Hyundai
86
176,684
Sany Backhoe Loader BHL75 BHL95 SLB95 Maintenance Manual 2023
Brand: Sany
Type of Manual: Maintenance Manual
Model: Sany BHL75 BHL95 SLB95 Backhoe Loader
Publication Date: 2023
Number of Pages: 2057 Pages
1 Foreword
1.1 Read the maintenance manual​
1.2 Description of maintenance standard​
1.3 Handling of electrical and hydraulic components​
1.3.1 Matters needing attention when dealing with electrical components​
1.3.2 Attention when dealing with hydraulic components​
1.4 Pipe connector​
1.4.1 Pipe connector​
1.4.2 Tightening torque of pipe connector​
1.4.3 O-ring connection​
1.5 Bolts and nuts​
1.5.1 Table of Standard Tightening Torque​
1.5.2 Bolt type​
1.5.3 Bolt tightening sequence​
1.6 Maintenance of split flange​
1.6.1 Maintenance of split flange​
1.6.2 Table of Tightening Torques of Split Flange Bolts​
1.7 Conversion table​
2 Safety
2.1 Instructions for safety decals​
2.1.1 summary​
2.1.2 Safety signal terms​
2.1.3 Other signal terms​
2.2 General precautions​
2.2.1 General precautions​
2.2.2 Safety Rules​
2.2.3 Keep working area tidy​
2.2.4 Fluid storage​
2.2.5 Part washing​
2.2.6 Backhoe loader cleaning​
2.2.7 Decent clothing​
2.2.8 Personal protective equipment (PPE)​
2.2.9 Correct use of tools​
2.2.10 Fire extinguisher and emergency exit​
2.2.11 Emergency exit and emergency hammer in cab​
2.3 Perparation work before maintenance​
2.3.1 Preparation before working​
2.3.2 Self-preparation​
2.3.3 Warning sign plate​
2.4 Notes for maintenance​
2.4.1 Operation while the engine is running​
2.4.2 Remove machine accessories​
2.4.3 Work under the machine​
2.4.4 Add or replace oil​
2.4.5 Alignment of parts​
2.4.6 When using a hammer​
2.4.7 When compressed air is used​
2.4.8 Welding operation​
2.4.9 Safe operation of high pressure​
2.4.10 Beware of high-pressure liquids​
2.4.11 Be careful of hot coolant​
2.4.12 The air conditioning system​
2.4.13 Safety utilization of electric power​
2.4.14 System is powered-off​
2.4.15 Battery operation​
2.4.16 Accumulator​
2.4.17 Avoid fire and explosion hazards​
2.4.18 Dispose of waste properly​
2.5 Other points for attention​
2.5.1 Precautions for hoisting and signaling​
2.5.2 Precautions for using mobile crane​
2.5.3 Precautions for using bridge crane​
2.5.4 Selection of wire ropes​
3 Specifications
3.1 Overall dimensions​
3.2 Working range​
3.3 Working range(extendable stick)​
3.4 Backhoe lift capacity​
3.5 Backhoe lift capacity (extendable stick)​
3.6 Technical parameters​
3.7 Weight Table​
3.8 Oils​
4 Structure and Function
4.1 Engine(Tier 4)​
4.1.1 General​
4.1.2 Engine electronics​
4.1.3 Surrounding​
4.1.4 Preparations for initial commissioning​
4.1.5 Starting​
4.1.6 Electronic engine control​
4.1.7 Instruments and symbols​
4.1.8 Shutting off and lag time​
4.1.9 Lubricating oil​
4.1.10 Fuel​
4.1.11 Coolant​
4.2 Engine(Tier 3)​
4.2.1 General​
4.2.2 Fuel System​
4.2.3 Injector and fuel line​
4.2.4 Lubrication system​
4.2.5 Lubrication system flow chart​
4.2.6 Cooling System​
4.2.7 Cooling system flow chart​
4.2.8 Intake system​
4.2.9 Intake system flow chart​
4.2.10 Exhaust system​
4.2.11 Exhaust system flow chart​
4.2.12 Electrical Equipment​
4.2.13 Engine test​
4.3 Drivetrain​
4.3.1 General​
4.3.2 Hydraulic torque converter and transmission​
4.3.3 Drive shaft​
4.3.4 Steering front axle​
4.3.5 Rear drive axle​
4.3.6 Rims​
4.3.7 Tires​
4.3.8 Service brake system​
4.4 Damping system​
4.5 Cooling system(Tier 4)​
4.5.1 General​
4.5.2 Radiator​
4.6 Cooling system(Tier 3)​
4.6.1 General​
4.6.2 Radiator​
4.7 Working device​
4.7.1 Dimensions of parts​
4.7.2 Dimensions of backhoe boom​
4.7.3 Dimensions of loader boom​
4.7.4 Dimensions of stick​
4.7.5 Dimensions of backhoe bucket​
4.7.6 Dimensions of loader bucket​
4.7.7 Dimensions of the stabilizers and the pads​
4.8 AC system​
4.8.1 AC​
4.8.2 Location drawing of AC parts​
4.8.3 Control panel​
4.8.4 AC schematic diagram​
4.8.5 Refrigeration principle​
4.8.6 Compressor​
4.8.7 Clutch​
4.8.8 Condenser​
4.8.9 Expansion valve​
