Hyundai
86
176,834
Sany All Terrain Crane SAC5000S Service Manual 2022
Brand: Sany
Type of Machine: All Terrain Crane
Type of Manual: Service Manual, Electrical and Hydraulic Pneumatic Diagrams
Model: Sany SAC5000S All Terrain Crane
Publication Date: 2022
Number of Pages: 736 Pages
1 Introduction
1.1 Importance of This Manual​
1.2 How to Use This Manual​
1.3 Organization of This Manual​
1.4 Correction Request Form​
1.5 Contact Information​
1.6 General Repair​
1.6.1 General​
1.6.2 Cleanliness​
1.6.3 Removal and Installation​
1.6.4 Disassembly and Assembly​
1.6.5 Pressing Parts​
1.6.6 Locks​
1.6.7 Wires and Cables​
1.6.8 Shims​
1.6.9 Bearings​
1.6.10 Gaskets​
1.6.11 Batteries​
1.6.12 Hydraulic Systems​
1.6.13 Fatigue of Welded Structures​
1.6.14 Loctite​
1.6.15 Fasteners and Torque Values​
1.6.16 Lubricants and Fluids​
1.6.17 Wire Rope​
2 Safety
2.1 General Safety​
2.1.1 General​
2.1.2 Hazard Alerts in This Manual​
2.1.3 Machine Safety​
2.1.4 Operator Safety Information​
2.1.5 Operator is Important​
2.1.6 Operator Qualifications​
2.1.7 Job Site Safety​
2.1.8 Job Safety​
2.1.9 Surface and Underground Hazards​
2.1.10 Electrocution Hazard​
2.1.11 High Voltage Areas​
2.1.12 Transmitter/Communication Towers​
2.1.13 Pre-Operation Inspection​
2.1.14 Personal Protective Equipment​
2.1.15 Fire Safety​
2.1.16 Dust Hazards​
2.1.17 Repair Safety​
2.1.18 Electrical System​
2.1.19 Environmental Precautions​
2.1.20 Towing or Lifting the Machine​
2.1.21 Optional Attachments​
2.2 Product-Specific Safety​
2.2.1 Authorized Use of the Machine​
2.2.2 Unauthorized Use of the Machine​
2.2.3 Job Site Precautions​
2.2.4 Operational Aids​
2.2.5 Escape Tool​
2.2.6 Crush or Pinch-Point Precautions​
2.2.7 Crane Stability and Structural Integrity​
2.2.8 Wind​
2.2.9 High Altitude​
2.2.10 Load Charts Manual​
2.2.11 Counterweight​
2.2.12 Cold Weather Operation​
2.2.13 Load Moment Indicator (LMI) Systems​
2.2.14 Permissible Ground Pressure​
2.2.15 Personnel Handling​
2.2.16 Safety During Operation​
3 Electric system
3.1 Description​
3.1.1 General​
3.1.2 Alternator​
3.1.3 Batteries​
3.2 Carrier Fuse and Relay Panel​
3.3 Superstructure Fuse and Relay Panel​
3.4 Electric Service​
3.4.1 Preparations Before Electrical Parts Servicing​
3.4.2 Starter - Remove​
3.4.3 Starter - Install​
3.4.4 Alternator — Remove​
3.4.5 Alternator — Install​
3.4.6 Battery of Carrier Electric System — Remove​
3.4.7 Battery of Carrier Electric System — Install​
3.4.8 Anemometor​
3.4.9 Aircraft Light​
3.4.10 Anti-two Block Switch (A2B)​
3.4.11 Angle Sensor​
3.4.12 Height lamp​
3.4.13 Work Light of Boom​
3.4.14 Junction Box​
3.4.15 Cable Drum Outside Boom​
3.4.16 LMI Display​
3.4.17 Emergency Stop Switch​
3.4.18 Rocker Switch​
3.4.19 Operation Panel​
3.4.20 Joystick​
3.4.21 Hoist Monitor​
3.4.22 Pedals in Operator's Cab​
