Hyundai
86
176,684
Sany Backhoe Loader BHL75A Operation and Maintenance Manual
Brand: Sany
Type of Manual: Operation and Maintenance Manual
Model: Sany BHL75A Backhoe Loader
Number of Pages: 242 Pages
1 Foreword
1.1 General​
1.2 Safety information​
1.3 Page description​
1.4 Introduction​
1.4.1 General​
1.4.2 Directions of the machine​
1.4.3 Running-in of new machines​
1.5 Product information​
1.5.1 General​
1.5.2 Machine data plate​
1.5.3 Engine data plate​
2 Safety
2.1 Safety decals​
2.1.1 General​
2.1.2 Location​
2.1.3 Description​
2.2 Safety information​
2.2.1 Safety rules​
2.2.2 Handling of abnormalities​
2.2.3 Personal protective equipment​
2.2.4 Fire extinguisher and first-aid kit​
2.2.5 Safety equipment​
2.2.6 Keeping the machine clean​
2.2.7 Keeping the cab clean​
2.2.8 Locking of safety lock control lever​
2.2.9 Armrest and ladder​
2.2.10 Precautions for working at heights​
2.2.11 Keeping clear of the accessory​
2.2.12 Don’t get stuck in the articulation section​
2.2.13 Preventing scald​
2.2.14 Fire and explosion prevention​
2.2.15 Actions in case of a fire​
2.2.16 Windshield cleaning solution​
2.2.17 Preventing flying components​
2.2.18 Prevent falling, flying and invading objects​
2.2.19 Accessory installation​
2.2.20 Accessory combination​
2.2.21 Cab window glass​
2.2.22 Unauthorized retrofit​
2.2.23 Operation on loose ground​
2.2.24 Site survey in advance​
2.2.25 Don’t approach high voltage cable​
2.2.26 Ensuring favorable view​
2.2.27 Ventilation of working environment​
2.2.28 Prevention of asbestos dust​
2.2.29 Cab emergency exit​
2.3 Safe machine operation​
2.3.1 Start​
2.3.2 Operation​
2.3.3 Parking​
2.3.4 Transportation.​
2.3.5 Battery​
2.3.6 Towing​
2.3.7 Lifting by backhoe loader​
2.4 Safe maintenance instruction​
2.4.1 Precautions before maintenance​
2.4.2 Self-preparation​
2.4.3 Preparation of working area​
2.4.4 Steps of engine shutdown before maintenance​
2.4.5 Warning decal​
2.4.6 Proper tools​
2.4.7 Maintenance during engine running​
2.4.8 Operation under the machine​
2.4.9 Be careful of hot cooling system​
2.4.10 Safe operation of high pressure hose​
2.4.11 Be careful of high pressure liquid​
2.4.12 Welding operation​
2.4.13 Safe maintenance of HVAC group​
2.4.14 Precautions related to high voltage​
2.4.15 Accumulator​
2.4.16 Preventing the danger of fire and explosion​
2.4.17 Regular replacement of safety related parts​
2.4.18 Maintenance operation​
2.4.19 Proper waste treatment​
3 Specifications
3.1 Overall dimensions​
3.2 Working range​
3.3 Backhoe lift capacity​
3.4 Technical parameters​
4 System Functions
4.1 Machine Overview​
4.2 System Introduction​
4.2.1 introduction​
4.2.2 Frame​
4.2.3 Cab​
4.2.4 Backhoe work equipment​
4.2.5 Loader work equipment​
4.2.6 Stabilizers​
4.2.7 Drive system​
4.2.8 Power system​
5 Operation
5.1 System Components​
5.1.1 Cab​
5.1.2 Operator seat​
5.1.3 Battery main switch​
5.1.4 Main power switch​
5.1.5 Backhoe operating model switch valve​
5.1.6 Front control panel​
5.1.7 Side control panel​
5.1.8 control mechanism​
5.1.9 Combination instrument panel​
5.2 Start Switch​
5.2.1 Introduction​
5.2.2 Start switch​
5.2.3 Stopping the engine​
5.2.4 Operating procedure​
5.2.5 Loader operation​
5.3 Machine Transportation​
5.3.1 Introduction​
5.3.2 Moving, loading and unloading the machine​
6 Maintenance
6.1 Introduction​
6.2 Check Intervals and Service Instructions​
6.3 Checking and Cleaning the Whole Machine​
6.4 Function Inspection and Maintenance​
6.4.1 Fasteners​
6.4.2 Hydraulic oil and hydraulic system​
6.4.3 Electrical system and electrical devices​
6.4.4 Lubrication​
6.4.5 Loader safety locking support​
6.4.6 Add wiper water​
6.5 Maintenance Schedule​
6.5.1 Introduction​
6.5.2 Maintenance schedule for the diesel engine​
6.5.3 Hydraulic system maintenance schedule​
6.5.4 Gearbox, shaft and steering device maintenance schedule​
6.5.5 Brake maintenance schedule​
6.5.6 Electrical system maintenance schedule​
6.5.7 Other components maintenance schedule​
6.5.8 Functional operation maintenance schedule​
6.5.9 Oils​
6.6 Maintenance Method of The Engine​
6.6.1 Checking for leaks​
6.6.2 Clean air filter​
6.6.3 Checking the batteries and wires​
6.6.4 Coolant level​
6.6.5 Replenishing the coolant​
6.6.6 Cleaning radiator and changing coolant​
6.6.7 Checking the engine oil level​
6.6.8 Changing engine oil​
6.6.9 Change engine oil filter​
6.6.10 Clean/change/vent the fuel prefilter​
6.6.11 Change the fuel filter cartridge​
6.6.12 Empty water tank​
6.6.13 Change the fuel pre-filter insert​
6.6.14 Vent the fuel system​
6.6.15 Belt drives​
6.6.16 Replace V-rib belt​
6.6.17 Filling Urea​
6.6.18 Replace the filter element of the SCR supply module​
6.7 Brake​
6.7.1 Parking brake​
6.8 Rear Axle​
6.8.1 Oil grade​
6.8.2 Changing oil​
6.8.3 Oil level check​
6.8.4 Wear measurement - multi-disk brake​
6.9 Front Axle​
6.9.1 Oil change​
6.9.2 Control of steering rod and tie rod joints​
6.10 Power transmission​
6.10.1 Oil level check​
6.10.2 Oil change​
6.10.3 Filter change​
6.11 Hydraulic System​
6.11.1 Introduction​
6.11.2 Checking oil level​
6.11.3 Replacing filter element​
6.12 Electrical System​
6.12.1 Fuse​
6.12.2 Relay installation​
6.12.3 Common failure checks​
6.12.4 Fuse replacement procedure​
7 Troubleshooting
7.1 Overview​
7.2 Common Failure Analysis and Diagnostics of Diesel Engine​
7.3 Engine protection function of the electronic engine control​
7.4 Use of the engine diagnostic key​
7.5 Common Failure Analysis and Diagnostics of Gearbox​
7.6 Common Failure Analysis and Diagnostics of Electrical System​
7.7 Common Failure Analysis and Diagnostics of Drive System​
7.8 Common Failure Analysis and Diagnostics of Drive shaft​
7.9 Common Failure Analysis and Diagnostics of Hydraulic System​