4.8.10 EVAP & HTR UNIT​
4.8.11 Pressure switch​
4.8.12 Temperature sensor​
4.8.13 Refrigerant​
4.8.14 Compressor oil​
4.9 Hydraulic system​
4.9.1 Hydraulic circuit diagram​
4.9.2 Hydraulic principle of movement of each work equipment​
4.9.3 Hydraulic arrangement​
4.9.4 Hydraulic tank and oil filter​
4.9.5 Piston pump​
4.9.6 Pilot oil source block​
4.9.7 Steering system​
4.9.8 Main valve​
4.9.9 Hydraulic principle of movement of each work equipment​
4.9.10 Hydraulic circuit diagram​
4.9.11 PPC accumulator​
4.9.12 Pilot oil filter​
4.9.13 PPC valve​
4.9.14 Ride control​
4.9.15 Hydraulic cylinder​
4.10 The engine control​
4.10.1 The MCU​
4.10.2 The engine control function​
4.10.3 The engine controller function​
4.11 Electrical system​
4.11.1 Starting circuit (T4f deutz)​
4.11.2 Starting circuit (T3 Cummins)​
4.11.3 Traveling and P position control​
4.11.4 Turn signal lamp, hazard warning lamp, wiper, washer and horn control​
4.11.5 Work light control​
4.11.6 Brake light and indicator control​
4.11.7 Pilot switch and automatic idling control​
4.11.8 Lateralshift switch,leg combination lamp and license plate lamp​
4.11.9 loader control handle​
4.11.10 Engine intake preheating control​
4.12 Display​
4.12.1 General​
4.12.2 Operation​
4.12.3 Power-on password​
4.12.4 Flow and speed settings​
5 Standard Values
5.1 Standard Values for Engine-Related Parts​
5.2 Standard Values for Transmission-Related Parts​
5.3 Standard Values for Chassis-Related Parts​
6 Testing and Adjusting
6.1 Measuring the exhaust smoke color​
6.2 Valve clearance adjustment (T3 Cummins)​
6.3 Valve clearance adjustment​
6.4 Compression pressure measurement​
6.5 Inspection and adjustment of the work hydraulic pressure​
6.6 Inspection and adjustment of oil pressure in control oil line​
6.7 Measuring the output pressure of pilot valve​
6.8 Work Equipment Pilot Valve - Adjust​
6.9 Measuring the drift of the work equipment​
6.10 Release of residual pressure from hydraulic lines​
6.11 Measuring the oil pressure of the transmission​
6.12 Measuring the oil pressure of the brake system​
6.13 Bleeding air from each system​
6.14 Checking the hydraulic oil level and filling when necessary​
6.15 Checking the engine oil level​
6.16 Brake​
6.16.1 Parking brake​
6.17 Rear Axle​
6.17.1 Oil grade​
6.17.2 Changing oil​
6.17.3 Oil level check​
6.17.4 Wear measurement - multi-disk brake​
6.18 Front Axle​
6.18.1 Oil change​
6.18.2 Control of steering rod and tie rod joints​
6.19 Power transmission​
6.19.1 Oil level check​
6.19.2 Oil change​
6.19.3 Filter change​
6.20 Belt check and tension adjustment (T4f)​
6.21 Belt check and tension adjustment (T3)​
7 Fault diagnosis and troubleshooting
7.1 Fault diagnosis and troubleshooting​
7.2 Working procedure for fault diagnosis​
7.3 Inspection before fault diagnosis​
7.4 Types and steps of fault diagnosis​
7.4.1 Fault diagnosis category​
7.4.2 Steps for fault diagnosis​
7.5 Connector​
7.5.1 Connector list​
7.5.2 Connector location diagram​
7.5.3 Table for number of common connector pins​
7.5.4 Connector list (T3)​
7.5.5 Connector location diagram(T3 extensible stick)​
7.6 Fault diagnosis when the current fault code is displayed​
7.6.1 Information in the fault diagnosis table​
7.6.2 Fault code E202 power supply voltage too high​
7.6.3 Fault code E401 Abnormal CAN bus​
7.6.4 Fault code H404 converter oil temperature too high alarm​
7.6.5 Trouble code P104 engine overspeed​
7.6.6 Fault code P301 coolant temperature too high​
7.6.7 Fault code P302 coolant level too low​
7.6.8 Trouble code P101 Low engine oil pressure​
7.6.9 Trouble code P401 fuel level too low​
7.6.10 Fault code P501 Air filter blocking​
7.6.11 Fault code P502 High temperature of charge air​
7.6.12 Fault code P601 water separator water level too high​
7.6.13 Fault code P702 SCR system fault​
7.6.14 The fault code P704 urea fluid level is too low​
7.6.15 Trouble code P705 engine inducement alarm​
7.6.16 Fault code P707 regenerative system fault​
7.6.17 Fault code P802 internal engine fault​