3.4.23 Windshield Wiper​
3.4.24 Windshield Washer​
3.4.25 Skylight Wiper​
3.4.26 Tricolor Light​
3.4.27 Work Light​
3.4.28 Slewing Encoder​
3.4.29 Third Wrap Protector​
3.4.30 Check Engine Error Codes​
3.4.31 Check Transmission Error Code​
3.5 Load Moment Indicating System​
3.5.1 E-touch Display Programming Procedure​
3.5.2 LMI Alarm Icons​
3.5.3 Parameter Setting​
3.5.4 Operation Parameter Setting​
3.5.5 LMI Calibration​
3.6 Troubleshooting​
3.6.1 General​
3.6.2 Multimeter​
3.6.3 How to Read Electrical Schematic Diagram​
3.6.4 No Display or Abnormal Display of Anemometer​
3.6.5 Boom Head Angle Sensor Error​
3.6.6 CAN Bus Error​
3.6.7 Carrier Bus Error​
4 Hydraulic system
4.1 Description​
4.1.1 General​
4.1.2 Special Attention on Hydraulic System​
4.1.3 Draining and Flushing Hydraulic Oil​
4.1.4 Removing Air From the Hydraulic System​
4.1.5 Parts Replacement​
4.2 Supply Pressure and Return Circuit​
4.2.1 General​
4.2.2 Hydraulic Filter​
4.2.3 Hydraulic Oil Cooler​
4.2.4 Hydraulic Pumps​
4.3 Valves​
4.3.1 General​
4.3.2 Pressure Setting Procedures​
4.3.3 Main Control Valve​
4.3.4 Hoist Counterbalance Valve​
4.3.5 Boom Tele Counterbalance Valve​
4.3.6 Boom Lift Counterbalance Valve​
4.3.7 Cab Tilt up/down Conterbalance Valve​
4.3.8 Auxiliary Operation Valve​
4.3.9 Hoist Brake Valve​
4.3.10 Swing brake valve​
4.3.11 Outrigger Directional Control Valve​
4.3.12 Emergency Valve​
4.3.13 Steering Governing Valve​
4.3.14 Rear Suspension Accumulator Valve​
4.4 Cylinders​
4.4.1 General​
4.4.2 Description​
4.4.3 Boom Lift Cylinder​
4.4.4 Boom Tele Cylinder​
4.4.5 Steering Cylinder​
4.4.6 Outrigger Beam Cylinder​
4.4.7 Outrigger Stabilizer Cylinder​
4.4.8 Suspension Cylinder​
4.4.9 Centering Cylinder​
4.4.10 Cab Tilt Cylinder​
4.4.11 Operator’s Footboard Cylinder​
4.5 Motors​
4.5.1 Hoist Motor​
4.5.2 Swing Motor​
4.6 Troubleshooting​
4.6.1 General​
4.6.2 Failure to Swing Right​
4.6.3 Fail to Swing Left​
4.6.4 Failure to Swing the Boom​
4.6.5 Erratic Swing Operation​
4.6.6 Main Hoist- Failure to Hoist Down​
4.6.7 Boom Lift Cylinder- Failure to Raise the Boom​
4.6.8 Boom Tele Cylinder - Failure to Extend the Boom​
4.6.9 Boom/Cylinder Pins - Failure to Pin out​
4.6.10 Oscillation Cylinder - Unintentional Action​
4.6.11 Auxiliary Steering and Centering Accumulators - Faulty Pressurekeeping​
4.6.12 Counterweight Cylinder - Unintentional Action​
5 Boom
5.1 Description​
5.2 Mechanical Principle​
5.2.1 Telescope Principle​
5.2.2 Boom Extend​
5.2.3 Boom Retract​
5.3 Main Boom - Remove​
5.3.1 Preparations for Removal​
5.3.2 Pivots - Disassemble​
5.3.3 Main Boom Assembly — Remove​
5.4 Main Boom - Disassemble​
5.4.1 General Description of Main Boom Disassembly​
5.4.2 Base Boom and Telescopic Cylinder - Disassemble​
5.4.3 Boom Telescope 1 Section - Disassemble​
