swing Operation
4.3.1 Swing Preparation
4.3.2 Swing Operation
4.4 Load Hoist Operation
4.4.1 Main Load Hoist Operation
4.4.2 Aux. Load Hoist Operation
4.5 Boom Hoist Operation
4.5.1 Boom Hoist Preparation
4.5.2 Boom Hoist Unlock
4.5.3 Safety Control
4.5.4 Boom Hoist Operation
4.6 Free Fall Operation (Optional)
4.6.1 Mode Switchover (Work Mode to Free Fall)
4.6.2 Free Fall Operation
4.6.3 Lifting Operation
4.6.4 Mode Switchover (Free Fall Mode to Work Mode)
4.6.5 Free Fall Modes
4.7 Work Instruction
4.7.1 Overview
4.7.2 Wind Force Influence
4.7.3 Operation in Wind
4.8 LMI Bypass Key Switch (in Electrical Control Cabinet)
4.9 Machine Parking
4.9.1 Requirements for the Ground
4.9.2 Boom System
5 Wire Rope5.1 Wire Rope Handling
5.1.1 Wire Rope Handling
5.1.2 Wire Rope Specifications
5.1.3 Winding Capacity on Each Drum
5.1.4 Wire Rope Length
5.1.5 Cautions in Handling Wire Rope
5.2 Wire Rope Reeving
5.2.1 Winding Wire Rope to the Drum
5.2.2 Winding Boom Hoist Rope
5.3 Correction Method of Entangled Wire Rope
5.4 Rope Socket Installation
5.5 Wire Rope Replacement
5.5.1 Replacement Standards of Wire Rope
5.5.2 Replacement Standards of Pendant Cable
6 Maintenance6.1 Maintenance Safety Notice
6.1.1 Maintenance Personnel Qualification
6.1.2 Risks in Maintenance
6.1.3 Cautions before Maintenance
6.1.4 Fire Prevention
6.1.5 Precautions during Maintenance
6.1.6 Safety during Repair
6.1.7 Precautions in the Long-time Storage
6.1.8 Bolts, Nuts and Hydraulic Piping - Tighten
6.2 Fluid Recommendation and Volume
6.2.1 Oil Volume Table
6.2.2 Recommend Fluid
6.3 Inspection and Maintenance Schedule
6.3.1 Inspection and Maintenance Schedule
6.3.2 Lubrication Schedule
6.4 Maintenance Procedure
6.4.1 Daily or Every 8 Hours
6.4.2 Weekly or Every 50 Hours
6.4.3 Every 100 Hours
6.4.4 Every 250 Hours
6.4.5 Every 500 Hours
6.4.6 Every 1000 Hours
6.4.7 Every 1500 Hours
6.4.8 Every 2000 Hours
6.4.9 Every 4000 Hours
6.5 Lubricate Schedule
6.5.1 Lubrication Schedule
6.5.2 Lubricate Every 50 Hours
6.5.3 Lubricate Every 100 Hours
6.5.4 Lubricate Every 250 Hours
6.5.5 Lubricate Every 500 Hours
6.6 Electrical system
6.6.1 Electrical System - Inspect
6.6.2 LMI System - Inspect
6.6.3 Battery Maintenance
6.6.4 Preventive Measures to Prevent Fire on Cables
6.7 Hook and Sheave Device
6.7.1 Hook - Inspect
6.7.2 Routine Maintenance
6.7.3 Sheave - Inspect
6.8 Maintenance of Wire Rope and Slings
6.8.1 Precautions before Inspection
6.8.2 Wire Rope Inspection
6.8.3 Wire Rope - Transfer
6.8.4 Wire Rope - Store
6.8.5 Wire Rope - Install
6.8.6 Wire Rope - Lubricate
6.8.7 Wire Rope - Cut
6.9 Inspection and maintenance under special work environment
6.9.1 Muddy and Snowy Environment
6.9.2 Seaside Operations
6.9.3 Dusty Environment
6.9.4 Stony Environment
6.9.5 Rock-fall Scenes
6.9.6 High Temperature Environment
6.9.7 Low Temperature Environment
6.9.8 Other Working Environment
6.10 Maintenance of Band-Type Free Fall (If Equipped)
6.10.1 Band-Type Free Fall Winch Overview
6.10.2 Winch Bolt Inspection
6.10.3 Winch Reducer Oil Level - Inspect
6.10.4 Winch Bearing - Lubricate
6.10.5 Adjustment and Maintenance of Clutch
6.10.6 Adjustment and Maintenance of Clutch
6.11 Crane - Store
7 Troubleshooting7.1 Jump-starting the Engine
7.1.1 General Information
7.1.2 Connecting the Jumper Cables
7.1.3 Starting the Engine
7.1.4 Disconnecting the Jumper Cables
7.2 Guidance on Troubleshooting
7.2.1 Engine troubleshooting reference table
7.2.2 Electrical system common troubleshooting reference table
7.2.3 Air Conditioning Common Troubleshooting Reference Table
7.2.4 Auxiliary System Common Failure Reference Table
7.2.5 Hydraulic System Troubleshooting Reference Table
7.2.6 Mechanical Transmission Troubleshooting Reference Table
8 Specifications8.1 Outline Dimensions
8.2 Major Performance & Specifications
- Sany Rough Terrain Crane SRC865XL Parts Book
- Sany Rough Terrain Crane SRC840 Parts Book
- SANY Crawler Crane SCC700 Partbook
- SANY Crawler Crane SCC1000C Operation Manual
- SANY Truck Crane STC250S5 Parts Book
- SANY Rough Terrain Crane SRC865 SRC865XL Safety Operation & Maintenance Manual
- Sany Crawler Crane SCC500E Maintenance Manual
- Sany Reach Stacker SRSC45H1 Parts Book
- Sany Reach Stacker SRSC45H1 Installation Guideline
- Sany Crane STC550T5 Safety Operation & Maintenance Manual
- Sany Reach Stacker SRSC45C30 to SRSC3615-3 Safety Operation Maintenance Manual
- Sany All Terrain Crane SAC1600S Electrical Hydraulic Preneumatic Schematics
- Sany Truck Crane STC250T5-4 Parts Book QZJ100000392
- Sany Truck Crane STC250T5-4 Electrical Hydraulic Pneumatic Schematics QZJ100000392
- Sany Truck Crane STC250T5-5 Parts Book QZJ100000390