7.7 Fault diagnosis of electrical system​
7.7.1 Centralized control box of electrical system​
7.7.2 Information in the fault diagnosis table​
7.7.3 E-1 Start failure of engine (T3)​
7.7.4 E-1 Start failure of engine​
7.7.5 E-2 automatic idling does not work​
7.7.6 E-3 The engine heating function does not work​
7.7.7 E-4 All hydraulic devices do not work​
7.7.8 E-5 No actions during traveling or deactivated gear-shifting​
7.7.9 E-6 Blank display​
7.7.10 E-7 No indication on the display​
7.7.11 E-8 Loader joystick switches​
7.7.12 E-9 The fuel level is not displayed correctly​
7.7.13 E-10 wipers do not work​
7.7.14 E-11 Turn signal light does not work​
7.7.15 E-12 Work light does not work​
7.8 Fault diagnosis of hydraulic and mechanical systems​
7.8.1 System diagram for hydraulic and mechanical system​
7.8.2 Information of the fault diagnosis table​
7.8.3 H-1 The work equipment acts slowly​
7.8.4 H-2 The engine speed significantly drops or engine stalls​
7.8.5 H-3 Working equipment does not work​
7.8.6 H-4 Abnormal sound in hydraulic pump​
7.8.7 H-5 Automatic idling does not work​
7.8.8 H-6 The boom moves slowly​
7.8.9 H-7 The arm moves slowly​
7.8.10 H-8 The bucket moves slowly​
7.8.11 H-9 The loader boom moves slowly​
7.8.12 H-10 loader bucket moves slowly​
7.8.13 H-11 The stabilizers move slowly​
7.8.14 H-12 The backhoe swings slowly​
7.8.15 H-13 Single cylinder no action​
7.8.16 H-14 Too large cylinder drift of the work equipment​
7.8.17 H-15 The work equipment action lag​
7.8.18 H-16 Other cylinders move when a single oil line overflows​
7.8.19 H-17 Too large overrun when swing stops​
7.8.20 H-18 Too large impact when swing stops​
7.8.21 H-19 Hard steering​
7.8.22 Service brake failure​
7.8.23 H-21 Parking brake cannot be released​
7.8.24 H-22 The machine travels slowly​
7.8.25 H-23 The drive shaft abnormal noise​
7.8.26 H-24 No output from front drive​
7.8.27 H-25 Front axle turning abnormal noise​
7.8.28 H-26 Axle rolls abnormal noise​
8 Disassembly and Assembly
8.1 Removal and installation of the fan​
8.2 Removal and installation of the water tank​
8.3 Removal and installation of the starter​
8.4 Removal and installation of the fuel pump assembly (T4f)​
8.5 Removal and installation of the fuel pump assembly (T3)​
8.6 The cooling system(Tier 4)​
8.7 The cooling system(Tier 3)​
8.8 Removal and installation of radiator assembly(Tier 4)​
8.9 Removal and installation of radiator assembly(Tier 3)​
8.10 Engine exhaust aftertreatment system(Tier 4)​
8.11 Engine exhaust aftertreatment system(Tier 3)​
8.12 Removal and installation of DEF tank(Tier 4)​
8.13 The fuel system(Tier 4)​
8.14 The fuel system(Tier 3)​
8.15 Disassembly and Reassembly of Engine Body​
8.16 Removal and installation of transmission assembly​
8.17 Removal and installation of transmission dipstick assembly​
8.18 Transmission radiator assembly​
8.19 Removal of brake system​
8.20 Removal and installation of brake pedal​
8.21 Removal and installation of drive shaft​
8.22 Removal and installation of front axle​
8.23 Removal and installation of rear axle​
8.24 Disassembly and Reassembly of transmission and axle​
8.25 Removal and installation of Ignition switch​
8.26 Removal and installation of display​
8.27 Display function interface table (T4f)​
8.28 Display function interface table (T3)​
8.29 Removal and installation of controller assembly​
8.30 Removal and installation of electrical centralized control box​
8.31 Centralized control box of electrical system (T4f)​
8.32 Centralized control box of electrical system (T3)​
8.33 Removal and installation of batter​
8.34 Removal and installation of main power switch​
8.35 Removal and installation of high-current relay​
8.36 Removal and installation of steering column​
8.37 Removal and installation of working light and turn signal light​
8.38 Wiper​
8.39 Removal and installation of stabilizer​
8.40 Removal and installation of backhoe working equipment​
8.41 Removal and installation of loader equipment​