5.4.4 Boom Telescope 2 Section - Disassemble​
5.4.5 Boom Telescope 3 Section - Disassemble​
5.4.6 Boom Telescope 4 Section - Disassemble​
5.4.7 Boom Telescope 5 Section - Disassemble​
5.4.8 Auxiliary Boom Nose Sheave - Remove​
5.5 Main Boom - Assemble​
5.5.1 General​
5.5.2 Boom Pins - Assemble​
5.5.3 Boom Tele 6 Section - Assemble​
5.5.4 Boom Telescope 5~6 Sections - Assemble​
5.5.5 Boom Telescope 4~6 Sections - Assemble​
5.5.6 Boom Telescope 3~6 Sections - Assemble​
5.5.7 Boom Telescope 2~6 Sections - Assemble​
5.5.8 Boom Tele 1~6 Sections - Assemble​
5.6 Main Boom - Install​
5.6.1 General​
5.6.2 Boom Pivots - Install​
5.6.3 Boom Accessories - Install​
5.6.4 Adjustment​
5.7 Main Boom - Inspect and Adjust​
5.7.1 Boom Inspection​
5.7.2 Wire Ropes Inspection​
5.8 Troubleshooting​
5.8.1 Boom Side Deflection​
5.8.2 Boom Telescoping Failure​
5.8.3 Boom Section Retracting by Itself​
6 Turntable
6.1 Description​
6.1.1 Hoist Assembly​
6.1.2 Swing System​
6.2 Parts Locatoin​
6.2.1 Description​
6.2.2 Turntable Frame Location​
6.2.3 Triple Hinge Location​
6.2.4 Counterweight Location​
6.2.5 Main Hoist Location​
6.2.6 Auxiliary Hoist Location (Optional)​
6.2.7 Superstructure Warm A/C Location​
6.2.8 Shelter Location​
6.2.9 Swing Bearing Location​
6.3 Repair​
6.3.1 Hoist​
6.3.2 Hoist Brake​
6.3.3 Swing Brake​
6.3.4 Swing Drive​
6.3.5 Swing Bearing​
6.4 Troubleshooting​
6.4.1 Main Hoist – Operation Erratic​
6.4.2 Swing – Operation Erratic​
7 Engine System
7.1 General​
7.2 Engine - Remove​
7.2.1 Preparations Before Removal​
7.2.2 Pipes and Drive Shafts - Remove​
7.2.3 Radiator Assembly - Remove​
7.2.4 Engine and Transmission Assembly - Remove​
7.2.5 Engine and Transmission - Separate​
7.3 Engine - Install​
7.3.1 Engine and Transmission — Install​
7.3.2 Radiator Assembly - Install​
7.3.3 Pipes and Drive Shafts - Install​
7.3.4 Engine Covers - Install​
7.4 Fuel System​
7.4.1 Description of Fuel System​
7.4.2 Fuel Tank - Remove and Install​
7.5 Air Intake System​
7.5.1 General Description of Air Intake System​
7.5.2 Air Intake System - Remove and Install​
7.6 Cooling System​
7.6.1 General Description of Cooling System​
7.6.2 Effects Of Cooling System Neglect​
7.6.3 Coolant​
7.6.4 Cooling System - Remove and Install​
8 Power Train
8.1 General Description of Power Train​
8.2 Transmission​
8.2.1 Structure and Function​
8.2.2 Transmission - Remove and Install​
8.3 Transfer Gearbox​
8.3.1 Structure and Function​
8.3.2 Transfer Gearbox - Remove​
8.3.3 Transfer Gearbox - Install​
8.4 Gear Oil Cooler​
8.4.1 Gear Oil Cooler - Remove​
8.4.2 Gear Oil Cooler - Install​
8.5 Emergency Steering Pump​
8.5.1 Emergency Steering Pump - Remove​
8.5.2 Emergency Steering Pump - Install​
8.6 Power Takeoff Device​
8.6.1 Power Takeoff Device - Remove​
8.6.2 Power Takeoff Device - Install​
8.7 Angle Transfer Gearbox​