8.42 Removal and installation of extensible stick​
8.43 Removal and installation of multi-purpose bucket​
8.44 Removal and installation of engine hood​
8.45 Removal and installation of front hood and counterweight​
8.46 Removal and installation of canopy​
8.47 Removal and installation of parts in the cab​
8.48 Removal and installation of glasses in the cab​
8.49 Removal and installation of hydraulic tank​
8.50 Removal and installation of loader valve​
8.51 Removal and installation of backhoe valve​
8.52 Removal and installation of hydraulic pump​
8.53 Removal and installation of steering unit​
8.54 Removal and installation of pilot oil block​
8.55 Removal and installation of pilot valve for stabilizer​
8.56 Removal and installation of pilot valve for loader​
8.57 Removal and installation of left pilot valve for backhoe​
8.58 Removal and installation of left pilot valve for backhoe(Extendable stick)​
8.59 Removal and installation of right pilot valve for backhoe​
8.60 Removal and installation of right pilot valve for backhoe(Extendable stick)​
8.61 Removal and installation of backhoe pattern changer​
8.62 Removal and installation of ride control valve​
8.63 Removal and installation of clamping cylinder solenoid valve​
8.64 Removal and installation of tee transfer valve within auxiliary system return line​
8.65 Removal and installation of boom cylinder for loader​
8.66 Removal and installation of bucket cylinder for loader​
8.67 Removal and installation of stabilizer cylinder for backhoe(middle range)​
8.68 Removal and installation of stabilizer cylinder for backhoe(side shift)​
8.69 Removal and installation of stabilizer cylinder for backhoe(side shift)​
8.70 Removal and installation of swing cylinder for backhoe​
8.71 Removal and installation of boom cylinder for backhoe​
8.72 Removal and installation of bucket cylinder for backhoe​
8.73 Removal and installation of stick cylinder for backhoe​
8.74 Removal and installation of multi-purpose bucket cylinder​
8.75 Disassembly and reassembly of hydraulic cylinder assembly​
8.76 Service instructions for 5000cc-b32 control valve assembly​
8.77 Service instructions for scx120-g2 control valve assembly​
9 Appendix
9.1 Appendix​
9.2 Hydraulic and Electrical Diagrams​
9.2.1 Hydraulic diagram (extensible stick)​
9.2.2 Electrical diagram (extensible stick & T4f)​
9.2.3 Frame harness (extenible stick & T4f)​
9.2.4 Cab harness (extensible stick & T4f)​
9.2.5 Fuse box harness (extensible stick & T4f)​
9.2.6 Steering column harness​
9.2.7 Lamps harness​
9.2.8 Engine EAT harness​
9.2.9 Electrical diagram (extensible stick & T3)​
9.2.10 Frame harness (extenible stick & T3)​
9.2.11 Cab harness (extensible stick & T3)​
9.2.12 Fuse box harness (extensible stick & T3)​
9.3 Transmission Maintenance Manual​
9.3.1 TABLE OF CONTENTS​
9.3.2 SPECIAL TOOLS /COMMERCIAL TOOLS​
9.4 Front Axle Maintenance Manual​
9.4.1 Preface​
9.4.2 Safety​
9.4.3 Notes on Repairs and Assembly​
9.4.4 Technical Data​
9.4.5 Settings​
9.4.6 Tightening Torques​
9.4.7 Workshop Equipment​
9.4.8 Preparatory Activities​
9.4.9 Dismantling​
9.4.10 Testing, Measuring, Adjusting​
9.4.11 Assembly​
9.4.12 Annex​
9.5 Rear Axle Maintenance Manual​
9.5.1 GENERAL​
9.5.2 LABELING OF IDENTIFICATION PLATE FOR ZF-AXLES​
9.5.3 Examples of contact patterns for the Gleason gear tooth system​
9.5.4 VERGLEICHSTABELLE FUR MASSEINHEITEN CONVERSION TABLE RABLEAU DE CONVERSION​
9.5.5 BEZEICHNUNG DER GESETLICHEN EINHEITEN DENOMINATION OF STANDARD DIMENSIONS DENOMINATION DES DIMENSIONS STANDARDISEES​
9.5.6 TIGHTENING TORQUES FOR SCREWS (in Nm) ACC. TO ZF STANDARD 148​
9.5.7 SPECIAL TOOLS FOR DISASSEMBLY AND REASSEMBLY​
9.5.8 COMMERCIAL TOOLS FOR DISASSEMBLY AND REASSEMBLY​
9.5.9 ZF-MULTITRAC AXLE MT-B 3070​
9.5.10 Output​
9.5.11 Multi disc brake​
9.5.12 Differential DHK-750​
9.5.13 Input​
9.5.14 Differential DHK-750​
9.5.15 Multi disc brake​
9.5.16 Output​
9.5.17 Input housing and park brake​
9.6 Engine Maintenance Manual​
9.6.1 Title page​
9.6.2 Foreword​
9.6.3 General​
9.6.4 Safety information / User Information​
9.6.5 Job card overview​
9.6.6 Job cards​
9.6.7 Special tools​
9.7 Diagnosis and Errorcodes of the Engine​
9.7.1 38 / 523925 / DFC_ARlySCB_2​
9.7.2 40 / 523927 / DFC_ARlySCB_4​
9.7.3 42 / 523924 / DFC_ARlySCG_1​
9.7.4 43 / 523925 / DFC_ARlySCG_2​
9.7.5 44 / 523926 / DFC_ARlySCG_3​
9.7.6 45 / 168 / DFC_BattUSRCMax​
9.7.7 46 / 168 / DFC_BattUSRCMin​
9.7.8 47 / 168 / DFC_BattUSysReacMax​
9.7.9 73 / 523912 / DFC_BrnDVDsPSRCMin​
9.7.10 84 / 639 / DFC_BusDiagBusOffNodeA​
9.7.11 85 / 1231 / DFC_BusDiagBusOffNodeB​
9.7.12 86 / 1235 / DFC_BusDiagBusOffNodeC​
9.7.13 88 / 102 / DFC_CACDsPSysReacMax​
9.7.14 89 / 102 / DFC_CACDsPSysReacMin​
9.7.15 93 / 110 / DFC_CEngDsTPhysRngLo​
9.7.16 96 / 110 / DFC_CEngDsTSRCMax​
9.7.17 97 / 110 / DFC_CEngDsTSRCMin​
9.7.18 98 / 110 / DFC_CEngDsTSysReacMax​
9.7.19 99 / 110 / DFC_CEngDsTSysReacMin​
9.7.20 101 / 111 / DFC_ClntLvSysReac​
9.7.21 121 / 1109 / DFC_CoEngShOffDemIgr​
9.7.22 122 / 523698 / DFC_CoEngSpvsShOff​
9.7.23 129 / 3224 / DFC_ComAT1IG1VolDLC​
9.7.24 130 / 3224 / DFC_ComAT1IG1VolTO​
9.7.25 134 / 523939 / DFC_ComAT1IGCVol1BAMTO​
9.7.26 138 / 3234 / DFC_ComAT1OG1VolDLC​
9.7.27 139 / 3234 / DFC_ComAT1OG1VolTO​
9.7.28 141 / 523942 / DFC_ComAT1OGCVol2BAMTO​
9.7.29 164 / 523211 / DFC_ComEBC1TO​
9.7.30 168 / 523935 / DFC_ComEEC3VOL1TO​
9.7.31 169 / 523936 / DFC_ComEEC3VOL2TO​
9.7.32 171 / 523212 / DFC_ComEngPrtTO​
9.7.33 172 / 523741 / DFC_ComEngShOffEBC1​
9.7.34 179 / 523240 / DFC_ComFunModCtlTO​
9.7.35 281 / 523766 / DFC_ComTOTSC1AEAct​
9.7.36 282 / 523767 / DFC_ComTOTSC1AEPas​
9.7.37 283 / 523768 / DFC_ComTOTSC1ARAct​
9.7.38 284 / 523769 / DFC_ComTOTSC1ARPas​
9.7.39 291 / 523776 / DFC_ComTOTSC1TEAct​
9.7.40 292 / 523777 / DFC_ComTOTSC1TEPas​
9.7.41 293 / 523778 / DFC_ComTOTSC1TRAct​
9.7.42 294 / 523779 / DFC_ComTOTSC1TRPas​
9.7.43 300 / 523605 / DFC_ComTSC1AETO​
9.7.44 301 / 523606 / DFC_ComTSC1ARTO​
9.7.45 305 / 898 / DFC_ComTSC1TETO​
9.7.46 306 / 520 / DFC_ComTSC1TRTO​
9.7.47 360 / 523982 / DFC_DevLibBattUHi​
9.7.48 361 / 523982 / DFC_DevLibBattULo​
9.7.49 376 / 630 / DFC_EEPEraseErr​
9.7.50 377 / 630 / DFC_EEPRdErr​
9.7.51 378 / 630 / DFC_EEPWrErr​
9.7.52 381 / 411 / DFC_EGRDeltaPMin​
9.7.53 387 / 523612 / DFC_EngICO​
9.7.54 388 / 190 / DFC_EngPrtOvrSpd​
9.7.55 389 / 190 / DFC_EngPrtSysReacFOC1​
9.7.56 390 / 190 / DFC_EngPrtSysReacFOC2​
9.7.57 391 / 190 / DFC_EngPrtSysReacORC​
9.7.58 417 / 171 / DFC_EnvTSRCMax​
9.7.59 418 / 171 / DFC_EnvTSRCMin​
9.7.60 419 / 190 / DFC_EpmCaSI1ErrSig​
9.7.61 420 / 190 / DFC_EpmCaSI1NoSig​
9.7.62 421 / 190 / DFC_EpmCaSI1OfsErr​
9.7.63 422 / 190 / DFC_EpmCrSErrSig​
9.7.64 423 / 190 / DFC_EpmCrSNoSig​
9.7.65 464 / 97 / DFC_FlFWLvlSRCMax​
9.7.66 465 / 97 / DFC_FlFWLvlSRCMin​
9.7.67 472 / 94 / DFC_FuelPSRCMax​
9.7.68 473 / 94 / DFC_FuelPSRCMin​
9.7.69 474 / 94 / DFC_FuelPSysReacMax​
9.7.70 543 / 676 / DFC_IAirHARlyErr​
9.7.71 544 / 676 / DFC_IAirHARlyNoLd​
9.7.72 545 / 729 / DFC_IAirHtOL_0​
9.7.73 549 / 729 / DFC_IAirHtSCB_0​
9.7.74 551 / 729 / DFC_IAirHtSCG_0​
9.7.75 559 / 523895 / DFC_IVAdjDiaIVAdj_0​
9.7.76 560 / 523896 / DFC_IVAdjDiaIVAdj_1​
9.7.77 561 / 523897 / DFC_IVAdjDiaIVAdj_2​
9.7.78 562 / 523898 / DFC_IVAdjDiaIVAdj_3​
9.7.79 563 / 523899 / DFC_IVAdjDiaIVAdj_4​
9.7.80 564 / 523900 / DFC_IVAdjDiaIVAdj_5​
9.7.81 565 / 523350 / DFC_IVDiaBnkShCir_0​
9.7.82 566 / 523352 / DFC_IVDiaBnkShCir_1​
9.7.83 567 / 523354 / DFC_IVDiaChp_0​
9.7.84 568 / 651 / DFC_IVDiaCylNoLd_0​
9.7.85 569 / 652 / DFC_IVDiaCylNoLd_1​
9.7.86 570 / 653 / DFC_IVDiaCylNoLd_2​
9.7.87 571 / 654 / DFC_IVDiaCylNoLd_3​
9.7.88 572 / 655 / DFC_IVDiaCylNoLd_4​
9.7.89 573 / 656 / DFC_IVDiaCylNoLd_5​
9.7.90 580 / 651 / DFC_IVDiaCylShCir_0​
9.7.91 581 / 652 / DFC_IVDiaCylShCir_1​
9.7.92 582 / 653 / DFC_IVDiaCylShCir_2​
9.7.93 583 / 654 / DFC_IVDiaCylShCir_3​
9.7.94 584 / 655 / DFC_IVDiaCylShCir_4​
9.7.95 585 / 656 / DFC_IVDiaCylShCir_5​
9.7.96 592 / 523615 / DFC_MeUnOL​
9.7.97 594 / 523615 / DFC_MeUnShCirHSBatt​