8.7.1 Structure and Function​
8.7.2 Gear Oil Cooler for Lower Angle Gearbox - Remove​
8.7.3 Gear Oil Cooler for Lower Angle Gearbox - Install​
8.7.4 Gear Oil Cooler for Upper Angle Gearbox - Remove & Install​
8.7.5 Gear Oil of Lower Angle Gearbox - Drain & Change​
8.7.6 Lower Angle Gearbox - Remove​
8.7.7 Lower Angle Gearbox - Install​
8.7.8 Gear Oil of Upper Angle Gearbox - Drain & Change​
8.7.9 Upper Angle Gearbox - Remove​
8.7.10 Upper Angle Gearbox - Install​
8.8 Drive Shafts​
8.8.1 Structure and Function​
8.8.2 Notes and Warnings before Drive Shaft Removal​
8.8.3 Drive Shafts - Remove​
8.8.4 Drive Shafts - Install​
8.8.5 Drive Shafts - Check​
8.9 Troubleshooting​
8.9.1 Engine Oil Sludge​
8.9.2 Engine - Oil Pressure Too Low​
8.9.3 Engine - Excessive Oil Level Drop​
8.9.4 Engine - Coolant Temperature Too High​
8.9.5 Engine - Excessive Fuel Consumption​
8.9.6 Engine - Lacks Power or Stall​
8.9.7 Engine – Failure of Ignition​
8.9.8 Drive shaft - Too Much Noise on Drive Shaft​
9 Braking System
9.1 Brakes​
9.1.1 General information​
9.1.2 Brake Slack​
9.1.3 Brake Pad​
9.1.4 Brake Air Chamber​
9.1.5 Brake​
9.2 Air System​
9.2.1 Description​
9.2.2 Parts Location​
9.2.3 Repair​
9.2.4 Charge Air​
9.2.5 Air Pressure Inspection​
9.2.6 Leakage Inspection​
9.2.7 Moisture Draining/ Air Release​
10 Wheels and Tires
10.1 General Description of Wheels and Tires​
10.2 Tires - Exchange Position​
10.3 Tires - Remove​
10.4 Wheels on the Front Axle - Install​
10.5 Wheels on the Rear Axle - Install​
10.6 Tires - Disassemble​
10.7 Tires - Assemble​
11 Axle and Suspension
11.1 Non-driving steer axle​
11.1.1 General Description of Non-Driving Steer Axle​
11.1.2 Non-Driving Steer Axle - Remove​
11.1.3 Non-Driving Steer Axle - Install​
11.2 Driving Steer Axle​
11.2.1 General Description of Non-Driving Steer Axle​
11.2.2 Axle 1 - Remove and Install​
11.2.3 Axle 2 - Remove and Install​
11.2.4 Axle 4 - Remove and Install​
11.2.5 Axle 5 - Remove and Install​
12 Steering System
12.1 General Description of Steering System​
12.2 Power Steering Box - Remove​
12.3 Power Steering Box - Install​
12.4 Toe-in - Measure​
12.5 Toe-in - Adjust​
13 Outriggers
13.1 General Description of Outriggers​
13.2 Outriggers - Inspect​
13.3 Outrigger Assembly - Remove​
13.4 Outrigger Beam Cylinder - Remove​
13.5 Outrigger Stabilizer Cylinder - Remove​
13.6 Outrigger Stabilizer Cylinder - Install​
13.7 Outrigger Beam Cylinder - Install​
13.8 Outrigger Assembly - Install​
13.9 Troubleshooting: Outriggers Telescoping - Out of Synchronization​
14 Appendix
14.1 Hydraulic Schematics​
14.1.1 Superstructure Hydraulic Schematics​
14.1.2 Carrier Hydraulic Schematics​
14.2 Brake Schematics​
14.2.1 Brake Schematics​
14.3 Electrical Schematics​
14.3.1 Superstructure Electrical Schematics​
14.3.2 Carrier Electrical Schematics​