9.7.98 595 / 523615 / DFC_MeUnShCirHSGnd​
9.7.99 596 / 523615 / DFC_MeUnShCirLSBatt​
9.7.100 597 / 523615 / DFC_MeUnShCirLSGnd​
9.7.101 599 / 523615 / DFC_MeUnSRCMin​
9.7.102 612 / 523612 / DFC_MoCADCNTP​
9.7.103 613 / 523612 / DFC_MoCADCTst​
9.7.104 614 / 523612 / DFC_MoCADCVltgRatio​
9.7.105 615 / 523612 / DFC_MoCComErrCnt​
9.7.106 616 / 523612 / DFC_MoCComSPI​
9.7.107 617 / 523612 / DFC_MoCROMErrXPg​
9.7.108 618 / 523612 / DFC_MoCSOPErrMMRespByte​
9.7.109 619 / 523612 / DFC_MoCSOPErrNoChk​
9.7.110 620 / 523612 / DFC_MoCSOPErrRespTime​
9.7.111 621 / 523612 / DFC_MoCSOPErrSPI​
9.7.112 623 / 523612 / DFC_MoCSOPLoLi​
9.7.113 624 / 523612 / DFC_MoCSOPMM​
9.7.114 625 / 523612 / DFC_MoCSOPOSTimeOut​
9.7.115 627 / 523612 / DFC_MoCSOPTimeOut​
9.7.116 628 / 523612 / DFC_MoCSOPUpLi​
9.7.117 629 / 523612 / DFC_MoFAPP​
9.7.118 630 / 523612 / DFC_MoFESpd​
9.7.119 631 / 523612 / DFC_MoFInjDatET​
9.7.120 632 / 523612 / DFC_MoFInjDatPhi​
9.7.121 633 / 523612 / DFC_MoFInjQnt​
9.7.122 634 / 523612 / DFC_MoFMode1​
9.7.123 635 / 523612 / DFC_MoFMode2​
9.7.124 636 / 523612 / DFC_MoFMode3​
9.7.125 637 / 523612 / DFC_MoFOvR​
9.7.126 638 / 523612 / DFC_MoFQntCor​
9.7.127 639 / 523612 / DFC_MoFRailP​
9.7.128 640 / 523612 / DFC_MoFTrqCmp​
9.7.129 641 / 523612 / DFC_MonLimCurr​
9.7.130 642 / 523612 / DFC_MonLimLead​
9.7.131 643 / 523612 / DFC_MonLimSet​
9.7.132 644 / 523612 / DFC_MonUMaxSupply1​
9.7.133 646 / 523612 / DFC_MonUMinSupply1​
9.7.134 714 / 523612 / DFC_OCWDACom​
9.7.135 715 / 523612 / DFC_OCWDALowVltg​
9.7.136 716 / 523612 / DFC_OCWDAOvrVltg​
9.7.137 717 / 523612 / DFC_OCWDAReasUnkwn​
9.7.138 732 / 100 / DFC_OilPSwmpSRCMax​
9.7.139 733 / 100 / DFC_OilPSwmpSRCMin​
9.7.140 736 / 100 / DFC_OilPSwmpSysReacLoMax​
9.7.141 737 / 100 / DFC_OilPSwmpSysReacLoMin​
9.7.142 752 / 107 / DFC_PAirFltDSysReac​
9.7.143 772 / 102 / DFC_PCACDsEnvPPls​
9.7.144 774 / 102 / DFC_PCACDsPhysRngLo​
9.7.145 776 / 102 / DFC_PCACDsSRCMax​
9.7.146 777 / 102 / DFC_PCACDsSRCMin​
9.7.147 795 / 411 / DFC_PEGRDeltaPSRCMax​
9.7.148 796 / 411 / DFC_PEGRDeltaPSRCMin​
9.7.149 807 / 3253 / DFC_PPFltDiffNpl​
9.7.150 809 / 3251 / DFC_PPFltDiffPhysRngHiShOff​
9.7.151 810 / 3251 / DFC_PPFltDiffPhysRngHiWarn​
9.7.152 812 / 3251 / DFC_PPFltDiffPhysRngLoShOff​
9.7.153 813 / 3251 / DFC_PPFltDiffPhysRngLoWarn​
9.7.154 814 / 3253 / DFC_PPFltDiffSRCMax​
9.7.155 815 / 3253 / DFC_PPFltDiffSRCMin​
9.7.156 825 / 523009 / DFC_PRVctOpnMax​
9.7.157 826 / 523470 / DFC_PRVFrOpnPresInc​
9.7.158 827 / 523470 / DFC_PRVFrOpnPresShck​
9.7.159 828 / 523470 / DFC_PRVMonSysReacShOff​
9.7.160 829 / 523470 / DFC_PRVMonSysReacWarn​
9.7.161 830 / 523470 / DFC_PRVOpn​
9.7.162 831 / 523470 / DFC_PRVQBalChk​
9.7.163 832 / 523470 / DFC_PRVRPOutOfRng​
9.7.164 833 / 523009 / DFC_PRVtiOpnMax​
9.7.165 847 / 1176 / DFC_PTrbnUsPhysRngHi​
9.7.166 849 / 1176 / DFC_PTrbnUsSRCMax​
9.7.167 850 / 1176 / DFC_PTrbnUsSRCMin​
9.7.168 856 / 523613 / DFC_RailMeUn0​
9.7.169 857 / 523613 / DFC_RailMeUn1​
9.7.170 858 / 523613 / DFC_RailMeUn10​
9.7.171 859 / 523613 / DFC_RailMeUn2​
9.7.172 861 / 523613 / DFC_RailMeUn3​
9.7.173 862 / 523613 / DFC_RailMeUn4​
9.7.174 864 / 523613 / DFC_RailMeUn7​
9.7.175 876 / 523470 / DFC_RailPRV4​
9.7.176 877 / 157 / DFC_RailPSRCMax​
9.7.177 878 / 157 / DFC_RailPSRCMin​
9.7.178 925 / 523720 / DFC_SMHtrTDycFail​
9.7.179 926 / 523720 / DFC_SMHtrTDycInvld​
9.7.180 927 / 523721 / DFC_SMNoAvl​
9.7.181 928 / 523722 / DFC_SMPerPwm​
9.7.182 929 / 523722 / DFC_SMPwm​
9.7.183 930 / 523721 / DFC_SMTDycFail​
9.7.184 931 / 523721 / DFC_SMTDycInvld​
9.7.185 932 / 29 / DFC_SRCHiAPPHTLIS​
9.7.186 935 / 91 / DFC_SRCHighAPP1​
9.7.187 937 / 29 / DFC_SRCLoAPPHTLIS​
9.7.188 940 / 91 / DFC_SRCLowAPP1​
9.7.189 943 / 3532 / DFC_SRCMaxUTnkLvl​
9.7.190 945 / 3532 / DFC_SRCMinUTnkLvl​
9.7.191 946 / 1079 / DFC_SSpMon1​
9.7.192 947 / 1080 / DFC_SSpMon2​
9.7.193 948 / 523601 / DFC_SSpMon3​
9.7.194 956 / 677 / DFC_StrtHSSCB​
9.7.195 957 / 677 /DFC_StrtHSSCG​
9.7.196 958 / 677 / DFC_StrtLSOL​
9.7.197 960 / 677 / DFC_StrtLSSCB​
9.7.198 961 / 677 / DFC_StrtLSSCG​
9.7.199 973 / 523612 / DFC_SWReset0​
9.7.200 974 / 523612 / DFC_SWReset1​
9.7.201 975 / 523612 / DFC_SWReset2​
9.7.202 976 / 91 / DFC_SyncAPP​
9.7.203 978 / 29 / DFC_SyncAPPHTLIS​
9.7.204 980 / 523550 / DFC_T50Err​
9.7.205 994 / 105 / DFC_TCACDsSRCMax​
9.7.206 995 / 105 / DFC_TCACDsSRCMin​
9.7.207 996 / 105 / DFC_TCACDsSysReacMa​
9.7.208 997 / 105 / DFC_TCACDsSysReacMin​
9.7.209 1007 / 412 / DFC_TEGRClrDsSRCMax​
9.7.210 1008 / 412 / DFC_TEGRClrDsSRCMin​
9.7.211 1011 / 523960 / DFC_TEGRTPhysRngHi​
9.7.212 1015 / 520521 / DFC_ActrCustCrntMeasSRCMin​
9.7.213 1014 / 51 / DFC_ActrCustCrntMeasSRCMax​
9.7.214 1016 / 51 / DFC_ActrCustInvalidPosErr​
9.7.215 1022 / 51 / DFC_ActrCustSRCCrntMax​
9.7.216 1023 / 51 / DFC_ActrCustSRCCrntMin​
9.7.217 1024 / 51 / DFC_ActrCustSRCMax​
9.7.218 1025 / 51 / DFC_ActrCustSRCMin​
9.7.219 1026 / 4769 / DFC_TOxiCatDsNpl​
9.7.220 1029 / 4766 / DFC_TOxiCatDsPhysRngHiShOff​
9.7.221 1030 / 4766 / DFC_TOxiCatDsPhysRngHiWarn​
9.7.222 1034 / 4769 / DFC_TOxiCatDsSRCMax​
9.7.223 1035 / 4769 / DFC_TOxiCatDsSRCMin​
9.7.224 1036 / 4768 / DFC_TOxiCatUsNpl​
9.7.225 1039 / 4765 / DFC_TOxiCatUsPhysRngHiShOff​
9.7.226 1040 / 4765 / DFC_TOxiCatUsPhysRngHiWarn​
9.7.227 1044 / 4768 / DFC_TOxiCatUsSRCMax​
9.7.228 1045 / 4768 / DFC_TOxiCatUsSRCMin​
9.7.229 1097 / 4343 / DFC_UHtrPLSCG​
9.7.230 1096 / 4343 / DFC_UHtrPLSCB​
9.7.231 1094 / 4343 / DFC_UHtrPLOL​
9.7.232 1093 / 4345 / DFC_UHtrBLSCG​
9.7.233 1092 / 4345 / DFC_UHtrBLSCB​
9.7.234 1090 / 4345 / DFC_UHtrBLOL​
9.7.235 1080 / 3361 / DFC_UDosVlvSCHS​
9.7.236 1079 / 3361 / DFC_UDosVlvSCGOLLS​
9.7.237 1078 / 3361 / DFC_UDosVlvSCBOLHS​
9.7.238 1077 / 3361 / DFC_UDosVlvSCBLS​
9.7.239 1075 / 3361 / DFC_UDosVlvEPHi​
9.7.240 1073 / 4361 / DFC_UCatUsTSRCMin​
9.7.241 1072 / 4361 / DFC_UCatUsTSRCMax​
9.7.242 1069 / 4360 / DFC_UCatUsTPhysRngHi​
9.7.243 1098 / 523718 / DFC_UHtrRlyOL​
9.7.244 1100 / 523718 / DFC_UHtrRlySCB​
9.7.245 1120 / 4375 / DFC_UPmpMotSCB​
9.7.246 1118 / 4375 / DFC_UPmpMotOL​
9.7.247 1117 / 523632 / DFC_UPmpMotNoAvl​
9.7.248 1113 / 4366 / DFC_UHtrTnkSCG​
9.7.249 1112 / 4366 / DFC_UHtrTnkSCB​
9.7.250 1110 / 4366 / DFC_UHtrTnkOL​
9.7.251 1109 / 523719 / DFC_UHtrSMSCG​
9.7.252 1108 / 523719 / DFC_UHtrSMSCB​
9.7.253 1106 / 523719 / DFC_UHtrSMOL​
9.7.254 1105 / 4341 / DFC_UHtrSLSCG​
9.7.255 1104 / 4341 / DFC_UHtrSLSCB​
9.7.256 1102 / 4341 / DFC_UHtrSLOL​
9.7.257 1101 / 523718 / DFC_UHtrRlySCG​
9.7.258 1121 / 4375 / DFC_UPmpMotSCG​
9.7.259 1222 / 190 / DFC_ComEngSpdSensFail​
9.7.260 1181 / 168 / DFC_BattULo​
9.7.261 1180 / 168 / DFC_BattUHi​
9.7.262 1170 / 523612 / DFC_MoCSOPPsvTstErr​
9.7.263 1157 / 97 / DFC_WtLvlFlFWLvl​
9.7.264 1139 / 4365 / DFC_UTnkTSRCMin​
9.7.265 1138 / 4365 / DFC_UTnkTSRCMax​
9.7.266 1136 / 3031 / DFC_UTnkTPhysRngLo​
9.7.267 1135 / 3031 / DFC_UTnkTPhysRngHi​
9.7.268 1132 / 4376 / DFC_URevVlvSCG​
9.7.269 1131 / 4376 / DFC_URevVlvSCB​
9.7.270 1129 / 4376 / DFC_URevVlvOL​
9.7.271 1128 / 523632 / DFC_UPmpPSRCMin​
9.7.272 1127 / 523632 / DFC_UPmpPSRCMax​
9.7.273 1122 / 4334 / DFC_UPmpPPhysRngHi​
9.7.274 1223 / 51 / DFC_ActrCustHBrgOL​
9.7.275 1224 / 51 / DFC_ActrCustHBrgOvrCurr​
9.7.276 1226 / 51 / DFC_ActrCustHBrgSCB1​
9.7.277 1227 / 51 / DFC_ActrCustHBrgSCB2​
9.7.278 1228 / 51 / DFC_ActrCustHBrgSCG1​
9.7.279 1229 / 51 / DFC_ActrCustHBrgSCG2​
9.7.280 1230 / 51 / DFC_ActrCustHBrgShCirOvrLd​
9.7.281 1231 / 51 / DFC_ActrCustHBrgTempOvrCurr​
9.7.282 1232 / 51 / DFC_ActrCustHBrgUndrVltg​
9.7.283 1239 / 523984 / DFC_ARlySCB_5​
9.7.284 1241 / 523986 / DFC_ARlySCG_4​
9.7.285 1242 / 523987 / DFC_ARlySCG_5​
9.7.286 1337 / 2797 / DFC_IVDiaShCirGndToutBnk_0​
9.7.287 1338 / 2798 / DFC_IVDiaShCirGndToutBnk_1​
9.7.288 1339 / 2797 / DFC_IVDiaShCirGndTstBnk_0​
9.7.289 1340 / 2798 / DFC_IVDiaShCirGndTstBnk_1​
9.7.290 1381 / 164 / DFC_RailBSA​
9.7.291 1398 / 1136 / DFC_TECUPhysRngHi​
9.7.292 1423 / 51 / DFC_ActrCustSysReacMax​
9.7.293 1424 / 51 / DFC_ActrCustSysReacMin​
9.7.294 1455 / 3711 / DFC_RgnTempNotRea​
9.7.295 1505 / 524057 / DFC_PSPCtlPresBuildUp​
9.7.296 1533 / 524074 / DFC_ComRxSCRNoxDsOL​
9.7.297 1534 / 524075 / DFC_ComRxSCRNoxDsSC​
9.7.298 1535 / 524076 / DFC_ComRxSCRNoxUsOL​
9.7.299 1536 / 524077 / DFC_ComRxSCRNoxUsSC​
9.7.300 1537 / 524078 / DFC_ComRxSCRRatLamNoxDsRngHi​
9.7.301 1538 / 524079 / DFC_ComRxSCRRatLamNoxDsRngLo​
9.7.302 1539 / 524080 / DFC_ComRxSCRRatLamNoxUsRngHi​
9.7.303 1540 / 524081 / DFC_ComRxSCRRatLamNoxUsRngLo​
9.7.304 1555 / 524063 / DFC_SCRHtrBLOL​
9.7.305 1556 / 524063 / DFC_SCRHtrMRlyOL​
9.7.306 1557 / 524063 / DFC_SCRHtrPLOL​
9.7.307 1558 / 524063 / DFC_SCRHtrSCR​
9.7.308 1559 / 524063 / DFC_SCRHtrSCG​
9.7.309 1560 / 524063 / DFC_SCRHtrSLOL​
9.7.310 1561 / 524063 / DFC_SCRHtrSMOL​
9.7.311 1562 / 524063 / DFC_SCRHtrTnkOL​
9.7.312 1565 / 524065 / DFC_UCatUsPPhysRngHi​
9.7.313 1566 / 524065 / DFC_UCatUsPPhysRngLo​
9.7.314 1569 / 524065 / DFC_UCatUsPSRCMax​
9.7.315 1570 / 524065 / DFC_UCatUsPSRCMin​
9.7.316 1581 / 524067 / DFC_UPmpTHtrPhysRngHi​
9.7.317 1582 / 524067 / DFC_UPmpTHtrPhysRngLo​
9.7.318 1585 / 524067 / DFC_UPmpTPhysRngHi​
9.7.319 1586 / 524067 / DFC_UPmpTPhysRngLo​
9.7.320 1598 / 524065 / DFC_UCatUsPNpl​
9.7.321 1639 / 524147 / DFC_SCRCoBldUpLoPres​
9.7.322 1646 / 524063 / DFC_SCRHtrSMDfrstOvrTi​
9.7.323 1647 / 524063 / DFC_SCRHtrTnkDfrstOvrTi​
9.7.324 1655 / 1761 / DFC_SCRUTnkLoLvl2​
9.7.325 1698 / 524133 / DFC_HMIRestBtnBlk​
9.7.326 1699 / 524134 / DFC_PFltLdAshShOff​
9.7.327 1700 / 524134 / DFC_PFltLdAshWrn​
9.7.328 1701 / 524135 / DFC_PFltLdSotShOff​
9.7.329 1702 / 524135 / DFC_PFltLdSotSrvReq​
9.7.330 1703 / 524135 / DFC_PFltLdSotWrn​
9.7.331 1752 / 2791 / DFC_ComRxAirEGRTVBlkd​
9.7.332 1753 / Error path: DFC_ComRxAirEGRTVCANErr​
9.7.333 1754 / 2791 / DFC_ComRxAirEGRTVEOLLrn​
9.7.334 1755 / 2791 / DFC_ComRxAirEGRTVIntElec​
9.7.335 1756 / 2791 / DFC_ComRxAirEGRTVLrnAbrt​
9.7.336 1757 / 2791 / DFC_ComRxAirEGRTVOvrCurr​
9.7.337 1758 / 2791 / DFC_ComRxAirEGRTVPwrSplyHi​
9.7.338 1759 / 2791 / DFC_ComRxAirEGRTVPwrSplyLo​
9.7.339 1760 / 2791 / DFC_ComRxAirEGRTVRngLrn​
9.7.340 1761 / 2791 / DFC_ComRxAirEGRTVSprng​
9.7.341 1762 / 2791 / DFC_ComRxAirEGRTVTempHi​
9.7.342 1763 / 2791 / DFC_ComRxAirEGRTVTempHiCrit​
9.7.343 1857 / 523612 / DFC_MoFStrt​
9.7.344 1858 / 524147 / DFC_SCRCoRevVlvBlk​
9.7.345 1859 / 524175 / DFC_SCREffMonNOxEmRngHi​
9.7.346 1864 / 524178 / DFC_SCRSysPresMonSysPresErr​
9.7.347 1865 / 4360 / DFC_UCatUsTNpl​
9.7.348 1866 / 4334 / DFC_UPmpPNpl​
9.7.349 1867 / 524067 / DFC_UPmpTHtrNpl​
9.7.350 1868 / 524067 / DFC_UPmpTNpl​
9.7.351 1869 / 1761 / DFC_UTnkLvlNpl​
9.7.352 1874 / 524152 / DFC_ComRxSCR1TO​
9.7.353 1875 / 524153 / DFC_ComRxSCR2TO​
9.7.354 1881 / 4768 / DFC_TOxiCatUsDsNpl​
9.7.355 1891 / 524190 / DFC_HMIIndcLvl1Actv​
9.7.356 1892 / 524191 / DFC_HMIIndcLvl2Actv​
9.7.357 1893 / 524193 / DFC_SrvCoStstExsLon​
9.7.358 1894 / 524194 / DFC_SrvCoStstExsShrt​
9.7.359 1895 / 3519 / DFC_ComRxSCRDEFSensOvrTmp​
9.7.360 1896 / 3520 / DFC_ComRxSCRDEFSensSRCMax​
9.7.361 1897 / 3520 / DFC_ComRxSCRDEFSensSRCMin​
9.7.362 1898 / 3519 / DFC_ComRxSCRDEFSensTSRCMax​
9.7.363 1899 / 3519 / DFC_ComRxSCRDEFSensTSRCMin​
9.7.364 1900 / 524195 / DFC_SCRCrysMonTmrExc​
9.7.365 1904 / 3520 / DFC_ComRxSCRDEFConc​
9.7.366 1905 / 3520 / DFC_ComRxSCRDEFMeasCond​
9.7.367 1907 / 3520 / DFC_ComRxSCRDEFSensPhyRng​
9.7.368 1908 / 3519 / DFC_ComRxSCRDEFSensTPhyRng​
9.7.369 1909 / 4365 / DFC_ComRxSCRLvlSensOvrTmp​
9.7.370 1910 / 3532 / DFC_ComRxSCRLvlSensPhyRng​
9.7.371 1911 / 3532 / DFC_ComRxSCRLvlSensSRCMax​
9.7.372 1912 / 3532 / DFC_ComRxSCRLvlSensSRCMin​
9.7.373 1913 / 4365 / DFC_ComRxSCRLvlSensTPhyRng​
9.7.374 1914 / 4365 / DFC_ComRxSCRLvlSensTSRCMax​
9.7.375 1915 / 4365 / DFC_ComRxSCRLvlSensTSRCMin​
9.7.376 1917 / 3936 / DFC_PFltRgnTBsStp1​
9.7.377 1918 / 3936 / DFC_PFltRgnTBsStp2​
9.7.378 2007 / 524267 / DFC_HMIPreTrgIndcLvl2​
9.7.379 2008 / 524025 / DFC_PFltRgnLnchTExs​
9.7.380 2011 / 4171 / DFC_UCatUsTDynNpl​
9.7.381 2013 / 524147 / DFC_SCRCoBldUpLoPresRst​
9.7.382 2014 / 3520 / DFC_UQCDMinExc​
